View Full Version : Evo General
- GEICO is dropping me for "unacceptable equipment"
- Milky white substance in oil
- TI Exhaust cleaner???
- Best route to take?
- Need info
- Winter job - fuel system cleanout
- Best Bang for $ on Exhaust Manifold?
- why dont we do staggered wheels?
- Evo 8 Engine Question.
- are Evo engines more reliable/easy to work on than the STi's boxer?
- Ebay turbo-back with good muffler
- Help Needed: TiAL MVS Top bolt size?
- ETS Intake on Evo IX
- Cooling Pro Radiator?
- ARC parts
- 03 evo just hit 175k miles
- Fp white
- Warped Front Evo 9 bumper fix..
- transmission powder coating?
- Evo VIII vs IX brembos
- water temp settings?
- Center Hood mesh assembly
- Fluids
- Silicone IC hose replacment
- Help, need a small annoying part
- Terrible gas milage
- Curious: Who sells "D1 Spec" products?
- recaro sport seats?
- Losing pressure with double pumper
- Assistance in installing a front bumper cover for a Mirage- HELP please!
- Slightly different idling
- E85 800-1000hp Fuel System Setups
- have a headlight question need some help.
- winter time!
- Does your Evo shoot fire balls during daily driving??
- will a passenger side axle seal fit in the drivers side as well ?
- Anyone know this off hand?
- smoother shifting less drive train noise oil review
- bad missfire, but only after driving for 20-30 miles
- exhaust manifold stud broken in head...should I just run it?
- What next? MORE POWAH!! :)
- Who sells hood dampers?
- EVO IV parts - availability in US/Canada
- Quick question on AEM wideband
- voltage drop = idle drop?
- Please help!
- CBRD Speedfactory & Ball Bearings
- virgin evo in need
- Trouble removing front bumper
- VIRGIN Evo 8!
- Need a new front bumper
- Part number for block from Mitsubishi
- Evo 1 problem
- Evo Crankwalk and the Block Questions
- Rear end bang
- Barometric pressure signal sensor
- Petition for E85 SMOG EXEMPTION!!!!!!
- Will these exhausts fit?!
- Stock MAF filter size?
- Custom oil cooler questions
- The regional forums are a little slow so I figured I'd post this here
- Tranny
- Hit a deer last night! [MERGED]
- Sparktech COP Sequential Vs Motec M800 PnP
- I need Wheel help!
- My 2003 Evo 8 wont warm up while driving.
- cant get into 2nd at high rpm
- 05 Evo8 stock HID passenger side low beam not working.
- need diaqueen!
- gauge cluster question
- Do you work/build/tune your own evo ?
- how does the IAC and rear O2 sensor work with eachother?
- factory ECU octane sensitive?
- Electric boost controller no longer making sound...
- Need help on Greddy boost control profec B II
- evolutions a car that gets vandalised alot??
- upper ic pipe popping off
- mud flaps?
- Upper dash cubby?
- Where to buy stock lug nuts?
- Would you let your mom drive your Evo?
- RPM hang issue.
- 361.2 Miles to a Tank, Say What?
- VIII vs IX turbo
- question on innovate gauge
- Newbie mechanic questions for monstrous EVO
- My evo Ix AND LOVIN IT!
- Evo 9 Build
- what aftermarket lugnuts fit oem wheels
- Delay valve help
- Evo 4 Fog Lights?
- Quick question..
- Evo VIII and IX Coil Pack Question
- Dealer price on "new" bare Evo 8 4G63 block..?
- Broken Evo 9 Gearbox!
- Bov /sputter, brakes and rpm issues! Please help.
- How high would a 1.5 4G63 motor rev?
- Bad IAC?
- quick input!!
- Evo IX Video I made! Check it!
- Sea Foam
- Competition Clutch
- EVO IX tranny oil
- What size bulbs do i need for cig socket/ ic switch/ coin holder
- Turbo Timer HELP!
- Evo light bar?
- Polished Evo 8 intake manifold
- Exhaust vs Turbo Q
- Buying an Evo 8
- Vacuum needle drifting & vibrating on idle?
- Just got my hands on a 06 MR with only 19k on it
- Removing valve cover
- Installing AEM Inline Wideband
- Have A QUICK QUESTION
- Gauge pod setup
- Evo 8 dies under load
- The Best Fitting Voltex JDM Rear Bumper Diffuser Replica?
- o2 sensor issues
- radiator trouble
- Forge rs bov adjustable?
- AMS has discontinued cnc ported head
- innovate wideband sensor?
- Installed a JDM Exhaust on USDM Rear
- evo 4 fog covers?
- What To Do
- Help! driveshaft shaking and thumping
- Anyone using conventional 20w50 oil?
- Poor Starting Issues.
- What is this?
- Aem Digital Gauge Sensor Part Numbers
- head stud install
- Slight wine in 1st from 2k-3k
- EVO IX MR SRS light on
- Install Stock Seatbelt buckle on Sparco Sprint V
- Concerns: Garaged EVO??
- PTE 1200 injector users
- Evo 8 mr
- o2 sensor HELP!!!
- i need help!
- PLZ HELP Window Wiring
- New modified- CBRD cover-
- TOB + Grease?
- Some Advice
- Seibon hood vents during rain...
- Does the seatbelt go off with seat belt un buckled?
- SD n just running an Intake Cone?
- condition of spark plugs
- Body parts for Evo IV in Canada
- Need feedback please on exedy twin problems
- Broken axle?
- emission question
- Blox Front Motor Mount
- Jarretts new street build
- Is it worth it?
- Evo as your daily driven car?
- Got my TME to the US!
- Brake Calipers Installation?
- Turbo hotside
- Oil in intercooler pipe
- FIC injector question
- higher idle while rolling?
- How to Maintain a Proper Idle
- what is this??
- FQ 400 motor
- Transmission Fluid leak?
- Torque Pro ObdII
- electrical problem after hard acceleration
- Works Short Shifter
- Wtb Evo fender
- Rust in cylinder question.
- Lights/dimmer not working.
- Bye Bye Stock Wheels. 2 of 4 at least
- Compatibility
- Use E-85? READ THIS
- Hit 100k on evo
- Winter solution for metallic shift knob?
- Catalytic Converter Fit
- Deatschwerks Fuel Hardwire kit ?
- What weight oil do you suggest for a high hp evo in the winter?
- Mounting Oil Pressure Sender
- Need an Evo VIII 4G63 bare block...
- How old were you when you bought your first evo
- Bolt size for stock muffler to stock midpipe evo8
- Clutch question
- Need help
- OMP side bolt size
- What rims are these?
- screamer pipe
- Exhaust manifold removal
- spark plugs bpr7esix vs bpr7es.
- Post I have reached an entirely new level of uber geek..
- Bad startup
- Stock diameter?
- Purchasing an Evo IX (australia)
- Coolant hose popped off
- Car is boosting low
- turbo help
- pop quiz
- Cant hit full boost and car starts chugging at higher RPMs?
- running rich! ahhh
- HELP!! Persistent random multiple cylinder misfire with a random drop of idle rpm!
- fic 1250's, kelford 272's, and AEM series 2, 91 octane
- Strange Cold Start/Idle Issue
- Trading my evo for another evo... Need advice/opinion!
- Hood latch problem
- battery relocation kit?? suggestions?
- A leaky situation
- set idle for hks 272s?
- Weapon r intake manifold
- Window Motor Connector PLZ HELP
- is the evo 8/9 radiator support same as regular lancer?
- Fuel pump sending unit replacement?
- air intake questions
- Evo 7 & Evo 8 Left hand driving pillar
- tanabe exhuast fitment
- Best uicp & licp
- NEED HELP, Custom Build and No Fuel!
- Favorite / most missed evo
- need some quick opinions
- Whats the highest mpg your EVO has gotten
- Need help! Anyone know what size/brand injectors these may be?
- Might be time to quiet my car down.
- 52mm EVO Triple Gauge Pod problem
- Hard Starting with E85, switched back to 93
- Thinking of going 10.5 on my 8
- Idle problem after remove a line in pcv!
- hks 280 cam gear setting ?
- torque specs for motor mounts?
- How to maintain the turbo?
- Difference between Evo IX MR, GSR & such
- VR Speed Factory? no response?
- Best intake for the stock uicp?
- BOV Silicone hose
- Competition Clutch Question
- think of selling evo
- Strange acceleration
- Stock intercooler Size?
- header problem
- Reducing chattering and shuttering
- Iac question
- Need help from anyone using Apexi Exhaust Control Valve
- wideband problem when cruising
- 2006 evo wont shift into any gear
- Help: Is this o2 sensor destroyed?
- Do you remember the first time you drove your evo?
- help car is having hiccups/bogging
- Time to upgrade bottom end and Turbo
- Lifter noise questions
- Replacing Seat Belts
- Is my throttle body F*@#ed?
