PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Evo 5 speed transmission weight?
  2. High compression or what?
  3. Need some help from you Rally / High Dust guys
  4. Help with my build!
  5. Evo 8 front clip???
  6. adyno and or dinodyno android.
  7. A/C question "I broke it today"
  8. blower fan lvl only works on 4
  9. Whos RUnning a TIAL Q with no issues?
  10. My Evo Blog
  11. 2003 HVAC Issue?
  12. Geometry adjustment for EVO IX MR
  13. Quick question Evo 7 fuel problem
  14. EVOlutionary and Bruzewski Set Their Sights on ONE LAP OF AMERICA
  15. Anyone know the cost for VIII front fenders?
  16. Hallman pro vs pro RX
  17. Dyno FAIL!!!!!!!!!!
  18. Discussion about idle, dow321 sealant, BISS, ISCV, etc.
  19. Help meee!!
  20. Rod and Crank Bearings
  21. HELP!!! po112, po113, po122 HELP
  22. Has anyone used this?
  23. 5 speed to 6 speed swap speedo doesn't work??????????
  24. help rough idle n sputtering after 3000rpms. ive searched a lot!!!
  25. Where to get?
  26. Stance coil-overs for $800 obo in Orange County-please move to sale setion!!!!
  27. Another weird thing
  28. VIII vs IX starter?
  29. Buschur Racing open Saturdays???!?!
  30. Sequencial Shift Light Range
  31. aem wideband wires cut
  32. Everyone read this!!
  33. Multiple relays on one circut?
  34. Tanabe dp
  35. Is it possible???
  36. few fuel pump problems..
  37. HKS Mivec 272 cams?
  38. Car shut off, now wont start
  39. Do I need a tune after switch of FP 18 to 25psi Wastegate
  40. Whats up with the rude people on here?
  41. Fouling plugs every 200-250 miles?????????PLEASE HELP!!!!!!!
  42. Possibly dumb...but how do you remove the Mivec cam gear
  43. where should i buy my led interior lights??
  44. Good HID bulbs?
  45. Replaced fuel pump twice, dealer still says it's bad?
  46. who has actually has the balls to jump there evo
  47. $25 BSE Kit?
  48. why changing from 2.3 to 2.0?
  49. push through clips for slim fan
  50. WeatherTech Digital fit - floor mats
  51. MUSE IC pipes backorderd, wait or get weapon r?
  52. 2006 Evo IX Car won't start
  53. Feeler full ac setup
  54. Fuel Level Reads super low starting around last 1/4 tank
  55. Hopefully switching To Evo 9 From M3.
  56. Evo 8 s poiler colored section falling off
  57. car won't start
  58. Idle causing me a headache!
  59. Starting All over Again
  60. hard brake padel under boost
  61. p0134...sensor bad?
  62. no spark?
  63. BOV Placement
  64. Win a Sony Playstation 3 (PS3) or Gran Turismo 5
  65. Original 2003 battery
  66. Yakima Roof Rack Question
  67. noisy walbro fuel pump
  68. remove top dash panel or whole dash
  69. Evo 7 Wing Adjustment
  70. rs or cf lid??
  71. Does anyone have the rexspeed c/f ebrake handle?
  72. search Ignited Performance Panel
  73. Voltec Diffuser help!
  74. It's been awhile
  75. Weird fluttering noise
  76. ACD question
  77. idle issues
  78. Help: Broke Radiator overflow "Plastic bung"
  79. Scared stupid
  80. Vortex Gen color??
  81. gymkhanagrid live qualifying
  82. Fuel cut?
  83. o2 sensor question
  84. WTF:engine revs itself
  85. Dyno nightmare!
  86. Wideband o2 replacement
  87. S7 Gauge Overlay?
  88. new'ish evo guy
  89. Jerks after shifting with heat on
  90. Anyone have pics of their car with tein s techs?
  91. Water pump pulley pop-off
  92. My Evo shuts down
  93. timing belt; necessary to lock oil pump shaft?
  94. quick question!!
  95. Fp Red Internal Wastegate
  96. need advice on choosing a new turbo setup
  97. IAC testing question
  98. burning oil
  99. WATCH OUT FOR!!! Oracle Lighting Also knowed as AAC
  100. What to do with stock MR gauges
  101. high idle on stock 9
  102. Gates Balance Shaft Belt
  103. Radiator Install
  104. AIT JDM style rear bumper look-a-like..
  105. gear box
  106. good?
  107. Gas Mileage Real numbers WOW!
  108. Fujitsubo from drivline motoring
  109. OEM HID Replacement
  110. signal lights in headlight housing wont signal.....wth?
  111. Anybody had any experience with this after market fender?
  112. how much power???
  113. Torn Coolant line ?????
  114. Air Filter Replace Question
  115. holes in manifold port? your opinion needed
  116. Evo 4 motor build
  117. will upper dash panel from Lancer fit Evo 9
  118. Cold start slow crank
  119. Winged wheels
  120. WTB a power steering pump!!!
  121. ECU codes and unknown PO037
  122. Please take a look and tell me what the hect is going on
  123. Spoiler mounts rusted off!
  124. Lsd diferential
  125. Cold Start issues after Walbro install
  126. Coil on plug help! (pics inside)
  127. Just picked up an evo, having some problems.
  128. Best Glue to use to Seal Tails after open
  129. ** Uncle Sam has called so its time for a ROAD TRIP**
  130. Tips for a new EVO
  131. Noise
  132. Car keep dying at idle to low rpm
  133. Wilzig Racing Manor
  134. Wilzig Racing Manor
  135. Red 6.5 TME in Va
  136. Are these guys legit???
  137. engine harness problem .... need help !
  138. Polished diff fluid resevoir
  139. Read These Plugs
  140. Plugs
  141. Engine rattle(IC pipe)?
  142. Team AMSOIL/EVO
  143. Evo 8 Engine Relay
  144. Urgent need of Brake pads
  145. Happy Thanksgiving!!
  146. New noise
  147. got my car back today!
  148. Fuel gauge fluctuating. Only reads 3/4 full now!
  149. fp red or cams and the stock turbo
  150. How much should I get from insurance?
  151. Help with annoying Clutch engagement issue. Hd Video inside.
  152. Fenders?
  153. SRS Questions
  154. Funky Rattle
  155. hks ct200mr?
  156. I think I fried my ECU after installing turbo timer
  157. Adjusting Auto Turn-off Headlights
  158. Well at 224,700 Miles I rear ended someone!!
  159. Paint stripping from CF fenders
  160. Evolution icons for Garmin GPS
  161. Hesitation/Pulsating?
  162. Odd noise only over 20 mph
  163. EVO IX MR 6SPD WHP & TRQ #'s....What do you have.
  164. Weird Idle issue
  165. Adjustable power to wheels??
  166. oh..my.. look what i found..
  167. Lost Vacuum Hose
  168. any one know how tsudo echaust are?
  169. Change Rear Axle Boot
  170. WRX to EVO... what to look for
  171. where can I get an Evo shop manual?
  172. HELP! What is this noise? Have you ever heard it?
  173. Where to buy Mitsubishi specific tools???
  174. Help...Installing Oil Pressure/Temp Gauges
  175. EVOdoug's Build Thread
  176. Valve Spring Compressor Tool
  177. RECALL anybody used this one??
  178. Restoring Our Brembo's To beautiful Conditon!!!
  179. Blew something at the track... another stock block done :(
  180. Voltex Replica Kit
  181. Intercooler good or bad?
  182. How many people compliment your car daily?
  183. Evo 7 AYC differential
  184. Blew my motor!! so much for the FP Black on the stocker!
  185. what is faster?
  186. Headlight issue
  187. New Evo Owner
  188. titanium exhaust question
  189. some work i did on a EVOCOLT/COLTEVO
  190. I got a leak!! D:
  191. Changed Battery = Stalling Idle
  192. MR Oil Temp Sensor
  193. EVO8 Cat
  194. Any place sell the SE front lip NEW???
  195. Options for wider fenders?
  196. Cinderella needs your help
  197. Slightly louder than a stock exhaust? HKS Sport
  198. Crasy Thing!!! Anyone have any suggestions??
  199. CF Restoration
  200. Getting slower?
  201. Speedo Issues
  202. Major WTF is going on thread!!!!
  203. Overboost w/ CEL. HELP!
  204. unsprung weight research(rotors ect)
  205. Underpanal fasteners
  206. Why is my turbo timer transponder box ticking?
  207. End The Season For My AngryEvo8
  208. Help!!! Fuel shut off after accident
  209. need some advice
  210. VIII with a radiator leak, cracked coil
  211. Wideband Issues
  212. Clutch Grind when going incline
  213. evo 8 oem headlamp lens
  214. evo sounds like a wooden rollercoaster
  215. carbon fibre items?
  216. turbo.. pop... ??
  217. Double Dinn and Gauges. Where to relocate? I hate the Pod Pillar
  218. ebay floor mats?
  219. Any good shops in Cali that specializes in clutch installation?
  220. Front Wheel Drive? Help?
  221. Headlight & Fog light Indicator on Gauge Cluster Out
  222. Boys and Girls, Be Safe On the Streets!
  223. Steering wheel rewrap
  224. anyone uses BC Racing coilovers?
  225. How many miles on tank?
  226. doing some service on my evo 9 soon
  227. Porting Head??
  228. emissions problem
  229. 1320 engineering hid kit? good? bad?
  230. Boost Issues
  231. Evo IX turbo vs Evo 8.5 turbo
  232. How much to fix or change a gear box??
  233. hardblocking an evo
  234. Am i missing a piece?
  235. The Best Buy
  236. Small power band?
  237. buschur exhuast with titec 02
  238. evo 9 mr questions
  239. Help with Salvaged 2005 Mitsubishi Lancer Evolution 8
  240. Clutch feels weird help!
  241. Buddy Club Bucket Seats?
  242. 2006 Evo VIII MR headlight & tag light problem
  243. My evo met a guardrail :(
  244. Shell build up
  245. My Evo Was The Victim Of A Hit & Run
  246. what up with fp blacks for sale?
  247. help finding a hks iv 4 evc power harness
  248. High altitude... lets set some things straight.
  249. Coilover FAIL!!!
  250. Emissions testing
