PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Just raced my car at the Ridge Motorsports Park! Vid inside
  2. a few timing belt hydraulic tensioner questions
  3. Fmic power gain
  4. How do you find out if a color is a 1,2 or 3 stage? help
  5. Where is the Engine coolant temperature sensor located?
  6. Washed the firewall area by mistake and the car won't start. PLEASE PLEASE HELP
  7. ETS Red Anodized IC on evo 8/9
  8. Can anyone tell me where the MAP sensor is located?
  9. got into an accident
  10. With apologies to Boostin Performance, v.Bummed
  11. question: AGP vs. ETS IC for evo 9
  12. Where can I buy OEM Cubby Hole / Storage Compartment
  13. 2008 Lancer GTS
  14. Wanted UICP for evo 8
  15. Supertech Valve spring install question.
  16. Is this wing salvagable??
  17. Very hard to cold start on E85
  18. Removing AC? How to reduce pressure?
  19. 3 starters in less than a month
  20. Exhaust concerns
  21. Help driver side window not working
  22. What do you think of this mod list?
  23. Is this an OEM or aftermarket cat?
  24. Help me for roms
  25. Trunk lid help
  26. Strange Light On Dash. What is it?
  27. gsc s2 , need advise asap!
  28. ebay intercooler
  29. Phantom knock???
  30. Listen to this please
  31. BOV Mounting - Short Route vs Stock Route
  32. broken screw head
  33. What your best 1/4 mile tims In a 6spd
  34. anybody using a P&H injector driver?
  35. Spring Mod Users
  36. Fuel pump turns off
  37. Evo IV stateside registration?
  38. Boost leak/leaking bov/wtf
  39. Ets licp fitment issue
  40. Evo stall after new coils
  41. what kills...
  42. Evo ix vs x
  43. MAF Sensor?
  44. 260kmph meter for evo 6
  45. If your cluster bulbs are old replace them for improvement
  46. Any manuals for aligning a Angle sensor and steering wheel?
  47. Boost leak testing
  48. is this can just a big leak! lol
  49. just got these in the mail and they were free!
  50. my car keeps killing iac's
  51. headlight turn signal bulb size?
  52. Problem with Speedometer and Manual Boost control
  53. Water temp guage while driving
  54. Car is breaking up on WOT - Help !
  55. 0 Vacuum at idle HELP!
  56. EVO 8 Guru Question!! Front subframe not happy!! ; [
  57. GodSpeed Project parts questions?
  58. Dimensions of MZ690116 oil filter (Need filter wrench)
  59. Best Velocity stack/airfilter combo for those that have relocated ACD
  60. Brian Crower Retainers on GSC Beehive Springs
  61. Intake Pipe
  62. GSC 272/272 affects!!
  63. Quick stupid spark plug question
  64. Bov Powder coating
  65. supporting your turbo
  66. oem evo injectors
  67. Buschur Racing "Kits"
  68. Is this from the inventor of EVOSCAN
  69. Any chance of mounting stock MR oil temp gauge in 52mm hole?
  70. Idle Problems :(
  71. Evo 7 Drivers Side Window Actuator question
  72. Part out or sell as whole question
  73. How do you store your evo for winter???
  74. short shifter review
  75. Quick question on battery terminal
  76. Utter failure at removing transmission for clutch swap.
  77. These upgrades ok for a DD?
  78. bc racing coilover spring change noob help
  79. Clunking noise in reverse
  80. My buddy's parting an '04 Lancer with a spun bearing...
  81. Evo 8/9 same isc?
  82. Borla header
  83. newbie need help with intercooler & piping fitment
  84. Best sun visor ever - HeatShield
  85. Armrest CIGARETTE LIGHTER socket not working only front socket
  86. FF DD Questions
  87. Anyone recognize this exhaust?
  88. USDM Evo 9 IX Wiring Schematic
  89. 2006 EVO IX 5 Speed Drivetrain Fluids
  90. Thoughts on Megan Racing Radiator?
  91. Is this an authentic AMS intercooler?
  92. vacuum source question
  93. Help me identify this Hi-flow cat!
  94. rattling sound under car when rpms are at 2500-2800
  95. New Holley Fuel Pump Line
  96. which gas is better?
  97. Changing timing belt
  98. Limited slip diff question
  99. extended warranty modified vehicles
  100. Turbo Upgrade
  101. Bolt of fuel tank cover broken. how to proceed
  102. High flow cat vs resonated test pipe, which is quieter?
  103. 120 MPH, Oil light flash.
  104. ACD in trunk oem pics
  105. p0340 Camshaft Position Sensor "A" circuit (B1) ?
  106. Wideband install rough idle?
  107. Evo 8 emission HELP
  108. Skid plate help?
  109. Also thinking about it :-/
  110. hate electrical...
  111. need drag help.
  112. Short shifter opinions
  113. Identify that connector!
  114. evo 8 exhaust
  115. Cracked valve cover...
  116. Installed cams today, one very minor issue?
  117. Just Curious? Thinking about selling my car
  118. Totalled my evo 8 rs, what next?
  119. Apexi s-afc2
  120. Hks recirc
  121. Hit a HUGE Milestone Today in the Evo.....Epic..
  122. Opinion on my ix
  123. Lower temp thermostat? PRO'S /CONS
  124. Belt Orientation
  125. Is this a good idea for a setup?
  126. Cluster (odometer) trouble :/ HELP PLEASE!!!!
  127. Where to buy assortment of hex head bolts ?
  128. Will my evo be totaled??!?!
  129. Evoscan on Network Computer - Needs to Access Network Drive?
  130. question: how long will it take to take whole dash out ?
  131. Stock OEM parts
  132. Is this a fair quote for carbon fiber wrap?
  133. idle issue
  134. low temp thermostat
  135. Exhaust sound control valve?
  136. 04 Evo need rear spoiler repair
  137. Where to buy cv axle BOOT only?
  138. Any Evo owners out in the Antelope Valley?
  139. Could it be the CV joint?
  140. Improve Driving Experience ?? [MERGE]
  141. whats the problem?
  142. D1 Spec boost gauge calibration.
  143. low idle after boost
  144. stiff gas pedal after fixing throttle body seals?
  145. Random crack?
  146. Evo Power steering?
  147. what should i do?
  148. Failed Emissions because is not ready
  149. bad gas? evo viii
  150. Exhaust search (I have searched :)
  151. Mi-Vec Intake Cam Gear Bolt Stripped!?
  152. gas mileage?
  153. Problems with mitsubishiparts.net
  154. Turbo timer crapped itself
  155. Tuners wanted or suggestions
  156. what gauges
  157. High 9 second car
  158. starting troubleshooting knowledge needed
  159. Evo 8 shifter is dead weight?
  160. Evo Ix A/C Always On
  161. Size of Nisei coupler that comes with LICP?
  162. TRE diff and Whiteline sway bar
  163. OEM Evo 9 Trunk Mitsubishi Emblem Size?
  164. road trip to Boostin Performance and Chicago (dyno sheet!)
  165. Snapped serpentine belt. Need diagram
  166. Alternator
  167. Team dynamics FQ400 wheels.
  168. Fantasy Street Build
  169. evo 8 shift knob removal?
  170. Evo 8 rear diff questions
  171. what is maximum exhaust temperature range ?
  172. New to the Evo family
  173. i hate driving this car!!
  174. Getting tuned tomorrow at Buschur.... Need e85 ASAP, where to buy?
  175. TRAILER HITCH on EVO 8??????????????
  176. wideband wiring
  177. spoolinup gunk?
  178. anyone with factory ww evo 9 paint?
  179. evo 8 rs srs light!!
  180. ***Evo VIII head gasket***
  181. Evo 3 lsd Evo 8us lsd
  182. How can u tell the difference between the tactrix 2.0 and the 1.3?
  183. evo ix clutch pill delete
  184. Clutch engages at the top
  185. blitz fmic
  186. Bolt sizes
  187. Tial BOV Q Vacuum at idle
  188. Grinding Noise - (Video)
  189. Wide bad O2 and air / fuel
  190. Key Blank
  191. torquing crank pulley bolt?
  192. 2 step question
  193. evo 8 infamously bad idle.
  194. leaky ACD pump line
  195. Stock IX - Low Boost
  196. E85 or Race Gas
  197. one last lc-1 question
  198. Evo IX Seatback Removal
  199. Ignition problem, car wont start
  200. getting in and out of boost
  201. Which BBK-B oil line?
  202. Help identifying what wasn't grounded in my engine bay
  203. Curious
  204. Suggestions on next step?
  205. HKS Injector Question
  206. stock 06 mr boost gauge?
  207. Cluster short?
  208. any rwd evos?
  209. Alternator and Random Thoughts - Please Help
  210. Help Identifying Random Unplugged Connector - Stock Evo IX
  211. CEL light but no CEL....
  212. ACD pump - protection from the elements
  213. boost leak at pcv valve???
  214. Initial HTA71 impressions
  215. Putting back the stock cams require tuning?
  216. Injen intake vs samco intake
  217. Evo 8 wont hold boost past 6k
  218. Looking for clutch suggestions for my EVO IX MR! Help!
  219. NASA Nationals
  220. Evo 8 breaking up at higher Rpms
  221. Clutch opinion for 350hp
  222. shaking metal sounds coming from car when driving?
  223. Paint matching
  224. Help/Advice: Old E85 and Low Battery Voltage Situation
  225. Troubleshooting question
  226. Finally got my wheels!
  227. Best stock style DV?
  228. Exedy Twin...already slipping!!
  229. Evo 9 DV guys..help me out plz
  230. Are "reusable" drop-in filters truely reusable?
  231. Random stalls while turning
  232. E-ACD and MPG Data
  233. Iac issues
  234. deep whining and crunching noise randomly while driving
  235. Tephra rom mod = slower Evo 8?
  236. Does this look legit?
  237. Increase in FP turbo pricing
  238. Autopower Roll bar question
  239. rpm hang issue?
  240. Does an older tactrix cable for dsm work on Evo 8?
  241. EvoScan vs Boost Gauge Boost Reading?
  242. Are OEM Fuel Rail Spacers Needed with...
  243. Question to those who let their cars sit for the winter. (If you have winter)
  244. Question about Car Ramps
  245. Upgrading Evo7 head. Advices wanted.
  246. Which front lip is the best for the Evo 9?
  247. greddy flange
  248. Intermittent Starting Problems - Mysterious Cause Identified and Fixed
  249. disappointed in times at the track
  250. CBRD Speedfactory - Testing at NJMP Lightning Raceway - 8.31.2012
