PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Evo viii up down temperature problem
  2. Center console custom
  3. Whine noise as rpm's increase
  4. NeverWet
  5. Lights/Instrumnet Cluster Issue
  6. Need a new tuner.. GOOD ONE
  7. Fp turbo intake
  8. Members in Illinois
  9. Is $16k reasonable?
  10. Understanding Offsets
  11. pin stuck in turbo
  12. Cargo net pics?
  13. Issue: Bad alternator?
  14. Gauge cluster light just wen out
  15. ARP headstuds torque help!
  16. Which brand of gauges to buy?
  17. Help!
  18. Misfire on cylinder 1 and 3 no injectors?
  19. Headlights
  20. Kids.... Sigh
  21. HVAC Control Swap -- still an issue
  22. Purchase without seeing
  23. Alloy wishbones Evo 4
  24. Evo 4 - 5 subframe measurements ?/??
  25. AC system re-install
  26. Vibration on the front seats?
  27. Evo 8 vs Evo 9 Pistons.
  28. Another BOV ? Greddy type RS
  29. radiator cap for 99 evo 6 ralliart
  30. Evo 8 MR Misfire Help
  31. Searched but could'nt find an answer p0335 p0340
  32. Misfire issues?
  33. Pleasantly surprised after finding this Video on how fast GT-a is compared..want a 5
  34. BG Syncro Shift 75w-80 Manual Transaxle Oil
  35. Evo 8 starting Problems.
  36. any in DE pull evo motors?
  37. Evo 9 MR Transmission help?
  38. crank no start
  39. Paint chip --_--
  40. Fixable Dent?
  41. New to evo m/boost issue
  42. Low idle / oil light coming on
  43. cutting out under wot
  44. Where to reset Evo 8 odometer
  45. Exhaust options...
  46. Possible spark plug cover hazard?
  47. omni 4 bar sensor install, need help.
  48. HELP: Thieves ruined my stereo harness!
  49. Refinishing carbon fiber wing.
  50. Wing off Ebay - White Carbon Fiber - How will it look on a WW EVO?
  51. P2096 Post Catalyst Lean condition
  52. AEM Tru-Boost vs Manual Boost Controller
  53. what does this plug go to?
  54. Opinions on a turbo outlet
  55. 2006 Evo 9 MR steering wheel vibration
  56. New to evos (trading my sti for an evo 8) need input asap. (please read)
  57. *** Watch out for fake Walbro 255's ***
  58. Where to buy small Mitsubishi Diamond Decals
  59. Opinions on Engine Management AEM or Stock ECU?
  60. Fog light question
  61. Where to order Bride Zeta III Type-L's
  62. Motor mount bolts?
  63. Fftec fuel pressure sensor adapter
  64. Check out this beauty on ebay...
  65. Struggeling with a dying engine issue, need some guidance.
  66. Anybody going to/running Pikes Peak this year?
  67. Need Help?
  68. Whats Up People, Need help with picking up Evo7
  69. Power Steering Question
  70. Shifting Problems
  71. cluster wiring question.
  72. Weird tail light problem
  73. Stronger "Regular" Size Battery
  74. SOLO 1 Circuit, Puerto Rico
  75. Three ACD lights
  76. 1/4 on 4g63 stock?
  77. egr solenoid
  78. Does shifting into 5th gear in the 1/4 hurt your mph?
  79. Safc question
  80. Looking for some input
  81. Strange noise coming from head/valve cover?
  82. Car bucks in full boost but not boost leak
  83. 10 year Evo anniversary - post if you've had your Evo for 10 years
  84. Evo 8 - 9 headlight conversion
  85. Need help rfp1 18x10.5 +15
  86. HKS SSQV or Synapse Synchronic BOV
  87. If I were to re-mod my evo with TIPS from 7 years of experience
  88. High Speed Autocross Highlights video - Blackhawk Farms
  89. What can I use to properly clean my Perrin intake air filter?
  90. Passing smog/out of state vehicle.
  91. Ecu question???
  92. Evolution IV parts compatibility, advice, and suggestions?
  93. turbosmart wastegate issue
  94. Miss fire or no?
  95. Few questions/issues
  96. Lash Adjuster REmoval tool?
  97. ix front bumper by color?
  98. Need Evo IV (CN9A) Parts (Window Visors)
  99. My CN9A in Okinawa
  100. Possible OBD Scan Tool for Mac OS X users with a Tactrix cable
  101. Weird Noise from back seat
  102. Hood vent fasteners
  103. Not too sure how to explain this
  104. Radiator Fan Does Not Work. HELP!
  105. 2003 evo 112500 miles what is it worth
  106. Do-Luck Widebody kit
  107. Has anyone had this problem before? (a/c under constant power)
  108. How much is an EVO 8 turbo worth with 80k
  109. Need help with what bulb to buy
  110. New high comp pistons.
  111. Strange water drip
  112. CP9A Questions
  113. Evo 8 front case gasket?
  114. Should I make a run of Evo 1-9 pods?
  115. Wtb evo 9 headlights
  116. Ecu anyone?
  117. I don't want holes in my front bumper
  118. Ceramic coat and heat wrap go hand and hand?
  119. EVO's with CB Radio's?
  120. What's up with Mellon Racing?
  121. Swapped in new IACV - Idle got way worse, dies at stop lights
  122. My GT-R answer: 1000 pounds & $60k cheaper
  123. stock radiator limit
  124. Acting weird... :/
  125. searching for Evo bolt "wizard/list"
  126. Where to buy OEM HID Ballast?
  127. Evolution badge help!
  128. ac compressor wont kick on
  129. Weird issue with my car... (a/c compressor/power steering)
  130. rear diff bolt part # (PICS)
  131. Double oil coolers?
  132. Haven't posted my Evo yet
  133. Opinions on track/street turbo
  134. Running on stock WG pressure. Wont go past 7-9 psi
  135. So what exactly do I need to increase my boost past stock?
  136. mitsubishi 2 pots 15" slips no spacer!
  137. Evo boost leak test with a question
  138. Limp Mode Question
  139. GSC S3 2.0L mileage
  140. please help strange grumbling sound.
  141. please help strange grumbling sound.
  142. Are Lightning Yellow Evos considered Rare?
  143. best turbo set up?
  144. Washington emissions failed
  145. FP Red vs GTX3076
  146. Advice needed on aftermarket fuel rail
  147. Optima Red Top won't fit...what can I do?
  148. boost/vacuum leak
  149. Mysterious Electrical Problem *PLEASE HELP*
  150. Looks Like I am in the Import Meet Street Car Competition
  151. Loose plug. What does it belong to?
  152. TRANSMISSION MECHANIC - South Orange County
  153. Custom J-pipe
  154. Acd pump bad or something else?
  155. looking to buying an evo soon
  156. AC is holding charge but button won't work thus no AC.
  157. Identify Part on Steering Ignition Lock
  158. Terrible gas mileage
  159. AC compressor pulley broke off.
  160. Body panel part #
  161. Slavaged title ??
  162. Help! spooling stutter and noise coming from belt cover!
  163. engine break-in oil replacement?
  164. indicators near right turn signal (on cluster)
  165. Help! Help! Help!
  166. Ams 3076 t3 kit install instructions?
  167. Evo 4 doors
  168. Adjusting shifter in Evo8
  169. Used EVO X with 52k miles for $23k .....????
  170. Has anyone had this happen.
  171. FML, Front LCA bolt hole crossthreaded!!! Threadsert?
  172. To those of you who have powdercoated your calipers
  173. o2 housing or dump worth it for ix???
  174. Evo problems
  175. Alt power wire
  176. Can't post?!?!?
  177. Highest Hta3076?
  178. Coolant Gauge? Electrical...
  179. new member
  180. Totaled? Not thinking so need help
  181. Troubleshoot Help
  182. Ticking noise from clutch or tranny?
  183. Quickest place to buy from
  184. I got 285 miles to a tank yesterday
  185. Crate engines
  186. lancershop.com
  187. I want to go wingless but...
  188. Buschur Race core fitment
  189. What to get and Help!
  190. Uknown part. Help please!
  191. Turning Vent Selection Knob Causes Oil Temp Gauge to Turn Off
  192. Wide band Decisions kind of stuck
  193. Im sorry to ask but...
  194. How to remove fog light cap from JDM headlights?
  195. Best sounding exhaust you've ever heard on a Evo 8/9
  196. Hvac lights messed?
  197. Richer Idle??? Only Home Couple Days, PLEASE Help!
  198. Help, wrong head gasket
  199. Please help a noob with pricing?
  200. What is the paint code for this red evo IX ?
  201. Injector size
  202. SUPER lean under boost
  203. Has anyone seen this volk watch before?
  204. Is my BOV Recirculated?
  205. Vss help
  206. F****n Thieves! Please Help
  207. Hood latch and cable broken
  208. evo 9 starter
  209. SES light issue.... in reverse!!! plz help.
  210. hallman mbc self adjusting
  211. Ongoing Issues.....
  212. Cracked Manifold!!!! Map short runner??!?!?!
  213. Help! Broken Downpipe bolts
  214. Ams exhaust?
  215. A/C Issues
  216. Broken Turbo/Manifold Bolt, Will not budge!
  217. 25g Kinugawa opinions
  218. Help with iac!
  219. Bought my First Evo, and im now experiencing the fail.
  220. Looking for a good exhaust for my new 13 mr
  221. ahh i miss my evo
  222. battery and brake light issue...
  223. VD and Mustang Dyno's
  224. Running Rough After 5 lbs or so of boost/ misfiring or starving for fuel
  225. EVO 8/9 rear diff issue explained (video)
  226. FP Adapter and Bolt
  227. salvage title autox
  228. Need help with timing.
  229. Poverty evo build what do you think?
  230. ny state salvage title inspection SRS light on
  231. help rear caliper bolt striped
  232. Tomei ti catback and dp with resonated test pipe.....is it worth it..
  233. 2003-2004 evo owners
  234. Replacing the engine wiring harness... sigh.
  235. diagnosing possible wheel bearing noise
  236. best evo 9 jdm rear replica?
  237. Need suggestions badly
  238. emergency! center caps stolen!
  239. To all People running hks hi power/silent hi power exhaust
  240. Double Pumper troubleshooting
  241. Oil Pump Sprocket?
  242. Factory temperature/electrical? issue.
  243. Can you fit an evo hood inside the evo?
  244. Making your Evo heavier
  245. Front lip
  246. MR 6speed drivetrain fluids
  247. Evo headlights-H1 or H7?
  248. evo wont start after exhaust install, Help!!!!
  249. Clutch Pedal
  250. Rear Motor Mount
