- transmission issue?(wierd sound)
- manual tranny magic save??
- 2004 Auto to manual tranny swap worth it?
- timing belt kit
- help: broken passanger motor mount
- Spongey peddal after clutch swap
- 2005 USDM Lancer Ralliart definition needed!!!
- Custom Cold Air Intake (temporary)
- An exhaust clip for anyone interested
- Headers
- Delta Cam Noise
- need help asap
- when do you add ECU management...
- Clutch pedal does not bounce back after disengagement
- 4g69 Oil Pan
- Adjusting throttle cable
- After market intake
- My Build Plans
- Fried ecu... help?
- Look what my RA did...
- Valve Guide Bronze
- Power Steering System
- 120K Service
- CherryBomb Turbo Muffler
- Are my axles toast lol (w/ vid clip)
- Whats this? another exhaust thread!
- Car loses power around 5,800rpms
- 4g69 swap
- Cometic High Compression Gasket
- clutch issue, tob?
- Oil On Spark Plugs
- Time to Mod??
- Gas sensor is off?
- timing belt replacement
- Delta camshaft noise?
- Hackish ECU Reflash REview
- were is the fuel filter?
- catback exhaust compatibility
- Passenger side fan
- rrm's p/p intake manifold
- ugh car wont start, advice please
- 4G69 oil pan
- EGR Removal ?
- CAI Filter Change
- Reflash and GT TB = Lean Code
- Clutch for turbo RA
- Which one is the Fuel Pump Relay?
- What oil is the best?
- p0183 fuel temperature sensor a circuit high input
- Clutch
- Will these clutch lines work in a 2004 RA
- Official Delta Camshaft Thread
- Those who have had tranny trouble.
- ralliart speed sensor or cluster problem
- Delta Cam
- Tranny issue
- Overheating
- Clutch/ rev noise??
- Hard time holding an Idle
- Noise from clutch problem
- Request for Dyno Sheets
- Lazukard Engine built !
- Spare parts
- 4G69 ecu flash
- Maintenance Question
- REVIEW: SDK Motorsports Ported and Polished Intake Manifold (with pics)
- 4g69 w/28,000 Miles!
- Rethinking my SRI
- Tranny gone
- will evo 8/9 bushings aluminum shifter bushings fit 05 ralliart
- trans adjustment?
- Help!! my RA suddenly accelerates when I have turned on the air conditioner!!
- Wiseco Pistons
- RRM Piggyback in Wisconsin?
- Afc
- Manual Transmission Fluid Drain Bolt
- Please Help! Ralliart won't turn over!
- Lancer Radiator
- CrAnSwIcK's 4G69 Build (rebuild)
- ? on stage 2 cam
- clutch/transmission problem..
- RA Headers
- stage what ?
- Performance Chip
- Valve Lash
- RPW Camshaft
- Hotter spark
- P2121 throttle position sensor
- For those of you who have Solid Mounts...Blox or otherwise.
- Transmission trouble!
- need help please
- Will this Catback fit my ride?
- Clutch master cylinder needed
- Piggy Back Help!?
- Itb
- Clutch Issue
- Transmission mystery
- Help with self tuning?
- Limited slip (good news)
- anyone with an HKS HI Power on a RA???
- attention! lol
- 4g69 to 4g69 swap
- Squeel and bad idle
- Request for exhaust feedback
- clutch slip of death
- P1020 Help
- Throttle Body or RRM Timing Box?
- Engine cuts off while driving!
- piggy back!
- is the ra short shifter universal?
- Problem with new clutch
- good headers?
- Thinking of replacing OBX headers..
- Rough Idle When Cold
- Tuning
- Need advice on Custom Camshaft
- OEM release bearing vs. aftermarket
- Can We Make An Evo Engine Swap To Ralliart?
- alternator problems...
- Flywheel
- RA race car
- Rough Idle.
- Two Questions on RRM Ported head
- Turbo
- conversion to manual tranny...tired of being AUTO and TURBO...
- Timing belt/UDP
- Exhaust warranty
- What is this sensor?
- upgrade my injector
- EVO VIII intake manifold on a N/A 4G69
- Blinkers\Sidemarkers
- What filter do I need?
- Last cylinder extra room
- Junkyard Ralliart
- CAI problems
- Calling all Auto Ralliarts! HELP!
- Reflash Review
- air filter ?
- exhaust...
- transaxle whine?
- indio540
- how to increase the 4g69 gear ratios?
- rev limit issue
- Weird Idle/AC, defrost issue
- manual trans issues...
- How many volts to fuel pump
- What is a good aftermarket Clutch for RA?
- P2195
- Ported IM with eclipse V6 TB question
- RA oil pan
- Trans Fluid Change
- piggy plug and play setup
- Have you seen this intake!? Please help!?
- TB Swap
- RRM PB hard numbers
- How many KMs before timing belt/water pump replace?
- Giving the OEM flywheel the one-over
- Engine Knock
- Oil light at idle
- Found this, while poking 'round
- Balancer Shaft Tight shreded belt
- piggy back ecu
- voltage after underdrive pulley install
- Paradigm Performance Ported Intake Manifold
- Ralliart Starter
- Help please SOS
- can i resurface?
- need help? 4G63T head swap for my 4g69!!!
- Car Starts without pressing clutch
- MAF died :(
- Tensioner
- can anyone HELP with flywheel?
- problem with the idle of my car
- HELP MIVEC HELP needed ASAP!
- RRM Piggyback Configuration (Map) Problem
- wiseco pistons for RA
- Walbro 255 Fuel Pump
- Ralliart Custom Intake Project
- 04' RalliART Engine trans pull
- Crankshaft Position Sensor Location
- ecu
- Intake Manifold Thermal Gasket.
- Evo Turbo set up ECU??
- Weird Oil Leak
- So I thought my timing belt broke... now I'm just confused.
- The Importance of a Cold Air Intake Filter
- Porting of Intake/TB
- Making my own thermal spacers
- For those with Transmission problems
- cold air intakes, looking for opinions
- RA Transmissionb Question
- Coming due for a T-belt, need ideas
- Thinking of doing another upgrade!
- What upgrade should I do next?
- Interchangeable Transmissions
- ecu flash product
- Aem intake cold air and shortram and bypass valve
- Transmission help =(
- 02 sensors, CEL's and headers
- Custom Exhaust Ideas?
- Mating the Evo & the RA
- 04 Radiator Fan
- Thermal Spacers
- Transmission Question
- fly wheel ? can anyone help
- Any EMS available for these cars?
- Injen CAI for A/T on it's way
- ACT clutch throw out-bearing
- Clutch fork
- 04 Ralliart Gear oil / gearbox
- Hoping to add Nitrous... Help?
- Getting Rid of Drone?
- Just to be sure... Header+Downpipe
- Problems after UDP install
- Where to purchase MAF adapter?
- Clutch Adjustment
- Water pump failure at 45K! WTF, anyone know how to replace?
- Sos help please
- Anyone use the eBay intake as a short ram?
- Throttle Body Spacer anyone?
- Randome Pieces of information
- clutch lines...are they interchangeable?
- Injen air filter replacement for RA 2005
- Seen on ebay, heads up RA auto owners
- UDP problem
- MAF adapter
- Magnaflow Question
- 06 Ralli, Axle back UR exhaust
- Help Please..Grinding Noise On Cold Start
- R4 software and vista
- Lancer RA reflash ... in a different way
- Mishimoto Evo III Radiator
- Header Set-up
- Bought a AEM SRI.
- What is this wire to?
- Cold air intake (NA Ralliart)
- what shifter bushings fit?
- Wiring harness
- So just a little problem.
- OBX Racing Header
- I need help deciding on mods
- 2004 ralliart timing belt replacement
- Noob questions
- CAI question
- Code P0300
- Superduper Hackish Reflash!
- Codes after installation of TM
- How/where do you get tuned?
- Another Hackish ECU Reflash Review
- help.. really bad problems
