View Full Version : Evo General
- Japan Bound!
- weird clicking noise after braking?
- FP black install soon
- Key/Remote Combo?
- Help worry !
- what does it take to beat my buddy's 12.5 sec s2000?
- changing etacs... need reprogramming keY??
- Stupid Question
- Loud Popping/Shimmy While Turning ONLY!
- ACD & anti lock
- Max
- Does anyone make a silver/silver carbon fiber trunk???!?!?!!
- is this site legit
- JM Fab intake pipe
- Sudden Squeak!
- some questions about buying used evo 8
- ideas for spare spot on cluster
- Cooling fan problem
- Question about tightening wastegate arm/ possible issues
- To stroke or not to stroke? 4b11
- Greddy Type RS adapter
- stainless exhaust shield. anyone make them?
- Paint code/color question.
- Squealing on passenger side
- Where to buy evo 8 radiator support?
- Caliper pricing
- New evo, need to find Lug nuts for factory tires, and new wheel studs!? Help
- What is the most power made with a FP Black on pump gas?
- BlueMax injectors
- evo ****ing sandwich with a little voltex sauce (accident pics)
- Evo Dave???
- Co-efficient drag of Evo without the wing?
- Lugnut decision help!!?!!
- Deer ends track weekend
- Hid kits? Where could i get them?
- Removing the trunk spring bars
- Need Help. No Power. Rough Acceleration
- Where to get white clips for headliner?!
- Tune required after 60k service???
- Need Input ~ DuraFlex Front Bumper
- Are there fewer Rally Red Evos out there than others?
- turbo inlet size help
- The sound of my Evo's death throes
- Noise @ 25mph only - Disappears after flogging the car?
- Tune help Nj turbo xs utec
- Did I see you broken down on the GWB tonight?
- Throwing a new code.. p0172
- 5w-20 motor oil
- Parking light part number?
- small pack of muteki sr35 lug nuts
- If you have an Evo RS: please look, need info on interior!
- Characteristics between EVO IX
- Next round of mods recommendations?
- car cuts out after bov install
- Simple battery question
- Need HELP, transfer case seals leaking
- Valve cover install fail! so pissed! HELP
- can a turbo warp on the cool side?
- long rod motor
- I'm looking for good injectors that will give me no cold start or warm start issues.
- Injector help! 780cc
- DDM HID ballast & OEM connector issue
- Will 3M auto tape leave residue on my dash?
- What is your cruising and boosting temperatures????????
- FP red service life?
- Is there a 60-130 thread for the evo guys?
- stock clutch RIP
- Just great..Citation & Fix-It Ticket
- What Mods Should i Do next?
- mods/turbo to reach low/mid 400hp
- exedy clutch disc question
- Bigger injectors
- Sold my 2nd evo. :(
- Fuel pump, relay?, starting issues,
- Intake duct with aftermarket intake
- im buying this...
- Help..
- Help: Brake cylinder stopper on strut bar
- ***cam gears***
- Evo VIII Fuel Sending Unit Resistance Range? Anyone?
- Looking for 2007 Evo 9 MR
- Grounding ideas for relocated batteries?
- Evohead lights
- simple question, can you run leaner then 14.7 in closed loop?
- Injector requirements
- What are My Options? (FF V Band Exhaust Manifold)
- Evo6 Tommi Makinen Edition
- Spoolinup COP installed, Evo IX MR.
- MAF honeycomb question
- Starting problems round 2
- exhaust leak?
- My baby "Eva" is sick help me!
- What metal in the evo 8 steering wheel?
- acceleration
- German Castrol 0W-30
- Pennzoil Ultra?
- Tune
- Evo 4 Problems Boosting
- Last Formula Drift race of 2010 at Irwindale this Saturday [DISCOUNT CODE]
- Logging wideband through ecu in evoscan
- Currently looking to purchase an evo 8/9
- Crappy Startup - Spark Plugs?
- HELP!! Aem 30-4408 boost gauge issues.
- Windshield Regi/Inspection Holders
- Evo vs STi October 23rd Raceway Park
- Road trip and no cruise control!!!!
- 17x9 with lowering springs?
- Hesitation/Breakup above 3000rpm
- Evo 8 Tranny Question
- rb26dett swap
- racing harness
- 2.3L Stroker owners; what are your idle / cruising AFR's?
- Double Pumper/Aquamist
- Part numbers for Evo9 IX Turbo install kit
- Baysonr evo 9 lip
- Is it me or is the drivetrain movement making me miss 3ed?
- Car losers power under hard accelleration
- Evo 8-9 engine in Evo 1?
- exhaust leak. need some help.
- Greddy Ti-C TBE vs TurboXs TBE????
- Help me pick out new brakes!
- Good car cover for winter storage?
- My Mods Thread (for personal reference/linkability)
- evo 7 with evo 9 parts?
- DAMN RACCOON destroyed my SE lip
- *ATTN* - Buschur Racing Customers...If you've had a magazine/internet feature...
- Orange paint for JDM headlights?
- "fun factor" w/ FP Black + stock block/stock cams???
- Worlds slowest FP black evo? HELP!
- Front motor mount vs weapon r engine damper??
- post videos of you modding your evos
- 450+ low end torque and 500+ hp
- BR 2.4 - Round 2
- just burn etacs
- 03 evo radiator fan controller
- Buying a "clean" Evolution 9?
- How to buy a "clean" evolution IX(GSR, SE, MR) -- READ ME.
- Clicking/Hopping Feeling While Turning *HELP!*
- Thinking about comming to the dark side, Subaru owner with many questions. :)
- Is removing the cylinder head a tough job???
- Evo8 Workshop manual (wiring question)
- Glove box squeak fix
- ix headlight housing
- 04 vs 05 MR
- QTP down pipe opinions
- what wheels spacers will make stock wheels flush? and yes i searched
- Little chips in glass
- Mystery Coolant Leak
- SBR 2.4 FP Black Build
- HELP!!! Replacing Clutch
- Hks 272/272 cam help!
- Why not ask more $$$$ when selling an EVO?
- 05 evo 8 transfer case
- tuner show in Pacific NW
- Carbontronix or OEM front bumper
- Replacing Tranny Bellhousing
- Better o2 sensors???
- Evo died on the way home.
- need help with problem
- upstream O2 sensor
- so im looking for an evo..advice
- Anyone ever try this turbo cooling technique?
- plans for 2011
- HELP!!! Clutch Fork Won't Spring Back to Positio
- Whining noise from pass front wheel???????
- Evo IX MR (What's it worth?)
- evo weight controll
- Looking to buy an evo..
- how much does a ralliart uicp go for now n days
- GReddy SE Cat-back Exhaust - EVO X
- AEM UEGO install = Feedback Noise!
- Cant find Answer re: PCV Delete
- cylinder
- Help...CP9A/Evo 5 - No speedo
- Did I blow my ECU?
- Any Members in the Deland FL area?
- Vaccuum Hose ID Sizes? TIAL BARB?? Cleaning up Engine Bay.
- Anyone try the CF knock off ralliart mirrors?
- help fixing my motor mount
- Any idea how to fix this?
- help needed!!!
- Ebay CF RA style lip for evo 9
- Evo 8 Turbo bolts?
- Help! My Evo has an extreme loss of power at 4k rpm
- Want to Purchase a Built short block ?s
- :( NEED some good advice!!!
- New(ish) Evo
- Please help: Car won't start
- Anyone buy a jdm knock off?
- hks hi power
- Can we add Fuel Stablizer to E85 gas?
- remove/replace coldside of turbo?
- Getting ready for the drifting title fight! Who's going?
- stock cat 02 sensor
- Car stalls EVERYTIME after letting off-- is it batt or alt?
- HELP! Leak getting in trunk
- Sputtering, acting really wierd
- Intercom for the evo
- What to do with the dash and the title?
- i HATE it when...
- Vids and pics section?
- Replacing stock gauges in 05 evo rs
- Exedy Rep?
- e8 head specs
- Shearer Fabrication Contact?
- just bought synchromesh!
- Looking for Part Number for ACD Reservoir cap
- ALLLLL the parts for 60k service neccessary??
- Changing your oil too much is bad!?
- Help! There's mold in my AC
- my set up!
- Will Evo VI radiator fit to Evo VIII ?
- loud bump.
- battery terminals
- Hardware websites?
- Storing the EVO..for a LONG time.
- Where to buy turn signal lense ?
- Buying service for out of state evo?
- hks hi power!!
- NEED HELP with my Cobb AccessPORT live data, what numbers should i be looking for?
- New Evo :)
- Mudflaps help....
- afr gauges
- Can you Figure it out ?
- I just want my car back.
- How much would you guys pay? (pull engine/tranny/reinstall)
- o2 bung missing?
- Coilovers which?
- Evo 9 Shatters/shakes when turning left or right
- Strut bar question's.. Please answer
- Blew my turbo
- Official - Evo Towing Thread
- opinions please
- need help with clutch choice
- exhaust question
- Question about removing the steering wheel
- Some of you might like this: New Recaro Child Seats
- R&D Factory Knob
- blue smoke at high rpm shift???
- AEM tru-boost any one use it?
- AMS vs STM oil cooler kit
- evo 9 as a first car
- right rear axil Boot problem?
- Sparco seat belts harness
- Can someone help me asap! Im ordering in about an Hour need last opinions please..
- Unlocks during a tune... Simple help please
- RHD JDM Evo IX? Oh god...
- EBC question...
- o2 sensor help!
- Removing PCV valve before powdercoat?
