- 4b12 swap ES help
- how to tune my cs3?
- Learned value reset
- Block Heater Install
- xml defintion , I can build for anyone
- 2006 Lancer Starter
- How to replace valve seals 4g13
- It's happening! 4g64 swap into my OZ.
- Weird issue
- Confused with misfire issue
- code 0412 catalitic converter
- looking for a new biss screw
- Broke my 4g94
- Looking for forged Rods and Pistons(4G94)
- 2003 Lancer OZ-Rally Clutch Problem; Gears Grinding
- Transmission fit help
- 2004 Lancer 4G94 error P0420
- Lancer 2002 engine
- engine swapping questions
- 2004 Lancer ES: Have you ever seen this (see photo) missing part in the SRS airbag li
- New Lancer ES Owner
- Issues with the ole es lancer
- Head swap
- Lancer Head Gasket Leak / Need Advice
- Scuffed cylinders, risk it an run it or scrap?
- What size ac delete belt do I need
- HELP!!!!! Car revs in park and neutral but not in drive
- 2003 lancer es wont rev up at all
- 4g94 5 speed transmission can works on 4g69 engine?
- Idle/BISS Iac adjustmnet
- Map Sensor low Voltage
- Engine timing question
- Need help
- Help!
- Replacing timing belt - crankshaft pulley spinning
- Bypassing ac compressor and need the new belt length
- Light pulley and moods 4G94 OZ Rally
- 4g94 cam options
- just bought a 02' lancer need help to find parts
- Please help
- Form 2.0l to 2.4 for dodge stratus
- Engine done for?
- P0300 causing transmission issues?
- Stage 2 Cam + Piggyback +Hydrolic/Solid lifter change, opinions?
- 03 lancer issues shifting
- Whats your guy's opinion on Chinese parts?
- No start
- Cooling fan module issue?
- What parts are involved in priming the engine for start?
- someone who can help me get this part number for this clock Spring
- Cold Plugs 03 Lancer Oz Turbo
- 03 lancer es 5 speed
- tmshot4u
- Need some help please
- 2006 lancer
- Starter relay
- 4g67? Will a 4g67from a 90's eclipse swap into my lancer
- 4g67 dohc on block 4g94
- Auto oz 02
- Turbo manifold
- Engine running rough
- What is causing Sputtering in engine?
- true RWD Lancer???
- 4G94 sohc -> dohc
- P0443 problems evap circuit.. Help
- Individual throttle bodies (ITB) on lancer 4G18
- engine missfire in cs3
- 4G64 swap in my 02 oz lancer.. ecu issue, need info / help
- camshaft
- 2.0L to 1.8L GDI
- Just need verification
- spark plug gap pliers
- ใช้ท่อนบน4g15 Dohc ประกบท่อนล่าง 4g18 ได้ไหมครับ..
- 2003 OZ Rally/general exhaust question
- Need tips on power steering cooler install
- 4g94 rebuild
- 4g63 swap with automatic trans
- 2003 Lancer 4g69 swap
- long time lurker, new input on serious issue
- Bouncing idle when rolling in neutral
- Exhaust Sounds Like Total Garbage - Fix?
- 2003 Lancer OZ Rally, I feel stupid need help!
- Best Engine to swap for more power!
- Lancer es cai
- Stock injector size
- Confusion on a catback exhaust from magnaflow
- Engine swap from automatic platform to manual platform - needed parts?
- will a 4g15turbo Mivec fit easily to a F5M211 gearbox in a Lancer CS3A ?
- 02 lancer oil pressure sensor broke engine block
- My $20 short ram
- engine noise
- reflash Lancer 05 4g94
- Overheating on 30 min trip with ac
- Header Help please!
- Strut bars
- alternator overcharge HELP!
- modification capabilities of my 2.4l
- 87 or 88 octane?
- First Mods?
- idle low then dies?
- valve adjsutment
- 02 front end on 04 ES?
- Sheroku's Lancer OZ 4G64 Project
- 4G18 Engine and ECU problem
- Exhaust Resonator Mid Pipe Differences
- Engine replacement questions
- upgrades
- Timing belt replacement
- Crankshaft Sensor 2002 Mitsubishi Lancer
- Engine swap
- 2004 Lancer ES General Question
- My oz rally motor is ticking
- 2003 Lance ES - won't run - I'm STUMPED.
- need help with my 4g94
- Clutch Assembly 03 ES
- Easiest swap for a 2005 Lancer cs3a with a 4g18 engine and a Manual f5m411 gearbox
- Some white smoke
- 2003 lancer oz cam???
- idling issues
- Fuel pump motor
- Motor mounts cause vibration when reverse
- 2002 Lancer ES cracked exhaust manifold - replacement options?
- Throttle body question
- Need help with my engine
- Ask Signal Distibution Timing Lancer 4G67
- Loud rapid Tapping and misfire on cylinder 2
- aindii
- NA or Turbo?
- CE9A Swap
- Oil light comes on after oil change
- 2003 lancer oz 4g94...blowing ignition coil.
- Parts Lancer
- 4G94 install intake valve springs installation
- Evo 8 Manual swap to Auto
- EBay timing belt kit????
- Engine will NOT crank
- 4g93 camshaft on 4g94
- Crankshaft Seal Removal/Replacement
- :mitsu: Where can i purchase a 4G93 Cylinder Head :mitsu:
- which is the best build?
- Radiator mount question.
- 4g93t gdi engine and transmission swap into a 2003 lancer es
- Question: 02 oz rally manual transmission in 04 lancer es
- cd5a head
- A/C Delete Question
- 4g92 head swap
- CA Smog question
- Turbo Fuel System Needs (no FMU)
- anyone else turbo there 4g13? results?
- Engine stalled but didnt shut off?
- fuse and electrical questions
- Short Ram Intake vs Stock Air Box
- 4G63 Swap
- Trouble Code P0135
- Bought another Lancer
- 4g93 connecting rods in 4g94?
- Need Engine Parts?
- ?? 4g94 ball bearing between backing plate and block
- 4g94 build!
- Header Suggestions
- 2003 zip motor CAI
- Sometimes my car shuts off. I need help.
- Odd P0340 Issue (with fix)
- 2002 OZ Rally header and downpipe question
- Test Pipe
- 2006 ES Turbo
- Lancer 2006 JDM 4G15 to 4G94 Swap
- 4G64/4G63 Hybrid
- Short Ram or Cold Air Intake
- 06 mitsubishi lancer power increase
- Lancer throttle cable
- Best Oil and Filter to use
- I need help BAD!
- Cruise control problems.
- High idle
- El Diablo Blanco: 4G69 2.2L Evo IX build
- Is it worth putting a turbo on my 2002 lancer?
- Engine Problems
- What should I do first?
- Toxic Fab 16g turbo pair 400$ So-cal (CRAIGSLIST FIND)
- Head swap
- 03 es
- ECU vs. PiggyBack! on 04' ES
- 4g94 build
- DOHC or SOHC
- Lancer 03 ES Idea Looking for Feedback
- 2002 lancer internal rebuild
- LED for HVAC and instrument cluster confirmation
- Head Swap
- Canadian Lancer Sportback Engine Parts
- WTB Ripps Supercharger stage 1
- Spark plugs.. Decisions.. Decisions
- 2005 Lancer ES Racing Engine When Hot
- My 2003 Lancer ES project 4g64 block 2.4L DOHC Kia head swap help
- hey guys
- Quiet Exhaust on my ES.
- Long time reader first time poster.
- 4G94 SOHC (A/T) N/A Forged Pistons?
- Pix on 4G94 (CS6A) 02-03 Lancer(s) Oil Catch Can/Universal Overflow Tank & Torque Da.
- Rebuild Kits for stock 02 ES?
- How much horsepower can I get out of a 4g64?
- Cam sensor based on Casting Number?
- Help identify this part embedded
- 2003 4g64 Idle Problems
- Are there Nitrous Kits for a 2003 Lancer ES?
- Engine Rebuild?
- How can I increase my top speed on 2003 Lancer ES?
- Engine and transmission mounts?
- How ? Engine cover removal
- Help with gasket replacement timing belt..etc
- bad passanger motor mount 04 lancer oz rally
- 03 lancer es exhaust flanges
- 03 lancer es straight pipe
- 04 es hillclimb car? Help needed
- Help me build my 2002 LANCER ES :/
- Exhaust
- motor build
- Winter mods? Block heater?
- 03 lancer es rpm surge when coasting in drive
- 4G93 on Ebay
- Nana gone bad
- Balance Shaft belt?
- 4g69 ralliart swap
- 4g94 SOHC to DOHC
- High Output Alternator?
- oversized valves
- Another NOS/4G94 question.
- Debadging gone wrong..
- 02 lancer oz rally header question
- Advice for relocating battery to trunk (and a question)
- 04 Evo head into Lancer ES?
- Evo MAF, k&n filter problems
- 03 Lancer engine transplant questions
- Yet another, wait for it, engine swap (I know a lot of threads about this one)
- All You Need to Know: The DOHC 4G9X Headswap
- Blown Head Gasket
- Parts for Cylinder Head rebuild.
- Choke sound on shutoff
- My Intake!!!
- 03 OZ Rally Part Needed
- Fan running after engine switched off
- Can anyone help me?
- Srt-4 Engine and Tranny swap.
- 13.0:1 Ethanol Powered 4G94!
- 2" headers to 2.5" exhaust?
- Standard or Direct Coil Packs?
- Performance 4G94 Ignition Coil Pack?
- Need help
- 2013 Lancer ES
- 4G93 head swap
