View Full Version : Lancer Engine Tech
Pages :
2]
11
12
13
14
- Brake Bleed Screw Size
- Clutch Bleeder Screw
- '04 Lancer ES - What's the best synthetic oil?
- Exhaust Evo8-9 Muffler
- Cams
- Switching mani for header...
- Engine "Clicks" When Cold
- Engine overheats only when stopped?
- 02 Lancer 2.0 Engine Replacement Questions
- 02 OZ Rally Lancer Parts Needed.
- Coil pack order
- Lancer 2002 OZ ECU Probblem!!
- Engine swap options
- Timing belt WAYYYYYY over due!
- SRI For 2003 Lancer Es?
- 4G94 to 4G94 engine replacement
- 4G94 DOHC Conv.
- 03 oz rally shift knob
- Stock 2003 Lancer ES
- es lowering spring
- Interesting
- Has anyone..?
- rpm drop after installing new headlights
- 02-06 Lancer Engine Compatibility
- A little stuck.
- possible to install lifters upside down?
- Most power out of an NA 4G94 build
- Need Performance Input.
- need some input
- timing adjustments?
- yet another swap question
- Head removal
- Engine Swap Question
- exhuast options
- valve seals
- trying to help a freind
- Crashed my car (FRONT END DAMAGE)
- 13.0:1 4G94 Pistons from Wiseco!
- No Start Issue
- Misfire Question
- spark plug condition
- EGR Selenoid Valve?
- 4G94 304 Stainless Exhaust Flange Available
- DNA Motoring Header... $79 ?!?!?
- Throttle body cooler...opinions?
- VIDEO ADDED! Adjustable cam gears, how to adjust them at the camshaft or crankshaft?
- Engine Rebuild (STOCK)
- 2 Year Old Swap!
- bad cat
- Hey I am Newbie, this is my 4g94 lancer
- How To: Lancer to Evo Throttle Body Swap (Completed)
- Check engine codes on 2003 lancer oz?
- 4g93 DOHC were to buy.
- Catalytic Converters, catco, bosal, or eastern catalytic?
- car keeps stalling
- Car won't start, clicking when turning key
- Info Request: 4G93 and 4G94 Heads
- 05 lancer es 5spd
- Radiator + Thermostat options
- Roll down the windows
- 03 Lancer ES - Bad CAS or bad timing belt?
- 05 Lancer ES--When to change timing belt
- Walbro 255 help?
- lsd
- Mod Advice Needed - Headers, CAI, and Exhaust
- Another 4g64 Swap!
- Start Up Issues
- Chrome intake manifold
- Ignition Specs?
- 4B12 Swap...?
- Ignition Coils/Plugs/Wires...AGHH! Help
- Valve Spring.. Where to buy them
- Unusual wiring harnesses 03 Oz
- Going form high mileage engine oil to full synthetic
- Belt screams only when I start the car
- Motor Mount HELP!
- ac delete belt
- ac help
- Evo 8/9 Coil packs on a Lancer?
- Upgrading Exhaust equipment.
- Potential problem with valve seals (need advice)
- timing belt
- PCV Valve location on 03 Lancer?
- Lancer OZ N/A Build , timing issues anyone help ?
- Walbro 255 install
- 03 Oz Rally problems
- Valve replacement? advice needed.
- Advice on a crankshaft joint oil leak
- help with ecu 03 lancer es
- Coil Packs, which to buy
- Exhaust system for Lancer 05
- 02 oz rally
- crappy header, question
- Possible Turbo
- Engine swap?
- What I need to sprint race!!
- Fuel fiilter
- 4g93E Head parts compatibility?
- sard fpr
- Just got headers installed !!
- 4G93 Intake manifold
- help installing a turbo
- OZ hit 185,000 Miles... Service Time!
- removing intake manifold
- Wrapping Headers - Good/Bad?
- egr valve not functioning
- Car wont start need help
- Washed Car Now Wont Start
- engine swap questions
- The next upgrade on NA Lancer - FPR or bigger injectors
- Lancer Roll Call
- Ok, ive read up and want some opinions
- Boosting my 03 ES
- 4g64 intake manifold
- Turbo on a 03 ES?
- 4g63t
- New motor won't fire
- wanting to mod my 03 es someone help
- Burning Oil
- ID the EGR Solenoid (with pics)
- The Notorious P0403 and P0401; ARG!!!
- Need your expert Help
- Looking for new exhaust maybe?
- help with 2002 lancer engine!!
- tsudo exhaust
- Idle issue
- Something that has been grinding the hell out of my gears...
- Lancer Over Heating!
- Is My Clutch Slipping? What Do I Do?
- noise
- Valve cover torque specs and pattern if any.
- 02 lancer oz wont fire
- Let me hear some opinions...
- P0171, low gas mileage, high fuel trims
- Rebuild Block & Head
- Help problems
- lancer 2003 es tuning, i need help
- Lancer is not taking off help!
- What would you do with 10k?
- injectors????????
- Need Help On Engine Swap
- 03 oz rally electrical problems
- New to the lancer world...a few questions
- oil leaking between transmission and engine!!!!!
- Help please!!
- Help with battery please
- Please Help!
- p0421
- jet v force or apexi neo?????
- chipped ecu or piggy back?????????
- Engine Sludge
- fuel pump going out???Need HELP
- AEM vs K&N Intake
- fuel injectors
- Car deing
- Burning excessive oil.
- g94/g69 swap??
- fuel injectors?????????????
- just got my 2002 lancer oz rally
- 4G93E (All-Motor) Build
- Your Review on some header!
- 93/94 intake manifold
- Straight Pipe Exhaust....
- quick question guys
- HELP timing belt
- Power steering and A/C delete
- Lancer es/oz engine swap thread
- cleaning the intake manifold
- suspension help
- Ac
- HELP!!! headers...
- Please help, turbo compatibility.
- dohc head swap on a 4g94
- Color Changing Guages for Shift Light
- Suggestions on exhaust system
- New Intake?
- 4G93 Intake Manifold on 4G94 (Fuel Rail not flush)??
- evo 8 exhaust on lancer es...
- Mis-fire on cylinder #4
- Alternator Help
- The Project!!
- A/C Makes a Clicking...
- 4g64 swap question
- Main studs
- Bad Oil Pump or Worn Out Engine?
- Cylinder Head Removal Help.
- Catalytic convert help
- conversion to dual cam
- Need this part
- I have a bone stock 04 Lancer ES and I wanna do a swap.
- Will RA fog lights fit in an OZ?
- Intake is making a different sound?
- 125,000 miles and counting
- spark plug anti-foulers
- Cat + Exhaust manifold, recommendations
- Flickering oil light / low idle
- new at this need help!!!!
- idle advice
- lifters/rocker arms/ ticking
- Good Header
- Oil pump
- Rrm headers with check engine light
- Drop in mileage after K&N Drop in Install
- Exhuast fitment question
- A/C is blowing warm air. Low on Freon?
- Need help installing aem uego! Asap!!
- new junkyard motor, flywheel access plate?
- Exhaust Sound
- Exhaust question?
- oil change question
- Put in New Spark Plugs Now Smoke! Help?
- What would be best
- Need help for Head Swap
- main caps arent lining up?
- Bearings yo!
- 4g94 piston rings
- where to buy rod/main/thrust BEARINGS
- help?
- Synthetic Oil Xperience
- Attn Lancer Community!!!
- Car is having a horrible miss or something bad
- 02 Lancer ES (A/T) Valves/Retainers/Springs/Head Gasket?
- Megan Radiator on my 06 es
- Header choice
- power steering belt keeps sliding off
- weapon r- aem
- Headers
- Need an engine
- catback system?
- Proper way to clean EGR and ISC?
- Where can I find some slim fans?
- Exhaust and header
- Any CA smog experts here?
- 04 Oz Mods
- Steering column Pod
- 4g63 / 4g94 swap question
- Smell of coolant but no overheat?
- lancer oz 03
- Burning excessive oil. Still.
- engine replacement for 02 oz.
- Glow Shift Gauges install help!!!
- 2006 Ralliart Grille Question
- 2003 Lancer OZ Bown head Gasket Need HElp!!!
- 4g93/4g94 Tune Question
- 4g63 into a Lancer?
- any engine mod ideas?
- colling system
- What's next?
- Engine vibration in cold
- OBX Exhaust Manifold Headers
