PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Where to find this fuse?
  2. Weapon-r intake
  3. New Evo VIII owner..help with rough idle.
  4. wierd smell...help please
  5. motegi mr118
  6. My car keeps killing batteries?
  7. IX Front Bumper Hole Plugs
  8. One Touch Window Regulators?
  9. evo 7 expected power.
  10. New GGP IX Owner
  11. Please help identify this bracket!
  12. EVO IX cutout templates
  13. What size AN hose for radiator hose?
  14. Evo 8 stuck in gear
  15. No power evo 7
  16. Easy way to distinguish fuel pumps
  17. Drain plug sensor?
  18. Transmission install done, but is it correct?
  19. On/Off switch for meth and failsafe kit
  20. Original Build Paper?
  21. Transmission fluid
  22. are these numbers correct?
  23. fp flow advancement cover
  24. iat sensor
  25. Help passanger window on my Evo not working
  26. T-Case O-ring - Can I still get this?
  27. Need some help!!
  28. Damage to Rpf1 - Is this fixable?
  29. New compliation! HPF m3, m5's, evo gtrs!
  30. What tail lights do i have here?
  31. Which TiAL BOV is this??
  32. Fuel gauge not reading anywhere near correct
  33. Evo viii idc
  34. dont know where to start !
  35. Horrible rattle when decelerating ( o2 dump related )
  36. Front End Parts Diagram
  37. Anyone Interested in Rep Voltex Double Overs?
  38. MR Trans?
  39. need help
  40. 03 evo 8 performance parts
  41. Tire flat spot = tire scrap??
  42. Stuck throttle?
  43. EVO VI 2.3L Stroker issue
  44. What to do to get more HP out of my evo 8? FP RED
  45. Do I have a blown head gasket??
  46. Wanting more power!!
  47. 18 psi safe?
  48. air coming from spark plug hole???
  49. Bolt covers on the front bumper??
  50. p0630
  51. Dirty Coolant a Problem?
  52. Worth purchasing?
  53. Will removing the muffler in exhaust effect my tune?
  54. ac delete belt
  55. ATTN ebay customers
  56. act clutch problem
  57. Pls Help - Mit Oem 390cc Injector Latency Required.
  58. please help, idle problem
  59. Evo ix issue after motor swap
  60. High oil pressure?
  61. Rise of the DD Beast
  62. Transmission and TCase install question!
  63. Question about ECU/ECM
  64. Help with evo modification
  65. Real or Fake JDM Rear?
  66. New to the game and looking for help
  67. Who works on their own Evo's in Dallas Metroplex area?
  68. Help from another evo owner locally
  69. how to NOT ship a transfer case
  70. Electrical Problem After Crazy Rain Storm
  71. Does anyone know whose evo this is?!
  72. jumpy idle, need help!
  73. Need Help!
  74. Increased engine temperature readings after coolant replacement - Evo IX
  75. Cyber wide body kit
  76. Evo9 importing
  77. where can i find headlight lenses?
  78. Help me find this cars previous owner!
  79. Potential Evo Owner Questions
  80. What's my Evo worth?
  81. Does Mitsu sell the air bag trim ring?
  82. 25G turbo on Evo 9 is it laggy?
  83. Door handle seals
  84. 2005 EVO VIII vs 2006 EVO IX Front o2 sensor the same?
  85. Season closer at the drag strip
  86. Budget Engine build.
  87. Here are my compression numbers...
  88. front bumper
  89. Off TO TPG Tuning Tomorrow.
  90. Evo hibernation
  91. Need Help with air filter..
  92. Blow-by causing me to loose tons of power?? 2.4L/DBB-FPblack
  93. HID going out?
  94. Place to buy all the basic fluids for one change?
  95. Squash Performance Double Pumper -- Freeking Amazing
  96. MR Trans, Trouble getting into Reverse
  97. Too many alignments?
  98. The 2013 Approach to 400whp
  99. turbo help
  100. Just thought I'd share
  101. vibrant resonator size?
  102. Help P0135
  103. Loosing coolant
  104. Anybody reupholster stock seats?
  105. Where can i find a polyurethane se style lip?
  106. RWD Evo
  107. can the evo9 lower control arms be restored?
  108. I need a comfortable seat for my Evo 8
  109. Small drops of fluid - Too much PSI during Boost Leak test?
  110. 03 evo 8 exhaust leak?
  111. Donut Gasket question/Problem - Downpipe - HELP!
  112. TB Built evo viii 500whp project.
  113. Still 10.0 afr with aem tru boost and wideband!
  114. What size are Evo IX Center Caps (Enkei OEM)
  115. Need advice for my 2006 Evo RS after accident
  116. retune injectors?
  117. No power to Injector No.1 Plug
  118. Install Cams with no tune ?
  119. steering response not tight anymore?
  120. Vinyl stickers
  121. Evo Impounded, Worst Night Ever
  122. Cost of making Power.
  123. is there a boost gauge that fits the stock housing?
  124. Hard wiring non start issue
  125. question about lower control arm
  126. Cv joints
  127. How to run 275's?
  128. What turbo setup to go with...
  129. Price My Evo
  130. car wont stay idling after new pump and turbo
  131. Is 850cc injectors enough to go e85?
  132. Cost of a evo 9 SE steering wheel?
  133. Can this transmission piece be fixed?
  134. Anyone know anything about hks hi power exhaust?!
  135. Evo IX MR oil drain plug! (the one with the wire)
  136. Can anyone tell me if this is an EVO 9 or not?
  137. F-Con Navigator
  138. cecil county dragway, MD...Wednesday sept 25 cmon out!
  139. Evo VIII electrical issue??
  140. Seat brackets for Cobra Suzuka/Monaco Seat
  141. Fender pulling and rolling
  142. Fuel pressure wiring prosport
  143. Is this a legit 8 MR FQ-300
  144. New Idea
  145. Thermostat placement on evo 8
  146. Looking to buy an Evo 8 - any gotchas?
  147. New Belt Needed!
  148. anyone know thread pitch of evo 8 oem oil psi switch?
  149. what is this part called?
  150. Stock part pricing?
  151. White smoke
  152. Evo problem! help if you like.
  153. Poll: JDM Rear or Coilovers
  154. Just thought I'd share
  155. Anybody have evo year/color/trim production numbers?
  156. Big turbo help
  157. Injector/Low Impedance ?'s/Post count ups
  158. Custom carpet
  159. Full service manual "symbol"?
  160. evo 9 restrictor/boost pill?
  161. Blown axle ! Ok to race?
  162. Exhaust system advice please
  163. Evo 8 no hand brake light
  164. Used head studs?
  165. Dying Walhbro 255l
  166. cf trunk fit
  167. What size vacuum hose fits hallman mbc
  168. Battery Acid Corrison? Need help. (pictures)
  169. Best place to sell an EVO 8 ???
  170. Raising boost after tune
  171. gen swap help
  172. Front end alignment prices
  173. Help!!! Idle problem!
  174. I have a fuel problem
  175. help buying an evo IX
  176. 8 or 9 transfer case.
  177. Where can i find a evo 8 parts diagram?
  178. Compression Test results HELP diagnosing
  179. Is Clutch Chatter Normal? Evo IX
  180. transfer case issue.
  181. Clutch Engagement noise
  182. PTE 1000 injector stuck open
  183. Colour for EVO 7?
  184. Injector cleaning
  185. Do dealers generally stock evo 8 parts?
  186. P0134 and P0171 Help!
  187. turbo timer vs auto timer
  188. Cusco power brace install help!
  189. Evo X at NYST
  190. 4g63 Valve Cover Keychain
  191. Some help please!?!?!?
  192. Turbo Removal Help.
  193. 5th gear harmonic
  194. running issues
  195. to buy or not to buy
  196. need help
  197. Any vendors or anyone for Spooling up COP kit
  198. Jacking, Stands, and Pinch Rails
  199. LICP: AMS design vs ETS
  200. 2.0, keep or sell
  201. Stock IX tail light alignment issues
  202. What turbo?
  203. Built block questions
  204. removing exhaust manifold studs
  205. Price is right?
  206. What air filter do you guys recommend?
  207. Does this sound like an exhaust leak?
  208. Does this sound like a good deal?
  209. Turbosmart dual port BOV leak?
  210. Semi hit my Evo what should I Do,
  211. Can somebody explain to me Buschur blocks!?
  212. Seat alternatives
  213. Average machine shop time
  214. throttle body clean weird idle
  215. Weird idle
  216. Another 2003 gone... RIP SpazEvo
  217. Boost Issue After Injen Kit Installation
  218. hardcore face falling
  219. Any replica Voltex SPL Carbon Twin Canard (cwest bumper) evo 8/9?
  220. The OBD-II plug has stumped me.
  221. Reluctor position affecting HP on Evo 8
  222. Finding TDC
  223. Turbo laggggggg
  224. vendor on here for rota?
  225. more power
  226. Wiring tuck/Sensor ground questions
  227. Balance Shaft
  228. How to improve throttle response
  229. Evo 4 valve cover hole rear too big
  230. Need Help ASAP - New Evo Owner
  231. Factory clips
  232. Issues with Spoolinup COP
  233. Radiator fluid turned red
  234. My best way to clean aluminum control arms!
  235. Weird AC problems. 2 Fold
  236. How to install A/F Gauge
  237. evo 9 mr steering wheel locked up while driving
  238. Hobbs switch or two relays on double pumper
  239. Which vender carrys exedy pp02?
  240. I need help on what to buy!!
  241. Bottomed Out My EVO :\
  242. How to install the JDM Rear bumper on a evo 8
  243. Sexy evo IX vid
  244. Diagnosis Problem...03 Evo
  245. Reverse light not working?
  246. Speedo Dial Sticking
  247. New mods...no clue about power
  248. Evo 9 Wagon GT video Tokyo night drive
  249. 3rd Gear Acceleration
  250. omni 4 bar
