View Full Version : Evo General
- Photo Request: Cusco Power Brace Front Mount on a Evo 8
- Front bumper help please!!
- Rejected...
- OEM Lugnut HEAD size?
- Gauge install
- Service engine soon light
- CBRD around the shop--
- My Gauges.. :)
- Installing Interior Tonight
- Interesting
- 65mm Throttle Body Noise
- 6 Puck FX 400
- NOOOOB question ( head studs )
- Want to know about the Stock evo 9 HID
- 3 fuel pumps! WHAT!!
- Non ACD evo
- Cams before Tune???
- Local shop ruined my calipers...
- Throttle Body ?
- dipstick for stroker setup
- DIY small brake kit
- Can anyone show me what does the evo 9 diff looks like
- Resonator in Downpipe
- where are people putting jackstands? ? ?
- evo finally on the road
- How much off is your odometer/speed
- Custom shift light?
- Let's see your Evo and Motorcycle!!
- Evo Windshield "lightweight"?
- reference to Mudpit Thread
- Vortex roof wing
- Need help, want to install smaller wheels on my 8, front caliper problem ?
- Looking for your HELP :)
- Head gasket!!!!
- lower ball joint
- Exeddy twin feels to smooth???
- Mustang vs Evo Dry Lake Drifting!!!!
- bov recirc?
- Traded my X for this 8
- Changing the stock Recaro seat on Evo IX
- Aftermarket Boost Gauge from Stock MR Gauge Connections
- Lip install issues
- trying to track down a one-piece master to slave clutch line
- OEM Gear Oil Emergency
- X envy
- New Evo owner here, askin' some questions
- Should i get smaller injectors?
- Like me!
- help!!! flywheel cash!!!
- A/C delete guys chime in
- Evo shops in Orlando, Florida
- Oil temperature sensor
- Engine Turns, car won't start
- TBE and emissions testing
- The over-40 Evo thread
- HKS GD Pro Twin Plate Clutch/ pivot rod
- Help! Afghanistan car issues!
- Low Compression in 2 cylinders
- Mini battery
- ac compressor problem
- Is it me or the ACD/LSD?
- Blue smoke at start up on super cold mornings
- Overboosting Issue
- How long till E85 goes bad?
- Retainers broke off!
- Anybody ever.....
- Will EVO's drop in price?
- Alternator question....
- Quick question on Tial Q flange
- HELP! Mitsubishi CAPS program does anyone have it?
- Cylinder 4 reading low
- Question!!!!!
- How much is Everyone paying on insurance on there Evo
- EVO IX Noise from the serpentine belt area
- Smoking after seafoam
- lower intercooler piping fitment
- No strut bar on track day?
- What spark plugs?
- Cleaning transmission
- Bad idle..to no start.
- Tarmac, gravel and snow lights are on
- Best spark plugs?
- Need help fast!!
- what sensors are these? (Pics inside)
- car keeps frying ecu
- Water in cylinder 1 issue... Need advice
- what headlights are these?
- Diagnostic and Tuning Software
- Evo 8 ecu work on a evo 9?
- S3/S2 cams
- Has Anyone Blown a 100% Stock Evo?
- help with engine misfire/stumble
- gearbox really hard and reverse wont engage
- Stupid Curbs...
- CIMotorsports.net...Be Warned
- Used Fuel rail and Used walbro 255? good or bad idea
- Need Advice on front LSD and ACD
- Need help Identifying this Air BOX
- Car randomly dies
- Fuel pump relays?
- Bad misfire @5-6k...help please
- thanks to ivey tune
- Dreaded code 82
- found the issue with my transfercase
- Need my clutch replaced. Know of a good mechanic/shop i could go to?
- 600hp on 93 pump gas
- Qtp cut out, do u really need a retune
- Huge puddle from transfer case
- oil return line what happens if its too small
- Help finding metric gauge options
- my evo making weird noise
- Ignition Fuse keeps blowing
- Transmission Drain Plug Stripped
- No CEL ?
- Crank Sensor Plug
- mods advice questions
- Shop didn't bleed ACD pump after clutch install
- Rebuilt the evo, but having issues under acceleration
- IC pipe couple size?
- Evo 8 Fuel pump check?
- what should my next step be?
- Takata harness question
- clunking sound from front end
- External Wastegate O2 Housing
- Painting the valve cover?
- Speed sensor A malfunction?
- general question about hub bearing
- Edge Insight CTS for Gauges?
- What manifold is this?
- Low coolant level after a flush
- low oil pressure and oil leak
- What if you HAD to change up from your favorite oil???
- Kracka Crankcase Vacuum Kit; Can someone school me?
- Inspecting my car emissions
- Fuel Injector Question
- Who has knowledge on back of stock evo 8 headunit
- Will fuel pump hold out?
- How to remove radio/storage trim on Evo IX
- Harness plugs?
- HKS Kansai Box VS APS Cold Air Intake
- Building MOM her EVO..
- Evo on the Dry Lake Bed Drifting with Aerial Video
- Look what I found in my throttle body!
- ????Stupid question (tune or no tune)????
- Need help evo x wheels on 8
- How to tell if it's tuned ?
- What is the Fastest you've gone in your Evo?
- Alternator issue- fusebox MELTED!
- Cross threaded idler pulley bolt from the factory!
- 2006 evo mr cuts out/back firing under heavy throttle.
- How much heat.......?
- Couple NON Important issues I have
- Opinion and advice buying a car out of state
- Front sidewindows different Evo vs Lancer
- brake pads for evo 1 to 5 where to find in usa
- Headlight Question
- How much boost?(evo 8 MR)
- 91 octane on stock car
- Where'd you buy your EVO from?
- dipstick popping out
- Wheels locking up?
- Is a tune needed for adding a MAF adapter and cone air filter for an EVO 8?
- Resonated O2 dump?
- Lots of parts from the same store?
- Anyway to get better than 15mpg
- lowering evo without rubbing
- cold start idle problem
- What's up with e85
- Victim of Texting and driving.
- What do I do?
- EGR Evo 8 Question
- Stock cams?
- 400 is the goal
- How to drive a turbo
- Dilemma which option to go with.
- Trans problem!! Please help!!!
- oil on transfer after car sitting for a year
- timing kit & headstud labor cost
- Car shut down
- 03 Evo Heater/Fan/AC Knobs hard to turn
- Tranfercase whine... shop never changed fluid...
- Previous Owner Accident. Dealing with it. Got a few ?'s
- current jdm bumper prices
- difference between JDM & USDM non-HID VIII headlight assemblies
- Ureathane or metal shift base bushings?
- A picture of my car engine i need some help
- Wiring Diagram Question: Evo IX
- Friend driving = blown motor?
- 3rd grinding noise
- VIS Racing CWest style front bumper fitment-EVO 9
- Math question on numbers
- How Can I Make My Stock Evo IX MR SE Look More Professional and Subdued?
- Whistling Noise plz help!
- Engine misfire codes and foot well problems?!
- "Brick wall feeling", building boost in neutral, random idle drops, ect.
- JDM Diffuser color ?
- Looking for an APS Twin vent
- lancer evo acting up again
- Anybody going to daytona 500???
- any other IX's with low miles like this?
- Evo Died While Driving. PLEASE ADVISE.
- offset and backspacing
- Wheel bearing issue??? Or more...
- No power when ignition is off
- Blown Head gasket?
- trunk swap question
- grinding in brake pedal
- How many Guys still run Apexi AFC & AVC-r and Ecuflach
- a problem evo, to sell or not to sell.
- Ac Compressor failure
- My car's spool is slower now. Help!
- first evo, evo 9. engine problems. help
- LICP blowing off... ah...
- Vac port on intake
- Boost leak?
- code 82
- help me identify this
- quick question: Is this a missing hose line?
- E85 vs Q16 at Same Boost
- Need info on an exterior piece
- Full tank Walbro install?
- s205b turbo
- Looking to get a new header....
- Farmington Dragway Video
- What would it take to make 450-500whp?
- Removing under cover
- heater knob
- fuel pump/filter
- HVAC gears
- evo 9 running rich bad gas mileage
- o2 sensor code brand new o2 senors!!!!!
- Future of E85?
- 5858 on stock manifold
- Oil leak - Gasket spray question
- Evo VIII and EVO IX
- good read on e85
- Evo 8 rs xxr 527 wheels
- Help identifying a seat
- It's that time of the year again...
- Woo hoo! I finally secured an MR!
- Evo 8 rs oil catch can
- clunking
- Using oil? Help
- classifieds?
- Timing belt replace?
- Pulling my hairs off
- Mini Battery
- disassembling the wing
