- Stock Block FP Red (SS) Kelford 272 93oct 28psi (3port vs MBC comparison inside)
- Terry's Stock block Evo 8 RS FP Black (MHI) GSC S3 93oct
- knock on e85
- Stock Block JDL T3 6266 GSC S3 E54 Fuel - 646WHP | 139.66
- Evo 8 Stock block FP black - 402 HP 318 TQ - 29 psi - Buschur Tuned
- Reasonable numbers of a Td05 16g?!
- have stock evo and ecu can i do a e85 transfer?.
- 2.3L EVO 9 With Owen HTA 71
- Evo 8 basic Boltons tune
- i want a tune
- Some stock block/turbo results on e70 for those interested
- PT 6062 Gen 2
- Joe's Evo IX Stock block MAP EF3 93oct & E60
- Any Gen2 GTX3582 results yet?
- Atif's SLR2.2 ETS 6466 AEM Infinity Evo IX 804/626
- Data on internal vs external WG
- Evo ix whp?
- 2.0 Evo IX Mivec 6266 on oem camshaft
- 2017 Self tune vs Pro Tune thoughts
- Evo IX stock block big power 624whp | JDL T3 6266 S3 E54
- TSComp 2.0L ATP GTX3582R GSC S3 Skunk2 FiTronic E15-69
- BBK Full, SD, Stock Mani, Cosworth Cams, Stock Bottom End, etc on 93
- 03 Evo BW s364.5sxe 2.0l pump gas 93 640hp
- Evo 8 - 2.4LR GSC S3 Sheepey T3 FF 6466 E70+
- Evo IX MR - Sheepey T3 6266 GSC S2 E50 FiTronic
- Evo IX FQ340 395whp on mustang
- Evo 8 very light mods low mileage 91oct very high elevation
- Evo 8 stock block FP Green 73hta SS | S2 | basic bolt ons 92 + 300cc | 29psi
- Evo 8 Bolt ons
- Cerevo's 2.0 HTA71 GSC S2 budget build 2016
- Looking for a map for evo8 with 9 turbo
- EnglishRacing Drag 8 1195whp 7285 Gen 2 56psi
- Justin's 2.3L 623/510 FP Black Evo 8 E85
- MKC Performance Tuning by Chad
- Around how much do you think ill make?
- Sean's 858/623 SLR2.2 aluminum rod Q16 Evo IX
- Evo 8 GSR 811/658 E85 SR2.4 6466 build
- Evo 8 Built 2.3L Fathouse Topmount 6466 GSC S3 Magnus V5 E54~
- FP Black 91 octane 500+ whp pump gas
- evo 8 stock psi?
- TSComptuned Full Build - 2.0LR T4 PTE 6266 Gen2 Ported everything FiTronic 93-E72
- TSComptuned Full Build - 2.3L CBRD BBK-3B GSC R2 FiTronic Flex program E64 & 93oct
- evo mapping in uk london area needed
- Any ideas on power?
- Morgan's Evo IX Stock block JDL 6266 stock cams E54 results
- EFR 9180 Break in tune 430whp 20psi
- No power at lower RPM's - Tune review
- Brandon's Evo 8 - Stock Block XS Power 6266 GSC S2 FiTronic 93/E70
- Thinking about running 1200cc pte injectors
- Ethan's Built 2.0L Sheepey vband Topmount 6466 GSC S3 E70~ lowboost
- Estimate power ability?
- Daine's Evo 8 Built 2.0L /w ETS 6466, Ported 70mm intake mani, GSC S3, 93 & E75
- Joe's ER 2.2L Sheepey T4 TS 6466 GSC S3 Magnus v5 FiTronic 93/E85 results
- TTP Engineering - Bad
- Evo 9 EFR7163/Origin Fabrication/Full Race/Pump 93
- Tyler Evo 9 CBRE 2.0 FF T3 20G/td05h 538/446 DynoJet
- Evo 9 CBRE 2.0 FF T3 20G E85 513whp
- Knock Activity
- Stock Block - FiTronic Flex Fuel - GSC S2 billet - Oldschool ETS 61mm turbo kit
- 2.4LR evo 9 Holset HX40 with billet 67mm
- Rough Idle Occasionally Stalling
- build #2
- Modified by KC?
- Self built 2.4 LR, 6062 on pump 91
- Evo 9 bbk full 460 93oct. 500 e85
- EVO 9 Engine Blow-by
- Anindo's TSComp 2.3L GSC S2 PTE 6266 93oct Setup
- Evo IX - FP red, bolt ons, 272s, stock bottom end, 93/e85 dyno results
- EVO 8 CBRE 2.0 6466 1450's E70 37PSI
- Evo 8 2.0L FobiaFab FF 6466 E85 42psi
- Evo 8 W/20G
- 2.4 Evo builds using HX35/40 turbo!
- List of e-tuners
- TSComp 2.3L - FiTronic - FP Black Stainless SS - GSC S3 - Skunk2 Ported - 93 - E70
- Evo IX 2.4L Sheepey Top mount 6765 R2 AMS F1i E85 WG pressure vs 43psi
- Tuner in New Jersey
- Reputable tuners in the NC area
- TSComp 2.3L - CBRD BBK-3B - GSC S3 - 1200cc of alcohol
- Evo 8 Stock Block - FiTronic - FP Black SS housing - Kelford 272 - 93oct, E53, E80
- Evo IX Custom Blue Sheepey Evo - 2.0L Sheepey FF 6766 GSC S3 E88 40psi~
- 2.3 cbrd efr 7163 548/459
- MIL.SPEC 2.4L v.2 HTA Grn R2's E85 27.5 psi = 580whp
- Evo IX FiTronic Stock Block FP Black Tomei 270 E81
- 2.3 with FP black take 3.....bbk-c d done...fp red done
- Boosted Tuning Dyno Tune - EVO 9, SD, Xona 95-67 on 91oct + low boost E85
- 2winscrolls 2.0LR S366 evo 8
- 600whp on FP red?
- Bolt on e85 tune?
- Evo IX FiTronic TSComp Built 2.0L FP Zero GSC S3 Cams E85
- Tobz Dyno Evo 9 FP Black
- Opinions of PTE 5858 set up
- Mustang Dyno results. 6262 setup, stock bottom end, pump gas
- Where to dyno tune Near delaware
- 624whp 628ftlbs FPGreen HTZ Journal bearing evo 9 TPGtuning mustang dyno.
- 7163 Evo 6 2.3 ltr
- Tuning for Pops and Bangs on Overrun and Engine Braking
- Standard 2.4L,BB5858 E85 35PSI 652/558 AWHPTUNING STREET TUNED
- Why knock at the top of 3rd with only 8 degrees of timing?
- Mitsubishi Evo World Record 1291 AWHP
- Big power difference between gears?
- Where is this knock coming from???
- Built 2.0L Sheepey T3 FF 6466 Kelford 272 E85 41psi
- Built 2.0L Oldschool BR Cast 3065R Kelford 272 93 & E85
- Built 2.0L - Stock turbo to HTA3582R
- Stock block Sheepey T4 6262 GSC S2 93oct
- FP Black 574 whp 2.3 self tuned
- Stock Block vs Built Comparison - 2.0L STM FF 6266 GSC S3 E85 32psi
- Stock block FullRace T4 GT4088R Stock Cams 93oct (Odd unique setup)
- *Help* Evo not making power on dyno
- Evo 8, FP Red, e85 and 93 oct dyno results
- AEM analog E85 Gauge wiring to 9 ECU to log?
- Driven Fab Evo 9 7163 EFR 593/583 Dynojet
- Wideband help
- Jason's 2.3L GSC S2 FP Black
- TSComp 2.0L ETS T3 6466 Kelford 272 E85
- 2015 Evo X Results (Blevins)
- Evo IX FiTRONIC Built 2.0L FP Black MHI GSC S2 E13-E79
- 2.4LR ETS T3 6266 turbo kit GSC S2 93oct
- Kartectuning goes 8s!!
- EVO IX Re-tune
- Built 2.0L Stock turbo Magnus v3 E85 30psi
- Evo 8 FP 71hta 91/E85 results
- What power can I expect?
- 2.3L FP Green 73hta MHI S2 93oct
- Johnny TSI new LR2.4 build - 734whp/552 tq
- Mike's 608whp E85 LR2.3 FP red (twin scroll)
- Atif's 608whp 6262 S1 Street Evo
- FP Red DBB results
- Boosted Tuning Dyno Tune - EVO 9, stock turbo, GSC S2s & 91oct
- Fp red went out so tried something new
- Built 2.0L FP HTA3582R GSC S2 AMS F1i FiTRONIC E72
- 520/481 2.3 red dbb road race car c16 dynojet
- Any tuning shops in OH, Western PA, WV or Eastern KY?
- Need help...Broken ring lands...need shop advice
- Strange fuel issue - looking for ideas
- Hta71 vs HTA Green Downgraded :) - VD
- super 99 or 6870 or newest xona
- Tune
- BOOSTED TUNING Custom Remote Tune On a Dyno - Evo 8, 2.3, 6466
- My evo tune
- Tuning Trip Announcement!
- 600whp on a single 450 with e85
- 2.4L Evo 9 custom Precision 6666 E85
- Evo 8 SSL - Built 2.0L Stock IX turbo GSC S1 93 & E85
- Need Vet Member Help About Old Tuner
- Evo IX stock block - FP Black SS housing GSC S2 Skunk2 intake mani E85 & 91oct
- Evo 8 stock block Fp Htz Green SS housing
- Evo IX Stock block - FP Green 73HTA SS housing GSC S2 cams 91oct vs E50
- My Evo
- 2007 Evo IX GSR 6spd Tomei 7960 Cosworth M2 100RON 25-27psi
- TSComptuned 2.2 Super LR - ETS T3 6466 S3 cams AMS VSR 93oct 28-29psi
- First Time Dyno Tuning What Should I Bring?
- How does this Virtual Dyno graph look?
- 2.4 fp black ss housing 540/495
- Josh's 712whp LR2.4 6466 "The Grey Plague"
- Juan's 642whp 6266 Evo 8 2.0L
- Powertec 2.3L 6466 E85 VD numbers
- Real Street Evo 9 2.2 FP RED BB 650whp MHI and SS housing results
- stock motor GT3076 / 93octane - take a look
- 2.3L fp black ss housing 680/521 VD
- PTE 6062 - 2.0L - 478whp/391tq @25psi- 93 octane
- Daniel's 519whp FP Red on E85
- Tony's 92 octane 400whp Stock turbo VIII
- Stock Block PTE 5858 MAP T3 turbo kit GSC S1 93/E85
- Any real gains?
- Evo 8 400+hp VD
- Fully built evo 8 MAP EF3 Dyno results
- Stock turbo Evo 9 Dyno your thoughts
- Opinion on Kelford 272/276 12.0/12.5mm Lift
- Evo 8 Stock Block FP Red 91 oct
- Zeitronix boost monitoring
- Fp red bolt ons e85
- Evo 9 turbo bolt ons e85
- LA tune?
- Mitchell V's 848whp 6466 2.0 E85 Highway monster
- evo ix 6266 gen2 849whp
- Evo 8 * 9 Turbo/S3/E85/Bolt ons/Force Fed*
- Built 2.0L FullRace 3582R TS S2 93oct 29psi
- BOOSTED TUNING Custom Tune Evo 9 on E85
- Real Street Evo 9 FP RED BB MHI Stock Engine/Cams 615/477 Dynojet
- HKS EVC 6 IR 2.4 settings
- hx40 evo9 boostin performance tuned
- FP HTZ86 looks very promising..
- need HELP!!!!! 2150 fic
- KT Motoring or Road Race Engineering for a Tune!?!?!
- Professional Awesome Time Attack Evo 2.2L GTX3582R 162mm Rods 4Pistons Racing Head
- 600whp stock block 93 pump
- BOOSTED TUNING Custom Dyno Tune - Curt Brown Build, STM 6466 & GSC S3s on 91oct & 116
- 5leeper's New Evo - TSComp 2.0L FP HTA3586R Wilson V2 GSC S3 - E85
- Neal's Built 2.0L FP Zero GSC S2 MAP Rev3 93oct + meth results
- Crown tuned LR2.4 Evo 9 HTA3586
- Egor's Evo IX 2.4L Sheepey Top mount 6765 T4 GSC R2 E85 35psi results
- Mirage GSX with EVO 4 egnine JDM 472whp (Holset hx35)
- another evo 9 turbo e85 400/400 dyno
- Stock block Evo 8 MR PTE 6062 DBB testing 570 whp 420 torque
- Stock Block - STM Forward Facing 6266 / GSC S3 / E85 / 560-670whp
- Kelvin's 566whp LR2.4 GTW3476 92 Octane
- Brett's Evo 8 2.3L 6266 Gen2 FiTronic powered E15-75
- Need Forum Help w/Power Dip on Dyno Graph, Evo IX, BBK Full + Bolt Ons
- AG Auto Built 2.0 FP Black jb SS S3 cams E85 40psi
- Evo IX 2.0 Mamba Turbo GTX3584R + water/meth. injection
- Boostin Performance built FP Zephyr 06 MR
- 1144whp Evo 8 - English Racing
- Evo 8 - Basic Bolt-Ons *Boostin Performance*
- Virtual Dyno help
- Recognizing a Race-Friendly Dyno Graph
- FP Green 73 HTA Stock Block S3 Cams
- Sonny's 2.3L 633whp FP Red Single Scroll C16
- FP Green HTA 73 with built 2.3 block 93 octane
- Colin's @ turn14 Evo IX MR Stock turbo GSC R2 cams 93oct results
- Jeff's Evo IX Stock block ATP GTX3582R (Stock Frame) GSC S2 Map Rev3 91oct & E85
- My stock block evo 8 mr ss fp black
- Ryan's Built 2.0L FP Green 73HTA (Xona-Rotor/Stainless housing) S2 cams E85 36psi
- Map 2.0L FP6466HTZ 784whp/591wtq @42psi
- JDM EVO 7 2.4 Block with Turbolabs 35r 93oct
- Fred's Evo 8 Stock Block FP Black GSC S3 CBRE ported everything e85 results at 36psi
- ReaperX 396/355 Mustang Dyno, 93oct, Stock Block, GSC S2, FP 71hta Evo8
- Evo 8 Full Race BW 7670 EWG's
- Full built 2.0 hx40 build
- 350+ whp
- Evo 8 /w Buschur 2.0L Stock turbo BC272 Magnus v3 E85 31psi
- awhit17's DBW Tuned, Pump 93, 400whp, stock block, 71HTA IX MR
- FP zephyr 702hp/532TQ 10.02@144
- Rich's 2.3L Stainless housing FP Black / GSC R2 cams / E85 28psi
- FP Green w/ SS housing dyno?
- Evolution Dynamics Evo IX - stock turbo, 93 oct
- Evo IX MR SE - BR 2.3 / BR FS635 turbokit / Cosworth M2 / AEM Series 2 / 33-41psi E85
- Shootout Tune
- Buschur 2.3rpm 6466 AMS intake manifold e85
- Dyno tuning in Missouri
- Went to AMS today, stock motor FP Green, 93, 410hp
- Built 2.3L FP Red S2 cams 104oct Sunoco 35psi
- Haltech Elite 2500 EVO 8
- Long Trip to 400
- Evo9 440whp/335wtq - Tomei ARMS M7960 + Speed Density + Built Engine - Pump Gas
- tuning with restrictor
- 2.3L stroker power expectations?
- JP's 800hp Evo 8 RS 6466 ETS FF E85 41psi
- The "Junk Evo" - Built 2.0L / Toxicfab FF 6766 / AMS F1i intake mani / E85 - 43psi
- Help to make 400HP
- Evo IX - Built 2.3L / FP Black DBB (MHI) / GSC S3 / CBRE Ported everything - 707/652
- MAP T4 PT6466 Review and dyno - Lots of Pictures
- 500whp 2.4 93 octane
- Pte 6062
- Evo 8, GSC S2, MHI FP Red, E85
- Evo 4 - MAP 2.1L (4g64) / MAP 6466 Turbo kit / GSC S3 / Skunk2 IM / 93oct
- Evo 8 - Built 2.0L / Ported 20G turbo / Kelford 272? / E70
- Evo IX MR - Stock long block / FP Black / Stock cams / E85 + EF3 vs Black comparison
- Evo IX - 2.1L JMF turbo kit /w 6466 / GSC S3 / JFM intake mani / 93 + E85
- The search for 9's continues...Stay Tuned Evo hits the drag strip
