PDA
View Full Version : Evo X Electrical / Audio / Security
Pages : 1 2 3 [4] 5 6 7 8 9
  1. ticking from the stock head unit
  2. Lincense Plate Bulb (White not bluish)
  3. MMCS Firmware change
  4. Chinese Head Unit
  5. X Headlight differences ?
  6. Mito-02 RF Sub Help!!!!
  7. UK Navigation MMCS
  8. wiring connector... male and female
  9. Steering Control Problems!!
  10. Finally Done with everything on my evo X :)
  11. Evo X Bluetooth worked until lastnight... Help
  12. HELP! Viper alarm system.
  13. Bluetooth to Bluetooth AUDIO player??
  14. Navigation system
  15. DRL question
  16. TMC Antenna = N/A
  17. Audio Aux?
  18. wiring diagram that includes USB ipod connectivity?
  19. OEM headunit USB problem
  20. Aftermarket Head Unit
  21. Installed head unit, always resets when car turns off
  22. Navi current position incorrect
  23. Evo X MR Navigation problem?
  24. Question about my head light daytime running lights
  25. Looking for a compatible Headunit to use with the iPhone 5
  26. Bluetooth Audio suddenly stopped working
  27. Confirm on getting homelink mirror for our car
  28. Best buy satellite kit, will it work?
  29. Evo x headlights i need help! asap
  30. Need help with LED Tails
  31. Instructions to solder RCA's onto MMCS headunit
  32. Confused/need help with getting sat radio
  33. Stealth Gauges.
  34. iPod track sorting on mmsc
  35. Alternator whine
  36. iPod control problems - 2012 MR
  37. iPhone 5 iOS6 will not connect to USB?
  38. How to update navi..
  39. Evo x navigation issue
  40. Custom map on Navi
  41. Engine Check and other warning
  42. 2012 fuse bluetooth with aftermarket radio
  43. 2012 Evo X Nav traffic
  44. Solaris Yellow Bulb in Side Markers...
  45. Electrical system lock out
  46. Window reset
  47. Who makes these taillights
  48. climate control
  49. Mysterious White Ribbon
  50. Noticed something interesting tonight...
  51. Took radio out, now I have an Airbag light solution?
  52. New audio suggestions
  53. MMCS usb memory recall...
  54. Navigation problem
  55. Tail light short
  56. Factory GPS and Sirius antenna with aftermarket radio?
  57. Evo X fuse to older bluetooth
  58. MMCS no-2 for fuse?
  59. seat belt sensor
  60. If I remove the MMCS Navi, will this faceplate work?
  61. Switching from Prosport wideband to Innovate
  62. HELP-FUSE keyless trunk not operating
  63. O the rattles
  64. USB Port in Glovebox Won't Recognize Devices
  65. If I replace the MMCS with an aftermarket head unit, can I keep Fuse working?
  66. I think my MMCS ipod died
  67. 2012 Fuse - is it normal for audio to come from 1 speaker?
  68. 2012 MMCS - Rear Seat Display N/A ?
  69. Hands Free System new module
  70. tail light shut off
  71. 2012 MMCS - increase navigation volume?
  72. Stock 2010 Evo X audio possible problem.
  73. cant unlock doors by touch
  74. 2012 MMCS with iPod = slow?
  75. FAST system removal
  76. Critique my sound system I'm building
  77. Leveling Switch Wiring
  78. 2012 MMCS compatible with older RCA connector?
  79. Remote Start
  80. Looking for Fuse version 11.0.0 software download
  81. Did my radar/laser install this weekend.
  82. Electrical/battery problems Yippee
  83. Mmcs aux
  84. Replacing stock Nav with Aftermarket
  85. Aftermarket Alarm w/ FAST system
  86. Sirius Antenna
  87. Stock EVO X radio Question
  88. Pro Sport boost gauge flashing
  89. 2008 EVO x MR - Daytime Running Head lights
  90. Show me your ground
  91. Anyone upgrading speakers and adding amp to non-RF OEM headunit?
  92. Relocating the Hazard switch and airbag indicators.
  93. Axxess ASWC wiring update
  94. Battery Issues
  95. Someone Please Help Me!!!!!!!!!!!!!!!!!
  96. PAC-SWI wiring - WTF? everything looks correct, but it wont work!?!?
  97. My interior + carpc
  98. Fake Mitsubishi navigation worth buy
  99. Alt. Whine & Steering Wheel Controls
  100. 2008 Mitsubish Lancer Evolution MMCS screen freeze
  101. wrc gearshift monitor
  102. Hard wire a micro USB
  103. Need seat heater toggle switch part #
  104. looking for wiring diagram for mr158402 infiniti amp
  105. Is this a good Ground? Hearing a louder buzz in the radio speakers
  106. Spyder headlights
  107. Which Double-Din Headunit Would YOU get?
  108. ARK MFD2 + O2 Adaptor Install
  109. Anyone Running the New Buschur Mini Battery Kit?
  110. Rockford Fosgate system cost
  111. First Headunit... suggestion?
  112. Dynamat Hoodliner?
  113. Alarm help!
  114. Soundstream head units
  115. Amp for 1800 watt alpine type r 12 inch
  116. Everything you need to know about the stock RF system.
  117. Stock GSR Base Radio Specs
  118. Looking for a legit Audio/Rear-Cam Install place in PHILLY/South Jersey Area
  119. Horn going off when reconnecting battery?
  120. In-dash carputer + audio build
  121. Alpine INE-S920HD installed
  122. Satellite Radio Antenna Placement
  123. aftermarket HU for 2011 new outlander
  124. KENWOOD DNX-5190 AM FM CD DVD NAV $649.95 shipped
  125. Finished up my audio system over the weekend
  126. 2004 Lancer Shift Light Install
  127. MZ360136EX with MMCS?
  128. S.M.A.R.T keyless control
  129. when will MMCS reads street names?
  130. In-dash nav with evo-scan
  131. 13.5 in. subs / 2012 evo gsr
  132. Anyone using a Motorola Droid RAZR with the FUSE bluetooth?
  133. Finally got rid of the factory sound system!
  134. Kenwood dnx5190 special buy @ wicked cas
  135. MMCS problem - no sound!
  136. bluetooth, USB, FUSE, conFUSEd!
  137. Replacing stock Rockford Sub
  138. What radar detector do you use in your Evo?
  139. OEM navigation 2011/2012 info wanted
  140. ? About a Rear Camera install
  141. Battery, Alternator, or Fuses?
  142. Evo USB compatible with Droid?
  143. 2008 MR stock speaker ?
  144. Problem with stereo security and remote locking
  145. Sony DVD HU with Evo X featured in video (now with review)
  146. OEM 08 Navi on 2010 Evo
  147. Help what plug is this?!?
  148. Window roll down
  149. Bluetooth and aftermarket HU
  150. best turbo timer?
  151. Upgrade my 2010 to 2011+ navigation system?
  152. Stock Navigation Sound Upgrade
  153. New head unit and Antenna Reception Problem
  154. weird HID issue need some help
  155. Deck Change = Rattle
  156. Stock radio replacement question
  157. Harness and dash kit for 2012 X
  158. Audio Suggestions for my 2008 Evo X MR
  159. Security System needed on my 2008 Evo MR
  160. Help me build a stereo package!
  161. Navigation System Package?
  162. should I get a TomTom Nav?
  163. Front speakers do not fit
  164. NX501A Replacment Brackets
  165. AFS as DRL?
  166. Boost gauge installed, safe to use cigarette lighter?
  167. Climate Control??
  168. Inaccurate Defi Boost gauge
  169. I want to upgrade my audio system, can I have some advice please?
  170. Vent Boost Gauge VBG1 ( Digital Led Bars & numerics )
  171. Aftermarket alarm question
  172. Charge iPhone while using Bluetooth option?
  173. HID bulb deals?
  174. MMCS Question
  175. Remvoing the stock speakers
  176. Aftermarket head unit (how do i hook up the back up camera?)
  177. Radio isn't turning on HELP!!!
  178. Flash drive no worky in USB port
  179. Will stock wiring work with aftermarket speakers and amp
  180. Running only front speakers?
  181. 2011 MR keyless unlock
  182. MMCS gauges?
  183. Oem sub help
  184. Stack wideband and boost gauge both reading incorrectly?
  185. KeyFob Won't open door remotely
  186. Does anyone have any idea about this touch screen?
  187. 1156 DRL socket WTF???
  188. Small, Lightweight Battery
  189. OEM Ballasts blew
  190. Stock wiring (rockford) capacitor location
  191. Stock navi dash gap (after removal of MMCS)
  192. Stock '12 MR Audio?
  193. 08 EVO MR Rockford Sound Issue No Sound
  194. need to change the stock speakers
  195. MMCS car info - average speed way off!?
  196. 2011 Evo Sights and Sound 9 speaker system, where the other 2 speakers?!
  197. Voice PA system (expected Juvenile actions) :)
  198. Request: Evo X battery wire schematic
  199. Steering Wheel Controls
  200. Anyone installed Escort ZR4 on their Evo X?
  201. USB Audio Issue
  202. Ipad dash build for evo x!!!!
  203. Removing the OEM Siruis receiver?
  204. Navi dilemma - HELP
  205. Non-nav stock stereo questions
  206. factory nav compatability across years
  207. Aftermarket amp question
  208. How to get rid of whine when charging iPhone?
  209. Question about steering wheel control interfaces
  210. Hands free EVO X
  211. ipod album playing
  212. Steering wheel audio control +aftermarket radio question
  213. question on FAST key security level
  214. Sirus Radio
  215. Another factory NAV question
  216. Depo oem style headlights
  217. Anyone know a similar headunit to the JVC Kameleon Headunit
  218. Installed projectors now low beams won't work.
  219. Factory radio not working.
  220. Bluetooth with factory Nav
  221. OEM radio head unit problem
  222. Viper Alarm
  223. Possible to dim prosport boost gauge?
  224. drl and low beams not working after crappy hid kit removal
  225. Bluetooth Connection
  226. Evoscan question
  227. subs problems
  228. Evo Navi Option
  229. 2008-2010 nav unit in 2011
  230. aftermarket nav questions
  231. Splice Locations?
  232. hid kit issue
  233. Boost gauge install..help. Can't find the accessory power
  234. Passenger Side speaker Problem
  235. two MMCS issues...
  236. Speaker and amp recommendations needed
  237. MITO-02, dumb question.
  238. HIDs
  239. New map update includes RTT?
  240. Radar Detector Hard Wiring Into Dome Lights
  241. iphone plug into AUX , noise in the back .
  242. Turn off proximity beep?
  243. Dnx9990hd kenwood excelon pre-order wicked cas $200 store credit 603-642-4222
  244. Real time traffic (RTT) not working on 2010
  245. 2012 Aux port?
  246. Replacement Tweeters for RF System
  247. List of Bulbs?
  248. Anyone knows how to do this mod?
  249. 11 GSR USB Problem
  250. Need help with 2011 Evo GSR navi system
