View Full Version : Evo General
- Needing help with power steering part
- Evo 9 broken mivec banjo bolt
- Relocate Earth cable
- Evo stutters at 4k+ rpms
- Ayc
- --Need HELP! Starting issue--
- Rexspeed VS Voltex Rear Diffuser
- Is this my turbo coolant line?
- Why do my Gauges flutter like this? (video)
- Gauge Increments to buy
- 1.5 Ton HF Jack with Rexpeed Side Skirts?
- would you buy a second hand turbo from a wreck?
- transmission or clutch problem. maybe?
- Gap Between Roof & Vortex Generator
- water methanol kit
- Genuine Evo 3 or not
- Loud clunking!! Yay!
- Holy Buzz Batman, reverberation at 4K RPM
- ACD Relay specs, anyone have them
- Seeking advice vibrations
- 2003 Evo 8 MHI FP RED JB stock block build/progress
- Trying to find loud metal on metal sound
- Is it worth owning an Evo in California?
- Bad fuel pump?
- Evo 9 front control arm hardware
- Well this happened today.
- Weird acceleration on Evo 9
- evolution 4 (need help )
- Cap turbo coolant lines?
- Evo 8 not starting after cams
- Extremely lean idle , car dying
- Evo 9 mr Spring question
- Mud flap question.
- Evo 8 Help "Will not start" *with video*
- Evo wont start/crank
- Great Evo 3 from Slovakia
- Evo 8 engine and transmission question
- ⛔★ Evo 8 only boosting 11-12 psi (boost solenoid ok, no boost leak)
- New to the forum , would like to know opinions on best precision turbo ;minimal lag
- Any lightweight alternatives to front bumper support?
- Seibon Carbon Fiber Hood Question
- No Acceleration
- Car cranks, has fuel, has spark, but doesnt start???
- Evo IX fuel inquiry, 93 octane availability
- sometimes drive perfect and somce times stall when coming to stop
- Go pro quality action cam sj5000
- FP .020" PURPLE oil filter/restrictor
- anybody have a unlimited carfax trial?
- Has anyone tried to start there own drive club ?
- Evo 9 engine sputters won't go past 2500
- Specifications of this emblem GSR Evo 3
- Test drove an EVO, vibrations when idling
- NEED HELP!!! Evo loses power randomly
- Where can I get replacement Pins for the interior harness.
- Oem part
- What cam gear should i go for?
- Im thinking of buying a shift knob made of Delrin, how durable are they?
- Ecu and immobilizer with different key HELP!!!!
- EvoVIII hood
- 05 Mr, Tranny Max Hp
- New Battery and Alternator-- car will not start
- Evo 8 Hood?
- Light Bulb for MR Boost gauge
- In need of some build advice
- Help! Came home and car doesn't crank!
- Red Evo, Brembo Paint Color?
- Evo clutch job - First go-around
- Evo 8 non cdi sparktech question
- Evo 7
- leaking bov
- Evo IX Belts and Fluids Inquiry
- I am looking to buy an Evo 8 Engine
- 600hp Evo build
- Project Blue Bird
- Socal is flooded... and my car got some water... what do i do?
- Car wont start in cold
- Car completely dying.......electrical issue
- Magnetic Drain Plugs Evo IX
- Which in take and which manifold to get?
- Evo 4G63 Block Girdle Shipping Weight
- Would you buy an evo with more than 200,000km
- -HELP- 93 Octane vs 91
- Gas, brake and clutch pedal swap
- Brand new member - Evo 8 questions
- Lucas ethanol fuel conditioner (E85 users)
- Help diagnosing starter issue
- Hesitation, Stuttering, Bad Fuel Pump???
- broken crank!
- To emblem or not to emblem?
- Road race reliability
- PRL Motorsports
- o2 dump loosing power?
- I just don't get it!
- another three coats on plastidip
- AFR @ cruise readings
- Camera Headrest mount for Recaro
- Front lip???
- What kind of front lip is this ?
- How to Clutch / Pedle adjustment ! Help
- ESpec Industries???
- Please help
- Sticky/Broken RPM meter?
- Who makes an auto trans for evo 9
- Evo autozone
- Never before seen CP9A Front Bumper
- Merry Christmas to Me.....
- New AcCompetion clutch stage 3 ( HELP )
- Engine lag
- ho ho ho
- is my boostin tune safe?
- Recommend a suspension and brake
- P0134 Code, Sensor replacement & New motor still problematic
- idle
- AEM 3 gauge pack
- Bought Evo VIII shell
- Diff, T-Case, and Transmission Flush
- i did a thing. (custom fab)
- 2003 Evo 8 and keyless entry with no programmed keys
- Won't hold idle and crazy AFRs, help please
- Br cai 8/9
- White smoke from exhaust on start up
- What oil are you running - anyone use 0W-20
- Dw200
- Fuel pump problem?
- can't post
- Tracking Evo 4 - Sump baffle
- How to post in "For Sale" section?
- Changed crank and cam sensors, still getting codes and no start
- Low voltage overheating ? Or false reading?
- Full fluid change
- Day 1 evo 8
- No start issue, not sure where to look anymore
- ETS Short Route UICP Replacement Couplers
- broke stud on starter solenoid
- My knob won't turn on ac.
- Anyone drive a fully stock Evo?
- Reclear or Paint Carbon Fiber?
- has anyone tried to replace the 03 center console for the updated 05?
- "4G64xmas" Special Deals
- E-85
- Where to get Defi Racer pressure gauge supporting wiring?
- General Questions
- Variable idle AFRs and Vacuum
- Injector problem in my evo iv
- Licp and UIcp
- Next steps for my 8- blew evo 9 turbo
- Can you lower boost without retune?
- Evo 9 no fog lights, what are options?
- Freeze plug stuck
- Question about Topspeed pro 1 exhaust
- USDM Headlight differences
- Evo 7,8,9 steering wheel into 4,5,6
- Are Evo's more fun then motorbikes?
- Car stolen!! >:(
- Evo is broken down. Thinking alternator...
- Headlight Flickering
- torque spec?
- Aem water temp gauge
- 1997 EVO IV BOV Help!
- URGENT: Possibly buying evo questions
- Flashing SES light under load
- High Pressure Fuel Pump Line MIA?
- ⛔★ Evo 8 dies after letting off high throttle and clutch in
- ⛔★ Evo8 Shake under braking :-(
- MAP EF3 oil line
- In need of some guidance (Evo 8)
- Innovate wbo2 and gauge help
- Good Tampa, FL Shops
- Ralliart Lip Replica for Evo IX
- VIII often has rough Idle and car dies often
- Grandpaevo getting close to 400,000 miles!
- Turbo problem?
- Those running English racing boost activated cutout.
- Cars and coffee ride fayettville
- Timing belt change on a low mileage 2005 car?
- Extreme Tuners Drag Evo
- Peak boost only under engine load?
- Evo 7 body kit
- Daily driven high hp evos!!
- Can someone tell me what this line goes to?
- Santa arrived early - with pallets of goodies.
- evo dying issue for over a month now..
- Restore or part out?
- Head Gasket Question
- Rough cold start on 93, suggestions?
- What front bumper is this??
- 3 port set up on Turbosmart Wastegate
- Clutchless 4 Speed ( C4S )
- Buscher street core
- Muffler bolt.
- What is it that you like about your Evo?
- AEM vs. Innovate Motorsports AFR
- Evo 8 SES Light
- new to the evo forums
- What brand is this lip?
- Which has the best front design? EVO V, EVO VI, EVO VI TME
- HKS twin clutch slipping already ?
- HVAC Air Selection knob stopped working and temp doesn't get hot
- Fully built engine and head with a little bit of lifter tick
- totaled?
- Evo IX seat leaning/not straight
- 2003 evo 8 turbo kits. 450 Goal
- Been out of it for awhile, need some opinions on basic power mods
- MAF to Speed Density Questions:
- How many people made the switch!!
- 2 questions Evo fam! Noise on rainy days and clutch
- Battery Not Charging - Evo 6
- North West !
- Newly Built EVO -Leaked Oil, Didn't notice until oil change (2-3 quarts low)
- Airbag Recall Pacific Northwest
- DSPORT Black Friday 4G63 Deals
- New member
- EVO 6 vs. CT9A (7/8/9) hood/fenders/bumper differences?
- Anyone know this car?
- lifter tick?
- Can't choose between black or gunmetal jdm tails
- The FML thread!
- Bought a wrecked evo. help identify previous owner/give me advice
- prm shaking
- Where are the Black Friday sales!!!??
- EvoScan and OBD Link SX
- wheel dude scam?
- How much would this evo go for?
- Radar Detector law
- Windshield washer fluid lines
- hks down pipe and apexi exhaust system
- Need Evo 8 trunk W/ holes
- Newb question need help please
- Help!!!!!I'm going crazy !!!!!!
- My first Evo!
- UAC AC Compressor
- Sell or Mod?
- Noob alert
- Evo died on me today
- Eva 8 build slow but well just slow
- E85-r
- evo 8 engine
- 2015 Super Lap Battle x Global Time Attack Finals Highlights Video
- Please diagnose (oh noes another tcase/rear diff question)
- Rear diff question
- Clutch switch and interlock switch
- Stock HID headlights 6000k, 8000k, 10000k
- Newly built 2.0 liter 4g63
- Electric Blue Evo wheels
- 5-speed with 6-speed shifter console
- Electric blue evo
- JDM BUmper
- Do Luck install question
- What parts or brands do you want to see Black Friday specials on??
