PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Injector testing
  2. Help! evo5 bodykit
  3. Amsoil dealer
  4. Evo 8 temperature gauge
  5. Old timer, thinking of getting another but torn!
  6. steering linkage issues
  7. Price check Evo 9 TB 86k Miles
  8. Any Good Tuning Shops in Las Vegas?
  9. Can anyone take a look at my launch map?
  10. Hood dampers For carbon hood.
  11. afr/timing fluctuations/idle issues
  12. Safety recall questions
  13. Mysterious noise, HELP!
  14. Undercoat?
  15. oil smells of gas
  16. Window regulator
  17. Evo 8 5 speed to 6 speed mr swap help parts
  18. In StockACT Sprung Street Disc w/ HD Pressure
  19. Where does this wire go?? (Evo 8)
  20. Hi! I need some help with my Evo 8
  21. Anyone know if mitsubish dealership will install a oem engine
  22. Price check on a 2003 Evo 8
  23. evo 8 thrustplate
  24. EVO 4 Raliart 300kmh cluster
  25. Evo Wont Hold Idle FF Turbo SD
  26. ISO: Evo IX Rolling shell
  27. Evo 9 vs Evo 8 Front Bumper Cover.
  28. Tomei usa vs tomei japan
  29. What is in higher demand?
  30. Is it worth installing new rings and bearings?
  31. fastest evo 4
  32. Evo 9 mr 6 speed
  33. Underglow fitment
  34. need help with wheels and finding a member
  35. What plugs into this harness?
  36. Starter trigger wiire
  37. Evo 8 trade offer. Reliability?
  38. Thinking of relocating CT9A battery to trunk, fabricating a box and rewiring?
  39. 450 pump install
  40. Transmission Leak Help !!!!
  41. Does any 7-bolt Pan fit on a Evo 1 7-Bolt 4g63t?
  42. Help please
  43. Evo 8/9 Wing Re clearing
  44. Moving to Jefferson county co.
  45. Best oil on stock motor/bolt-on car?
  46. do Evo 8 mr headlights fit in Evo 7?
  47. Voltex Bumper Side end pieces
  48. OEM Mitsubishi Parts
  49. Any self-proclaimed evo 8 experts out here
  50. Another clutch thread
  51. Where to safely jack up and place jack stands on Evo 1
  52. Ebay Side Markers
  53. EGR Intake Manifold Port Question
  54. Which Evo to buy?
  55. Another milestone
  56. Disconnect clucth interlock switch?
  57. Financing evo IX
  58. New to evo's, buying one, wondering how much I can flip this.
  59. A/C component compatibility
  60. Fuel Pump Issues
  61. Carbon Fiver Vortex Generator
  62. What do you guys use to cover hole in bumper?
  63. Should I trade my STI for an Evo 9 MR?
  64. Only 150+ miles on tank!!! Evo 9
  65. Identify this connector (searched)
  66. Interchangeable parts with evo 7
  67. Need help figuring out this noise! Video
  68. Looking to get Evo 9 bbs rims.
  69. Headlight wire
  70. Evo 9 Tank Not Filling Completely
  71. Intercooler and charge piping
  72. Evo 7 sunroof and drivers window doesn't work at all.
  73. Rpm drop after launch & shifting
  74. Radiator fan control
  75. Tial q
  76. Factory Jack vs Jack Stands
  77. Help me thread ? Idling high
  78. Service Engine light Flashing while using launch control evo 8
  79. Help me identify this cut wire under dash.
  80. Electrical issues...
  81. A/C is popping the 10A fuse - Help?
  82. Outside Door/Windows Trim
  83. Evo 8 hood/bumper on Evo 7?
  84. What is this for??
  85. Looking for EVO 9 MR full built
  86. Radiator
  87. Repairing wing mounts
  88. EVO 7 directional AC fan not working??
  89. Evo 6 coilover help
  90. Arc intercooler Evo 8 compatible to Evo 9
  91. front crossmember bolt/thread sizes
  92. Evo IX MR w/175k Miles - Rebuild or..?
  93. Help!!!! Need A/C male connector
  94. Thermo fan adjustment issues
  95. Carbon Creations Carbon Fiber Fenders
  96. Car is running 11.1 with OG Green @ 123 mph....changed to ef4 dont like it
  97. Evo 9 87mm bored out head gasket
  98. In the process of cleaning up my evo 8 engine bay
  99. Might as well start another AC help me thread
  100. 100 octane at the pump in NJ
  101. Your opinion about this evo
  102. EVO 2 RS questions
  103. Running 315/30/18's on a stock* body evo - RS motors evo 9 build specs
  104. EVO 9 VS EVO X - maintenance costs
  105. Another air bag recall?
  106. 2006 mitsubishi galant--rpms drop when ac turned on
  107. Black Ooutline on Evo 8 Windscreen
  108. Just got my car detailed... check it out!
  109. Starting/turning off problems
  110. custom intercooler brace/crash bar
  111. I do not know what this is
  112. Power Steering Loop Delete
  113. AC blows cold then warm then cold again
  114. A/C work on max -- A/C button not responding
  115. Evo IX - RHD vs LHD Steering Wheel
  116. *Need some help* central door lock acting weird!!
  117. Evo 8 Rs Paint Code
  118. Evo 8 undertray
  119. cheapest place to pickup Bride Gias V1 seats?
  120. How to remove Evo 8 MR shift knob
  121. Holes in rear chassis legs, worth replacing?
  122. boost and uego
  123. Horn and SRS airbag light,need help!
  124. Difference Between US Spec Evo 9 and Japan spec
  125. Is anybody using the Duraflex EVO 9 Front Bumper?
  126. Evo recaro seat trim missing
  127. Trunk badge placement on a 9
  128. Hail Damage Evo 9
  129. Need help identifying real or fake Momo Steering
  130. Aftermarket shift knob evo 8
  131. Any cool aftermarket ft Bumpers?
  132. Evo 9 front bumper question
  133. Rust Issues
  134. Torn splitter/lip and what to do
  135. Some days are just bad days
  136. Help!
  137. Snapped ac knob
  138. Request: Under-hood fuse picture
  139. Part number for the fastener/clip for the air vent on the evo
  140. Help me identify correct radiator support part #
  141. Evo 7 GTA Headlight/Signal Issue
  142. service engine soon LIGHT CAME ON! Need HELP
  143. EGR Hose Help
  144. Heater Control
  145. JDM 2003 ECU Lambda Rear pinout
  146. **boostin performance tax return sale **
  147. 15 years with a USDM Evo 8
  148. Downpipes that actually fit FP 02 Cast Housing?
  149. Newbie Evo 1
  150. Coolant everywhere
  151. 8200 RPM Tachometer
  152. Boostin Performance 2.5" Short Route Upper Intercooler Pipe - EVO 8/9
  153. I am so pissed at Mitsu right. ACD pump $2200
  154. Tuning Special @ Boostin Performance - 13% OFF All Mitsubishi Tunes in March
  155. **Boostin Performance Ported Stock Intake Manifold** (Evo 8/9)
  156. Evo7 Loud vibration/buzzing from front of car HELP
  157. biss screw adjustment, but without scantool
  158. 02 lancer air not working right
  159. Low mileage ‘06 MR and Maintenance?
  160. Ordering factory JDM parts?
  161. Need some input on Evo 8 MR
  162. Jesson motorsport mega build thread!
  163. LHD/RHD Headlights compatible?
  164. Sard Fuel Regulator - Real or Fake
  165. STM Clutch Line Help
  166. how do you ship out of state Long / Short Block?
  167. Evo 9 Alcantaras Vs Evo 8 Cloth Seats
  168. Daily evo 1 for newbie?
  169. EVO Search
  170. Brembo Crossoverline HOLE is stripped :(
  171. wheel moves back and forth when lifted?
  172. external wastage setup
  173. Coolant "Leak" Question
  174. All Weather/Weathertech Mats/Floor Liners
  175. What next?
  176. AEM tru boost
  177. Hella smoke
  178. Suggestions on how to ship a headliner?
  179. Aftermarket Wheel Speed Sensors
  180. Scopione Carbon Fiber Vortex Generator
  181. Help: Need 86.5 head gasket 1.2mm
  182. Dimmer not dimming
  183. Seeking opinions on mods/direction
  184. Evo III Import process help(USA)
  185. Special thanks to Matt @ Spoolin Up
  186. slim fan help
  187. SSSperformance Ignition Coil Pack
  188. Design recommendations on a brush guard/light bar?
  189. Best way to check out an evo in another state or across the country?
  190. Downpipe Questions (WTB)
  191. evo 9 front lip
  192. Crank Sensor Air Gap Evo 8/9
  193. Evo wont start, Help!!!!!
  194. 100,000 smiles
  195. Need some opinion on rebuilt title evo 9
  196. Driver door caution/information stickers
  197. Evo 8 - Strange noise around 5500rpm?
  198. Evo ix carfax
  199. Anyone buy aftermarket AC parts?
  200. Another battery and brake light flashing questions
  201. Are the front bumper black foam inserts necessary?
  202. Stupid question about market place...
  203. Aftermarket headlight assemblies
  204. Have any of you guys seen these fenders?
  205. Evo 8/9 - dashboard top removal
  206. cold start nightmare
  207. Evo 8 Having problems
  208. G35R exhaust manifold needed for EVO8
  209. Just bought an evo! having issues though...
  210. Confused about Manley h-beam rod part numbers, which one do I buy?
  211. Synchrotech VS Oem Trans Rebuild for Evo 8?
  212. quality oem bumper replica
  213. Which Evo should I buy?
  214. Evo 8 MR Production Number?
  215. Diaqueen LSD Gear Oil - Discontinued?
  216. Need help identifying an alternator
  217. BOV ring?
  218. Car not starting
  219. Cooling/Heating issue
  220. Wtb Anyone selling any bbs lm
  221. What is a reasonable price for this EVO
  222. Recommended service intervals and oil used
  223. Code error 41-82 pump ayc evo 8
  224. Evo 8 spal fan wiring help
  225. Evo Rear Bumper Alignment
  226. 700+ WHP street owners
  227. Car Security
  228. Leaving the Evo World after 11 years on here
  229. Evo 6 Recaro seat fabric
  230. Evo 9 MR Shifter Trim??
  231. Evo 8 Check engine light - P0243
  232. Help ID Recaro seats 2005 Evo RS
  233. HID headlight bulb
  234. Steering rack ID help please
  235. OBD II Scanner
  236. Evo 4-9 brackets for crossmember mounts the same? Need verification ASAP please!
  237. Fake Walbro?
  238. Mivec gear 14mm hex cap
  239. Evo won't idle at all.
  240. How much is my 8 worth?
  241. Pricing Guide for 2003 Evo VIII 196k miles
  242. Going price of evo VIII rolling shell
  243. Dzus type fasteners or something better?
  244. Sunroof issue (broken parts, not loose screws)
  245. In dash double din w ability to view Evo scan and listen to music/radio?
  246. Possible IX Purchase
  247. Evo 9 APR rep lip
  248. AEM wideband, connect to ECU or serial?
  249. gauge pod
  250. Evo Auto transport....2017 edition
