View Full Version : Lancer Engine Tech
Pages :
7]
11
12
13
14
- throttle response
- Lancer ES Engine
- Exhaust system difference 03-04
- Need 10 hp plzz!!
- Burning off oil
- O2, Wideband, egt sensors
- rmr intake filter size...
- oil catch can
- Problem Spark Plugs Coil? CEL
- Radiator problems
- RRM intake manifold and throttle body ?s
- Can Someone Point me to an Oil Cooler?
- whats the max power oz can handle on block?!?!
- 4g93 pulleys for 4g94 lancer
- weird cel
- What about DC Sport or Apex'i exhaust ??
- drop in filter
- Finally ...
- Greddy evo 2 exhaust question?
- Magnaflow exhuast leaks...New install
- Getting a new muffler
- Check out these injectors
- OZ RALLY Exhaust question
- A little research goes a long way...
- header making nose
- anyone running aftermarket connecting rods?
- torque pattern header
- Short Ram Intake Vs Cold Air Intake
- Swap Auto for Manual tranny
- Willing to learn
- idle adjustment
- BIRTHDAY!!! What upgrades should i get?? PICS! HELP MEH!
- Bigger injectors make a big diff?
- Installed RRM Test Pipe and Lightweight Crank Pulley today!
- No idea where to start
- Pulleys
- 05 lancer es returnless fuel system.
- warranty
- Piston and connecting rod donation
- Another Mod! intake Manifold
- any type of spark plug wires?
- need pointers
- Sea Foam
- Help!!!!!
- Engine Swap
- Exhuast ?
- Camshaft...
- header question
- valve cover gasket....
- Help!!!
- what you buy with $2000 in N/A mods
- Need Help Yet Again
- 6A12 MIVEC swap
- engine temp gauge?
- Running lean? Oh crap.
- NSC engine damper
- Any ideas for a catback for 04-05 lancers?
- Intake Question
- unhooked O2 no code
- Headers
- 02 Sensor Melted?
- Magnaflow 3 chamber muffler
- Head Studs for the 4G94?
- What other performance besides turbo?
- Jdm N1 02-06 Mits Lancer Es/ls Oz
- idle issue not RRM piggyback, could be and most likely is...
- Please help with my exhaust.......
- gear studder
- 2002 - 2003 lancer downpipe?
- SRI for 05 ES... yeah right... HELP
- Which Cat-back Fits?
- I need an o2 sensor
- engine swap
- Not much low end?
- 2002 lancer oz o2 sensor signal wire?
- Forged Pistions
- Need some NA advice
- Exhaust Concern...
- Arp head studs
- Weapon R review
- Front Mount "Cold Air" Intake
- extending o2 wires?
- my car is sucking right now...
- choosing intake
- High Flow Cats - shapes = ?
- Highest MAP on N/A car
- removing cats? @ muffler shop...
- Adding a cat to stock exhaust with afterm. muffler
- Magnaflow 2.25" Catback
- Valve Adjustment? lifters?
- Battery
- 02 bung placement with RPW race
- I don't want to sound like a Honda
- Balance Shaft Removal...
- Wow, and you thought YOU were a noob!
- arcing problems + a relapsing misfire
- Importing RPW engines
- RPW Headgaskets....give me suggestions.
- Cold air intake?
- intake Mani help!
- Intake air cooler?
- Any Ideas???
- Terrible Noob Question, Need Help Now
- All you need to know: SPARK PLUGS!
- magnaflow catback installed
- header question
- Should I clean the runners?
- A few questions on fuel needs and tuning
- dyno ?
- Boe's fuel rail
- Automatic frustration
- Fuel Question (just Ordered from RRm)
- Air Ducts and water/weather?
- A little help please - Vacuum lines
- cam in an 05 OZ?
- Nitrous?
- Engine Swap????
- Air intake for Automatic
- cat coverter
- Engine miss?
- best na setup
- RRM CAI Review
- Ok here's the scoop
- 05 us lancer es - FPR
- custom catback exhaust
- compression bent piping
- Warm Up Cat ISSUE: HELP!?
- Down Pipe
- Shell Gas best for pig?
- Ok I searched, one last question re PB
- 05 lancer es.
- Big problem with MAS
- Attn: OZ rally lancer owners!
- mod my lancer, help?
- Valve Cover Problem
- Bad gas mileage! Help
- Exhaust
- Yet Another Kamikaze Header Thread . . . please help
- Koyo Radiators N E good?
- 4G64 for $1000
- Searchin for best ECU
- Header Bolt Reinstall
- Rebuilding engine tips?
- Skunk 2 for Lancer ES?
- Kamikaze Header (yes i did search)
- A'PEXi Engine Monitor
- What coolant and mixture do you use?
- EVO engine swap into Lancer ES 4g94
- Speed and Run Catback exhaust
- Timing Belt Covered Under Warranty?
- O.Z. ralli turbo and AWD?
- pulley
- RRM Headers
- air fuel ratio reading
- Illinois Turbo installers in QC or Peoria
- Resonator
- Another Intake Thread
- Compression Check, NEED HELP.
- weird problem - car stalled
- 4g63T VR-4 Motor Swap....
- Anything New?
- Kamikaze Header
- fmu problem
- any motor swaps i can do?
- oil question
- Which cold air do you recommend?
- Which Headers ?
- I just droped MAF
- 4g93t
- Road/ Race Piggy Back ECU Ver 2
- Engine Swap
- Head Bolt and Rod End Cap Torque Specs?
- 4g94 turboed?
- 02 Lancer OZ Apexi SAFC II settings??
- Possible valve problem??
- sheet metal intake mani?
- Ported/Gutted Exhaust Manifold
- Engine Problem
- ROAD/RACE Header with CEL ELIMINATOR
- Mitsubishi engine codes(4g94, etc.) fully explained
- How to read a SPARK PLUG
- Engine feels/sounds ruff when turned off
- Oil Filters - which one is the best
- Radiator hoses
- Engine hoses...
- Mechanical o2 seems to work w/ RRM header!
- Fiberglass or Carbon Fiber
- Gm Maf/maf-t
- Emission Recall Notice 02-03 Lancers
- RPM hang, DUE TO unlevel MAS??
- Govern Limiter
- Mods
- Evo Engine swap!!!
- stock intake hose replacement
- Help! Whats the technique to remove bottom left exhaust mani bolt?
- Headers????
- adjusting idle
- Spark plug change
- Power Steering
- Question about injectors?
- APEXI i-Moni
- Apexi super AFC
- Crank Pulley for the 2.0 engine
- DOCH 4g93?
- Greddy eManage...
- Haltech ECU Plug and Play 99% finished for Lancer/Mirage
- put new longblock in....problems!!!
- Need a little help with an intake...
- What wires do you splice into for the RRM Piggyback
- Auterra Dyno run
- Engine rebuild
- 9.75:1 octane needed?
- reflash??
- $530.00 for a darn MAF sensor
- New Lancer
- maybe valve problems???
- ECU Chip actually works??
- need help...i put on weapon-r short ram intake
- My ECU fried??????????????????
- plug info?? please
- Stock EGT?
- 4g63 Head on the Lancer OZ??
- flow numbers for a stock 4g94 head
- I've searched the forums...
- AFRs for given octane
- IT A OF The VALVE HIGH PERFORMANCE???
- wiring question
- Ah yes... New Lancer Owner...
- Porting explination
- HKS Super AFR
- My SRI install Bomz
- RamAir update
- Puffing White Smoke Out From the Exhaust
- my header
- RRM Piggyback problem....help
- any info or suggestions
- Big FIX! now just a few little fixes (slight miss fire)
- O2 sensor wires and problem
- New CAI
- Swap ??
- wideband narrowband o2 sensor help
- General Ignition question
- Anyone ever degree an RPW stage 1 cam?
- ~Walbro fuel pump loudness?~
- Tuning ignition timing with an e-manage
- Pictures of ported cylinder heads
- stock downpipe
- Fuel Filter location
- Correct NGK Spark Plug Number
- Intake/exhaust Valves
