PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Carbon Wing inserts
  2. Tcase whine question
  3. help with timing!!
  4. Timing belt skipped 3 teeth....No Bent Valves!!!!
  5. Stock 9MR Graphite Grey Front Lip
  6. what motor do i have?
  7. Modding a high mileage EVO
  8. fiberglass hood issue
  9. Finally into the 11s
  10. Mystery bolt
  11. seized front hub
  12. Kiggly Racing HLA best bang for your buck!
  13. Another mods question
  14. What to do next??
  15. What Evo VIII is worth the most to you?
  16. What Evo IX is worth the most to you?
  17. Filling fuel tank=better tranny shifting?
  18. Do evo 5 recaros bolt straight into evo 4?
  19. I got bored and found this.
  20. Front bumper sag recommendation.
  21. Recognize these cams?
  22. Is a slight 2nd Gear Grind common on the 8/9
  23. My Evo wont shut off
  24. UPS messes up again.
  25. ship my car with 300 lbs. items loaded
  26. help dialing in revolver cams
  27. where to get some jdm parts
  28. Gurus please come in here! Everything I need to know.
  29. Which One Should I Get?
  30. Help me find this
  31. Evos body roll vs other
  32. EVO VIII oil leak below intake manifold area?
  33. Two Catalytic converters
  34. headlight bulb change
  35. EGR system Removal..exhaust manifold
  36. Ricer evo project - should i buy it?
  37. Will an OEM CAT PIPE fit a 3 inch downpipe/catback?
  38. Where to buy LICP for 6466 turbo?
  39. Circular Rubber Seal Under MAF?
  40. Oil feed to block won't thread?
  41. Battery terminal
  42. Best CF front lip for WW Evo 9? Help!
  43. Needing some help
  44. electric problem
  45. Having issues with Air Conditioning
  46. timing slip- no bent valves???
  47. Is it dangerous? Good idea?
  48. Evoscan cable?
  49. high power hks exhaust
  50. Will the EVO 9 cat work with EVO 8 catback?
  51. What size box?!
  52. Rear sidemarker out + now LH taillight help!
  53. rear o2 disable- ecuflash
  54. evo 8 wants to stall
  55. Muffler selection
  56. oil pressure wiring
  57. Where to buy Front Ball Joint Pinch Bolt?
  58. I have a ridiculous question about downpipe to O2 housing.
  59. Search challenge
  60. How to get in contact with Kunal aka "Kunizee"
  61. San Diego SMOG help
  62. Want to see what other people are running with the same set up
  63. Anyone have any reviews for evo 8 megan racing 70A rear motor mount?
  64. Whp on a built motor?
  65. what could happen?
  66. Problem with Cooling Fan Control assy
  67. Fog light question
  68. Headlight projectors blue?
  69. electric water pump
  70. SSL HID housing vs halogen
  71. HKS Turbo Timer maybe broken?
  72. evolution parts questions
  73. extra hand
  74. Need help to select fuel pumper
  75. Evo 8 Thermostat part number
  76. FP Black mods for 500 whp?
  77. How much power should all this get me? Preferably in whp
  78. #8 fuse keeps blowing
  79. 200 miles to the tank
  80. is rhdjapan a legit website?
  81. Do I need a retune with these Mods
  82. HELP!!!What the headbolt size on a evo 9???
  83. evo 7,8,9 nzdm vs jdm
  84. full tomei exhuast to loud??
  85. AVC-R issues with video
  86. 05 to 06 front bumper swap
  87. Buying an Evo 5 do they have the same rods as an Evo 6 or 7-9 ?
  88. Cheapest fender liner pricing new?
  89. evo ix mr
  90. Test Pipes
  91. Can't find oem jdm evo bumper.
  92. Is this too much OIL? with PICS
  93. Tuning advise
  94. anyone have problems with orders from dsmgraveyard?
  95. AFR sky rockets when I pump breaks??
  96. BorgWarner Turbo Options
  97. possible trans issue?
  98. Mini battery kit?
  99. Hey guys what turbo would you recommend with my set up???
  100. Where is the key fob receiver located on evo 9
  101. ac fan HELP!
  102. My HLA's are bad...OEM or GSC no tick?
  103. Evos+heat
  104. Mivec cam trigger wheel and Camshaft position sensor scratched
  105. JDM Rear Bumper support Question
  106. japanese vs usa turbo manifolds
  107. Which mod made you smile the hardest?
  108. HID on EVO RS Help
  109. Boost leak test
  110. Heads Up / Recall Notice EVO9
  111. Power window issue
  112. My used Evo story (bringing it back to life)
  113. Build a compression tester
  114. Water in a tale pipe and half coolant missing from reasivor after Hgasket change
  115. Engine shuts off?
  116. Car dying in de-gear situations, help?
  117. CV Axle Boot Replacement
  118. Mitsubishi Evo TSB May 2013 [MERGE]
  119. Oem alarm sensor on top of dashboard missing
  120. Alternator Bolt not going through
  121. Dual Maps
  122. DW300 question
  123. evo5 juddering when turning right
  124. checklist help
  125. Works Wheels CR 18's For Trade/ For Sale -- LOOKING FOR EVO X Wheels
  126. Smog help
  127. Defi boost and oil press. gauges flicker?
  128. Leak into drivers foot well
  129. Can Someone post a Pic? Fuse Panel
  130. muse-v-band 3"
  131. Symptoms of Rod knock on Evo 8/9?
  132. Anyone run stock cat back with after market test pipe and downpipe??
  133. Tapping for fuel pressure?
  134. small battery terminals
  135. Headlight taken apart - Need Help
  136. Has anyone ever replaced a gauge cluster light bulb before?
  137. Evo 9 Chain like noise from rear
  138. need Tampa local to help me trouble shoot!!!
  139. Will 20mm spacers rub?
  140. HELP! black gunk near transfer case, inner tierod, oil pan
  141. apexi ecu question
  142. no boost in 1st
  143. Fuse blocks?
  144. Fuel change
  145. evo 8 car bra?
  146. Tranny problem and a few others
  147. Trouble mounting battery in boot
  148. Recently, my dash sounds like it is made of cellophane
  149. Evo 8 No start
  150. Will my exhaust set up be to loud?
  151. fitment issues
  152. cat direction?
  153. Moving to VA.
  154. Tephra issues
  155. Cel p0132
  156. NY failed inspection
  157. What direction did you take your EVO?
  158. Car feels sluggish, very rich, low boost
  159. Need this answered
  160. Sporadic oil pressure.
  161. Evo 8 Mystery Noise Please Help!!!!
  162. ralliart ecu on evo 8
  163. Is this the diff leaking?
  164. AC not working!!
  165. where can i find an evo 8 manual?
  166. P0234 and P0507
  167. Getting ready to go for a tune
  168. Which evoscan cable to get?
  169. OBDII Monitors Not Ready
  170. Probably a stupid question..
  171. HELP! i just broke the heater control knob
  172. Exhaust Question!!!
  173. Looking for super-random interior trim clip?
  174. engine mount questions:
  175. Air duct dam
  176. Recirc wastegate dyno?
  177. Help with front bumper lip
  178. Help!!!!
  179. s90 70mm TB??
  180. Exotic Half Mile Event, P.R.
  181. Putting 8 turbo in the 9
  182. inconsistent timing belt tension?
  183. Exhaust Help
  184. Anybody using or have Experience with the Meagen Manifold for an Evo 8?
  185. Evo Flywheel. Resurface, or replace?
  186. Blasting a Valve cover
  187. HKS Mushroom filter-Dry or wet?
  188. Will it fit? Muse UICP + Intake Kit + After market Air Box?
  189. What pipe is this? Picture
  190. Suspension/stability modding
  191. $5 License Plate Bracket (No Holes)
  192. EVO IX 71HTA before/after boost leak test
  193. Turboboostleaktesters.com FTW!
  194. 12 gauge weather pack connectors?
  195. Transmission shifts hard during Dragracing.
  196. Sulfur smell and smoke coming from battery
  197. Stock Catalytic Converters.. Where can I get the most money for one.
  198. The end of another mess
  199. car spits out coolant?
  200. Quick help!!!
  201. Color help
  202. Starter problem.... (possible fix)
  203. Evo problems need help!!!
  204. *****elite auto works scam***
  205. who converted this turbo
  206. quarter mile time
  207. Sourcing a new front end
  208. Ssl evo 9
  209. What air filter are the best?
  210. Cleaning headlights?
  211. My friend offered me cash for my evo
  212. One headlight working?
  213. Can Anyone Make This?
  214. To keep or not: Exhaust
  215. Power steering cooler removal
  216. Transmission Hole
  217. Evo 9 headlight question
  218. jacks transmissions
  219. Pure Drive Performance
  220. mitsubishi evolution vi suspension
  221. SSL Interior really worth?
  222. help..smoke...ideas??
  223. Evo 8/9 Rpm spike probable solution!!!!
  224. where can I buy a voltex rep wing?
  225. Anyone using FP's 84mm intake with Injen UICP?
  226. tial q flange weld?
  227. Evo 8 fuel pump
  228. loose power boost
  229. Condenser Fan Issues
  230. Bushings question
  231. Weird start up issue
  232. Don't trust Carfax.
  233. Mitsubishi Lancer Evolution IX MR import?
  234. rear trailing arm link bushings? AMS vs Whiteline
  235. Evo stolen!!!!
  236. New quick release, but SRS light wont...
  237. Evo 5 Front lower arms
  238. Need help identifying part name?
  239. Couple questions
  240. Amplified Motorsports?
  241. Hid in non hid housing
  242. evo iv mods
  243. evo iv time to do a clutch questions
  244. Galant VR-4 owner...need a hand with my EVO 8 MAF/intake setup please
  245. Does this tensioner look normal?
  246. Car vibration at 45pmh
  247. Steering wheel click sound
  248. Best acd tuning
  249. New here>
  250. Scanmaster 3 ?
