PDA
View Full Version : Lancer Troubleshooting
Pages : [1] 2 3 4 5 6 7 8 9 10 11
  1. Replacing stock headlight socket with aftermarket sockets. Need HELP with wiring
  2. Lancer GLS 2003 not shifting, no power!!
  3. Squeak @ 1.2-2k rpm
  4. 2002 gauge cluster lights
  5. Can changing the fan controller for engine fan cause Check Engine Light?
  6. 2003 Lancer OZ Rally, car starts but shuts off when driving.
  7. Engine stalling while driving, restarts automatically
  8. Oz rally sunroof
  9. Major Coolant leak from driver side of engine
  10. 2002 Lancer OZ Cruise Control Help - Please
  11. Random Crank/No-Start Condition
  12. Lancer newbie, is it worth it?
  13. 03 Lancer has NO.... I mean NO POWER when on pedal
  14. 2003 OZ Rally starting issue.
  15. SRS Light
  16. 02 lancer rally constant engine stutter
  17. Shift Console Lights Out
  18. Electric Systems shutting down left and right
  19. 03 Lancer basket case almost assembled
  20. 02 Lancer LS A/C o-ring sizes
  21. Daytime running lights plate lights stuck on
  22. Squealing after Radiator Fan turns off
  23. Misfire , sputtering ?? help
  24. 2011 es spark knock!
  25. 02 lancer wont start after installing silencer
  26. Not firing on banks 2-3 and coil pack is burning up?
  27. 03 Lancer ES - Speedometer jumps to 60mph
  28. 03 ES - AC Blower stay on when key removed from ignition
  29. Door won't stay open.
  30. 2015 Lancer ES Bluetooth and Hands Free Controls
  31. Trunk lid compatibility question
  32. P0456 Evap related CEL
  33. 2006 Lancer Es Shifting
  34. jam nut holding on rear hub
  35. 03 Lancer ES Death and Rebirth Issues
  36. quick question about lights.
  37. burnt blower motor pigtail
  38. Can't get my OZ rally to start........
  39. 2005 Lancer Ralliart Ticking (Injectors)
  40. Parasitic Battery Drain
  41. Trouble with my rear roll mount of my 2003 lancer es
  42. my temp gauge doesn't work.
  43. Horn Wiring Check
  44. P0421 and.. crank case blow-by?
  45. Top Speed problem
  46. 03 Lancer OZ intermittant issue with Acceleration
  47. positive battery terminal with fuse
  48. can a P0301 mean anything else?
  49. Hey, I'm new and I have an inquiry.
  50. Front ECU issue?
  51. Transmission Knocking
  52. Possible Power/charging issue
  53. Front turn signal issues
  54. Intake and line to the PS pump
  55. 02 es cluster
  56. Lancer ES 2003 SRS light
  57. Lance ES 2008, P0443.
  58. 2006 Lancer ES - died while in motion
  59. Dashlight problem.
  60. 2004 Sportback idle issue after TB change
  61. 02 ES - Issue Accelerating
  62. Lancer hood latch broken
  63. Need a little help
  64. Lancer Es Leaking coolant
  65. Pliers for wheel bearing circlip
  66. Speedometer intermittently not working
  67. Issue with airflow meter
  68. 2002 lancer gdi not turning over
  69. Front door grinding front fender.
  70. 04 SportBack hatch stop light
  71. Overheating but not going all the way to "H." Coolant temp sensor or sender?
  72. Driverside head lights and tail lights are out
  73. Overheating and driving me nuts!
  74. Dash fuse box
  75. 2003 lancer oz rally ruff idle and oil light
  76. 2nd gear is grinding on my lancer 2003
  77. battery light issue
  78. Lancer Wheel Alignment Issue
  79. 2003 Lancer ES Grinding only while driving, turning right
  80. Got a P0401 after all motor mounts changed
  81. Can't find front lip
  82. Multiple issues 2006 ES
  83. 2002 lancer ignition problems PLEASE HELP
  84. 2002 Lancer main harness problems
  85. Check Engine Light doesn't come on
  86. 04 Mitsibushi Lancer Rally
  87. Newly installed evo cluster problems
  88. Random misfire only at operating temp
  89. Heating Up at Idle With AC, 2003 Lancer OZ
  90. 2002 OZ Rally won't start
  91. The Catalytic Converter
  92. Core support change
  93. 2004 Lancer Not Starting
  94. What Is This
  95. Stripped hood latch bolt ?
  96. Steering Wheel Sounds Stripped
  97. Humming noise from front wheels
  98. 2006 Lancer ES P0303 after head install
  99. 03 OZ Knocking and Ticking
  100. Instrument cluster and interior lights not working
  101. 03 Lancer climate control lights
  102. 04 lancer ES losing lots of oil!
  103. 2002 Lancer running lights not working
  104. Cable broke on hood release.
  105. upstream o2 sensor wire colors,engine side
  106. Gas Filler Neck Question
  107. Help with HVAC 2003 Lancer ES
  108. Gas gauge oopsy
  109. parking lights not working correctly
  110. Test IAC
  111. Speedo and climate control won't stay lit at same time.
  112. Engine swap / weird buzzing sound with no trigger to the starter
  113. Help 2003 Lancer lots of white smoke at startup only
  114. signals don't work all the time
  115. incorrect temp reading
  116. 02 Lancer won't turn on :(
  117. Radiator fan connection
  118. 2003 Lancer ES - Constant battery drain
  119. '02 es, another no start
  120. Help with doors unlocking
  121. 2004 OZ dies during idle
  122. Misfire while driving FRUSTRATION!!
  123. P0335 and P0340 - Car Runs Fine
  124. Motor Mounts and Transmission Help
  125. Strange squeak
  126. 2002 Lancer ES won't start
  127. Codes after 4-2-1 header install?
  128. Radiator fan
  129. Alternator/battery relay?
  130. Input and Output sensor locations ?
  131. HELP! Battery drain and blower motor will not stop
  132. Door Locking issue
  133. problem with a EVAP HOSE, dont know where to plug
  134. 03 Lancer will not start
  135. Transmission Issue
  136. Radiator Fans Low Speed - Fan Control Module
  137. 03 lancer e's running issues
  138. Erratic speedometer 03 Lancer LS A/T
  139. 2003 Lancer Radiator Issue
  140. Bad transmission help?
  141. Car wont start. Simple quesiton.
  142. '04 Lancer ES - No start (detailed story)
  143. 03 Lancer Es rough idle/vacume leak
  144. 2002 lancer loose wire, solutions??
  145. 02-03 vs 04-07 rear doors
  146. Ac off or not cool makes my motor die
  147. 2003 mitsubishi lancer es ignition coil issue help
  148. P0171 EGR valve smoke test leak
  149. 2004 Lancer ralliart keeps blowing fuse #1 in the dash -no start issue
  150. 2002 Lancer ES P0443 - Evap Purge Solenoid
  151. Fuel sending unit going bad? 2002 OZ Rally
  152. A/C delete belt for 2003 Lancer models
  153. My Apexi SAFC was stolen now what?
  154. 02 Lancer ES - Sway bar bushing help
  155. 2007 Lancer ES
  156. Test Pipes??
  157. Will 2003 lancer es engine wire harness fit a 2005 lancer es? both 2.0
  158. 2005 lancer es egr insufficient flow
  159. tricks on removing this motor mount
  160. Persistent EGR Issue
  161. Lancer not starting
  162. HVAC Concerns
  163. 2002 Lancer with P0443 code.
  164. 2003 lancer es rough idle !! help !!
  165. What's this? Help asap. with pics.
  166. 02' Lancer front passenger window problems
  167. AC Relay or Clutch Gap?
  168. Lancer blowing hot air
  169. 03 lancer es trouble starting
  170. Recovery from water damage
  171. Catalytic Converter Issues!!!!
  172. 02 Lancer ES Idle/Electric Issues? Please help!
  173. Return fueline non existant after newer engine swap
  174. 2002 LS Dieseling
  175. A/C Compressor issues
  176. Dying Lancer Seeks Assistance :/// (sludge in bell housing)
  177. Intermittent Wiper Upgrade
  178. 4G18 Idle Problem
  179. just bought 03 lancer oz rally
  180. Lancer 2.0 P0303 code trouble
  181. Boss kit for a 2003 Lancer ES
  182. AC won't take refrigerant/blow cold air.
  183. engine vibrations
  184. How do I replace the backlight in the Automatic Stick?
  185. 04' Lancer! Catalytic probs!
  186. Rattle noise passenger side dash area
  187. Unknown Emissions Part help
  188. 2003 es overheating
  189. Dead ECU
  190. incorrect egr flow on 03 lancer oz rally
  191. Does alternator power run through battery terminal fuse?
  192. Cigarette lighter/ashtray wiring.
  193. will an Evo 8 steering wheel for in my '03 lancer es?
  194. Spindle fitment
  195. Lancer jerks when accelerates
  196. Poping sound when turning
  197. P0134 code, no activity, bank 1 sensor 1
  198. Starting Issues
  199. Downshifting gears from 3rd to 2nd-impossible
  200. parking light issue
  201. Rattling from brake??
  202. Hazard/Signal won't work.
  203. Ashtray light isn't working...
  204. cranking but no start...
  205. New Timing Belt Clunk & Slight RPM Surge
  206. Key was not turning
  207. 2003 oz rally no start. has fuel and spark
  208. 2002 OZ cluster light problem
  209. throttle body problem
  210. Replacing motor mounts - a cautionary tale
  211. Major coolant leak 2004 Lancer ES
  212. Window Regulator/Cable
  213. 2002 Lancer OZ Rally Overheating problem!
  214. Lancer spedometer problems
  215. Gas pedal sticking
  216. 2006 oz rally clutch or transmission, help
  217. Totaled body engine okay wont start
  218. What throttle body would fit an 06 lancer es?
  219. Why wont me lancer start
  220. 4G93 cam sensor, Cylinder misfire issues
  221. Turn signals not working
  222. Weird power issues...
  223. lancer ex original headlight adjustement
  224. Adjusting 2004 lancer oz rally headlights
  225. Lancer ES Won't turn on. Need help!! Please :)
  226. 7.5 fuse keeps blowing after hitting a rock on FWY
  227. vibrating sound when driving?
  228. Gasoline Smell
  229. P0420 Code on OZ Rally
  230. 2004 OZ-Rally alternator problem
  231. P0134, P0138pd, and P0141 Questions...
  232. 2002 lancer running rough
  233. Idle drops when using HVAC fan
  234. 02 Lancer Fan spinning fast/Temp Gauge going up
  235. 2006 ES Flywheel HELP
  236. Lancer Indicator Light Issues
  237. New Battery, New Problems?
  238. 02 lancer ES check engine light NOT coming on
  239. 2002 lancer cedia glx issues 4G18 1.6l Aisan carburetd!!
  240. complete lack of power after timing belt shredded
  241. Throttle Body??
  242. License plate
  243. Fuse Box Needed
  244. Code P0171 Please Help!!!!
  245. Auto Gear Change Cable
  246. a/c compressor/harmonic balancer problems
  247. Power Steering Idle/Tensioner swap???
  248. bad bearing, but which one??
  249. P0137 and P0421
  250. Engine Noise After timing belt, normal?? Please help
