PDA
View Full Version : Lancer Engine Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14
  1. hydrolocked motor going threw new options.
  2. Engine electrical problem, Need Help...
  3. used cylinder head
  4. swap for a 4g94
  5. 4g93 crank pulley
  6. Still running rough
  7. Radiator Question
  8. Greddy Emanage Ultimate
  9. 03 OZ Cold air Intake Water Problem.
  10. My 4G94 Mivec build up
  11. APEXI SAFC 2 Harness Compatability Question
  12. 2g eclipse intake mani?
  13. new headers, and now stalls
  14. Stock injector and fuel pump flow rates...
  15. Help! 03 Lancer ES ((Bad Sensor))
  16. strange box in my dash
  17. 4g93t whant buy....
  18. idoling prob
  19. Clutch kits
  20. 1/4 mile time attack!
  21. 4g64 question....
  22. Another Misfire problem, can anyone help?
  23. idle problem, please help
  24. 4g94 gasket specs
  25. Misfire help needed
  26. sillicone radiator hose kit
  27. Gates racing products?
  28. cat question...
  29. help finding sway bar 03 lancer oz
  30. Engine rebuild kits?
  31. Stalls...
  32. 4G94 Forged rods
  33. exhaust question... anyone?
  34. need some help!
  35. 6A1X / 6G7X Engine Swaps
  36. Magnaflow Exhaust
  37. Removing oil pan
  38. Increase HP for a '09 Lancer GTS?
  39. Evo Swap ?
  40. Help and Advice
  41. Cai?
  42. wiring harness diagram.
  43. 4963 swap
  44. Possible Engine Swap??
  45. Timing belt tensioner
  46. Need help finding the right exhaust
  47. Best Mishimoto Radiator Kit option
  48. Problems finding new valves
  49. 4g94 dohc-gdi
  50. 1G TB Does it work
  51. 4G93T swap
  52. EVO Engine swap
  53. Low End Torgue
  54. Question on fans
  55. intake manifold upgrade?
  56. please help.. turbo/IC 03oz
  57. Performance Upgrades?
  58. Will it fit?
  59. Cams.
  60. Lancer es 04 exhaust
  61. Question About Exhausts?
  62. cheapest place to purchase a greddy ti-c
  63. Motor Mount bolt size
  64. Upgrade? or sell for evo?
  65. need opinions please
  66. Cylinder Misfire Help
  67. Crank Pulley Noise
  68. new intake,wierd idle
  69. quick question RRM headers
  70. need some idle/rpm help
  71. got a good laugh out of myself
  72. 4g94 is it interference or not...
  73. installing BOV/WG/& psi gauge
  74. 02 Oz Spark plugs
  75. RMR Intake on an ES
  76. 4g63??
  77. engine miss/service engine light
  78. Aeromotive FPR fittings
  79. Installing New Intake-> Trouble with screws
  80. What kind of intake?
  81. Compression test
  82. Muffler Question
  83. Stock Air Intake on 06 es question
  84. audible difference between crankwalk and pulley damper wear?
  85. 2003 lancer es
  86. Engine Swap
  87. 02 OZ engine swap
  88. 03 OZ Rally: Doing timing belt anything I should know?
  89. boost stock internals
  90. Authorized Modifications
  91. question about top end and bottum end
  92. P&P head and intake
  93. Need help, in middle of install.. Wideband LC-1
  94. 2003 Lancer Es want an engine swap
  95. Wiseco Pistons...?
  96. Timing belt replacement time after 100k?
  97. Is their an oil filter that lasts 10-15k miles?
  98. half size radiator.. what is needed to make it work...
  99. anyone on the RPW stage 2 cam
  100. Recommend spark plug wires?
  101. ok, injectors question..
  102. 80,000 miles... What should I do for maintainence?
  103. 4g94 DOHC?
  104. Dynomax Super Converter (CAT) any good?
  105. large oil leak
  106. pauter rods
  107. How many cats?
  108. Do i need a tune with high comp pistons?
  109. Need an OIL PAN..
  110. not sure if im posting in the correct section...
  111. engine build
  112. Coil Pack Recommendations
  113. Dun Dun Dun... Cracked Header :(
  114. oil light flashing at idle?
  115. What CAT do you recommend
  116. What dohc head for 4g64?
  117. Is it ok frun the walbro 255 N/A?
  118. What would be the best brand of headers to purchase?????
  119. What you all need to know about motor oil in our Lancers.... PLEASE READ
  120. RPW Camshaft w/ 4G93 Valve Springs
  121. quick question
  122. 4G69 swap, opinions
  123. Do I need to chage t-belt now???
  124. RRM Lightweight Pulley
  125. Flooded Engine
  126. Cat Question
  127. do evo catbacks work with oz?
  128. exhaust gasket
  129. Vacuum hose to intake?
  130. gas mileage high than low than high
  131. brake problems
  132. swap?
  133. o2 sensor
  134. Dimensions for a custom test pipe
  135. Where do you buy your parts online?
  136. Air Diversion Panel Question
  137. Need some quick help please
  138. CEL code P0421
  139. Bad Slave Cylinder ***n again!!!
  140. a quick question - header
  141. greddy help
  142. mod help
  143. Setting tdc with aftermarket camshaft...
  144. bad compression? bad piston rings? help
  145. Sound Problem with mods
  146. volo ecu
  147. 2003 auto coldair intake
  148. Dynolicious
  149. From World engine to Hybrids and evo swaps
  150. the right turbo
  151. Rrm Piggy!!!!
  152. Kill Switch
  153. Shop manual for 04 OZ Rally
  154. will these injector work?
  155. Oil Pan gasket torque
  156. Check Engine Line - On because of Cat? Need to fix....Emissions due.
  157. Universal Code Reader???????
  158. Please Help/ Motor Mounts!!!!!
  159. Crankshaft Pulley
  160. RRM Piggyback and Header
  161. Hey guys I have a Quick Q.
  162. RPM and MPH Help
  163. 4g94 mivec??
  164. CEL on
  165. is it possible
  166. CAI whistle after exhaust install???
  167. Does this work?
  168. Help Needed!! Engine Misfire
  169. Apexi Neo
  170. piggy problem
  171. Is the price worth the outcome?
  172. Timing belt issues/question
  173. engine oil light
  174. 02 intake manifold on 06 motor
  175. header sensor
  176. exhaust measurements!!!
  177. mods
  178. head stud help ?
  179. good brand battery?
  180. water pump replacement
  181. engine replacement questions
  182. Pulleys oh my
  183. Car stalling after K&N, HELP PLEASE
  184. Oil Pan Leak...What do you guys think?
  185. Idles keeps going higher and higher
  186. Spark Plugs
  187. easier way to tighten the altenator belt??
  188. Engine Sounds Like A tractor
  189. replacement exhaust hanger????
  190. 0-10 Take off Shudders
  191. Exaust too loud :(
  192. My OZ Exhaust Sound Clip
  193. HELP!Can't tell speed,temp or gas!HELP!
  194. idleing and higher rpm and spark plug help
  195. 2003 oz battery, alternator/high output qustions
  196. RRM cam gains
  197. Greddy EVO2 on an 04?
  198. whats next?
  199. Injen Short Ram Intake
  200. Performance Upgrades for 2002 OZ Rally AT
  201. 4G69 Into OZ Rally?
  202. Aftermarket Exhaust sound inside car
  203. Pulse plugs anyone?
  204. Fidanza Flywheel
  205. at what PSI do you go into the motor
  206. homemade intake
  207. whats a good swap
  208. To cold air intake or not to cold air intake?
  209. fidanza adjustable cam gears for 4g94
  210. maf adapter?
  211. Radiator drain plug location for a 03 Oz Lancer?
  212. Car only starts when jumped.
  213. Underdrive pulley stuck...
  214. My car is overheating..
  215. tachometer installation
  216. WARNING: Header Thread (found a new one)
  217. evo engine damper
  218. Bought a wrong kit: Can a 02-03 CAI fit a 05?
  219. is this somthin to be conserned about...
  220. Water temp adapter?
  221. Stock 2003 OZ, top speed results?
  222. 4g94 oem rods
  223. Should I buy an exhaust muffler or full exhaust?
  224. Where's the oil sending unit?
  225. Placement for Temp sender for gauge
  226. 4G93 TB ??? Need a quick reply...
  227. Im at 57k Miles
  228. Narrowband O2 Sensors
  229. Header, Cat-Back, Let me have it!
  230. Megan Headers for 04-06 ES/OZ
  231. what mivec head?
  232. camshaft duration and lift ???
  233. Thermostat Woes
  234. vacuum gauge
  235. rod bearing? piston rings?
  236. intake mani? suggestions?
  237. 02 Lancer Oil Capacity
  238. cam gear ajustement, how to ajust
  239. 03 Lancer OZ rally intake
  240. what injectors u guys using
  241. Random CEL today...
  242. 4G96 cams
  243. Exhaust options for 2006 Lancer ES?
  244. Timing belt change info
  245. Need OEM Mitsu Part numbers...
  246. New catback exhaust!
  247. clutch goes straight to floor with no pressure
  248. which radiator should i get??
  249. Anyone shoot nitrous (wet shot) thru stock 4G94
  250. Stocky Or A.m. Radiator
