PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. 2.5" down pipe, front pipe, cat removed .. 3" catback worth it?
  2. Is speed density really worth it ?
  3. Need advice for new purchase.
  4. lessons you've learned when working on your Evo
  5. Sheepey turbo set ups,
  6. Evo VI hood work on IV???
  7. loud clutch engagement noisy
  8. brake pedal stiff
  9. first day memories
  10. Evo 9 Wagon GT
  11. Quieting down exhaust. Resonator style/placement
  12. Evo 8 weird idle/misfire
  13. SRS Code 22/32
  14. anyone ever have any issues running space saver?
  15. Can I drive my evo 8 gsr in the rain with stock manifold
  16. Yellow Headlight Overlays
  17. Should I just throw my stock parts away?
  18. Evo 8 body question
  19. Evo 9 Seat Rails
  20. Anyone know which bumper/kit this is?
  21. Boost leak test issues
  22. OEM Ported Manifold benefits?
  23. HELP... looking for an evo, is this worth it?
  24. Anyone replaced the shift linkage before?
  25. timing belt/wp parts list... anything missing or recomended
  26. is an ETS licp a worthwhile mod?
  27. LF: parts for a friend for evo9
  28. Engine spits and sputters on idle!!!!!! Evo 8
  29. DIY EvoDave Front Fender Mod
  30. What to do about intake that previous owner had on?
  31. Need PN for Evo 7 front badge and bracket
  32. EVO 8 STOLEN - CHICAGO - Bridgeport
  33. TBE help
  34. What part is this?!?!!??! HELP
  35. At Last....it's time to get my Evo back on the road.
  36. Thoughts on rust/corrosion: would you buy or pass, and how would you value the car?
  37. best blow off whats best ?
  38. Gauge CLUSTER circuit board fried
  39. Evo 8 Mr Cannards?
  40. help!!! stripped rear diff fill plug
  41. Holset H1c Opinions?
  42. Muse/VSFR
  43. Eco iv cam sensor
  44. gruppie replacement found
  45. Help; Turn the steering wheel at idle, HIGH revs!?
  46. Stalling when idling
  47. Which CF hood ?
  48. parasitic battery drain
  49. Switched to Speed Density Lost Power?
  50. Best spark plugs for E85 (800+ hp)
  51. HELP! Interior Part #
  52. gear box shifter problems
  53. Anybody get their crate engines?
  54. English racing mini battery kit
  55. Vinyl wrapping in north Florida
  56. Brakes won't stop squeeling!!!
  57. Evo 9 Fuel pump problem
  58. P0300 Random Misfire Code Help
  59. Silicon Couplers Question
  60. Russell power steering fitting
  61. New 48" Koyo Radiator Replaces 55" Koyo Race - Installed
  62. e85 FP Black on Single Walboro 450?
  63. rear diff Vibration on Evo 6 @ 2000rpm... please help
  64. Who runs a catch can?
  65. ETS SD 4" Coupler
  66. EVO Triple Gauge Panel
  67. Low speed steering wheel wobble
  68. Steps to starting Evo after long term storage?
  69. Evo4 fuel issue
  70. Quite o2 dump
  71. Straight Pipe ?
  72. running lean at WOT
  73. Air bag recall update
  74. Compression/leak down numbers
  75. Evo ecu in DSM high idle
  76. evo 7 interior light problem (please help)
  77. Clutch Release Shaft Wear :0
  78. Evo VII's post your hood shots here!
  79. Does this SEEM like a good Evo IX, $15500
  80. Slim Radiator Options
  81. hey guys wondering if this will get me 550whp on 93
  82. 2003 evo 8 RUNNING VERY RICH only when turbo builds boost
  83. Need some input.
  84. WTB door lock actuator
  85. my first mod list, any changes you would recommend (Evo 9)?
  86. Help with wiring under steering column
  87. Another air bag recall update
  88. Vendors for Evo 5/V??
  89. EVO 8 Starts, runs briefly then dies.
  90. Jb FP Red
  91. opinions wanted.
  92. Who can can make me a Titanium Intake
  93. Who bought my car?
  94. Move from Las vegas to Virginia "boost" Evo VIII
  95. Anyone have Carfax subscrip?
  96. Rear wheels locked ???
  97. evo boosting only 10 psi after vac hose changed
  98. Crankcase pressure problem
  99. ETS UICP w/ Injen LICP?
  100. Manual Boost Gauge
  101. Lower Cubby Ideas
  102. Struggle starting... Viii
  103. Struggle starting... Viii
  104. WTB 03 Evo 8 shell
  105. Looking to buy evo
  106. whining noise at 40 mph evo
  107. Gap between headlight & fender on one side
  108. Fuel issue driving me crazy!
  109. Flywheel warped or master cylinder???
  110. spa gauge pressure sensor?
  111. $8000 to spend what should I do?
  112. Evo : idle cams more lumpier
  113. Cant build boost past 14 psi, and Crazy exhaust leak sound coming from engine bay.
  114. Fp 71hta needs?
  115. HELP!!! Unknown noise coming from FL.
  116. What timing belt should I go with for 850-900hp
  117. Should i pickup this X?
  118. install directions for toxicfab bumper latch kit
  119. ETS piping with AGP Intercooler
  120. Vishnu Performance Systems CA
  121. broke antenna
  122. blue and black smoke
  123. Boost dependency on external temperature
  124. DIY HVAC vacuum pump rental,refrigerant+oil volumes
  125. Rivet oil baffles in valve cover?
  126. shop review please- MAP
  127. why is my new tial q bov not working
  128. Looking through old build threads and I found this....
  129. Move on to an 8/9??
  130. Is lifter tick harmful?
  131. breaking up under boost
  132. evo 9 bov
  133. Switching to SD BOV question
  134. SD intake, vacume lines? what to do with them?
  135. Extended wheel studs... Which lug nuts?
  136. weird droaning noise came back again
  137. air conditioning issues
  138. NEED HELP STRANDeD
  139. car dying randomly
  140. How much to fix up before selling?
  141. Hks ssqv recirculating flange not fitting
  142. To Mod the Evo Or Not TO Mod
  143. Snow White (EVO 9 build)
  144. aftermarket sub with factory head-unit possible?
  145. switching Passenger seat to driver side? hear me out
  146. How much is an ARC intercooler
  147. Leaking radiator, whos at fault?
  148. 2003 EVO 8 fan control and sunroof problem
  149. my evo vII cutting out
  150. carbon skirts painted?
  151. Agency power Ti / Stainless Cat Back Exhaust, Resonator removal
  152. can anyone recommend an Overseas parts shipper?
  153. Evo Misfire Please help, tried almost everything
  154. Cheapest way to get evo 8 headlight housing, ballast, hid bulb?
  155. low mileage Evo
  156. Rear control arms that will fit Evo 6?
  157. Need help, evo cuts off when accelerator is pressed!
  158. Need Evo 7 bonnet vent clip!!!
  159. Lancer Evolution IX Wagon GT
  160. tuner needed!
  161. radiator fan runs engine off ignition on?
  162. Engine whining noise after all fluid replaced
  163. Boost leak? Need help!
  164. Evo towing thread?!?!
  165. Recommended 5 top mods on 93 pump?
  166. Gsc s2
  167. Evo 3, no boost at all
  168. Should I get an ayc light on dash at start up? I don't...
  169. Temperature / Fan Control Knobs
  170. 60k Service: A parts/pricing list, thoughts, and questions
  171. Stm intake
  172. Well thats not an Evo III
  173. Rust care and prevention
  174. About The JDM 180 Limit.
  175. Next up....Unisuede Interior. Question?
  176. Best place to buy aftermarket parts for Evo IX?
  177. Turbo oil line relocation
  178. Crank no start/ No spark any cylinder
  179. HKS Hi-Power Exhaust Evo 5 [Help]
  180. MR gauges replacement with cubby/insert??
  181. Auto Show - May 16th, 2015 (LaGrange IL) 120+ cars
  182. HELP Evo x recaros into Evo 8
  183. MAF bolt size
  184. Missfire issue
  185. Car dies when stopping after higher rev start
  186. help!!!
  187. Evolution V/VI
  188. Trouble Starting
  189. 8 vs 9 help
  190. Sad Sad Day
  191. Which LICP for AMS intercooler?
  192. Someone please help!! Looking for 4G63T swap!! Need the complete swap!!
  193. help!! Please.. is it gremlin or something different?
  194. Bad e85 or map sensor?? Or.....
  195. Parts: I need an Evo 8 ECU
  196. Evo smoking after cam and turbo install
  197. Stall, wouldnt start, got it running..check engine
  198. AC not turning on
  199. 57dr Gram Lights on Evo9 anyone?
  200. Evo 8 oil filter housing ports
  201. Best Fitting Voltex JDM Diffuser Replica
  202. what is this bar!!!
  203. My New 2001 EVO VII RS-II LHD
  204. The right exhaust
  205. Easiest way to replace rear wheel stud?
  206. Tony's lube and tune (San Diego)
  207. Help my Radiator is blown ? :/
  208. Frame Damage?
  209. My 06 is getting built!
  210. i want to make 400 hp (how)
  211. Where did you weld the bung for AIT for speed density
  212. How much do used Evo 9 Recaros go for?
  213. Anyone ever DIY vinyl wrapped anything?
  214. The right air intake
  215. Seat rails for Evo x seats
  216. end link allen bolt
  217. I bought my first EVO 8! Maintenance Sugestions?
  218. Changed clutch, now sensor failures...
  219. if you had it all over again what would you do?
  220. What to do???
  221. Anyone DD with ACD flash?
  222. trouble with my defi oil pressure gauge
  223. Looking for a Vortex Generator WITHOUT Antenna Housing
  224. [WTB] Evo
  225. Rs manual crank in gsr doors?
  226. 2008 lancer gsr questions
  227. Check boost leak
  228. Strut / coilover top nut thread size / pitch
  229. Evo 4 AYC vs LSD
  230. Vacuum line
  231. is an Evo a muscle car?
  232. EVO7 Idle boost issue
  233. intake weatherstripping
  234. RPMs don't drop when revving past 4K
  235. Car having issues starting.
  236. Idle drops very low after revving the car.
  237. Where can I get a 5 ply head gasket from
  238. Does lifter tap do any damage?
  239. What should I do while my engine is out of my car?
  240. Mitsubishi Lancer EVO 7 Rallyart question?
  241. Emmisions recommendations
  242. Oil leaking issue – under Cam gear cover
  243. Should I buy this Evo 8? Opinions
  244. I've never seen anything like this
  245. Can't figure out noise
  246. Racing Seats.. The impossible search
  247. license plate Part numbers
  248. Help With Buying an Evo 8 MR
  249. I just bought my first evo8 and I love it!!!
  250. What would you do if you were in my shoes?
