PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Is this a HKS RS Intake for a Evo VIII?
  2. How do you learn how to 'do-it yourself'?
  3. The Nurburgring, my first visit
  4. 8 to a 9 turbo swap questions
  5. Introduction/looking for advice
  6. mild whine sound 2003EVO8
  7. how do i fix my carbon fiber wing
  8. Evo threw a code today ( P0S07 ) Anyone know why it did?
  9. Smoke Coming From evo8 hood vent
  10. Mosiacmotorsports.com question
  11. Wrong bumper lip
  12. about jdm heads...
  13. Budget track car: Evo 6.5 RS
  14. im a noob n i need help
  15. must be a record... Somewhere...
  16. need help on drive shaft
  17. Buying used, what to look for?
  18. Anybody can source me an EVO 4 Owner's Manuel
  19. wheel offset?
  20. Should I use a oil cooler on a built motor ?
  21. Is it safe for passengers to ride in the back with a harness bar?
  22. Help: Cylinder not firing
  23. NEED a local shpp in the Knoxville, TN area to do some work on my EVO
  24. Odd mild Vibration when turning
  25. 100LL mix?
  26. Broken 6 speed
  27. Need estimated AWHP on a setup.
  28. Ses Light: PO505 Code
  29. FMIC Coupler size?
  30. Prosport Wideband 02 sensor
  31. a pillar question
  32. Electric Fan w/Evo 5 Radiator
  33. Intercooler couple question (quick and easy)
  34. My interview with Gearbox Magazine :)
  35. Evolution IX MR Alarm
  36. Thinking of leaving DSM's or an evo, which parts can I take with me?
  37. Gruppe-S 3Port Issue? Throttle-Flutter?
  38. best aftermarket floor mats
  39. clutch pedal adjustment
  40. Charging a brand new battery?
  41. Is this sound normal?
  42. anyone have the same problem???
  43. Turbo Torque Sepcifications? Need help
  44. New cams mivec problem
  45. My VIII is down with a blown motor!
  46. Clicking while braking
  47. what a tuner and engine builder does on his day off!
  48. Need help on removing a broken bolt
  49. I need a shift light
  50. Putting the Evo away.
  51. Deak's Silver Bullet Build / ETS, MAPerformance, Sparktech, CBRD Review
  52. Goodbye to my IX
  53. Evo too fast for Gallardo!
  54. Problems with Injectors
  55. Heat Shield Blanket for FP stock appearing turbos (FP Red)
  56. Don't know
  57. evo..rebuild.......sooooon n very
  58. The day has finally come...
  59. Evo 3 questions
  60. Anyone know where I can get a good, cheap, short throw?
  61. Gauge Needles not lighting up
  62. Engine harness quick disconnect
  63. Radiator Cap Size?
  64. Evo VIII electrical diagram (need one!)
  65. timing belt install procedure
  66. what going on with my car?? help------
  67. Could someone with an evo 8/9 do me a favor???
  68. Help with Stock radiator fan motor
  69. Is SMC out of business???
  70. Wiring question
  71. cat bolts
  72. X wing on IX or VIII
  73. VIn numbers on motor?
  74. Rear wiper delete fluid issue
  75. normal for a boost gauge to do this??
  76. Competition Twin Disk info
  77. AC help
  78. Need help on deciding which injectors to get.
  79. Timing Belt
  80. Center Gauge Cluster
  81. Magazine help
  82. I need help
  83. head gasket
  84. Will 2006 lancer driver side window fit to 2006 evo ix ?
  85. AMS fmic and ETS pipes
  86. access to mut3
  87. how did you guys wire up your AEM analog boost gauge?
  88. Evo IX on Bullrun '10
  89. Evo vi?
  90. Evo Badge Font
  91. Valentine's Day Disaster
  92. mods no dyno tune= very noticeable lag?
  93. Buying an Evo9.
  94. p0335 crank no start after head install
  95. help please! i just finished install on new cams
  96. Stock pistons?
  97. Any luck with Lamin-X?
  98. I just wanted to say...
  99. need help with purchase
  100. Replica TailLights Question.....
  101. evo 8 02 divorced downpipe
  102. Carbon fiber trunk with stock wing
  103. car die's when lights are turned on. why?
  104. wastegate being pushed open?
  105. possible to fix a hood?
  106. HELP! drivershaft
  107. steering wheel hub kit
  108. What side spat is that?
  109. Megan racing catch can help
  110. Abs light on all time no fault code
  111. Smallest size injector for e 85
  112. Headlight flicker? help please
  113. stock guage cluster bulb out!!!
  114. any source on OEM style Evo 8/9 headlamps?
  115. Evo 8 motor need asap!!!!!!
  116. Need some wiring help!
  117. Evo 8 to 7 Rear Bumper conversion?
  118. Grinding when turning right?
  119. 3 acd lights
  120. Do you disable your clutch switch?
  121. Help w/ deciding on a Body/Wide Body kit
  122. CF hood which dampers to use?
  123. Dual A-Pillar
  124. Concern with getting a Tune
  125. Whos Car?? What Difuser??
  126. Project
  127. Upper Intercooler hose replacement
  128. Anyone know evo8 seat spacing measurements?
  129. Coolant Overflow Hose
  130. compression surge whats the deal
  131. ODB2 bluetooth + phone app ???
  132. White only comes in MR or RS..true?or False?
  133. Car will not start once turned off and try to restart on hod days
  134. Any particularly good online sources for discount OEM parts?
  135. Vibrating/rubbing noise when full steering lock ???
  136. Need help (missing key)
  137. UICP Blowing Off Throttle Body
  138. Evo Ix Mr vs a regular evo
  139. 3 " uicp to big?
  140. Damaged EVO IX FMIC
  141. No more chevron...
  142. Do my AFR is right
  143. Some EVO III info please
  144. Would an Evo VII CF spoiler fit an Evo VIII ? ?
  145. crank sprocket slipping on timing belt
  146. I need one of these. Check it out plz.
  147. B-day Presents
  148. Car Covers which one!!!!
  149. I NEED INPUT ON 2.0 or 2.3
  150. boot lid tension
  151. Looking for some upper intercooler piping
  152. Farewell 4g63, my DSM/Evo days are over...
  153. Please help!!!
  154. stripped bolt holding trans to motor What to Do now?
  155. transmission removal issue
  156. Evo 9. What is this
  157. Oil leak need help---------
  158. Buzzing shifter caused by a little spring
  159. Rain = Sputtering?
  160. The ex Traded in her 06 EVO 9 for a BMW.....sad sad days!!!
  161. BR-Stage 3, ported manifol....need to make a quick decision on meth kit
  162. Idle issue
  163. Radiator Fan Control Module
  164. Lowering the car with an SE lip
  165. Seibon CF hood with stock vent...
  166. New to EVOs and looking/possibly buying an 03 this Thurs...help/advice/knowledge!
  167. Trouble shooting the drivetrain
  168. Opinion on spark plugs!
  169. noisy fuel pump
  170. wats wrong with my evoIX ?!
  171. EVO at RedLine Time Attack
  172. Testing the Go Pro Hero.
  173. Please help! Axle Shaft threading damage
  174. K&N drop in filter
  175. does evo 8 rotors fit evo 6????
  176. 06 graphite gray Evo IX rim suggestions?
  177. 10.5 hotside?
  178. Keyed!!!!
  179. New Black & Blue EVO VIII
  180. about tune after intake install
  181. Now accepting Forum Wars Season 2 preliminary apps
  182. Evo dies because of man's ass
  183. I got my golden ticket!
  184. 06 Mr is it running correctly?
  185. Help Identify This Single DIN Tripple Gauge Setup
  186. Question for those with Evo VII JDM Taillights - Where is the red coating?
  187. TIRE SMOKE & RACING ACTION! Watch the 2010 Nitto Drift Teams Tear It Up [VIDEO]
  188. Evo back up and running
  189. 4g63 internal differences
  190. hks cam install issue:(
  191. Help the 8 won't start.
  192. HKS timing belt
  193. Bad alternator?
  194. Demon-Carbon-Fiber-Trunk aka Do-Luck Replica?
  195. headlight fading
  196. need some help
  197. What are the different clock wires?
  198. Calaway Road
  199. 80w nokya hyper yellow 2500k h11 headlight fog bulbs
  200. my heat doesnt work help
  201. EVO IX MR 155,000 mile maintenance
  202. Holy hole in the block!!!!
  203. New owner in trouble
  204. Formula drift road atlanta 5-08-2010. Lots of pix.
  205. Ugh need more help!!!
  206. Evo 8 non fogs to fogs????
  207. Service Engine light!?
  208. Someone mooning causes evo crash
  209. What should I do with my Evo?
  210. ETS LICP Owners
  211. CBRD Spring Dyno Day
  212. peakboost where'd u go ???????
  213. Where to buy clear side markers for the front and rear?
  214. epm 02 dump?
  215. Gonna start a new gig, Daily "Whos EVO is this?" (pictures of evos from the auction)
  216. Mechanic for the EVO
  217. Changed Spark Plugs, Car died from Cold Start
  218. exhaust, mixing & matching Cobb w/Buschur
  219. timing belt?
  220. Found a Evo in Brooklyn, need opinions
  221. Quick walk-through video of a 500whp IX
  222. high rpm grind in 5th issue
  223. License plate frames
  224. Anyone know where to get new inner skirt liners (behind the fender)
  225. Check engine light?
  226. Right Side Splash Shield part number
  227. Loud spool issues
  228. Suggestions on MODS for a IX MR?
  229. Where to find Evo 7 centercaps?
  230. Shep tranny problems
  231. Just came across this obx fmic
  232. Evo 8 Approximate Roof Measurement
  233. HELP! Car won't start!
  234. Need to get a race bumper install ASAP
  235. ACD pump question
  236. evo 8 short block in evo 9
  237. Something big soon
  238. Do Non hid and hid headlights share the same housing and projector?
  239. need help with bumpers for Evo IX
  240. gauge pod
  241. Lights on or off?
  242. Hpautoworks.com anyone use them before?
  243. Boost issues
  244. APS discontinued
  245. LancerFreak311 is back! Lookin at buyin an Evo (finally)
  246. Sound deadening... Where, how, and how much?
  247. Need help with Transmission
  248. Evo got knifed BUT it's being ressurrected!!
  249. Misfiring but not throwing a code????
  250. Check Your PCV.
