View Full Version : Evo General
- Triple gauge pod conundrum
- evo 6
- Stock Evo ix won't boost past 10psi
- jDM headlights
- emission problems, evo 8
- Is this tuning as effective as other type of tuning? Will I see Gains???
- Oil cooler feed and return lines
- Evo 6 momo hun adaptor
- How to recirculate ETS Short route BOV location
- 350whp goal
- muse o2 dump help!!
- Evo starter
- Stock EVO 4 intercooler pipe size
- ACD reflash low speed binding noise?
- Evo 9 Wagon For Sale
- Evos from canada
- is this the last bastion of Evo resistance? The Alamo?
- Cams
- Lost the key
- AEM Failsafe Gauge install *help*
- Problems with gas and trunk lever
- Decided to tune myself
- In need for a Tephra V7 Tune with all unlock Mods.
- ?'s To Ask When Buying A Built EVO
- Weight difference Between ACD and non ACD
- Christmas Thread! What are you getting?
- Evo 8/9 ETS 3" Exhaust Catback
- Turbo spool but no boost?
- Is this a real AMS intercooler?
- Tuning/Boost/AFR question
- 5600Miles Drive! Traveling with Evo 9 Mr
- Im looking for EVO 8 CARBON FIBER FENDERS or wide body kit!
- Help to get an Injector Sheet data
- Sparco harness bar hardware?
- License plate lights bracket removal
- evo 9 gsr ssl or evo 9 mr
- how could this be an even trade?
- EVO VIII misfiring
- apex silver evo down
- Car breaks up under boost even under no load (Video with DETAILED description)
- brakes engaged while driving??? HELP! PLZ
- Front under brace
- Evo 8... I've broke something
- Car cranks...Cranks....Starts...Then Wtf??
- Picking up my new evo
- How much power can the stock rs lsd handle??
- "Junk Box" EVO Gone But Not Forgotten.
- Transmission Clean
- How a $5 part screws up a $5,000 dollar build.
- evo 8 startup troubles
- Best Battery?
- Interested in getting an Evo
- Seat Belt Light and Chime due to bad wires. Not your usual problem
- Hood vent insulator
- Air Intake - Silicone Vs alloy pipes.
- intake air temp questions
- Do You Guys Like This Color?
- 8200rpm with 20g turbo?
- Doing things again how would you build change
- Ralliart Carbon Fiber Double Din
- Bad mpg causes?
- Evo ix clutch
- Is this a fair price?
- Buying an Evo, tell me if this is a good deal please?
- Brainstorming for a CF manufacturing business
- Forward face turbo tips and advice
- 2003 evo 8 worth
- 04 Evolution leaking gas
- Christmas Evos
- Advice on buyin a 03 evo 8..
- EVO 8 Windshield Replacement
- shortening wheelbase for project?
- Ecu Flash tuner in Miami needed
- December FCOTM
- Main battery fuse keeps blowing
- Swapping CAM sensors
- People who have made the jump from 4G63 to the newer 4B11 Evo X few questions
- DIY Maintenance/Repair Videos
- Ready to burn this car
- evo 8 fitment help for rpf1 17x9.5 +18 already did research
- Whats the max you can get out of a walbro 450?
- Evo 9 Steering Wheel Horn Button Replacement
- a noobs evo 9 perspective - first drive
- Front and rear running lights not working...
- 4g64 vs g4js questions already searched!
- Do I need to upgrade my intercooler?
- Radiator....
- starting a build 4g64 vs g4js questions already searched!
- Not Performing As it Should.
- Just a little review that shows the kind of shop that STM is
- CSL-type trunk lid versus standard? (carbon fiber)
- Removed crankcase nipple
- Speed Density MAT Sensor help
- Question about AFR while driving
- My car Wont turn on unless I use jumper cables wtf
- Evo IX / P0234 Boost Limit Exceeded Code? Help?
- Totaled? :(
- Fuel pump install, car wont start? Help
- innovate lm-2 logging with evoscan/ecuedit
- Need help...
- Clutch problems maybe??
- What would you pay for this beauty?
- Engine Build Advice
- Which intercooler coupler will I need?
- Speed density sensor question
- Evo 8 Trunk Interior
- Timing belt installed tooth up and still ran for months
- Newbie
- Voltex Type 5 1500mm GT Wing - How to spoke a fake?
- update! best manual boost controller?
- Auxiliary lighting
- Please advise me a clutch!
- Evo iv hesitation under boost
- Evo 9 mr jdm (chrome black) headlights
- Afr drop after shifting normal driving
- Rear license plate light.
- No Acceleration in Boost
- this is whats going on in Australia
- OEM hood air grille or CF vs FG hood vent?
- Optima Battery didn't fit
- How "illegal" is the Evo8 in Canada?
- EDM Evo9 throttle body question
- Flywheel Life span
- MAF and Cone Filter stolen…..NEED HELP with questions
- ***HELP!! Grinding Noise while Cruising***
- Research Help
- sell car to carmax????
- What would you do? Evo 9, 2015 Wrx, or ???
- AEM UEGO calibration number (P00-P04)
- evo 7 tuner?
- EVO 4 Front Lip
- JDM IX Rear Bumper Question
- Evo IX Winter Build... halp pls
- installing gsc s1 cams
- Does Tomei M7960 Turbo fit Muse O2 Dump Pipe?
- Faulty AC Switch/Relay?
- Help with buying an evo
- Identifying these cams
- Question
- evo 8 alternator issues
- Lean wot afr Aem wideband going bad?
- Evo 8 fenders fit Evo 9?
- Gutted stock muffler
- Evo 8 Nose chop
- Tial MVS waste gate install
- Decrease Understeer WITHOUT Increasing Oversteer?
- Where to find factory service manual EVO 4
- Rough and lean idle at start up. Evo 3 with Evo 8 ECU.
- Hola from Kuwait
- Hey Peeps! New Evo 9 owner here
- Play in rear wheels
- Evo V buying help
- 03 GRS to 04 RS ECU swap
- Can a Evo 9's water system work on an Evo 7?
- power enterprise 2.4 head gasket ? please help
- AC quit (not a shim/clutch issue)
- Exhaust Heat Shield
- Evolution IX exhaust manifold, equal or unequal manifold
- Lean wot
- NGK AFX wideband
- 2nd lifted head in a month? Bad thread???
- Dyno Horsepower number database
- Evo ix intake
- swapping out EDM evo 7 ecu for evo 8?
- How to tell if a Evo 8 FQ300 is genuine?
- Servicing Evo 8 FQ300, what oil should I use?
- Dyno Read out
- New Clutch
- Back into a EVO!
- Newb (future) Evo 9 owner, question for someone located in Illinois
- Trouble with starting
- assess the damage please
- Looking to learn how to self tune
- No SES on start-up. Need Help
- half size radiator?
- Evo 8 MR trans drain plug location?
- Evo lifer? Or....
- right hand side evo VII
- Evo 4 OEM Fender??
- Maxing out the double pumpers at 700hp?
- Parking brake stuck and will not release
- EVO VIII for sale options
- Derrick corbett bought grimmspeed 3 port
- Quick question
- Air Bag recall notice?
- 04 Evo VIII RS project
- Rexpeed Exhaust Shield Tape Placement / Fitment
- Quick question regarding BOV
- Oemmitsubishiparts website
- Evo won't start/ Which Engine Option?
- Buying built evo
- 91 with 10% Ethanol or 94 with NO Ethanol
- Loose timing belt issue
- Drivetrain issue
- How much power?
- help with cam and crank sensor p0335 p0340
- any good leather treatment??
- Coilover question(not another what brand do I buy)
- Are any of you guys in or know anyone in Turlock, or Modesto, or nearby?
- Short hub fitment
- No boost?
- Replacement Evo VIII Seat
- Choosing a turbo manifold!!! Please HELP!!!
- Evo 9 SD Map
- Is this a good deal considering stock and clean?
- Evo 8 Mesh
- Mounting the battery under the dash?
- What do i need to change from 20g turbo to 25g?
- WRX MY11 v evo IX
- Do need to port my head, aiming for 500ish whp
- Advice, critique & general thoughts on my Evo 8 future mods
- Smoke blue when cold start
- Evo 9 parts to buy?
- Pricing on a 03 Evo 8??
- Evo VIII questions
- Evo 8/9 Front Seat Nuts
- '05 MR - Invidia 3" DP
- heat from vents
- Faded window trim?
- Starting issue
- Lancer Shop?
- Transfer case specs
- Anyone In Michigan care to help me out? (COPART Related)
- Injector help
- Charging issue?
- 1981 Sigma 4g63 to 4g63T engine swap?
- Code No. P0170: Abnormal Fuel System
- Where to get rear wheel arch factory clear bra?
- How much power and time should this set up make on 98 octane EF3 set up
- EVO IX Price?
- Pc680 terminal issues
- Vis cf hood squirters
- Progressively Overboosting More and More?
- Evo 8 core support
- Turbo install smoke from turbo to manifold?
- help titanium exhaust
- My evo 8 daily driven.
- Evo on stands. Rotors move in neutral
- What to do what to do
- What Oil to use with e85
- Fuel really lean... Cant be pump
- Aison Grey?
- short shifter
- Front bumper quick release fasteners
- X to VIII?
- Need help removing rock chips off my evo iii asap!!!
- Fuel pump fuse or relay
- Service engine soon light
- part out car?
- ABS BRAKING PROBLEM NEED HELP Evo7
