View Full Version : Evo General
- Mini Battery kit, which one do i pick?
- New Evo IX owner
- need help. new* NO AC ? not working at all.
- Random gauge question
- no throttle response??
- A/C compressor clutch
- Missing...
- Where is the cabin air intake located?
- 400whp evo
- Just how loud is the Greddy Ti (Neighbor & Work Concerns)
- No trunk light
- iscv issues
- Help with my idle issue please!
- Throttle body seal leak? No more!
- Over Rev
- Driver side tail light out!
- Manifold Bolt Stuck!
- shifter on my evo is very stiff in every gear
- What would you do with my situation?
- New Guy quick few questions
- Blowing smoke burning oil need input
- Strange noises on boost
- In$urance Quotes
- Sunroof Control Acting Goofy...needs reset? HELP
- Car runs like crap after injector and walbro install
- WG actuator arm
- Combination to run 10.80
- Looking for Roll cage and front lip & ideas to make it look better..
- Help my evo died driving on the highway and will not start
- steel braided clutch/brake lines
- ARC is it coming back up??
- Weird steering wheel issue
- bride seats
- Popping out of 4th @5k+RPM
- E-85
- Mbc vs wastegate forge
- e85?
- resale value of our cars?
- M.O.D Roll Call
- help: grimmspeed EBCS 3 port
- Ran Engine with no oil
- Boost gauge problems
- P0300 HELL! please help.
- AC problem on evo 9
- knock sensor
- help vibration under load!
- Injen pipes/Intercooler HELP
- Finally got car back, now more bad happens
- Buschur Intercooler
- woke up to a rough idle
- E-Check Issues
- Greddy comp tic question
- E85 setup trying to choose manifolds tb and o2
- Went to the drag races today.... confused
- CEL no cat questions.
- Vinyl Wrapped Evo's (cars) how well does it hold up for DD?
- Clear coat flaking
- fit K&N airfilter to turbo inlet..Bad idea?
- A/C compressor clutch engages when jumped
- Rust in fuel tank. What would you do?
- Long Cranks after COP install
- Real Ralliarts?
- speed density question
- Persistent Exhaust leak
- PTE 1000 Injectors?
- Is anyone NOT running a puller fan?
- Buschur Racing Evolution MAF Pipe Kit and filter
- Thermal camera
- Need Help with Smog, plz!!!
- Strange whistle
- Temp Up and Down
- Decent GG color match.
- Evo 8 not starting?
- Rotella 15w40 is ok?
- Buddy gave me a turbo, help identify
- evo 7 smoke help!!!!
- OEM sport meter install
- Seting up AEM AFR to match AemPro [Aem Ems v1] my issue..
- ID these injectors Please...
- How much should I discount from the sales price for a bad...
- Another big build statistic: Thinking of getting something else
- speed density help!!
- eBay n1 exhaust input?
- The plastic under tray ?
- SES Light (help)
- Evo 8 Radio help
- What part is this? Next to side mirror
- A/C purging on highway
- Steering wheels
- evo 8 major syptoms
- Car won't start! Help?!
- Younker Mitsubishi Meet
- head to block alignment bushings?
- Question on boost levels in different gears and tuning
- what the fastest 1/4 mile you have run in your 6spd
- knocking sound HELP !
- Keep Blowing This fuse - Car cuts out when it blows
- OEM belts vs aftermarket (GATES)
- Help Trying to install injectors.
- Nos octane booster
- 60k Maintenance help!
- New AEM boost gauge reading wrong?
- Car always jerks when shifting when pushing it...
- Valve cover breather filter
- Hey doin my own t-case
- 1-3-5 Gas Saving Trick
- Great new product, AEM Wideband Failsafe gauge
- Question On Evo's Timing Belt Mileage
- help in decision
- Boost slowly dropped in 3 day wtf??
- DeatschWerks Fuel Pumps
- Hauling off to CBRD - trailered for more power!!
- Key question
- Dur, so that didn't go as planned - ABS sensor removal
- Ams Small battery kit vs Batter relocation??
- After 2.5 years, thinking of selling up...
- please help identify this boost solenoid
- I/C piping question
- Which GM IAT Sensor for SD?
- Crank sensor p0335/Starter not good but good.
- Weird problem with the car...What could be causing this
- UPS guy delivered some goodness.
- Stock FPR from EVO 8 limits?
- Rough grinding nosie????
- Patch radiator? Or not.
- alt noise after battery relocate
- What is considered "good compression"
- how many evo iv owners on here?????
- Can I use this fuse box for 12v source?
- speed density question?
- What Apexi Maf Adapter do I get?
- Small filter options for turbo inlet??
- Need help!! smoke!
- Good idea or not?
- EVO IX ALLEGED squeal fix is Part #: 1091A133
- Instrument Panel LED's
- Anyone know Freddy302
- evo 7
- Burping the radiator question
- My VIII blew up a rear end in 10 mins!
- Suggestions: Should IC be next?
- Not Boosting
- Part with no record from Mitsu?
- Who's racing CNY-SCCA Cherry Valley Motorsports July 8th?
- New Evo 7 owner help!
- Need Oil Filter Housing Bolt Specs
- Steering column issue....HELP
- Problem with my Evo
- Am i missing anything?
- 05 issues
- PO300 after TBelt install, EVO IX
- Help I need a new front air dam
- Radiator help please...
- Quick Rant
- Can anyone tell me what part this is? ECU adapter for??
- Stock spoiler
- Daily driving my IX, mod further or leave it alone?
- How Many 03's Are Left?
- chicago area people please help me out!
- Evo 9 SE MR suspension options
- help with wobbly shifter
- AMS Intercooler & Cusco Front Power Brace
- question about E85 tuning.
- Jdm bumper price...
- rear bushings?
- looking for e-tune!
- Where to buy bolts/nuts for OEM sliders to OEM seat?
- Ghetto catch can
- intercooler kit recommendation
- Name this part
- AC Compressor issue. Opinions wanted.
- Dyno tune vs Email order
- 3 Bar Map in EvoScan?
- Help: Front Lower Control Arms
- Evo 8 Wont Crank
- Lots of smoke! Oil burning!
- How hard to find Evo ix seats
- removing the engine bay sound / firewall mat?
- I guess reverse doesnt like me
- Looking for this part!
- MIVEC Install Issues
- Running E85 - Damage O2 sensor?
- Cant rev above 2500-3000 rpms.... Please help
- Thoughts about welding Stock Muffler to Aftermarket Exhaust?
- are the evo 8 headlights the exact same as the evo 9??
- Another what will it run/how much power am i making thread
- Car shut off while cruzing to a stop
- Evo 7 wont run issues
- 17" hoosier vs m&h slicks
- evo ix front bumper with evo viii intercooler
- Question about boost gauges.
- Bad Alternator Question
- FP3794 or FP3586?
- Sick deal on greddy bov flanges
- Fuel line ann fittings
- Thread got detele don't know how. But. Asking about acd pump need new or parts
- is an evo 6 fuel pump the same size as an evo 3 one?
- Question On Driver Side Door Power window Switch.
- Horn doesn't work
- Hooking up a LED light to the CEL signal??
- evo 8 interior question
- battery relocation, what AMP for circuit breaker?
- Tuning Problems
- 2.4 pistion help
- like wheel shake...but really strange
- any ideas on price..
- Removing Lancer backing in Gauge Cluster
- Just got tuned... is this ok?
- When I fill up gas,EVO doesn't start up! HELP
- Lh tuning
- Hose that goes nowhere... need help
- Evo VII issues, plz help
- wondering if this is someone on the Forum
- Low Speed Popping Noise?
- Need new evo3 16g ASAP in Chicago
- Pic Request: IAC O-ring
- JDM bumper diffuser got squeezed
- AEM boost gauge
- Evo question transfer case
- Intercooler HELP
- I turn key, and NOTHING ...
- HKS gauges
- Catalytic Weak Efficiency
- Will this evo ix control arm work on an evo viii
- Map ecu 3
- Oil Change At 36 Miles.
- catch can/slim battery tray
- Skreeching noise when pressing the clutch...Is this normal?
- Turbo Fantasies
- Change Interior Lights
- All ACD lights on.... Need a new pump?
- Loud Lifters
- Missing relay ?
- Help! non-starter :(
- Has anyone of you ever done a complete car build?
- does this sound normal?
- MLR Sprint Series Promo Videos 2012 (The year the Scooby's came out to play)
- rear door handle problem
- Help with timing belt, turbo and fuel injectors.
- What is this cable?
- Radiator Fans for Evo8
- Removing panel under steering wheel... ?
- mivec oil control valve banjo bolt
- What metal is the buschur intercoolers made from?
- Best Small Battery
- ACD Lights Coming On
- what is the normal oil temp of the engine?
- Input Shaft/Tranny Seal question/insight...
- 6262 turbo
- Idle Issue
