PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. HVAC lights and rear passenger side light don't work....Please help.
  2. Cup Holder Diameter
  3. Any Evo IV's out there?
  4. Motor Shipping Dimensions
  5. Evo Lover and Terrible mechanic (BUILD PLAN)
  6. Pillar gauges help
  7. evo 8 lean issue...
  8. vehicle emission control information sticker 2006-2007 model
  9. IX bogs in 5th when in WOT from 80-110
  10. Looking for 5 speed gate selector lever
  11. Bought an Evo with the coolant lines bypassing the heater? What should I do?
  12. just another EGR thing...
  13. vehicle emission control information sticker 2006-2007
  14. Need Help Intermittent boost Only ~11 PSI
  15. Spun bearing?
  16. virtue motorsports
  17. Built not bought.
  18. Pulling the head with IM attached?
  19. Bumper question
  20. 05' EVO VIII Noise hum/moan
  21. Replaced TB shaft seals more than once?
  22. MAGNUS intake manifold?
  23. Anyone Know What this sensor is for????
  24. Redline S1 Fuel injector/system cleaner
  25. Please Help! Evo 8 Idle and Starting problem
  26. Evo 9 mesh wire!!
  27. Wait times for BBK
  28. Original Clutch lasted 106,000 miles (still working)
  29. evolution turbo change..
  30. I'd like to go back to original stereo
  31. New turbo what would go great with the new one
  32. anyone else thinking about trying the new ford focus rs when it comes out
  33. Passenger Headlight
  34. Recommended Battery for Evo w/ Security System
  35. Aftermarket Performance
  36. Evo 8 rattle noise? or lifter noise? Help!!
  37. Need some advice on supercharging my 380kw evo 6.5 :D any 1 know if its doable?
  38. red evo 5 in bellevue, wa
  39. Mines JDM ECU wont let me edit it
  40. evo 8 headlamp
  41. Your doing it wrong! How not to buy an Evo 8
  42. EVO IX Starter OE Number
  43. Need your guys help.
  44. Evo IX dies when coming to a stop
  45. coolant leak drivers side
  46. Removing engine piece by piece?
  47. Help needed from experts :P ..evo IV Boost problems
  48. Insurance through Hagerty now possible
  49. EVO 9 mr FQ 360 alloys
  50. MAP Stainless Steel O2 Eliminator Downpipe on lhd Evo 9
  51. lost my pops and bangs on overrun
  52. evo 8 resale value / buying another one
  53. Tuning for boost controller, air filter and wallbro 255
  54. evo 8 or 9
  55. Help identifying block.
  56. Twin Exhaust Anybody??
  57. Identify Headstud
  58. hids not working
  59. Doing valvesprings... dropped a valve...
  60. Boost solenoid problem?
  61. Cusco Oil Catch Can query
  62. pushing power
  63. Evo 6 intake
  64. 2003 Evo 8 build
  65. ACD question!!
  66. Evo V rough idle when warmed.
  67. I'm Back! Here is my 2004 EVO 8 Build
  68. Kelford 272 to GSC S3
  69. Better Call Saul
  70. safety related recall - headlight switch
  71. 'Filthy Evo' in Grassroots Motorsports Magazine
  72. powder coating hks
  73. Evo specialist in Michigan
  74. Drain and Fill plugs for EVO 8 MR
  75. Recently installed cutout problems
  76. Trying to get another evo
  77. Evo Owners of Wisconsin!
  78. evo 8 shifter assembly
  79. mechanic by memphis
  80. Help find Evoclub/autocross meetings in Miami greater area
  81. Rear door handle removal!?
  82. Throttle Body Shaft seals
  83. 2002 - Only Battery light on - Battery & Alternator checks good
  84. need some info
  85. AN fitting question, need help.
  86. my first track session with my findings.....plus a video
  87. Help Needed Please!!
  88. Evo 8 Build!
  89. Interior Upgrades
  90. Neon SRT 4 and Evo 8 swap injectors??
  91. starting issue any help
  92. Catch Can question.
  93. My evo looks like hell, best way to refresh
  94. new unusual noise under my car just happened today
  95. Evo 8 sometimes tried to stall when stop
  96. AMS F1 intake manifold with ETS uicp, will it fit??
  97. Replacement Cylinder Bracket (The Squeal)
  98. Car starts then dies, then crank no start
  99. Spark plug fused and blew out and threw cover
  100. Alky kit users, please chime in...
  101. Evo died while idling, won't start back up!
  102. why does my Evo smell different from any other car?
  103. VIII ECU in V - high idle issue
  104. SRS Error Code
  105. Need advice on evo purchase
  106. Noob with evo 4 😝
  107. Getting into an Evo
  108. New IAC - High Idle
  109. Evo IX; The famous serpentine area noise question, help!
  110. Looking for 52mm Gruppe-S gauge pod
  111. Good news and need help with the Bad news
  112. Advice for upgrades
  113. Ayc problem need help asap
  114. Car doesnt start every once in awhile
  115. Evo 8 Airbag recall issue
  116. Cobb Oval Cat Back Exhaust For Sale
  117. Tps
  118. What could cause this? idle rich then lean
  119. rear diff cusco????
  120. Cams or Turbo? need mod advice
  121. anyone got a good method to DYI remove stone chips?
  122. Wire diagram alternator
  123. 05 Evo Mr rebuilt title resale vaue question
  124. Radiator Fan stays on even without a key
  125. buying first evolution in Canada
  126. Which slim fan for Koyo 4-6 Rad on evo 9
  127. Any good clutch installers in the PDX area?
  128. my track day driving questions to the experianced guys
  129. Major Service (60mile/100km) questions
  130. Evo 8 ACD fluid
  131. New Gates water pump leaking
  132. Help, anyone know how to photoshop, help!
  133. Your favorite wideband (No AEM UEGO please)
  134. evo 8 ticking only when in boost???!!
  135. Evo9 MR Not Going into gear when Cold or first start up
  136. To the knowledgable and/or mechanics - Clutch replacement questions
  137. Clutch disabled, anyone know any shop near Palm Springs?
  138. P0335 and P0340 no flywheel catching?
  139. do you have tools in your car when you drive?
  140. Orbital kit
  141. Burnt Copper Brembos and valve cover with silver Evo VIII?
  142. Advice on set up
  143. Carbon fiber care specifically "matte" finish
  144. a/c for front facing turbo
  145. Z owner considering an EVO
  146. 03 evo 4g63 testdrive questions and what should I be paying
  147. to those who have made a milspec harness....
  148. Help!
  149. tps sensor helppppp
  150. Good source for parts oem and aftermarket
  151. Boost Leak Test #failing
  152. Clutch Disengaging Issue
  153. NW Burbs of Chicago.
  154. Lancer/Mirage convert to evo 8
  155. Evo 9 list of problems! -.-
  156. Evo ix low compression + boost leak (high milege)
  157. Throttle Body Cleaning
  158. SES Light on P0202
  159. Toxicfab still around?
  160. Cluster removal
  161. Evo 8 running rich
  162. My EVO IV Resurrection!
  163. Evo 7 NACA Hood vent
  164. upper tie bar or upper radiator support
  165. Lean Issue?
  166. Heat Shield Under Car? OK to remove? OK to use heat wraps?
  167. Scissor vs single column lifts?
  168. can anyone ID these cams
  169. Instrument cluster wire diagram...
  170. How many radiator fans does evo ix have?
  171. Strut Bar Bolts - Torque
  172. ELM 327 and P0500
  173. evo VIII build
  174. Evo 6.5 TME, back in the evo game
  175. IAC Screws
  176. 350whp not safe?
  177. can Americaaans understand which language this is?
  178. Gas pedal vibration when AC set to number 4 setting (high) 2006 EVO IX RS
  179. Intercooler Piping coupler replacements
  180. Oil cooler line routing?
  181. Blue Evo 9 MR?????
  182. Evo 8 spotted in another TV commercial
  183. Will Be Selling 2006 Apex Silver IX MR should I remove after market high end audio
  184. A/C and A/C light is always on
  185. Should I put my intercooler piping back together for a compression test?
  186. Anyone using the varis shift knob?
  187. Exactly when does a BR double pumper "max out"?
  188. 03 Evo 8 not starting, but I have done some diagnosis
  189. help. ..
  190. Trying to find the buyer of my PF01Evo wheels
  191. Walbro 255 HP or NON HP?
  192. Rear door dome light switch isnt working...
  193. Driveline Motoring Contact
  194. 2003 evo 8 gonna burn it down please help
  195. 02 sensor dying?
  196. My WW IX featured on RXSpeed
  197. 2005 Evo ABS F/R Sensor plugs into what...
  198. evo 8 engine shake
  199. Help ID these cams.
  200. Ok lets get together, need some pictures
  201. 08 evo with a GT3076?
  202. Another Evo Lost
  203. water leaking only driver side !!!
  204. Does anyone have NGK Power Cables on their 8 or 9?
  205. Abs brake master cylinder
  206. AFI high-z injector experience
  207. EGR delete question
  208. Pump Gas setup
  209. Outer cv axle assembly
  210. source for parts bolt and nut sizes
  211. Are OEM Parts always required?
  212. new evo owner/member
  213. Evo Upgrades For Beginner
  214. Wetsanding carbonwing
  215. what LED tail lights are this?
  216. Throttle body
  217. High idle
  218. can someone tell me what this little gold valve thing is just under the manifold
  219. Turbo backend
  220. first time at the track with the ix
  221. Clutch question
  222. can anyone tell me what the problem is?
  223. 2005 Evo breaking up in boost
  224. Just starting out an looking for some advice!
  225. Opinions on Damage
  226. evo 9 front grill mesh
  227. Need help with front lip decision evo8
  228. Why people rebuild then sell???
  229. Evo ix won't start
  230. Exhaust????
  231. Evom/facebook/locals evo 8 build!
  232. Grinding sound when turning right under power only
  233. 4g63 timing belt evo 4 vs evo 8
  234. Has anyone tried using the stock lancer rear crash beam with the evo JDM bumpers?
  235. Evolution 8/9 Production Numbers - GSR/RS/MR (2003-2006)
  236. best fluids for evo 9
  237. fumoto plugs any good?
  238. Is my transmission done?
  239. Wiseco Hd2 Ring Gap
  240. Pls help!! which mirage?
  241. Coolant leak
  242. anyone know what year evo this is
  243. bleeding clutch and air only comes through
  244. CAS Cam Angle Sensor Repeated failure within 30 days
  245. Burning smell after trans/tcase/rear dif fluid change
  246. Bad COP?
  247. Whats the highest HP stock block 4g63?
  248. Need help to ID Camshaft
  249. automatic tranny pricing
  250. Optima Redtop VS Traditional Battery?
