PDA
View Full Version : Evo Dyno Tuning / Results
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14
  1. 3" vs 3.5" exhaust debate
  2. 2006 Evo IX RS - G35-1050/S3's/Built 2.0L - 800hp+
  3. Buschur 2.4LR, FP Red E85 results
  4. G25-700/G30-725-Dyno
  5. Dyno Tuning Near Southern utah
  6. Evo 8 - Overboosting
  7. Car removed tune
  8. Garrett G30-900 turbo. 665whp on E85
  9. dyno tuning HELP
  10. Exo IX MR Stock Block Blouch 2.0 XTR BB
  11. AGT 55mm JB dyno weird spike and dip
  12. ecuflash
  13. FP Black 635hp/554tq!!
  14. Tuner's in NJ
  15. Evo 8 boost / vacuum problems
  16. What power to expect? 7864s .82ar tial
  17. Turbo 6870
  18. Has anyone had this experience?
  19. 2.4LR w/6870
  20. ISO Good tuner
  21. Evo 9 Stock Turbo on 93
  22. Intermittent Random Knock
  23. RMC Evo8: 2.2LR G30-770
  24. Evo 8: 416whp/355wtq
  25. Daily Driven 2005 Evo VIII 285WHP/306TQ
  26. Feedback - Loggin Data Evo 8 MR 2004
  27. RMC Evo8 FP Green and GSC R1's
  28. Evo 8.9 RMC 2.2 FP red
  29. Timing retarding to -10 only at WOT with unusually high load
  30. Evo 9 Map spec 2.0 fpzero (5280)
  31. AMS 2.3 build e85
  32. Speed Density Tuning and Elevation
  33. Evo4 - Tactrix 2.0 Datalog
  34. Ecuflash on Windows 11 working
  35. 10:1 comp EVO 8 with Garett GTW 3884 6265r gen 2
  36. evo 4
  37. Evo Tuner in Northern VA
  38. Thoughts on head work
  39. aem infinity vs link G4+
  40. Curt brown 2.o ss fp red update
  41. ATP GTX3071R Gen 2 2.3L 450whp @26psi 93 pump gas
  42. FP (Forced Performance) Evo IX 71HTA CHRA turbo
  43. Help Addressing possible lean out issue
  44. 6062 Evo makes 573 whp on pump gas at 30 psi
  45. EVO 4 450Nm 390HP
  46. Unlumpy poncam suggestions
  47. Tune for O2 dump?
  48. Stm FF manifold A/c compressor clearance?
  49. Deatschwerks 1500cc
  50. OBD II and Sparco Evo 8Apexi Engine Management System
  51. Evo 9 stock block FP Black
  52. need help tuning
  53. Evo Cam idle tuning.
  54. 8.2:1 on a 2.0 LR ?
  55. any suggestions
  56. HELP! Ivey tuning experience? and 4130 performance?
  57. Knock or not?
  58. 633whp Low Setting 😁
  59. Evo 8 MR GSC S3 Cams Stock Turbo 425whp/425wtq
  60. 2 litre forged build
  61. No cold start high idle
  62. AUS Injectors
  63. Evo 8 Stock block FP Red 93 octane VD results
  64. crank no start
  65. Evo 6 E85 tune
  66. How much power would be “safe”/ build ideas
  67. PLEASE HELP tuning problem with 2.3 Evo 9
  68. Evo 8 precision 6062 gen2
  69. looking for tuner stock ecu tephra v7 SD
  70. Evo 8 lean idle, and lean cruise
  71. 4G64 2.4 Long Rod 91+Meth DD
  72. Curt Brown 2.0 SS FP Red Flex Fuel
  73. Who on here has motec
  74. HTA71 questions
  75. Tuning
  76. CURT BROWN 2.15L S362 vs S366 Results - 93 Pump
  77. Large vs Small Runner Manifold Dyno Test
  78. How much WHP?
  79. need pros opinion on my tune?
  80. in desperate need of tune
  81. HELP! Looking for a shop to work on my evo 8
  82. 2020 Buschur Racing Build / Progress Thread
  83. Evo can’t make more than 320whp
  84. 805 whp evo ix 2.3l efr8474
  85. Stm intercooler + pipes
  86. Looking for hta71 results mustang dyno
  87. 870hp/670tq valve float?
  88. HELP !Something wrong with the dyno.
  89. 2.1 fully built with gt3582r turbo
  90. Efr7670 2.4l 9rs
  91. Inputs for achieving 400WHP on Evo IX 98 RON (93 OCT) (Dyno Chart)
  92. E85 with my setup?
  93. 4g63T evo 9 tuning in or around Georgia
  94. Xona Rotor 78-65 Fueltech FT550 98 oct ron 12%ethanol
  95. Evo 8 FP 71HTA, Built 2.0 506HP 466TQ
  96. looking into 2.2 Long Rod build
  97. 2.3L Stroker GSC s3 Cams SD Issues [HELP!]
  98. 440hp/410trq // GSC-S1 cams - EVO 9 turbo - ASM tuned
  99. Evo 7, Stock Block, Evo 9 turbo, HKS 264/264
  100. The little BBK full
  101. 550whp GTX3071R Gen 2 2.0L build
  102. Anyone have pump gas results for super 99 or 6870
  103. 2005 Evo 8 MR, stock turbo, 272 Kelfords, e85
  104. Logging issues
  105. what extra mods will benefit the most for my build
  106. Freshly Built FP RED EVO Not Making Power
  107. GEN I GTX3582r vs S362 SX-E / Curt Brown 2.15L / Pump Gas
  108. Curt Brown 2.15L / S362 SX-E (68mm) / EVO IX / Pump Gas
  109. look for a base map for my evo 8
  110. EVO IX - Stock engine with S362 SXE / WSRD
  111. Getting a tune soon, any guesses how much hp it'll make
  112. Evo V Dyno
  113. Evo IX tunes by English racing on methanol by tuned by ER
  114. Morrison Fabrications Evo 8/9 Stock Replacement Manifold Back-to-Back Dyno Testing
  115. Buschur built 2.0LR with 6266 Gen 2
  116. Help with expected power results
  117. What type of power loss will a leaky throttle cause
  118. Curt Brown 2.15L / GTX3582r GenI / EVO IX / Pump Gas
  119. G42, 6875 pte, 9280 efr
  120. Evo 8: MHI HTZ Red, S1 Cams, E85
  121. First dyno tune. Evo 8 w/ 9 turbo by Evolution Dynamics
  122. Evo 4 with 9 turbo- max stock bottom end power?
  123. Evo 9 on a 2.0L with FP Black
  124. O2 voltage and fuel trims issue
  125. Evo 8 possible power levels
  126. Drunkmann Tuning: Evo 8 on 92oct and 9 turbo in Hawaii
  127. Will I need a re-tune ?
  128. No tuners around - ECU flash?
  129. Evo 9 RS Stock turbo, stock cams, E-85 at RRE
  130. 2013 EVO X GTX3576r
  131. 73 Hta Green + Built 2.0/S2's/CB head
  132. E85 evo 9 turbo w/ bolt-ons 432hp 406tq!
  133. Evo IX MR: HTA71/S1/air filter/2.75" O2/LICP
  134. AGSpec built 2.0
  135. Power levels so far/shed built.
  136. Evo8 2.2sr ETS 6466
  137. Basic Bolt-on 8 results
  138. Tscomptuned
  139. 2.3 gtx3071r 93 oct + meth thoughts and opinions wanted
  140. 6766 dyno results
  141. 320whp with bolts on?
  142. Stock turbo TSCOMPTUNED Evo IX MR results
  143. 05 evo 8 stock turbo gsc s2 cams results
  144. FP Red SS Housing Results, might want to go Green...
  145. Tuners in so cal area
  146. Bought a used shortblock - let’s see what it’ll do...
  147. Virginia Beach tuners
  148. Virtual dyno download link
  149. High Load Figures, 340!
  150. Tuners in West Fl
  151. Full bolt on e85 evo 8
  152. ATP GEN 2 GTX3582R result thread
  153. Evo 8 boost breaking up
  154. Evo turbo testing and results
  155. Please help a 4yr old understand the IX e85 fuel system dilemma
  156. how much hp will i gain on my setup if i add water meth
  157. FP red ss housing 93octane/Sunoco 104
  158. UMS Tuning 1195whp/848wtq 1/2 mile Evo VIII
  159. Evo 3.5 (Mirage) Dyno, making Jam on the heartbreaker!
  160. 2.3L FP Black Sunoco 104octane
  161. Anyone running an EFR 7163 on stock block?
  162. Dyno tune tomorrow
  163. Questions on tuning GM 3Port.
  164. EVO 8 FP RED Flex Fuel E70
  165. Tribotex: any results from using this on their Evo?
  166. tunning technologies tunning experience?
  167. Evo9 Stock turbo 92octane
  168. Evo9 Stock Turbo numbers , i think it's fast ;)
  169. Lots on Knock, Virtual Dyno and Logs Inside. HTA Green, Help
  170. 20g/10.5 results!
  171. Just got dyno tuned results
  172. Dual maps?
  173. Help! Error CSV Log Data / Live Virtual Dyno
  174. 2.4LR Evo 9 93oct Virtual Dyno Results
  175. fully bolted 8 with 9 turbo
  176. Big turbo setup-pump gas.
  177. FP 71HTA / S2's / E85 / 459 & 402 @ 24PSI / RRE "Sam" Tuned
  178. Evo 8 tuner near Boise Idaho?
  179. LA Tunner p0300
  180. Turbolabs 25G FP Black/EF4 replica on 2.3 stroker with R2 34 psi log inside
  181. Stock block ef4 generating super low numbers
  182. Silverflyer Evo 9 FP green 73HTZ MHI S2 cams results
  183. '06 Evo IX MR, Full bolt ons, 91oct
  184. Evo 9GT JDM Owen 68hta Stock Block
  185. wga spring size for power goals?
  186. How much more power can i make?
  187. help timing 2.4 4g64
  188. Stock Block Borg Warner S363sxe on C16 - mustang dyno results *video*
  189. Freak stock block?
  190. 2.4 set up and hp numbers
  191. Revhappy's FP HTA71 GSC S2 Cams 93 and E85
  192. Looking for a tuner
  193. Evo IX MR Dyno questions.
  194. Built EVO 8 - ECT raising when WOT
  195. Evo 9 Built 2.0L Blouch Dominator 1.0XTR GSC S2 E85
  196. Evo 8 Pump gas BW 363 SX-E Results
  197. Evo IX MR BR 2.3L PTE 6262 Kelford 272 E70 24psi
  198. Stock block Evo IX FP Black (Oldschool twinscroll MHI) Cosworth 272 E85 30psi
  199. Evo 8 - Stock Block - BW SX200 - GSC S3 - E70
  200. Stock Motor, ETS V Band 6466, Speed Density, 93 / e85
  201. Evo IX stock turbo S3 cams bolt ons 93 oct
  202. 2.0 6466 evo 9
  203. Neal's Built 2.0L PTE 6766 ETS T4 FF S2 Map Rev3 FiTronic E74
  204. Ryan's Evo 8 Built 2.0L 6266 Kelford 280 E67 FiTronic Flex Fuel
  205. Evo 6 Tommi Makinen edition tuning
  206. Xona 78/64?
  207. Evo 8 - Built 2.0L GTX3584RS S3 93 & E85
  208. Id1300x scaling latency
  209. Evo IX - Built 2.0L Stock Turbo GSC S2 - FiTronic Flex Program 93 & E68
  210. Ets intercooler tune
  211. Stock block evo 8 FP54 pump gas
  212. quick spooling turbo to make over 500whp
  213. fully built 2.4 with fp green on pump gas
  214. BR 2.4L FP Black JB/MHI Map Rev2 E70 27psi progressive to 34psi
  215. Evo 8 Built 2.0L Sheepey Topmount 6466 GSC S3 E85 39-40psi
  216. Stock Block HKS 7460GTII 91oct 23-24psi
  217. GSC S2 cams,stock turbo+ e85 5150 racing tune
  218. 2.1LR Garrett 3794R GSC S3 Magnus V5 93 & E70
  219. Mixing E98 with C16 ?
  220. Evo 8 TSComptuned 2.3L Billet Sheepey 6466 Top mount GSC S3 - FiTronic
  221. Drew's 2.4LR Sheepey FF T3 6466 GSC S3 Magnus V5 E85 results
  222. Tuners in Orlando/Kissimmee FL
  223. How much HP?
  224. Lamar's lightly modded Evo 8 - Stock turbo S2 Stock injectors 93oct
  225. Fuel efficiency issue
  226. Evo 8 Borg S363 SX-E Stock block 93oct. 490/394
  227. Evo IX Stock Block FP Zero SS Cosworth M3 E85 29psi
  228. gsc s3
  229. Super 94 Dyno results 973whp/659wtq
  230. Stepping my IX up for 91/E85, looking for final preparation suggestions
  231. Where should I take my Evo in Orlando for Mods/maintenance/Tuning?
  232. Avi's Stock block Evo 8 FP Black SS Kelford 272 93-E78 FiTronic
  233. Evo IX Stock block, turbo - 91/e85
  234. Does anybody know a good place in Houston to do a tune
  235. Chris's Evo 8 /w Built 2.0L 71HTA S2 93 & E70
  236. Best tuning place in central NJ?
  237. Tuning results 06 Evo MR
  238. Norbert's Stock block Evo 8 MR - Sheepey vband PTE 6266 Gen2 HKS 280 104oct
  239. fp red dyno is a bit lazy ( suggestions)
  240. EVO8 stock turbo 380/382hp
  241. Stock Block FP Zero results on E85 S2 cams
  242. evo 8 Stock block JMF vband PTE 6766 600whp~ | FiTronic
  243. New TSCOMPUSA tuned evo 8!
  244. Retuned Brett's Evo 8 /w TSComptuned 2.3L PTE 6266 Gen2 ETS T3 Turbo kit FiTronic
  245. Arthurs 700hp Forward Facing GTX3582R TSComptuned 2.0L FiTronic machine
  246. Joe's English Racing 2.2L FF 6466 S3 Magnus V5 FiTronic equipped Evo
  247. EVO 7 JDM Stock Internals 480whp on Mustang
  248. Little torque monster on 93oct Evo 8 2.4L S3 Stock IX turbo
  249. Quick Question on 255 walbro
  250. Another 600whp+ stock block evo 8 6266 /w STM hot parts kit E85
