View Full Version : Evo General
- Aftermarket Gauges Foam/Rubber
- Hub centering rings?
- Catalytic Converters, Hi Flow or Oem Cat?
- Tow Bar
- Intermittent crank???
- IX seats are killing me
- Bride Seat owners
- what should look for when buying an Evo 8
- does ANYONE have a knock sensor socket?
- Braided Hose or Hard-Line for ACD Relocation
- Whats off?
- Does an company make a front lip like the voltex
- Brake Guide Development
- Help! Speed Density Question.... Car not running right
- looking for this front lip
- High HP timing belt
- Proper wheel fitment Enkei Nt03
- Anyone running Kelford 264/268 combo?
- help! launch control
- No g force pull feel !!!
- Cylinder Head
- E85 or E98 in NJ???
- My clutch is making a weird clunking sound
- Identifying parts for part out.
- Radiator fan, yes? No?
- What would you pay for an evo IV in the US?
- OEM Coolant/Water Temp Gauge not working
- how do i change liscence plate lights?
- Radio fuse randomly blew, cant find the problem?
- Help! Evo idles really bad and stalls when coming to a stop/reverse? ideas/fixes?
- does the evo 9 have a fan in front of the radiator
- Need help
- Evo Rally 2013 pictures
- Evo Finally Done.. Just Need Tuning!
- what is a greddy turbo timer worth?
- Evo radiator help??
- Nisei uicp bov recirc pipe
- which 4 point harness to buy
- Black friday 2013
- car revs on its own, temperature stays at cold. causes/fixes?
- Misfire
- Is a 2003 8 w/ 56k for $20k a good deal?
- Clean 03 Evo on ebay
- thread pitch help
- How much is my car worth? (2006 IX SE Apex Silver oem)
- Help?? Defi VSD Boost/Turbo timer instructions needed!!
- Running Lean on start up
- radiator smoking?
- Winter floormats, who makes them?
- water neck leaking coolant... need gasket!!!
- Vin verification for modified vehicles
- $32k for an viii with 150k miles?
- top power stock td05?
- No More Boost Taper
- power steering pump?
- Got a problem & need advice.
- How long did it take you to find your evo?
- New tires and wheels! XXR 527
- front inner fender well liners have a brace?
- help me decide if I need more fuel
- Jun 3.5 inch Ti exhaust
- Injector wire - short
- no heater and no AC
- need tune?? Noob help
- I need help with which car I'm buying.
- Help! Compressor surge!
- Evolution 8 & 9 Clutch.
- after market seats , discuss , add
- My AYC decides it is superman sometimes?
- Stupid Question about higher mileage
- Works underhood & shifter bushings cleared my third gear grind
- Where do these plugs go?
- Any Vendors or shops buy used/blown shortblocks?
- 3" V-Band Flange Titanium
- How come with half a liter less displacement....
- cylinder head identification
- 03 Evo with 05 engine
- opinions on boost gauges
- Mini Battery Under $120
- Evo 8 E85 first time at Irwindale 1/8 Mile
- ETS TBE Question
- 03 Lancer rear bumper same as evo 7?
- Evo 7 wing
- Hks twin power dli issue, HELP
- Ignition Coil
- Anyone know if they make a GoPro license plate holder?
- built evo 9 engine not running right!
- Aem tru boost ext sensor doesnt read right.
- Possible transponder going bad?
- tubed front end
- CELs po138 po141 po300
- Engine problem
- Hard to sell built Evo???
- What is this part?
- Intercooler spray leaks when i top it up
- Redlinegoods alcantara steering cover
- 600hp clutch
- Is it just me or has Evo prices gone up?
- Ice car club race event
- best oil for built engine?
- I have a 2005 Evo 8 RS : Would a Evo 9 Turbo benefit me?
- GodSpeed Evos?
- Battery died, now idle is at 3k, AEM EMS
- How much abuse can it take?
- How long did you lower ball joints last?
- Weird Engine Vibration Above 2,000RPM
- Stock Evos
- GSR EVO 1 problems
- HELP identify this intake or filter.
- Anyone Else Read This Book?
- Evo issues... Ticking... boost... Help
- blown ignition coil
- F up Evo ix
- Popping off T-clamps/Tial BOV?
- Power Steering Pump?
- Coolant leak
- Evo X steering wheel is Evo 8?
- D1 drift event in Tokyo - video I shot today
- Rich at Idle jumpy RPM Help :(
- clutch choice
- Stuck Transmission Suggestions
- Wavy AFR line on E85? Any ideas why? got PIC
- Sold my EVO IX SSL today :(
- What is that noise? (video)
- One side of my OEM HID stopped working
- Nisei Upper Intercooler help intake
- Good brand for a car cover?
- Nisei uicp bolt to plug
- Speedometer
- boggy from 2k to 2,800k rpm only
- Another noise thread - I need ideas
- what plug is this on evo 9 engine harness
- stock evo 8 muffler weight??
- so cal evo owners on e85
- Tactrix 1.3 cable repair?
- what is my 05 built evo 8 worth???
- Evo 6 intermittent idling/starting/running issue
- Acceleration Problems
- Boost control problems, running out of ideas!
- 4:11 Final drive with 26" QTP?
- Intercooler Idea
- How much is my Evo ix MR RR?
- Noob question
- Order cv shafts online ?
- Cv shaft assemblys ?
- Spoolin up #1 In customer service!
- where to buy gaskets?
- Knock has returned without anything changing
- Incorrect reading fuel gauge with fulll blown hat
- need a 4g64 block
- Low oil temp, boggy acceleration
- valve spring help!!!!
- So far in my Evo search
- Boost problems after 4K RPMS need help please car bogs out
- Looking for evo 8/9 for 14k possible?
- looking for a las vegas nv evo
- Removing EGT.....
- Evo V shifting
- TE37's 17x9 +22 how much work required to fit my evo wagon?
- How much would you pay for an Evo IX MR, salvage titled?
- 2.3 stroker advise
- FF with A/C what condenser is this?
- Lets play name that sound! Vid inside
- EVO VIII Seat Covers - New Pattern
- Evo 5 Style front bumper for my Evo 8?
- Mitsubishi's Facebook Fan Friday Feature!
- Anyone from Jersey City?
- help! my ACD cap fell off! Where can I buy a new one
- Alternator or battery~?~?~?
- ISO bolt size by front motor mount/tow hook
- A visit to Garage GFORCE Yokohama (Blog post)
- Evotraderonline?
- Evo VIII chokes with BOV
- electrical issue???
- Injectors Help!
- Help with strange intermittent o2 issue.
- Excessive Oil loss. Where did it go?
- Turbo choice
- @ cupertino
- Charge Pipe Problem
- d2s hid connector
- Evoscan download from TSCOMPUSA
- Broken Door Hinge
- Hks axle back(muffler) wanted
- black residue in intake
- brake problem...
- Transmission freeze plug size?
- CAS install help
- Competition twin disk rebuild question!
- Evo 8 upgrade help
- spark plug
- Odd fuel tank issue...
- Evo 7, next mods
- What spark plugs are you high HP guys running?
- evo needs a 03 outlander water pump? wth
- rockauto parts??
- Power steering pulley removal
- water pump issues?
- Borg Warner 366
- missing sub in evo 9 ssl
- suitable street cams
- Oil on Oil Pan Normal? Pic Inside
- Best area for evo,s 1-3
- ct9a under carriage/panel fit on evo6
- How many wires is safe to run to your tac fuse?
- MAF sensor connection
- Looking for Magnaflow #
- Questions about Slowboy Racing
- evo ix spark plug help
- MFI help - Runs with some help but should do on it's own
- Next: M3 or Evo 8?
- Evo3 powered Cordia
- clean fuel injectors
- What to buy?
- Rear Wing?
- Grinding/Rubbing? Left front wheel
- What is wrong?
- Replaced IX alternator, and now its blown the fuse :(
- Transmission issue?
- Gauge combo question
- Seibon Hood and Hard Liner Issues
- Forced performance Fp black lead / delivery time?
- To sell or not to sell
- ~~Question - Do I need to replace my fuel pump?
- Is it okay to buy used cams?
- Help! Im so confuesed
- Evo IX Fog Lights
- How to remove bottom portion of seats to make shipping easier?
- transmission diagnoise
- evo 8/9 dc sports intake with intercooler pipes n filter
- Have an evo im looking at and need some opinions
- Squeaking/rattling sound from front bumper!
- EVO IX ACD fluid?
- Few issues, any ideas?
- New Evo Wallpapers
- Evo Noob
- Getting Ready to Go Big......ish
- Evo 9 Marketplace
- Opinion Needed
- Stealership HELP
- Evo 8/9 IAC interchangeable??
- spark plugs and ignition help!!!
- Anyone Using an 02 Dump
- Falls flat at 6psi
- Evolution help?
- Transmission Question
- Lights out
- Evolution 7 RS-II (2002) Original Front Catalytic Convertor Part No
- lug nut
- Electric problem
