PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Just bought an Evo 7 GTA
  2. Evo 7 GTA
  3. Starter problem Please help
  4. Evo HVAC - Help? w/ pics
  5. Regular lancer drivers door window fits evo 9?
  6. Wing Re-clear
  7. "dry" vs "wet" carbon fiber.
  8. CBRD Bound for some fun
  9. Evolution 7 Part list
  10. Precision Tuning
  11. Lost my interior lights, door lockers, radio, clock, and ciggerette lighter.
  12. Need advice for a broken part on a brand new head
  13. new car
  14. Post-Accident Advice
  15. New Trunk Carpet
  16. HKS silent Hi power catback
  17. heat wrap o2 housing?
  18. #3 spun rod....help!
  19. Guys with Built Engines
  20. Collision Repair Nightmare
  21. MR Roof Rack
  22. Spark plug question.
  23. Yes, another Evo wont start thread.
  24. Why are people selling their evo's and what are you planning to get????
  25. Whistle, whine on highway
  26. rack and pinion banjo bolt size/AN size?
  27. Fuse blowing problem.
  28. Front lower control arm bolt snapped!
  29. 4G63 evo 1-3 build
  30. Trunk Bolt PN#
  31. brake help
  32. another P0138 heated oxygen sensor High voltage
  33. HVAC Bulbs
  34. VENDOR Needed. Seibon parts
  35. evo 8 headlights question
  36. New EVO Owner, help me troubleshoot please
  37. Camshaft position sensor improper installation!
  38. Bouncing idle
  39. Will Evo8 10.5 hotside fit on Evo 9 CHRA
  40. Help With Mod Plan For First Tune (On A Budget)
  41. Double Din
  42. Perrin Intake quick ?
  43. Xs engineering
  44. Gauge installation
  45. Its hard to get into 5th and reverse. bushing?
  46. need help with aem air fuel ratio
  47. Is it safe
  48. Expensive TBE worth it?
  49. need help choosing what color
  50. Roommates girlfriend crushed my hood. Carbon?
  51. Custom or Stock Evo?
  52. using tomei downpipe on evolution 8, is downpipe braket necessary?
  53. any tips for cleaning a titanium exhaust?
  54. Engine oil advice!!!
  55. Question on undertray on fender linings
  56. Considering a change
  57. possible crank walk?
  58. car running a bit cold?
  59. mpg??? help!
  60. New guy right here and a quick question!
  61. Almost 2 and a half months in a body shop and still not done...Venting part 2
  62. Have any of you ever filed a diminished value claim?
  63. Good Deal?
  64. New o2 Sensor reads under on AEM Gauge?
  65. something cool
  66. Need evo cruising music!...ideas please! [MERGE]
  67. Looking for previous Evo VIII MR owner - Lewisville, Texas
  68. Oil Pressure through the rooF HELP!
  69. alternator not charging with stock gauge removed in evo 8
  70. Check this deal out (Not Mine)
  71. Evolution 7 speedo off
  72. Spark plug wires
  73. walbro 255 fuel pump not priming
  74. evo ix gt adc question
  75. Perrin antenna
  76. MA Pothole 1, Evo Wheel 0 - Check this out
  77. Strut Mount - Any alternative to OEM?
  78. Test pipe
  79. HKS BOV on Evo IX MR
  80. Yakima Roof Rack Components
  81. Evo 9 front bumper not going on
  82. Evo 4 IV o2 sensor replacement
  83. Hks 280/280
  84. safc is junk on an evo? why???
  85. IAC valve picture?
  86. oil filter angled on car
  87. Whats this wire?
  88. Issue after grounding kit
  89. Car is leaning out at WOT after E85
  90. Use Stock SSL wiring for an after market sub?
  91. Exhaust?
  92. FP FAP Flow Advanced Port Cover -- Just ordered
  93. Stupid questions. Waste some of your time.
  94. Help me build a monster...
  95. Gauge Replacment Bulbs...
  96. Evo Service Manual with part numbers???
  97. Stupid accident.
  98. Check Engine Light & ECU codes
  99. Potential Evo Owner
  100. Blowing distribution block fuse
  101. need some help!!!
  102. gonna tune soon.
  103. Torque Solutions short shifter
  104. Just got an 06' MR with 40k miles :)
  105. My bov....
  106. Please help - need advise! Calling experts
  107. Evolution: The Difference in Driving
  108. CEL flash rapidly on boost
  109. Sharp Turn Chatter ISSUE
  110. Wheel rock chips / paint damage
  111. Picking Up EVO VIII Thursday!:)
  112. Is it possible to mount Brides to other seat rails?
  113. P0304 Cylinder Misfire Help!
  114. Crank sensor and Cam sensor issue.
  115. Re-wired DW301 Pump, Do i need a FPR now?
  116. UICP blew off = CEL on?
  117. Upgraded throttle body hose for Evo IX?
  118. Gauge Rings
  119. Suede Interior help
  120. how to make the fan for evo 8stay on
  121. Mitsubishi rvr
  122. CEL codes?? Possibly causes?
  123. ACD Function
  124. Exhaust upgrade 3.5"
  125. front fenders gone when purchased the car, what all do I need to replace?
  126. Litespec exh on IX
  127. Getting tuned Friday, have a question
  128. My radiator fan went.....
  129. evo boost problems
  130. Tips/Advice on buying a used evo...
  131. fuel issues.. please help!!!!
  132. PO121 code...
  133. ACD struggling pump noise?
  134. Prosport oil filter adaptor
  135. Torque on main studs?
  136. Test Pipe 02 Extender
  137. Help needed in Locating Evo 7,8 Chassis Number
  138. Good exhaust combo?
  139. volts gauge lights out
  140. Evo has been sitting
  141. Evo is misfiring ... suggestions?
  142. What is this part?
  143. where are the off brand ebay mini battery trays
  144. Deploying for a year...
  145. best way to spend 5 grand?
  146. Fluid Change Help Plz
  147. Do you daily your EVO? Would you rather have another DD?
  148. Which valve cover to go with?
  149. death whine coming and going?
  150. Ultragauge- anyone used or heard of these?
  151. E85 and tuning
  152. SoCal-Anyone have a clutch alignment tool?
  153. Shaking steering wheel [not brakes?]
  154. Any you paint your evo?
  155. remap with 80.000km? is it ok?
  156. First day with EVO out of storage and stalls out
  157. Mizu radiator
  158. soon to move frrom 91 to 93 or 94 octane
  159. wastegate and low vaccum
  160. My awesome custom faded voltex type 5 wing....
  161. Mivec cam seal??
  162. LEFT Tailight Out. Many Troubleshoots. HELP PLZ
  163. best o2 housing
  164. Alternator problem, brake, battery light is on.
  165. times in 1/4 miles with your Fp Black
  166. Thinking about a change c5z06 to Evo
  167. 03 Evo parking lights will not turn off
  168. is there a way to prevent anodized lug nuts to stop fading?
  169. High compression not working too well for fast Subies
  170. Trade in value now??
  171. My evo got impounded
  172. Ebay store ilovetacotaco
  173. Auto Evo???? Possible???
  174. Problems-hesitation and coughing
  175. front lower control arm bolt???
  176. Tranny problem?
  177. Outcome of drifting a Evo
  178. Intake tube fitment?
  179. P0300
  180. How do you take up tar material under rear seats? Pics
  181. Fuel Pressure Too High Help!!!
  182. ticking sound after 2.5k rpms
  183. Daily Driver Evos
  184. Fuse Panel Connector
  185. Newbie Question: Failed Smog inspection because my CEL light isn't working?
  186. Rear o2 question
  187. Anyone Knows Where I can Find This?
  188. Any difference between a 8 & a 9 hood ??
  189. Piston Condition??
  190. Has anyone tried this ebay Double DIN Conversion Kit
  191. is this exhuast leak
  192. Evo 4 - sourcing parts/getting work done
  193. Car covers?
  194. compressor surge fp black
  195. p0401 code
  196. Evo IX 2-Step doesnt work
  197. Driveshaft Part help
  198. radiator fan control module
  199. Stock IX MR bumper with C-West Side Skirts
  200. Evo 8/9 RS glass swap (or std lancer glass)
  201. AEM Boost Gauge Problemo. Would love some feedback.
  202. Value of 2005 Evo 8 GSR?
  203. Bigger the rim the higher mph?
  204. Help with finding a Repair manual!!
  205. So I started my "wire Tuck"
  206. To those with the buschur dp
  207. Did I just get incredibly lucky...?
  208. Car won't stay running
  209. My car is acting weird!
  210. A/C Condenser Leak. How do I recharge after replacement?
  211. downpipe to cat fitment question
  212. Smoke !!!
  213. ct9 packages
  214. How much water needs to be in the stock battery?
  215. 03 rear diff
  216. New Yorkers and East coasters!
  217. Tools needed for a timing belt job?
  218. Evo VIII/IX SSL/MR
  219. How do you take rear seatbelts out?
  220. Need Some Help With Parts
  221. Deatsch Werks DW 301 Installed. Questions...
  222. tactrix cable
  223. Radiator Coolant Leak At The Top
  224. Any of you guys road trip in your evo?
  225. 2003 Evo 8 Salvage Value
  226. Car won't start possible tune?
  227. fq-340 question
  228. possible smartkey retrofit?
  229. Extra boost due to mods?
  230. hole in the block
  231. search manual repair rear axle (AYC)
  232. Cold Start Help..
  233. Clutch and what is right for me?
  234. Back in the Game
  235. gas problem... help
  236. Amsoil fluids - X.L. oil and P.I. gas additive
  237. Oil Question?
  238. Knocking sound from valve cover? HELP PLEASE!
  239. My 2011 CBRD Long block Build
  240. Max PSI?
  241. time to say goodbye?
  242. evo 4 afm
  243. would an 8" muffler fit under USDM evo 8 rear?
  244. evo 8 sunroof question
  245. How much power can the 2.0 block take...
  246. evo 9 swap problem...
  247. Do I need to remove ground wires?
  248. Electrical Gremlins - Where is the Leak?
  249. evo 8 flasher/hazards problem.
  250. Boost Leak Testing. The rumors, and the facts.
