View Full Version : Lancer Engine Tech
Pages :
3]
11
12
13
14
- idling high
- What Catalytic Converter to get for 2003 Lancer OZ
- Throwing codes!!!
- Loud growl noise when turning steering wheel to right..
- Headers
- engine replacement
- Need transmission mounts,front and rear?
- Where can i find eyelids! Plz help
- Randomly poor mileage
- 4g93 CamShaft
- 04 lancer es Engine swap for 05 oz rally
- Catalytic Converter for 2003 Lancer OZ
- 03 OZ Rally Alternator Squeal
- Putting in a new engine.
- honda sound
- HELP! Blew main fuse (100AMP) on battery cable
- 2002 OZ Rally oil leak
- evo throttle body spacer
- timing marks
- possibly a Clutch problems? Help me!
- Overheating!!!!!!
- N1 exhaust w/ headers sound?
- cruise control?
- repair manual????
- Mexico 4g63!
- Battery and Brake Light Flickering
- $400 magnaflow catback??
- Best MPG
- 4g64 and 4g69?
- intake size?
- Why does my belt or something turning squeaks?
- Evo TB Spring tension adjustment
- engine swap 3.0L dohc
- Adjusting idle values in ECUflash, need opinion
- Help with Modding Oz-rally 06 5-spd Engine
- 4G94 setup in a Lancer 03 ES.
- low idle when cold, function test checks out ok though
- Lost
- Need some opinion on engine swapping for my 03 Lancer ES
- Trunk Cardboard Piece
- help need info!a
- Hanging RPM's
- new to forum looking to swap engine need help
- Where do you buy an upper oil pan
- Hard Starting
- Who has the fastest FWD lancer? ever?
- Headers
- should i put premium gas in my oz?
- 4G93 to replace 4G94?
- Flywheel Question
- Engine Swap
- Ralliart Engine swap in Oz rally
- oil dipstick tube removal??????
- Engine won't turn over
- Filter inlet size
- Throttle cable
- P0421 Recall Over 100k What Can I Do?
- Frustrated...
- Car Keeps Trying To Die! Dire Help Needed!
- Vacuum hoses
- Having a little trouble starting
- 4g94 JUNK??????????????
- Need Help
- Anyone pay to get motor mounts installed?
- [Evo 8/9] exhaust system question
- Piston Bore Size? 4G94
- Japanese motor????
- What did you do to your Lancer today?
- tiburon engine in lancer
- Bosch o2 Sensor Replacement, Bank#1
- 4g69?
- 02 sensor
- Anyone know what this is?
- Engine Swapping
- RRM Pulley Install Help
- 4g93t parts help
- cylinder numbers
- Fujita Intake 04 oz rally
- Oil Catch Can
- eBay Alternator
- Non-Resistor Spark Plugs
- Continuous P0421 after P0135
- Clicking Noise From TPS / Idle Sensor?
- stock injector size
- Help asap car problems please read!!!
- need a new exhaust
- problems with the clutch
- Will this sound good?
- 4g63 into lancer
- weird problems with the lancer o.0
- Anyone in WA State Instaleld The Apexi-Safc into the 03 lancer?
- Top end drying out?
- tool for removing crank bolt
- 4g94 upgrades
- Shipping Horror Stories Continue
- N-E 1 have the Correct Timing 4 ES Models?
- engines
- exhaust leak (flex pipe)
- maybe buying a 02 lancer
- Power mods to an 02 Lancer ES?
- 2 step on the lancer?
- is there n-e upgrades on ES fuels?
- Converting 4G63 Stock Turbo Mani To Fit 4G94?
- Radiator Question
- 4g94 to 4g63 need help plz
- I need to know what the following are for on the 4g94 intake manifold..
- 03 Lancer ES timing belt problems
- O2 Sensor-$300 Catylictic converter-$500 Stealership Prices?
- My NEW Bolt-On's
- Erratic idle (warm weather only)
- Good Tune-Up?
- Gates racing timing belt , ugh
- USDM lancer factory immobilizer
- wiseco pistons help?
- I Need More HP!
- what u think about this pistons
- 4b11/12 swap
- For those who need to get the crank pulley off
- Flange behind balancer...Need help
- ARP head studs?
- comparing the cost of + hp of 4g64 over 4g94
- Another 4g64 Swap/Build Thread
- jforward5's 4g64 Swap....
- Does my 03 Lancer ES have more than just spark plugs?
- How to get my slim fan on??
- quick question
- hmm..code p4021
- Swapping '03 Evo Powertrain/Drivetrain Into '03 Lancer ES?
- Where to find GOOD Cold air intake?
- Help please asap!
- Help On 4G94 GDI 2.0L DOHC
- Building 4g94 Non-Turbo
- ralliart to oz engine swap
- Tuned Timing Maps
- K20 swap into 2003 Lancer ES?
- Engine or head??
- Ignition Coil Clicking?
- Evo Cat, and exhuast...
- whats the best swap for a 4g94
- P0403
- need some help in chi. ill
- BISS screw adjustment
- Looking for stock headers/downpipe...
- engine harness
- intake manifold diagram
- need help dont know what it is?
- SeaFoam sucks :(
- EGR Valve
- 2002 Lancer OZ with an 03 Evo Engine...
- OBX 4-2-1 vs. OBX 4-1 headers
- header question!
- High Flow Cat o2 bung
- Help: Idle Control Valve
- Need help with a motor mount
- what turbo kit should i get
- Evo 8-9 TB on 4g93 IM ?
- CAT Modification
- RPW built me the WRONG camshaft!?
- How to: remove crank pulley.
- Fuel Sender Wire color
- g94 internal parts
- Spark Plugs
- 2nd o2 sensor!!!
- What belt to use if i remove AC?
- Need some help..torque specs.
- Sigh another stupid question
- OHM Resistance Level Fuel Gauge PROBLEM!!
- not a noob and still need help
- NOOB needs intake recommendation for 2010 Lancer GTS M/T
- RRM full exhaust on an OZ? Having a hard time finding.
- 2003 lancer es timing belt
- Need Advise on Fans
- What do i need to turbo a lancer ???
- New engine wont start!!
- Exhaust Manifold studs
- g93head/g94 block swap ?'s
- Aftermarket Headers With Stock Down pipe
- Fuel FIlter Chaning OZ rally 2002
- 2003 Lancer OZ engine swap
- quick question
- Cars at 150k kms, dealership recommends timing belt replacement..
- RRM Crank Pulley Question
- 4g94 build
- turbo headers/manifold
- EVO Heat shield on a 4G94
- Injector problem
- Intake for an '03 ES???
- Downpipe?? Please Help
- Headers and dp with stock muffler?!
- 4g63 intake manifold? Onto 4g94
- knock sensor
- Amsoil Oil Analysis
- EGR problem?
- The lution By 3rd KREW Performance
- Tune up needed!
- Lancer OZ rally Aftermarket parts.
- idle issue
- Head bolts
- Simple timing belt question
- What engine is this?
- DarkMitsu's 4g64 Swap Page
- Idles Low
- 4G94 Engine Build!
- crazy tick/ rattle
- 4g94 vacuum configuration
- ENGINE SCRECHING SOUND when Rev'd
- Evo 8 oem exhuast
- 4g93 intake vs 4g94 intake RESULTS
- Just bought 05 ES some questions...
- Good investment?
- JDM Mitsubishi GTO 6G72 Engine '90-'95
- Looking for a new engine
- swapped to an eclipse 501 MAF
- Oil on sparkplug threads - valve cover gasket?
- Kool Vue Cold Air Intake???
- power steering pump failing?
- i need your parts/advice
- Where Can I Get an OEM Air Box for my 02 Lancer??? *PICS*
- Greedy ti-c exhaust
- Help...can't decide!
- uh-oh....need rad help
- need help with timing belt
- Exhaust question...
- Dent + Oil Pan = Bad Lubrication ???
- Evo swap into 02 lancer?
- 4g69 in 03-03 oz lancer how to?
- Spark Plugs and Wires
- ECU compatibility through the years
- 4G94 Block, Who Makes It??
- Mirage cam
- lightweight front cross member fitment question
- Turbo VS Two particals nitrogen, One oxygen
- Aftermarket Mufflers
- Head 4G18 - 4G15
- Weight loss
- Question about how to make gaskets
- I need help
- Difference between M/T and A/T Exhaust
- Billet 70mm Throttle Bodies for those interested
- Question about honing
- Bad Valve Guides
- Engine knockong ?
- rrm header help
- ebay catback
- Fuel
- Head bolt torque specs and pattern
- Quick 4g93 question about head bolts.
- Power under $1.000?
- Valve Gasket Leak, Will This Work?
