PDA
View Full Version : Motor Sports
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
  1. Road Course Alignement Specs?
  2. Rally info?
  3. South Texas roll call
  4. Midwest Open Track Events (Road America/Autobahn/Blackhawk)
  5. Review: Corbeau Sportline RRB Seats in CT9A EVO 8 VIII
  6. 2019 STU Discussion
  7. CAE Shifter
  8. 2020 Gridlife Season - Changes / Discussion
  9. Breaking in new parts
  10. TrackTime Track day Laguna Seca, Dec. 22, 2018
  11. 2019 - SCCA Time Trials
  12. EvoX control arms (+20mm from 8/9), Are longer Axles also needed?
  13. Transfer Case with LSD in it but ACD not working
  14. 2019 ASP Thread - Is anybody out there?
  15. Evo Track Tips - Autobahn Country Club
  16. When upgrading E8/9 to X Brembo front, - upgrade rear too?
  17. Want a full cage. Any tips?
  18. Whiteline Rear Sway Bar Sizing Chart
  19. Sup w/them 2026 Spring Projects?
  20. Idaho Motor sports Scene ?
  21. 2019 D-Street discussions
  22. Track day ECU tuning??
  23. 2019 NASA ST/TT discussion
  24. Hyperco / Ohlins spring rates?
  25. Brembo BBK 4 piston or 6 piston
  26. 1-Way vs 1.5-Way Rear Differentials
  27. Evo 8/9 vs Evo X trailing arm. Are they the same?
  28. Transfer case problems, or just my new NT01s?
  29. Exh mani temps
  30. Cooling Setups for Track Use
  31. 2018 / The Speed Ring @ M1 Concourse
  32. To 315.... or not to 315?????? SP edition
  33. Going into ABS?
  34. STIFFNESS matters! -We back-to-back Carbon Revolution's CF wheels vs AL wheels
  35. New Evo 8/9 custom carbon fiber trunklid
  36. WTF alignment??
  37. Best way to rent a tow vehicle & a car trailer?
  38. Racing Brake BBK?
  39. AutoX driving techniques
  40. Rear toe change with load
  41. AutoX Tire pressure tips
  42. 255 vs 245 NT01 on 9.5" wheel
  43. Broken clutch disc - the domino effect
  44. New setup. Where to start?
  45. Post your competition suspension set ups here!
  46. Alcon Mono4 343mm fit 17" Enkei PF01
  47. Which tires for a wet track day?
  48. ASP classing question
  49. 1000 HP 4 Cylinder Engine Teardown
  50. Wavetrac on Evo 9?
  51. New AP Radi-CAL confirmed for Evo 8-9!
  52. Omega Evo latest
  53. Laguna Seca Track Prep
  54. WRC Germany
  55. Competition Suspension price range
  56. Ohlin rear shock top hat versions, there seems to be at least 2.
  57. Took 1st in NASA TT1 - Electric Vacuum Pump question
  58. NASA membership referral discount?
  59. Anyone running 18x9.5+35 RPF1’s?
  60. Do you balance your rims when mount stickies?
  61. Maintenance Schedule for Track Driven Evos
  62. Simplest Track Timer/Telemetry/Data App?
  63. Spinning front, inside tire.
  64. tube frame front end/radiator support
  65. Solution for overheating brake
  66. How do you guys know where race tracks/track days are near you?
  67. MIL Spec Engine Looms
  68. Global Time Attack
  69. Rallycross is the best thing ever (with picture)
  70. F1000
  71. One Lap RS / OLOA / Boosted Films
  72. Experience with Lime Rock track 86 Db sound limit
  73. Evo 8 Auto X questions/recommendations
  74. Let’s talk stand alone - specifically AEM/Infinity
  75. Good wet track day street tire?
  76. 275 on 10.5" wheel with new rules
  77. AutoX suspension abuse
  78. Ohlins ride height
  79. Question about rear diff and wheel lift
  80. Bucket seats and 5/6 point harness
  81. King Tut's NASA TT4 / Gridlife Street Mod Evo 9 RS
  82. Replacement top mount sphericals
  83. MCS 2WNR w/Hyperco springs and Eibach helpers
  84. Evo X Big Brake kit?
  85. 4g63
  86. Car is 3 wheeling, Stiffer swaybar or up spring rates?
  87. Pedal Boxes! whos got what?!
  88. DiaQueen discontinued - now what?
  89. Anyone have a set of ohlin DFVs off their car?
  90. English Racing ACD Tune Pre-Season Sale 2018
  91. Track Days
  92. SCCA: Time Trials
  93. JessonMotorsports Mega Build Thread!!
  94. Who wants me to do a build thread?
  95. Autocross Brake Pads
  96. whos running a sequential transmisison
  97. 100 Acre Wood
  98. Evo IX MR at NJMP SCCA
  99. 2018 B-Street discussions
  100. Tyre width more is better ?
  101. Photo dump from competition this weekend just been!
  102. Toyo 888r?
  103. Evo Track Tips - Road America
  104. 2018 STU Discussion
  105. Add some of your fav kick butt sound tracks to your track vid
  106. ACD Reflashing/ Tuning. whos tried it etc?
  107. Do you have blackstone labs results for your tracked car?
  108. Gridlife Trackbattle 2018 Discussion
  109. 2018 Northwoods Shelby Club Events (Road America/Autobahn/Blackhawk Farms/Gingerman)
  110. Evo 9 ALS strategy configuration
  111. 2018 SM (Street Mod) Autocross Discussion
  112. Ohlin Bearing Replacement, Possible New Source?
  113. Rear Toe Arms who uses what
  114. Interest in legit CFD designed/proven carnards for Evo??
  115. EVO I, II, III group A @ WRC
  116. Dry Sump Thread: More offerings are available!
  117. Greek Freak evo 9 hillclimb & circuit project
  118. Are my specs requiring new block? Bore size
  119. New Brake Rotor Option From PowerBrake
  120. Grid Life HPDE+ Rules
  121. Journal Bearing to Ball Bearing to race manifold = quicker spool on larger set up?
  122. 2018 Nasa TT/ST discussion
  123. HPDE Track Mods / Costs
  124. Hyperthetical track day insurance question
  125. Has technology made it possible to race 500HP EVO Safely?
  126. Anybody on 11" rims running 315's or better w/o widebody kit?
  127. GTA Super Lap Battle Buttonwillow / RS Motors
  128. have you ever chased a second?
  129. **Official Toolbox Thread**
  130. roll racing help
  131. Track cars with upgraded fuel systems & ignition - any tips?
  132. Switching from Bridgestone RE71R to Nexen N FERA SUR4G.
  133. Need some help - EVO IX RS boost gremlin???
  134. Hard nose dive under threshold braking
  135. Lets see your "Work Space" #ShopJealousy
  136. Heat Cycles
  137. What's a good Ride Height
  138. rear brake pad retainer pin fall out??
  139. Splitter angle at front of car
  140. Harness bar
  141. Tech Tips: Bump-steer effects from ball joint and caster changes
  142. Radial Mount Calipers
  143. Non-Evo fun cars
  144. Oil Pressure drops at Road Atlanta
  145. The Evolution of F-Prepared, Re-build Log.
  146. 3-d Suspension modeling
  147. shipping a car
  148. Does anyone know what two-piece rotors these are?
  149. Flat Bottom Floors and keeping diffs cool
  150. Anyone have pair of AP racing 2pc rotors laying around?
  151. Road racing with a big turbo setup
  152. Best place to buy race scrubs
  153. Are Sabelt racing suits ok?
  154. Road/Race Prep - Fuel and Cooling
  155. What data logging system?
  156. Steering Wheel Replacement
  157. Sway bar end links..
  158. Fire repression system
  159. Track safety check: common failure points?
  160. Wavetrac vs 1-way vs 1.5 way front diff experiences?
  161. Guide Lines for Adjusting 2 way external coilovers
  162. would you do another track day on this tire?
  163. Evo 9 track car for sale
  164. Please recommend a pad spreader for Evo8
  165. Far North Racing "Autocross to Win" now a book on Amazon!
  166. 18 X 9.5 Track Wheels
  167. RaceCapture/Pro Multi-Display Demo
  168. FP Red & wider tire/wheel feedback wanted
  169. Yokohama Advan A052
  170. MRLS 90dB sound limit: will pass?
  171. Help with 3 wheeling at autocross
  172. One Lap of America 2017
  173. Gridlife South 2017
  174. always wanted to go up against an STi
  175. Federal FZ201
  176. Fan Setup
  177. Outside of tire turning blue
  178. PSA: Dont Jump Lithium Batteries!
  179. best free track app for android?
  180. Does anyone RallyCross their Evo?
  181. carving it up in the wet
  182. Manual Steering rack - anyone use them
  183. What happens at the track day if you have a F1 car
  184. Lets See Those Custom Parts v.2023
  185. Upgrading Struts, couple of questions
  186. A7's for sale
  187. Can any stock frame turbo do 600awhp @26psi or less with quick spool?
  188. Rear Seat Deletes
  189. Hoosier Wet ??
  190. Any interest in my ARC intercooler?
  191. MFactory/YCW Suspension/SWIFT Springs - Looking for sponsored driver(s)!
  192. Limit for reliable power on track?
  193. 2017 Mt Washington Hill climb
  194. Curb weight reduction
  195. Best street alignmet
  196. $2,000 - $3,000 Coilovers. Let's discuss.
  197. 2017 B-Street discussion...
  198. ice racing in Northeast
  199. What material and coating are ball joints made from?
  200. Snow Rally and Drift
  201. 2017 nasa st/tt/pt
  202. 2017 SCCA Solo ASP Discussion
  203. 2017 SM (Street Mod) Autocross Discussion
  204. 2017 STU Discussion!
  205. Northwoods Shelby Club has added a second Road America event (April 29 & 30)
  206. Aftermarket steering wheel
  207. Wide Front Fenders
  208. 2017 Northwoods Shelby Club Events (Road America/Autobahn/Blackhawk/Gingerman)
  209. spherical rear coilover top hats?
  210. Evo 10 hubs on an Evo 8/9
  211. 100 tread wear tire talk. Need some opinions from track gurus
  212. Evo 9 RS Time Attack/Time Trails car for sale
  213. Racing seats
  214. X BBS rims with r-comps & 3-way coils
  215. Billet control arms, +1 to +3 deg caster, +0 to +1in length.. Is it a boat car?
  216. Toyo R888R anyone try them?
  217. Did I do good?
  218. Ohlins DFV who's rebuilding them?
  219. Model/Year Recommendations for Rallyx Evo?
  220. Camber, Caster, KPI, Steering Angle, AND YOU!
  221. going after a 360 at the last meet
  222. Alignment Question - Suspension Gurus
  223. Carbon headlight replicas in FS section
  224. NASA 2017 ST (TT) Rules Posted
  225. Power steering whining while autocrossing?
  226. Help analyzing tire wear?
  227. Enclosed trailer for two evo's??
  228. 2016 Nulon Nationals Round 4: DRAG BATTLE - the finale
  229. 2016 Nulon Nationals Round 3: TIME ATTACK / SHOW & SHINE
  230. Aftermarket Recaro Seat Mounting
  231. Staying in the seat without a roll bar
  232. Wtac 2016
  233. 2017 wrc
  234. RR Build considerations
  235. My Evo .VS. 991 GT3 Super Cup
  236. STU #86 - 2006 Evo IX SE
  237. Strange noise from driver rear side...
  238. Would like feedback from autocross run
  239. Wheel size for racing
  240. Light Weight battery
  241. Battery trunk relocation track day question
  242. Weight reduction
  243. Knee Pads
  244. Preferred tcase fluid for track day car?
  245. getting started autox/roadrace
  246. Measuring Braking Temps
  247. Evo X OEM Thermostat Lifespan/Reliability When Tracking
  248. Team O'neil Rally Fest 2016
  249. Trans fluid when using Clutch front diff
  250. 3-d printing and composites help?
