View Full Version : Evo General
- Help front idler pulley bolt
- Positive Camber
- 05 ssl fog light question
- Anything out there like the evoscan/carputer dash mounted?
- Hks turbo timer type one help
- Poorly rebuilt tcase
- Manifold Heat Shield Fitment on HKS Manifold
- EVO 1 Wheel bearings?
- Help with leak near thtle body
- Would you port/upgrade exh mani for HTA71?
- coates cylinder head, rotary springless valve system
- Carbon Fiber Sunroof
- Which is a overall better cam?
- 2005 Evo 8 SSL
- Stalling under Heavy Braking
- Any idea what this is useful for?
- Voltex
- Stainless Oil Cooler Lines
- Bracket location assistance needed
- Evo 8 Megan o2 problems
- Question about upper i/c piping?
- JDM rear??
- Which one is the stock JDM bov ?
- Varis Replica Evo 9 Lip
- aem fic injector scaling HELP
- ARP headstuds
- setting boost level question.
- Another Exhaust decision thread.
- Oil Filter Housing Feed Routing?
- evo 7 Oxygen sensor problem
- To buy or not to buy.. Flooded cars
- P0420 which sensor?
- What will break?
- Defrost gauge pod
- how to save fuel on evo?
- Question About IAC O-ring
- Stock Cam gears on 2.4 Built
- BBY Paint question
- Exedy Replace or not???? opinions pls
- STM tuned....my car is actually fun to drive now
- idle / start up issues
- evo 8 intake manifold and throttle body
- starter click... still
- Cluster Lights Go Off When Headlights are On
- Oil leak in rear passenger side
- BR BFIC/stock IC piping?
- Evo 7 Clunking at high RPM's
- Million-dollar drag race ~ World's Greatest Drag Race ~ Interested?
- should i upgrade my current inter cooler / piping advice needed
- Whirring sound from serpentine
- evo overheating after swapping new motor in
- Wrong tie rod evo 8?
- Fake Defi gauge
- A/C compressor oil capacity and wiring
- stripped bolt on valve cover
- Carbon Fenders
- Evo 8 dash interchangable with evo 9?
- Transfer case or trans noise? Please help!
- What did u "nickname" your EVO?
- whining.. not transfer case
- Driving Your Evo In The Winter
- Evo Randomly dies.....tried almost everything. help
- Evo 9 randomly not starting
- Evo IX has brutal acceleration off the 2-step.
- Do AEM Gauges (52mm) Fit into the STRi Gauge Pods?
- Weight reduction ?
- evo 8 power steering help?
- Some goodies on the way, HTA71, Comp Clutch
- What is this? Toyota Fijitsu ten unit behind glove box?
- 5spd VS 6spd shifter surround - interchangeable?
- Power steering leak Evo 8
- Just blew lower intercooler pipe any advice?
- Where are the watering holes in central Texas?
- How to tell your oil is aged and needs change
- Engine squeal help
- brian crower 272s or not?
- Quiet exhaust
- Boost drop. Please help
- IM sensor question.
- CBRD- little tidbits and pics--
- Going to change out fluids (13.6k miles). Some Questions.
- Hissing sound from intake manifold
- Next Round Mods $$
- Stock Crankshaft
- Highest HP Evo in MD
- Hood dampers
- trunk holes for wing [MERGED]
- what size is Fp Red?
- Remove this bracket?
- Figuring out LICP
- How many Evos have YOU owned???
- Quick question about change the piston ring
- Turbo upgrade, goal 120 MPH pump, EF2 or HTA71?
- Letting EVO sit with gas in tank
- X to 9 questions
- Quick question is this too tacky?
- Low cost oil feed lines?
- Greddy RS or Greddy Comp Ti-C
- Evo 8 question
- Why my serpentine belt tore out?
- Steering column slid off mount
- How to tell if you have cams?
- question on installing cams
- Looking for GSC s1?
- Failed inspection FTL
- Prosport gauges
- Megan Racing + Spring blots
- Drunken evo mistakes
- AMS TBE what are your thoughts?
- Who's rockin mud flaps?
- Cylinder 1 misfire
- Needing some help with my a new motor
- OBX Cams?
- Help: grimmspeed 3 port ebcs, can't boost over 15-16 psi.
- Part number for throwout bearing inspection cover
- Bleed screw on brembo snapped off inside
- locking out ? or something else?
- Problem With My 4 - Need Help Diagnosing
- Forged Vs Billet Vs Cast
- Dual exhaust tip: Same power, less noise?
- what to look for when reading AFR and is a retune necessary over time
- 7,8,9 parts on early evo's
- QTP with turndown question
- Evo 8 motor help
- question: remote tune
- Looking for TransferCase Bolt Part #
- EVO 9 idle issue
- Service Manual for 05 evo8
- Front windows not rolling up issue
- What do dealerships ask for when you take your car in for warranty work
- Bad MAF or tune?
- Evo 8 mods for Daily driving!
- Pump+Meth, vs Race Gas vs E85
- Exhaust system question
- Gauge location,Radio spot... Glare?
- Rear subframe for the sway bar does anyone keep these around? Need one..
- tranny question
- Help with 02 code P037 please, need to smog....
- cel knock?
- evo 8 tranny
- upgrade turbo
- evo iv in the states?
- Any street tuners??
- Oil pressure sensor broken?
- A federal agent pulled a gun on me.
- I got a question about tuning
- Blinking Service Engine Light
- Heat soak problem?
- Rear subframe BOLT BROKE both sides WTF? Need advice
- **** perrin psrs ****** mod
- Almost ready for shootout.
- Looking for product reviews, free sample - GTMat Sound Deadener
- LF air bag sensors
- motor mounts DD
- Car doesn't hold idle when cold
- Car falls on face after shifting
- AS Evo IX History
- Late spool after engine build
- P0122 how to fix it?
- Need pics Of Rear Evap delete connections
- yellow hid fogs lights?
- Injen intercooler piping+intake
- Just ordered a VG.
- Should I do an oil Change before autocross?
- Turbo issue please help
- MPG for e 85 vs 93 pump?
- evo 8 FMIC
- Clutch question
- Awesome Rally Evo save ! (PL)
- Question about the Cobb bpv.
- speed density converted ppl please stand up
- Innovate MTX-L Wideband AFR
- what is the OEM EVO 8 front bumper made of?
- Lower Rad Hose Evo 6-8
- Evo Crashes at Pikes Peak 2012 [MERGE]
- Help! Evo 9 front bumper hardware part #
- trying to hit 600? need advice
- Why so many Evo's for sale with low mileage on mods?
- Front lip question
- Help stripping black paint off the valve cover
- Non HID to HID headlights
- Sunroof switch oem mod!
- 2wd dyno tuning an Evo??
- Help!
- gauge pod HELP
- Front facing turbo in Heavy Rain Storm / flood ...
- Monster-Sport Electric car Pikes Peak
- SEL after boost leak test
- Evo 8 weight
- Evo 8 engine noise?
- CyberEvo dethroned as NemoRacing Evo wins WTAC 2012
- Idle Issue, Video Inside, TiAL leaking?
- EVO 1/8 mile times?
- 11.5 at 119 with stock 6spd and turbo
- AEM UEGO in "Lancer" Gauge Cluster
- o2 dump
- Internal wastegate.
- Teflon tape on AIT sensor
- TiAL 50mm bov causing my idle issues?
- Im new to the forum
- Unknown electrical plug hanging by ACD pump
- Pic/question half radiator users who still want A/C and better air flow
- Fujita vs ets
- Need help with Sparcktech COP wiring..
- qtp cut out question
- 3 port gm boost solenoid
- would like a refresh! input please
- Jackie Chan offers a tour around his special edition EVOs....
- Ac compressor and fan question
- Evo VIII with HID what trims?
- 2006 evo 9 mr
- Is this totaled?
- Worth or not, 05 EVO 30K miles, 15k...
- Chicagoland area:Window Tints
- worst dyno day ever
- Key wont come out of ignition easily
- ETS UICP + Injen Intake. Anyone?
- Hks bov question
- Under hood shifter bushings
- RCA 1200 cc injector help
- Installed factory stock boost solenoid still running 10 psi ( please read )
- Tunnel Heat Insulation w/o Carpet?
- issue at the dragstrip
- Air/Fuel is going crazy Evo 8
- Street Legal Rally Car
- just a quick question on filter
- Boost leak test.... have a leak at the throttle body bolts what to do
- does anybody daily drive a 550-650 whp evo
- Posted: 100k IX review
- duck clutch being disabled and owning evo?
- Dipstick Broke..
- Tech Help
- this just broke off
- E85 hp?
- ACD pump part number.
- Motor Mount Vibration
- Gears won't engage
- Evo 9 mr clutch issues
- Evo IX Exhaust Manifold Differences
- Power window slows down when pressing BOTH driver and passenger. how to fix?
- Evo IX question
- evo ix a pillar 3 gauge set, what one?
- Cleaning up my engine bay
- Fixing a cracked valve cover
- HID low beam adjustment issues
- AFR idle/driving/accel? I need some Opinions on this
- evo 8 engine code question
- Compression test result .. Need advice
- Need help on Fuse #8 short circuit
- Power Steering leak
