View Full Version : Evo General
- Whats next??? Help! =)
- Anybody else here thinks evos are going downhill?
- Intake manifold sensor
- FB Black feed line/oil pressure/temp sender install location issues
- Strange ticking sound under hood
- High idle after oem tb install
- cold start up is too good on my evo 6
- Hesitant start issues
- Precison 1000cc Injectors help!
- Gas door doesn't open?
- Goodbye to my Evo VIII.
- Help with Battery Drain Issue.
- Idle RPM Drop, Rich AFR, then normal.
- Tune for Exhaust
- Spark plug cover fits COP
- Part number help
- cams or turbo?
- Any tricks to valve cover removal?
- Need some First hand/Good information for Evo5 Swap.
- so after clutch install... :(
- Rear wiper stopped working, sprayer still works.
- Knock sensor
- Changed plugs, still having issues
- Rear window completely cracked, any ideas?
- hydraulic tob info needed!
- Is this headlight fixable?
- Wheel bearing or drivetrain?
- Happens but WOW!!!
- Anyone knows what goes here or what it's for
- My idle after aggressive rebuild (video)
- AEM wideband serial ouput
- VRSF FMIC Who has one?
- Real fix for p0011?
- Excited to ditch my ti-straight pipe exhaust for a ... Hks sport!
- Please Help!!! Still smoking evo...
- 2003 Evo VIII Spark Plugs
- Evo 8 with 9 hot side
- Are gauges essential or ridiculous?
- where can i find headlights that are not $1000?!
- Electronic Boost Controller Question
- Studs on evo 9 stock cat
- Check engine light on, boost to 15 lbs only, O2 sensor?
- An Evo that got dirty
- Aem wideband log delete
- So it's bloody cold out in NJ AND.......
- stupid snow question.
- OEM VIII BOV Acting Up?
- which evo4 to pick?
- OEM Rods and pistons,CroMo?
- How Many `03 EVO VIII`s with less than 100K miles out there?
- Instrument Cluster Lighting Issue
- steering response doesn't feel as tight as before the accident.
- Evo VIII cooling issue
- AEM short ram intake hole
- what is this noise?? *VIDEO*
- how old were you when you purchased your first evo?
- E85 Fuel system setup?
- manufacture date?
- AEM wideband failsafe
- Evo 8 Straight piping quick video - 9.5 compression 71hta/84mm
- P0340 & P0335 need help
- Help! Immobiliser Evo VIII ??
- gruppe s gauge pod
- clutch clip issues?
- 60mm centre gauge holder for rhd evo
- Car won't crank at all.
- HID Ballast
- Turbo inlet boot problems
- Cross Bars for evo8
- STM front crash bar
- idle issues
- Evo pillar pods
- Car wont boost more than 12 psi
- Service engine light(bad afr)
- are the USDM and JDM headlight parts interchangeable?
- 1st Gear WOT issue !
- Mitsubishi Evolution 8 Rebuild
- Evo VIII MR Dodgy Compression Test Results
- Infamous dipstick popping out with oil...
- not sure where this connector goes
- WTB: EVO VIII HVAC control unit
- Perrin dp rattle
- Quaife Center differential clarification
- evo 9 hood help
- Evo V Parts Cross over
- Vertically Installed RWD 4G63 Drift Evo - Kumakubo Team Orange
- Oil Filter Screw Stripped?(kind of urgent)
- Where to find throttle body UICP coupler?
- Help
- Info on Forced Fed Performance?
- Double post BC of time crunch......apologizes
- Evo 9 Rear JDM bumper extensions
- rusted bolts & nuts.
- Bad boost gauge?
- Help with p0300 code!!!!!
- Headstud socket size
- Criticize my new mods please!
- Need a picture of the EGR solenoid location
- Greddy Comp Ti-C + Invidia o2 Housing... What do you guys think?
- Pros and Cons? Thinking about Trading EVO VIII for EVO X MR
- Leaky coilover w/pics
- Mirage 4 door frame same as Evo 2 ?
- What todo? (06 Evo MR)
- Oil block adapter
- Hid cable going from the lower beam to higher beam.
- Need Advice on Changing Light Bulb
- rack spines?
- Color painted Coil on plug kit plate?!?!
- Where to buy Evo IX OEM interior parts
- Cold weather car smoking even after warm
- Evo IX Center Differential options
- Tranny mount studs
- Evolution IX Owners: NGK ILFR7H Spark Plugs...
- Engine stands don't fit.
- Brembo Hi Temp Brake Caliper Decal Stickers
- Fog Lights wont turn on
- Will 08-012' Lancer steering rack parts fit on Evo VIII?
- Engine oil drain when removing valve cover?
- 05 evo mr idle issues boost dropped blow by?
- evo 8/9 ecu mounting location pic?
- Special plug gap when running a COP?
- coolant leak, but where??
- Impending motor issues?
- bolt sizes
- Advice: Injector Cleaner
- whats my evo worth broke
- Problem when WOT
- Water temp not broken
- Headlight adjuster wiring
- 600 bhp Onboard special Hillclimb Switzerland FV20
- bent key :/
- When was the last time you changed...
- Evo ix bolt list?
- Gizzmo MS-2 electronic boost controller Install?
- Evo 8 A/C Problem
- Anybody else have the AEM digital pressure gauge?
- Evo V (In Canada)
- car wash and vent insulation
- odometer light question
- evo tails not fitting correctly
- Issue fitting stock cat on buschur scca catback
- Buying used evo/signing over title
- Who doesnt know how to install a walbro 400/415 properly?
- evo 8 water leak PLEASE HELP
- Evo 8 with evo 9 turbo help
- Evo Iv windshield replacement USDM
- Evo downpipe: ACD vs NON ACD
- What's the best bumper protector for parallel parking?
- Mystery harness behind pass. side headlight
- Mesh Grill missing
- Similar?
- any evo 5 or 6 owners with rear roof diffuser?
- Evo IV map light
- A sneak peak inside the new MAPerformance facility
- Rich idle??
- so many different IACs???
- Help starting idle problems!!
- Help
- Another evo improperly towed :( w/pix
- Porting
- AEM 50psi boost gauge vs Autometer Sport Comp 45 psi
- South NJ/Philly people, anyone with a fender roller?
- Unhooked connector?
- JDM Motor maybe?
- Brake part help!!
- Where to connect pcv valve hose on a Magnus v5 intake manifold?
- Where can I get this shift light?
- Another Mystery Item
- Air Fuel Ratio during Idle?
- Broken bolt on the fuel tank(by sending unit). How do I fix it?
- front motor mount
- S2000 Coil Packs Reviews?
- Need headlight lens!!!!!
- Do any Vendors still stock the JB HTA green?
- MR Gauge wiring compatible to others?
- Instrument cluster light pulsating
- Helppp my fuel gauge is not working after double pumper install please!!
- Broken O2 sensor, could really use some help
- Evo IX Dash vs Evo IX RS Dash
- Idle Issue
- Help i'm looking for my car's ex owner
- Issues with fuel system
- Short route icp
- Weird startup issue happens at random
- Lowered compression ratio, now running rich
- Scratching noise when let of gas pedal in gear or neutral
- Help a fellow member out
- Reliability build
- Idle bouncing between 2-3k rpm
- should i...
- wanting to make 450whp
- selling your "stock" evo, huh?
- vibration after timing belt/tensioner replacement
- Windshield wipers too loud
- evolution 9
- Am i missing a cover on my tranny?lost
- Needing an established e tuner for stock ecu
- Evo IV Cross referencing Question?
- another exhaust decision thread. ti or aluminum?
- P0300 idle issue i need some help!
- bov open at idle
- Evo 9 EEVS ticking
- Engine turn-over and clicking sound when wheel turned issues!!
- Thing that happen before New years.
- Pros Tuning Road Race Evo's Track Photos!!
- Valve cover repaint and work
- cold start ups.
- What do you do?
- Cyber evo bov question
- Just picked up evo number 3 last night!
- scanner or evoscan
- Help ID'ing something
- rock salt
- Clutch pressure plate opinion
- 45-50k regular maintenance
- What do you consider laggy?
- my evo quit running today.. fml. HELP.
- Turbo Smart E-Boost-2 setup
- Any pros here that know a lot bout snap on modis
- Pros Tuning Evo 8 @ Global Time Attack PBIR 2012 !!!
- Laile underpanel
- help evo8 wont start couple codes and ugly oil leak
- where to get this downpipe??
- Not a good way to end the year
- ARC down force meter! Anyone seen this?
- What size is this nut? I lost it during my motor mount install
- Some fun in the snow!
- what to do?
- Obd ii
- COBB or Greddy evo3 Turbo back
- just installed fic 1100...need help!!!!
- No power when keye is not turned in the ignition:(
- retrofit s2k cluster into evo 9?
- What you guys think
- What tubular manifold is this?
- Suggestions on tint and alarm
- Evo 8 Front to Evo 10 Front
- Engine hesitation
- Wrong route?
- Throttle body advice?
- Mirage-Evo Conversion Questions!
- Quick exhaust question
- ticking/knocking noise
- Id1000 questions
- Evo V and VIII front O2 sensor differences
- Anyone install Sparco evo3 in an evo?
- Wrecked my baby
- BBK full personal review
- Checking if parts are stolen?
