PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Anybody using a VIS Racing MR EVO 9 Bumper with the SE Lip?
  2. My "new" calipers
  3. need a catch can? 500hp stm/buschur
  4. AEM intake
  5. Shifter hard? stays in weird locations? Cables?
  6. carbon fiber hood help
  7. HELP electric shorts
  8. Buschur racing build opinions
  9. hks rs intake review?
  10. Egr cel please help me
  11. nobody has a double pumper in stock??!?
  12. Evo VIII vs new STI models
  13. fuel injectors
  14. Have a questions about a bov
  15. Plugs and coolant
  16. Evo 8 Roll Cage
  17. Rando hose to nowhere by fuel lines?
  18. Double Pumper or In Line Fuel Pump Set Up..?
  19. Help please
  20. Car "dieseling" after ignition off
  21. need advice
  22. megan racing dp v2
  23. Rexpeed exhaust shield
  24. aftermarket BBS lugs
  25. Evo 8 and Evo 9 Steering Column Covers The Same?
  26. Strange fluid appearing on hood
  27. Tomei Expreme Ti
  28. Anzo headlights?
  29. What do the letters mean on a turbo?
  30. quick question on BR double AN style
  31. track junkies, I have a question about front member power brace.
  32. Turbo Timer Hardwire Question
  33. new fuel system needed! vendors chime in!
  34. my evo 8 acting up today, opinions?
  35. System rich...injector?
  36. afr
  37. Need some guidance throwing P0011 AGAIN!
  38. 4g63 Stock Crank Journal Sizes/Measurements
  39. Options for upgrading an VIII 9.8 turbo?
  40. Which Lug Nuts
  41. Timing belt help
  42. EMail Tune - Mellon vs English Racing
  43. Rexpeed vs Ebay side spat
  44. suger in gas tank?
  45. FP Black with Stock 8 turbo with 10.5 Turbine Housing?
  46. CBRD- unveiled- 2013- Pics
  47. Weird colored badge question.
  48. who makes a good effective 3" resonator?
  49. Seatbelt bolt question
  50. Evo X turbo
  51. Turbo Decision
  52. Reliable decal vendor "Brembo"
  53. DP doesnt fit! help
  54. dsm 7bolt in evo 8?
  55. Question about vacuum at idle
  56. Best price ID2000 inj?
  57. regarding 60k maintenance
  58. Intake for 35r
  59. Stock Evo9
  60. I need BIG help...
  61. Beatrush Aluminum Underpanel w/ dzus fasteners worth the money?
  62. Rear Shock Adjuster Access
  63. evo 9 wont start after timing belt
  64. Exedy Twin Plate Clutch
  65. So what does it take to switch to E85?
  66. Stock cams to s3's
  67. Oil analysis of 176,000 mile Evo.
  68. Stock to Rally'ish suspension?
  69. Oil Gauges and Turbo Feed Line
  70. OEM aluminum trunks
  71. Oil coooler/Brake ducting
  72. Bust my Evo's cherry?
  73. simple question on the front bumper
  74. Where to buy; Jay Racing/Timing Belt tools?
  75. obd2 port, wont connect
  76. Drag Racing setup with street drivability?
  77. Buying EVO IX SE. HELP!!
  78. Evo 8 ppm question
  79. Transmission parts diagram, mitsubishiparts.net help
  80. Reliability of long drives with built motor
  81. Evo IV Replacement Turbo?
  82. anti-surge ports hurt spool?
  83. Good 4g64 downpipes?
  84. Help with HIDs
  85. Multiple Evo owners, stand up!
  86. running e85
  87. LC-1 Logging through USB
  88. Heater has quit blowing hot
  89. Cut timing belt in half to install?
  90. Strut Install...
  91. Alarm, disable imobilizer
  92. P420 Code Rom Related?
  93. 3 Power Lines
  94. aem error when logging afr
  95. nice intercooler
  96. 06 bumper on a 03 evo
  97. Wiper malfunction but wires are dry
  98. Looking for undercoating - Upstate NY
  99. Standing mile anyone?
  100. Car sounds supercharged?
  101. Help Evo 8 Tail light bulbs
  102. Evo Engines
  103. Rear windshield troubles...
  104. Cheap Do-Luck style lip
  105. Finding a stock UICP coupling replacement
  106. I know evo's are known to make some strange sounds...but...
  107. S3's on a small turbo
  108. question for the small battery guys
  109. MAF replacement/fail
  110. Burning clutch smell...help a newbie out
  111. Small thing on the back?
  112. How much?
  113. Carbon fiber center console
  114. Another Evo Gone =(
  115. Exhaust install question
  116. Cam Guru Help Needed
  117. What shift boots do you guys have?
  118. Importing to quebec
  119. please help!
  120. CBRD Speedfactory 2013 - Bigger & Better
  121. Where can I get
  122. Car charger problem
  123. Evo 5 AYC Swap
  124. drivability and life for quartermaster 8 leg.
  125. Evo 8 - No Electrical Power - Good Battery
  126. Evo 8 rear wiper stopped working...
  127. Does any 1 in the buffalo ny/wny have tactrix cable?
  128. Evo 8 MR style headlights
  129. How much should I pay for a used EVO 9 bumper?
  130. Motor/Legal Advice
  131. Tax Return sales
  132. English racing cams?
  133. Perrin tbe video
  134. What size bolts and hardware needed to mount oem wing / spoiler on?
  135. E85 Content Analyzer (Zeitronix
  136. Mirage coilovers similar to Evo V?
  137. anyone know ?
  138. Teaching my girlfriend how to drive the EVO
  139. A break from "show", want a little "go"
  140. Will lancer inner fender fit evo?
  141. Where's the throttle plate stop set screw?
  142. Best way to remove something that melted to my Titanium exhaust?
  143. headlight issue
  144. Tip on Searching
  145. Downgrading my fuel system?
  146. Antena broke off... Now what?
  147. best day ever!!!
  148. ebay stock exhaust manifold?
  149. ATF SP III Fluid Control Diff - What Fluid Is Used?
  150. Part compatibility question
  151. New engine or block?
  152. Wastegate muffler
  153. Defi Control Unit Question
  154. EVO IX Interior "dummy" panel
  155. Looking for an "Evo Family" pic I-X
  156. Fitment question?
  157. Recently hit 100,000 miles....now what?
  158. aftermarket bushings?
  159. Experience with waterless coolant?
  160. Compression Test Question
  161. HKS DLI removal?
  162. evo8 starter signal cable were does it go
  163. Flutter Problem
  164. What is this wire?
  165. Canada
  166. Help please!
  167. URGENT HELP NEEDED: Ebrake Shoe Assembly
  168. 6 speed short shifter
  169. Putting the Evo 8 back on the road...
  170. To all you Coloradans or any knows anything about elevated tuning...
  171. Evo 8, salvage question.
  172. Gauges in the dash trim?
  173. Hallman pro bc install
  174. Any Evo owners still using the (original) stock clutch?
  175. Evo VIII
  176. Sandblasting
  177. Where to buy Stainless steel flex section....
  178. Windshield Gauge Pod - Anyone?
  179. NJ: JDS Motoring Track Day @ NJMP!
  180. Windows?
  181. Goodbye OEM battery!
  182. code P0117 - need thermostat housing schematic
  183. Evo 9 Taillights Issue
  184. boost control
  185. modifying my stock engine??
  186. AMS Intake
  187. Anybody near Ventura Ca? Need some quick support
  188. Hey guys I need help identifying these camshafts for the Evo 9
  189. Wrong Oil? What you running?
  190. Evo 9 turbine housing
  191. Chassis question
  192. electrical system completely dead? won't even unlock doors
  193. aiming the EVO VIII head light. (horizontal)
  194. Can't Decide Final Drive Ratio?
  195. Normal Intake Air Temps?
  196. Removing Bottom Dash Piece
  197. Evo starter question for Mitsu guru's
  198. Best FMIC without modding the crashbar
  199. fp2 cams from 97 gsx on evo 9?
  200. pedal stop twin disc
  201. Perrin FMIC fitment problems. evo 8
  202. checking fuel pressure
  203. Oil on piston tops and out of exhaust on idle?
  204. MYstery SOUND watch video n comment PLEaSE!
  205. HID fogs not working
  206. vibration on steering wheel
  207. Well no wonder my car didn't run.
  208. Modded Evo VIII Racing on British Top Gear.
  209. GSC S2 on stock tune?
  210. Help Needed in Memphis
  211. Throttle Body
  212. Service exhaust code.
  213. car shuts off, codes for crank and cam sensor
  214. Any one had any luck selling their Evo on eBay?
  215. Out of fuel at 20psi???
  216. xxr527 wheels and tyres
  217. Stuck on which upgrades?
  218. Will stock plugs do me any good? HELP!
  219. DDM HID install on my 9 - unsuccessful
  220. Evo baseline maintainance questions
  221. transfer case noise & long trip
  222. Screw with broken head
  223. Help please..2 issues.
  224. walbro 255 help!
  225. Floor Jack Points for Lowered Car
  226. Is evo 'real' full-time AWD?
  227. what is the best intercooler on a budget?
  228. Alarm issues?
  229. greddy type s pdf instructions?
  230. Eratic Idle?
  231. Do it yourself headgasket?
  232. Need Advice ASAP! Relay clicking, gauge cluster always lit with no key in!
  233. Do-luck REP eBay lip kit for Evo 8
  234. What fuel pump should I go with
  235. JDM Evo Rear Instal question.
  236. goes into all gears but will not budge
  237. Why does my Radiator fan turn on when cold/hot?
  238. tolulene mix.
  239. Locked my car with key in ignition!
  240. Help! AMS VSR intake manifold? map sensor
  241. door beeps with door open after disconnecting battery
  242. anyone running a CX Racing Intercooler?
  243. Evo IX Gasket failure on dyno
  244. IX Front Bumper Removal?
  245. Idle problem? Cold starts? Running to rich? HELP.
  246. Shifter knob loose?!?! Please help!!
  247. Shifter
  248. belt chirping, gets worse
  249. Can I import my 1999 Evo 6 to the USA?
  250. Whats next??? Help! =)
