View Full Version : Lancer Troubleshooting
Pages :
7]
11
12
- Lancer+Extreme cold = no fun
- Bad Harmonic Balancer, need info.
- 2002 Lancer Temperture Knob hard to turn over
- Bought a K&N Typhoon short ram, Low idol/ oil light
- Weird noise when A/C is on
- Broke Intake Mani Bolt!!
- WTF? Steering Wheel Prob
- Shifting issue
- Cold engine startup problem. (whole car shakes)
- Speedo
- RPM bouncing while idleling
- Normal idle RPM?
- Why did Mitsubishi do this ? (spark plugs)
- scratch removers?
- HVAC no longer works. Any easy fix possible?
- Weird sound at start up
- Anyone have access to FULL TSBs???
- oil light comes on at idle?
- check engine light question
- Clogged Cat?
- engine trouble
- exhaust tip touching body kit!! what to DO??
- Car squealing at start up
- Lighting problem
- o2 sensor help
- Need guru help on power steering
- Need Help with Brakes
- Slave Cylinder
- Broken Temp Control Knob.....Help!
- Uneven tire wear
- CEL light on EVEN with eliminator!
- help!!my car dies and wont start!!
- cd player
- Rough Idle in the Rain
- wedge bulb for cedias
- car dies after stoping
- I think the blower motor may be going...
- Greddy evo2 Exhaust *BUMPER MOD HELP*
- Screwing around got me in trouble
- Hesistation
- HELP HELP HELP - water in engine!!
- Throttle/Gas Pedal Response
- Scratching sound when I brake!
- Car overheating
- Wheel Bearings Keep dieing
- Clutch pedal is harder to press down
- power steering??
- evo 8 wing install
- Blower Motor Sound?
- Tailight Problem *Wiring Perhaps*?
- 02 ES Stalls at idle
- Weird situation
- fog lights
- Fuel gauge Problem?
- Electrical Problem
- Odd problem
- Front end driver side shake?
- Sunroof won't close
- Rough idle
- Oil level and Pulsating RPM
- Suspension Rattle
- Fuel Inlet Restrictor where did it go??? ohh AND P0421
- HELP FAST!! Unsealing resealed lights..
- My Clutch!!!
- egr valve
- coilpacks
- clickclickclickclick when im in drive stopped
- noise going over a bump or dip
- exhaust replacement suggestions
- won't stay running
- High Rev Problem
- Hesitation in Accelleration
- ac problem
- Exhaust, Progress Antisway and springs problem
- need help car has i rough drive
- HID Problem
- Loud Noise under the car
- Idle Problem
- Fuel injectors/rail question
- Weird noise, and it's not the usual squeak
- o2sensor/Heater
- rough start up?
- hid flickering randomly
- Vibration when I drive
- Air conditioning leak? (need help)
- Brake light? WTF
- Simple question...
- Water??? from where
- RRM Header SES
- Car shakes at 75-80 MPH
- High mileage, what maintainence should be done?
- Fuel Gauge Problem
- p0102 error code
- Car won't start
- suspect: cv joint - culprit: ball joint?
- car pulls hard and wheels wobble at 65+mph
- High Idle, help!
- Control arm bushings????
- Cat Problems?
- backfiring question
- Ground Wire Kit Question!?!?
- SES Computer Code 0421
- Help trouble shoot my A/C porblem..hesitation
- Blowing Power Window Bus Fuses....
- Shifter problem...
- I think i f-ed up my trans
- High revs in park?
- Help Loud klunking sound Pics and more info inside
- Squealing belt
- accolade rear bumper cracking....
- LC-1 Wideband problems...
- Radio dont work anymore
- window no work
- Cel P0421
- RRM piggy Ver.1
- After a week of trying !
- Battery/alternator problem - help?
- Changing decks
- got a hole in your radiator??
- Cannot get remote programmed!!!!
- engine control fuse keeps blowing out
- Another RMR install problem/question
- Header Gaskets Question
- Startup problems...
- Idle problems
- Broken Spark Plug?? HELP!
- trouble removing badges
- Bigger Injectors for N/A lancer?
- A/C Problem
- P0135 O2 Sensor Heater
- Timing belt jump
- Oil Problems
- Is my clutch going out?
- Headlight Question
- High-pitched vibration noise
- Car problems!! Bah!
- 2002 ES Camshaft Position Sensor Install?
- Friction with Kartboy shifter bushings
- cruise control turns off when right turn signal goes on
- Need help getting the headlights off an 06!
- Spark Plug Help!!
- Wtf .. got my front strut bar today
- lights out!
- Ah I broke a screw!
- Temp control knob
- downpipe heatshield rattling
- Wow i juss installed my short ram intake
- Help! Cig lighter not working!!!!
- Help with FUEL LOSS
- A/C wont shut off!!!
- How do you take out door panels?
- Brights out, but reg. lights still on??
- CD player error ER1 ?
- turn signal fuse
- Wheel Shimmy
- Gasket???
- died left side(whole) lights! please help!
- RMR Lip Type1
- P0456: Evaporative... System Leak
- Weird idle
- Low Oil Pressure VS Slipping belt
- Where did you put/hide your ballast for your HID's?
- hummmmmm
- trip gauge
- here we go again
- Need to rewire back my oem headlights
- ticking/rattling/knocking/
- Tick Tock
- Belts
- Sudden power loss to cylinders 1 & 4 !?
- I got 99 problems...
- dash light problem???
- How important is 30000 mile service
- lancer running loudly
- Car stalled when I turned A/C on ???
- Cobalt Air/Fuel Gauge Problem...
- Belt problems!!
- windshields
- Windshield washer fluid pump
- OBD II codes
- Installing anti fouler on O2 sensor.. where is it?
- strange noise
- help Cel light came on last night
- Help please
- Clutch Problem?
- Idle thing Ive heard mentioned here before...
- Please help!! Check Engine Light on!
- speedio problem
- Odd Problem
- Idle Problem
- Problem With Idle Help!!!!!!!!!
- Has anyone else broken the locking ring for their headlamp?
- Loose steering wheel?
- eBay service manual cd
- Problem... is anyone outhere?
- Headers ...Huff.
- Adjustable shift light
- accelerator problem
- engine shut off when driving.
- Can't get the car to start but half the electricity works!
- Problems with PB V.2
- Squeeky noise w/Defroster
- CEL Still After Check Engine Light Eliminator
- Strange rattling sound - Any help appreciated
- having trouble disconnecting battery
- I really hope I dodged a bullet
- Idle problems..
- Sucked In water...need help
- READ THIS - water leaking, HVAC, blower motor
- trunk plugs
- Need help! Heater problem
- Help!
- Strange problem
- How To: Far left exaust manifold nut <- STICK THIS
- temp sensor
- Cigarette lighter fuse where??
- Problem with installing RRM test pipe
- clearing the CEL from header...
- Brake lights on w/ blinker & reverse?!
- Service Engine Soon light turns on and off
- dissapointing dyno results
- HELP _ Bottomed out Lancer
- AC not working...
- splash guard ripped
- #1 Cylender
- If I Get Zapped One More Time . . . !!!
- I'm officially stumped...
- Pioneer in Dash Screen/DVD AV INPUT PROBLEMS!!
- dude i need help trouble codes
- Factory Shift Indicator?
- my horn wont work
- ECU RECALL Now bumpy idle!!
- keys stuck!!!
- gauge cluster ?
- i need some electrical help....quick.
- Steamy windows...please help!!!
- AC/Heater knob won't stay down!
- Filter came off! Oops!
- How would this happen?
- RRM Test pipe buzz..
- problems with es
- WOW! i think that my car is EFFED!!
- water in intake
- Battery Problem
- AEM CAI rubbing...
- TPS readings on Auto
- MBC help
- PB ECU help, can't get front plate removed
- Gauge cluster wiring
- Drivers side power lock
