PDA
View Full Version : Evo X Electrical / Audio / Security
Pages : 1 2 3 4 5 [6] 7 8 9
  1. Pioneer AVH-P4200DVD + iPhone GPS (pretty awesome - check it out)
  2. Source for dash clips
  3. Working audio-video DVD
  4. OEM Navi Dash Trim
  5. Auxiliary Input Install in base Evo X GSR Factory Stereo
  6. What is this?
  7. Speakers
  8. OEM Mitsubishi Connectors
  9. Has anyone ever used the Alpine INE-S900r
  10. Help choosing a Dash Kit
  11. Issues with audio cutting off?
  12. Post pics of your NAV install
  13. Aftermarket Backup Cam problems
  14. Sirius Antenna Question
  15. I need to learn to format an MP3 cd setup
  16. Where is the USB Port located?
  17. PAC SWI-PS install help
  18. AVIC-z120bt VS Stock Nav VS Ebay Chinese Nav
  19. Wiring diagram for factory fogs
  20. Service Mileage on MMCS
  21. New kenwood excelon dnx9980hd specs and pre-order wicked cas 603-642-4222
  22. Custom Evo Audio Build
  23. Alternator capacity?
  24. USB + Ipod
  25. Head Unit Install Questions
  26. alpine ive w-505 + which ipod??
  27. Where to put 2 12 Inch Subs in Evo?
  28. Stock Speakers with Aftermarket Headunit
  29. EVO X Security
  30. Reverse signal wire?
  31. Anyone installed a Pioneer MVH-8200BT in an X??
  32. Steering wheel controls with Carpc
  33. Navigation Backup Camera Harness
  34. 2011 Sat radio module location
  35. have oem nav unit, do i need amp
  36. Factory Sat radio on aftermarket head unit
  37. Looking to buy a navigation system
  38. How to start a repo 2008 evo x gsr?
  39. New owner question about OEM Nav/40GB unit
  40. Running 4 ohm and 2 ohm Speakers Together
  41. Intermittent Right side Speaker non operation..
  42. Upgraded firmware, no RTT...?
  43. non-SSS non-RF non-NAVI Stock head unit and Line Out
  44. Can I keep factory bluetooth with aftermarket deck?
  45. AUX input
  46. 2010 stock Navigation / DVD on EVO
  47. Mounting Component Crossover
  48. After amp to Subwoofer?
  49. carPuter or CarPC
  50. Mmcs over heating issue
  51. Comp System Install Question
  52. which wire at the tweeter is positive/negative?
  53. Radio shut off after car turn off
  54. Need serious help with MITO-02
  55. Amp replacement project checklist
  56. Alpine Power Pack
  57. bluetooth question...
  58. Automatic door lock problem... Grrr!!
  59. Updating MMCS version?
  60. Audio system shorting out
  61. OEM Radio Brackets - Where can I get my hands on some?
  62. How much is Stock Mitsu Nav worth?
  63. Access back side of rca plugs?
  64. Sub Enclosures in Trunk Pics
  65. What are the best options for a dbl din head unit ?
  66. need urgent help: Mito-02 and Axxess ASWC
  67. stock BT mic with aftermarket headunit
  68. GI: REAL iPod adapter for Evo X
  69. Aftermarket Back up camera recommendation?
  70. Fuse system with USB retrofit question
  71. She ate my CD!
  72. navigation with ipod ?
  73. Have a base GSR... like to upgrade the loudness of the stereo...
  74. how to upgrade factory nav's map version?
  75. How much?
  76. Pioneer Z110BT bluetooth mic issues
  77. Will these Hertz speakers fit?
  78. Non SSS Fosgate OEM external booster ?
  79. ditching mmcs for car pc
  80. non SSS non RF speakers change, do it!
  81. Comp speakers ,amps & subs
  82. Ground Loop Isolater.
  83. Radio button illumination problems
  84. Measurements
  85. Aftermarket amp
  86. please give me a suggestion on good speakers that will fit
  87. 9 speakers?
  88. Speaker Wire Color - Pos/Neg
  89. fuse for dimmer
  90. Best alarm/remote start for the Evo 10
  91. Overhead Screen in Evo X
  92. Wiring diagram for DRLs for HID
  93. Evo X hard drive upgrade?
  94. Steering wheel scans radio not seek preset?
  95. Alpine CDA-105 installed on 2010 GSR
  96. New Sony DVD Nav
  97. How to install Pioneer avic-z120bt on non SSS EVO
  98. Aux input in non nav, non fosgate MR
  99. Is it okay to mount tweeter like this? *pic inside*
  100. Possible to Install Aftermarket Deck?
  101. Pics of stock speakers
  102. bluetooth controls on steering wheel will work with new navigation system>
  103. fitting subs in small trunk
  104. Nav system issue
  105. Component Speaker Suggestions
  106. Urgent need of help MMCS
  107. How did you guys install speakers?
  108. Custom sub box behind seat?
  109. best headunit/navi for evo x???
  110. need some help replacing Nav
  111. need help wiring alpine pdx5 into rockford system
  112. Ipod Aux input Cable Help
  113. iPhone 4 Help Integration
  114. Missing my bass
  115. MMCS with JDM fascia fitting?
  116. Aftermarket Speakers without an amp, worth upgrade?
  117. Factory radio problems.
  118. Stock Non RF HU, Sat Radio and an Amp?
  119. Single DIN Pocket?
  120. My Stereo setup
  121. Blown Sub
  122. Alternator / turbo noise while headunit is off??
  123. Reverse Light Wire
  124. IN car PC
  125. How not to get your Evo stolen
  126. Navigation security
  127. different touchscreen and bezels?
  128. Best replace 4 channel amp for SSS package in $300 range
  129. headunit steering wheel control functions?
  130. Ipod Hookup
  131. No Power to deck
  132. What powers the stock SSS system
  133. Bluetooth problem
  134. Rockford Fosgate sub stopped working
  135. swapping oem navi in place of stock sss stereo questions
  136. Sirius-XM Radio Question
  137. new alarm project.........
  138. Vent in trunk??
  139. Installed OEM navi : now I got problems..
  140. Factory Remote Start - Installed!
  141. Remote Start 2 Way Alarm Project for MR SST
  142. Battery powered BT audio reciever
  143. Backup camera marker setup/adjust?
  144. iPhone 4 + factory bluetooth troubles
  145. 2008 Mitsubishi Lancer stereo help needed
  146. re-format mmcs?
  147. Rockford stock decibel limit? Got the lamest ticket ever recorded by mankind today...
  148. Sound System Upgrade
  149. Factory bluetoothand aftermarket steering wheel
  150. What is this plug on the back of the OEM MMCS stereo?
  151. Radio static when fogs are on!!
  152. Krazy navi for the Evo X
  153. Screen Size of an OEM MMCS
  154. Dash plastic for aftermarket radio
  155. factory nav aftermarket amp
  156. Sneak Peak at my nearly complete Install
  157. MR Rockford into a GSR with non-rockford
  158. stock evo x radio
  159. Stock Audio Equipment Replacement
  160. Radio not working after gauge install!!
  161. nothing but trouble
  162. Kenwood DNX-7140 not good for quality audio????
  163. Evo X Sub box build
  164. What do I really want?
  165. Steering wheel radio controls - seek presets rather than all stations?
  166. looking for a nav
  167. double din nav install
  168. Pioneer Introduces Pandora Radio Integration - iPhone App [VIDEO & PICS]
  169. installing new amp and spkrs keep HU
  170. GPS recommendation
  171. Stock NAV Mp3 to HDD
  172. Running factory nav on a 2010 SSS...
  173. Interesting backup camera issue
  174. Please give me advise on car audio.....
  175. Nav Module Part number
  176. cant seem to find what im looking for
  177. Question about Rockford NAV antenna
  178. Metra to JDM, Night and day.
  179. Factory iPOD Solution - Anybody try it???
  180. Need help with AUX/Bluetooth/Steering Wheel module
  181. Replace stock sub with Alpine Type R
  182. Gauges on F700bt
  183. help choosing a sub...
  184. Anyone know the TSB number for the Rockford Stereo speaker issue?
  185. New Headunit?
  186. oem navi dash
  187. Radar detector in the middle rear head rest?
  188. AC lights do not turn on after installing new deck
  189. AMP/BASS Combo Question!
  190. Where to buy white clips that hold head unit trim? *pic inside*
  191. used factory navi for the 1st time today, question about the navi voice
  192. Hooking up Zune to mitsuibishi navi?
  193. CDT CL-62ProX
  194. Nav sys question
  195. Factory Nav incomming call beeps
  196. After market alarm with fast key ?
  197. Factory crossover location?
  198. factory Music Server question
  199. Replacing all the stock speakers????
  200. Pioneer vs Alpine
  201. Help me pick a head unit with front USB input!
  202. Help! Very weak sound output on speakers!
  203. USB / iPod Finally Coming to Mitsu Factory Stereos!!
  204. evo navi system
  205. Anyone know these pin outs?
  206. my trunk
  207. Questions about non-factory installed Mitsubishi navigation
  208. Any difference between 08 & '10 navi unit?
  209. Sirius radio subscription question
  210. Replacing the stock RF stereo
  211. A-pillar re-installation help...
  212. Clarion Navi & Pac Switch Jack Install (2010 Non SSS GSR)
  213. aftermarket in dash navi, what are my options?
  214. Stock Speaker Replacement
  215. Question for those w/Factory Rockford?
  216. front tweeter in Rockford Fosgate system - 2 ohm or 4 ohm?
  217. Stock/Factory Lancer Evo Alternator - How many Amps?
  218. New Install: Alpine INA-W900 All-in-one Navigation/Audio/Video System
  219. stock head unit grounding point
  220. RCA output with MMCS
  221. Painting fiberglass boxes?
  222. Aftermartket GPS Install Questions
  223. wtt dnx9140 for factory navi
  224. Need help figuring where this mounts and what it's for
  225. Can I keep factory Bluetooth on my 2010?
  226. Gsr removing blank button
  227. Need Help with Alarm
  228. Oem Amp Info
  229. speedo calibration
  230. Stock Rockford Fosgate mps ability?
  231. Factory Bluetooth
  232. SWI-PS and MITO-02 wiring question
  233. installing x910bt help
  234. Upgrading from the SSS package
  235. Metra Dash kit with Pioneer x910
  236. For those with Metra or Scosche Dash Kit
  237. Scosche BT800
  238. How to change out interior lights near ash tray and cig lighter?
  239. Stock Radio Questions: Not Fosgate
  240. HORNET 727T alarm system add on
  241. Dumb Questioning: Functionality of OEM System
  242. *Part 2* Pioneer unveils NEW products at 2010 CES [Video Coverage]
  243. Advice on purchasing items for new headunit install..HELP
  244. Navi GPS antenna
  245. audio problem on stock non-rockford stereo
  246. MMCS video in Motion for HKS comp 2 unit
  247. ANYbody have pics of their aftermarket radio/nav?
  248. aux-in poor quality/noise?
  249. Searching for The ipod cable for my car...
  250. Alpine PDX-1.1000 or JL Audio Slash v2 Series 1000/1v2 for a 13w7?
