- Car Dyno
- Custom Exhaust Setup Questions
- valve cover
- Valve Cover Bolts
- RRM and RPW
- Header Confusion
- O4 ralliart o2 sensors
- RRM Piggyback / Headers Combo
- bought drop in k&n filter and need your help!
- Where to get a new honeycomb?
- Estimates??
- Factory mistu ground wire kit
- Kamikaze header is on
- Hyper Ground Cables
- Cat converter options?
- Aftermarket Radiators?
- low end power???
- Spark Plug wires
- so i think im the lastest victim
- head swap: runs like a racehorse
- y does it tick?
- Aem Cai
- hp gain
- head swap: now won't start
- Purpose/Function of grounding wires?
- throttle line
- How do I?
- Piggyback solder questions
- RRM Piggyback
- bypass valve / hydrolock info
- Ignition systems
- Grounding wires
- valve cover qs!!!!!
- flowmasters
- greedy or Apexi!
- SRI/CAI question dealing with freeway driving
- Need some help with an OZ!!
- RRM Piggyback & cold weather
- S-AFC or Emanage?
- Throttle Tight, then throttle loose problem
- Magnaflow Exhaust
- Intake question
- Cold air intake...
- Twin Throttle Bodies
- HELP! oil pan drain plug bolt specs
- Walbro Fuel Pump
- Road Race ECU Misfire...
- Water Pump
- exaust/header issue
- kamikaze header install
- fuel rail swap
- Injector Resistors on Lancer?
- Brands of Intake
- 2 vs 2.25 vs 2.5 exaust
- ignition coils
- Yet another exhaust thread - but personalized!
- stock cylinder bore
- Making the exhaust decision
- port and polish
- plz ex. exhaust to a semi-newb!!!
- Intake Mod and Engine Photo *Comments Wanted*
- anyone using 2inch exhaust piping
- 4G94 specs
- Magnacore wires (again) few pros
- Exhaust
- Need more power
- Exhaust resonator
- Turbonater?
- Ecu, Looping????
- valve problem
- intake manifold install w/pics
- Is this correct? (Vacuum hoses)
- Shouldn't i be having more power?
- HELP! New Smog Laws = no intakes legal?
- Idle Flux?
- alternator belt??
- SOHC vs DOHC
- RoadRace Testpipe?
- Twin Filter Intake
- SES fix?
- oil ???q's???
- hot day, lumpy idle/stall please help.
- custom exaust
- voltage stabilizer?
- kamakazi header for 04
- 4g63 swap
- Fuel pump?
- compression
- I have a question!!!
- Intake manifold installation
- In search of braided steel fuel lines
- exhaust experiment and questions
- rrm pb ecu question
- Ignition and Fuel System
- RRM piggyback plus cams?
- ricey exaust like a vtec civic???? help!
- will i need the cai ne more
- Swaps???
- Cry02?
- Vacuum gauge
- Cold Air Intake for AT 02 lancer ES
- somebody install this urself?
- Where to buy new Engine Oil Pan
- okay one last v6 forum
- Okay second questoin.
- Turbo ES ???
- Possible Hp
- Tightening Throttle cable?
- turbo timers?
- RRM Auto Piggyback HELP!!
- Installing Upgraded Fuel Rail - 4G94
- Might Need a new alternator
- What is it and can i remove it?
- Sun Ground wire (hot Earth)
- Last day at track, dissapointed
- engine swap ?
- ECU or turbo first???
- CEL = Output speed Censor. HELP!!!!
- Looking for good intake kit
- RRM Intake Manifold and Throttle Body
- test pipes
- Sites selling CAIs
- What turbos are cam compatible?
- What else to change when timing belt is....
- How Tough Are the Factory Internals?
- Question about the Intake Manifold
- Engine?!!?
- Blew my engine - RRM IC Turbo
- Headers?????
- Throttle Body Port by ProflowDesign
- Convince me!
- Available swaps...??
- Ported Throttle Body & Intake Manifold
- Got my typhoon intake today!
- Magnaflow Install
- Mini style intake?
- Digital Readout - SAFC or other?
- Piggy Back and Shifting???
- head gasket change?
- Header + Catback Buzz Problem...fixed!
- Mas Help !!!!!!!
- Injen intake system
- performance parts 2004 lancer es
- How to: I.M and T.B
- 2002 Mitsubishi Lancer O-Z Rally Edition L4-2.0L SOHC MFI / Piston and Connecting Rod
- Has anyone used the "Bullfrog Head Packages" ?
- Lancer Shop short shifter
- whats a good super for ES?
- How fast could you?
- Intake manifold and TB.
- Injen CAI for 2004 ES
- stroker kit (US LANCER)
- Exhaust manifold bolts on Evo. The same as OZ?
- MAF simulator?
- Walbro pumps for OZ's ??
- Is this possible???
- gutted muffler?
- BOMZ Short Ram Intake
- Cylinder Head Gasket
- auto lancer
- 4g63
- Muffler - Oval or Round? Size?
- engine code ?
- how do i get more rpms?
- header installed! now i have some qs!
- Take it off!
- ?? on NOS, NX, Venom, ZEX all NO2
- exhaust gaskets
- HELP!! Do I have an Exhaust leak?
- Return of the coil thread.
- header install qs????
- A Question for RRM
- dont heart to ask.
- question on us lancer stock header
- Oil/fuel Sensor Placement
- Engine Swap?
- timing belt
- can these be changed?
- intake mani or throttle body?"
- what happens to Mass Air Flow Sensor(i think?) after a cold air intake installation?
- rrm header qs
- intake question :P
- RRM Header + Buschur downpipe?
- 04 Lancer FPR
- More tech questions I hope to be answered
- who is the faSTEST?
- what is the torque power band on an 03 OZ?!
- do the digital odometers on 02/03 lancer o.z reset to..
- quick question: will the guages cluster from a 02 work on the 03 lancer?
- Finding Rod Bearings.
- how to install aftermarket tach?
- mil eliminator install Q's
- RRM piggyback MPG
- Question about C.E.L
- Custom Machined Parts
- Help with Exhaust
- Need Help with AEM Cold Air Install
- do my plugs looks ok?
- parts
- Does Anyone know if there is an online Chiltons?
- help with my FPR
- What are the exhaust manifold torque lbs?
- Wires to tap for the 02 Simulator?
- got a question about fuel pressure adapter!!
- 02 sensors help
- Lancer Racing Electrical Cpu Module 5+ Hp????
- 2000 2.4L Eclipse Engine???
- Engine Bay Picture Help...
- Lancer 1.8 SOHC owners
- grinding question
- Radiator Fluid
- Need some opinions....
- Which Header???
- Header Q's
- What muffler should I get?
- 02 sensor wires questions
- mil eliminator help
- Intake Question
- exhaust piping question
- Pulley question
- Spark plug write up?
- Why the MAF??
- Mivec Head Swap
- Z1 Performance Chip
- need cam info
- Cooling Fans
- Lancer engine belts
- System pressure questions (Intake and exhaust)
- ebay intake
- rrm or rmr sri
- RRM Piggyback problems?
- Loss of Power
- How can i increase the gas millage of my 03 lancer es
- HEADERS question.. Help...
- how far can n/a go without fuel mods?
- feul rail
- RMR Intake: Noise Problem?
- PCV Valve Question
- 4G94 = Open or Closed Deck
- Evo Catback on ES
- ECU questions, if thread already exisits, please link
- BackPressure Qs?
- Idle Problem
- Rpw's turbo/supercharger cam shaft
- Low Temp Thermostats
- EMS?? Which one does what?
- Coolant Temp
- pully kit
- N/A questions
- piggy back/ headers
