PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Boost leak help.
  2. anyone weld their oil pan
  3. Where is the fuse for the sunroof?
  4. Evom first ever site-wide meet at Import Alliance! July 16th-17th 2011 Nashville, TN
  5. Trunk Lining | Lancer vs Evo8
  6. Clutch PROBLEM!!!!! Triple Disc
  7. Swapped wrx wagon or keep Evo?
  8. Whose car was this. Bought it from chicago motor cars
  9. Evo 9 Swap Into Evo 8 (NO SPARK)??
  10. Camshaft Sensor
  11. Longest distance you've driven your EVO?
  12. QUICKY: crank sensor & lower timing cover
  13. My basic bolt ons. and real bumper questions
  14. evo ix 2nd firewall relay????
  15. Rexpeed USDM Rear Diffuser
  16. vertical flow intercooer.
  17. Fp 3065 turbo kit questions...
  18. Opinion on this evo
  19. spark plugs $$$?
  20. 03 shell project/possible restore
  21. Can someone help me get a hold of Oliver Simons (worked at WORKS)
  22. front crash beam?
  23. Do i have a case here... ?
  24. Please vote for my evo!
  25. What A Pillar Gauge Pod to get, and which to avoid?
  26. EVO IV and crankwalk?
  27. Evo 7 rs & gsr rear diferential
  28. Vvme hid kit to replace oem ballast issue
  29. Bolt-ons and a tune ??
  30. evo 8/9 no bumper cover
  31. ETS 4" Downpipe Back Exhaust System
  32. evo IV with 8 and 9 parts?
  33. Connecting headlight to US household outlet
  34. anyone take apart a engine harness??
  35. gas smell when rev'd around 5k
  36. Supertech Dual Valve Springs
  37. New project need your advice :)
  38. Injen UIP?
  39. how many gallons to bring?
  40. quick question
  41. Need help getting a little more tail happy
  42. ABS Light On, Squishy Pedal WTF is wrong with this damn thing
  43. Samco silicone intake pipe
  44. Autometer Gauge Question
  45. looking to order one of these need help!
  46. need help removing trust gauge overlays!!!
  47. Hot Wheels using an evo for testing
  48. Power steering pump bad?
  49. Vent Visors for an VIII ?
  50. ATTN victims of the notorious fan controller
  51. VP M1 Meth???
  52. help me with a selection s1 vs s2...please
  53. Varis Front Lip?
  54. Is this boost leak?
  55. E85 conversion questions
  56. Paint or vinyl?
  57. Parking Sensor?
  58. P0335 Code and no start HELP!!!
  59. Give me your opinion on the evolution badge
  60. Tranny issue.
  61. cosworth 272 vs kelford 272
  62. So I was driving down the autobahn today at 120mph when...
  63. Need some good advice..pls help
  64. Evo Needs Some TLC
  65. Injector question
  66. Best deal on ETS Licp and Uicp kit?
  67. Apexi N1 Dampers w/ 10k springs
  68. UK EVOLUTION IX Trunk Emblem
  69. Cant find the right steering wheel hub adapter
  70. Top Notch Places to take your Evo for repairs
  71. darrn stylez >=[
  72. Brake light's Help
  73. short 44mm wastegate!?
  74. please verify black box on radiator fan!!
  75. Software Gauge Setup - Evoscan GPS and Zt-2
  76. Someone Broke my Rear window.
  77. Problem: inner child lock swtich
  78. Megan Coilovers Making Noise
  79. ATTN: Sellers and Buyers!!!
  80. Turbo Oil Water Install Kit Mitsubishi EVO 9
  81. What would I need to take a new camaro ss?
  82. Is TurboTrix out of business?
  83. Is this normal?
  84. I need feedback on this badd!
  85. Bumper Alignment
  86. Fan control box
  87. Help with new mods please :D
  88. Spring is in the air...
  89. Can a DP fuel pump support E98 and 800hp?
  90. Headlights?
  91. Best fitting A-pillar pod
  92. Evo owners with HKS 272 cams/AEM tuning Knowledge Please help i need some advice...
  93. throttle body high idle?
  94. part numbers
  95. what is this yellow-ish fluid in my intercoller sprayer?
  96. Electrical help
  97. Evos and beater cars?
  98. Fill Lifters before Installing?
  99. Turbo studs
  100. restricting downpipes
  101. wiper squirters problem..
  102. clearish oil leak near front of driveshft eny help!!_evo8 2005
  103. Trying to find ideas on IX valve cover
  104. White smoke pouring out of exhaust!! Help
  105. JDM evo 9 hid headlight housings in evo 9 usdm with hids
  106. arp extended wheel stud interchangeable between evo 9 and evo x?
  107. time to upgrade!
  108. name this part
  109. Egr deleted, vac lines question
  110. Question on Ethics... please help
  111. Pedal Sets for VIII
  112. Old School Evo Project is GO!
  113. VIII Chassis Number Location
  114. Couple quick wire color questions
  115. 06 bolt on opinions...
  116. my new evo8 just bought it a week ago took it to dyno and made 340hp a mainstream
  117. Rattle/noise
  118. Anybody ride with Liability only insurance?
  119. jdm bumper color / center bottom piece?
  120. SE Lip Mounting hardware?
  121. New Full Blown 70mm cast TB
  122. max HP with evo 8 injectors
  123. Red timing belt?
  124. anyone use this for map switching
  125. Evo IX Misfire and now P0204 Injector #4 circuit malfunction
  126. Can someone confirm what there Voltage is at the injector clip...
  127. How Many Front Lips Have You Gone Through?
  128. boost vacuum lines...
  129. AMS tbe and Megan o2 housing
  130. "AMS Remote Oil Pressure Sending Unit Line" Anybody using this?
  131. Clutch master cylinder
  132. My gas door does not open with the lever.
  133. JDM 4G63 won't rev past 3500RPM
  134. Im stumped. Cars running rich in open loop
  135. Future Evo owner looking for advice
  136. Broke nipple off of Fuel Pressure Solenoid
  137. FF Turbo Kit and AC
  138. Evo 9 SE available in white?
  139. Amazed
  140. EVO Newbie + what mods are these?
  141. Stock seatbelt with Pro2000.
  142. Reverse lights WTF?
  143. Fuel gauge to IQ3
  144. Whirring sound from the passenger side of the engine
  145. Is the j-pipe suppose to be like this?
  146. Lip or Splitter for dd evo
  147. Airconditioning rattle/vibration
  148. Some Chase Bays Product Development Input needed! (Brake lines)
  149. Car died this morning driving to school
  150. retuning after ported parts install?
  151. insurance question
  152. Brad Penn oil turned to Jello!
  153. finally!!! an ams fmic!!
  154. Rumbling under car
  155. Question about exedy twin
  156. Digital Autometer Gauges
  157. Erratic oil pressure readings with Defi BF
  158. ETS exhaust users... Love it/hate it?
  159. JDM Tailights?
  160. turbo flanges question!!! please help
  161. Wideband install.. where to put o2?
  162. why dosnt any1 use hks parts
  163. A Sad Day indeed...
  164. who has Fiber Images CF hood?
  165. Rally wing
  166. Do you let the significant other drive your evo?
  167. what kind of cams
  168. Cosworth Head
  169. wet carpeting =(
  170. Another one of those Whats this sound thread
  171. Intermediate shafts the same? MR vs GSR/RS
  172. Miget tuning the FP white
  173. buyin a used evo with damage, need advice
  174. buyin a used evo with damage, need advice
  175. Ok, I officially hate winter.. RUST!
  176. downpipe help
  177. Evo records and titles
  178. Tactrix cable questions?
  179. What timing light to use on the Evo
  180. EVO 8 SPOILER with/without
  181. My Evo 8 with 380 whp makes me happier than my Evo with 500 whp
  182. Crazy boost spike!!!
  183. clutch issue?
  184. recommended oil filter sandwitch
  185. Recommended Turbo rebuild shop
  186. Looks like an Evo 9?
  187. EVO Eco friendly? What gas?
  188. CNG Evolution's Idea
  189. Evo cubby hole
  190. Evo IX Blow-Off.
  191. who running 1600cc injectors
  192. evo 8 build
  193. My first evo story :)
  194. Gun pulled on me while drivin my evo
  195. need help with postin up stuf for sale on this forum
  196. how do i contact dynoflash?
  197. Where to source Pin's and Pig tails?
  198. 6spd shifter linkage retaining clip
  199. Front parking light fuse??
  200. Evo 9 Bumper Cover + Lower Intercooler Mesh
  201. can we all join this cause. keep the evo alive
  202. Mitsubishi belt tensioners are ****
  203. To buy or not to buy?
  204. Ash tray gauge pod
  205. Boost creep question
  206. Where to find 4inch maf adaptor (NOT 4.5inch vibrant!)
  207. Need help cel light not workng!
  208. Pink HID???
  209. will it work
  210. J-pipe to turbo gasket
  211. Something to think about please look
  212. Grind in 2nd 06' MR
  213. A problem i had
  214. Ready for inspection?
  215. Check engine light after turbo back exhaust install.
  216. Weight of an Evo?
  217. Safe to start?!
  218. Evo street racing on news
  219. WTB Exedy Twin
  220. Help me find this hood!!!!!!!!!
  221. Hot Wheel Commercial Evo
  222. How much will it cost me?
  223. Shoutout to Maperformance!!!
  224. Where to relocate the front license plate to?
  225. Fuel Cut?
  226. Pod like this for Defis?
  227. "LANCER" Race ends in crash
  228. invidia exhaust manifold + ETS metal radiator hose
  229. back at it again!!
  230. Intercooler sprayer
  231. Anyone running an aftermarket turbo outlet pipe?
  232. Start up problem.
  233. Inter cooler spray button not working???
  234. AMS fuel rail question
  235. Are there fogs forsale?
  236. Clutch install labor quotes
  237. What is this for ? mine is all rusted/oxidized !
  238. Is my evo making good power?
  239. Gas stations
  240. MITSU LineUp: if the evo is killed what would you buy next?
  241. Engine Cut off on part throttle
  242. STY decal?
  243. evo 8 MR ACD fuse
  244. how can i fit tial bov on this flange? (pic)
  245. fuel injector cleaner?
  246. Lancer evolution Coming to an End
  247. Boost activated cut-out DP
  248. Mitsubishi official says Evo franchise is dead
  249. 3BAR map sensor
  250. With the EVO now being extinct, does that mean the value of the IXs goes up?
