PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Canadian OOP Inspection for Evo 8
  2. Mitsubishi Evo 8 boost problems
  3. Rear Subframe Structural Support and Modification
  4. Evo 8 shutting off while driving
  5. How much would it cost to build a evo 8 or 9 shell
  6. Restoring stock carbon fiber Spoiler
  7. Extreme Tuners strikes again
  8. Speed Sensor Options - VI Trans and Speedo w/ VIII ECU
  9. help diagnose evo 5 problem
  10. EVO 9 MR - Help me restore and fix my baby :(...
  11. Power windows for EVO 6
  12. Fuel Vapor From Oil Cap/Catch Can
  13. Oil pressure gauge
  14. Evolution 9 ABS Cluth Pedal
  15. Have you had to replace ACD pump?
  16. Evo 8 Dash Light Not Working, Kinda?
  17. ignition Problem
  18. old school diy head/deck resurfacing method
  19. Master cylinder!??😵helpp!!!!
  20. GT400 series
  21. My Evo experience
  22. Front / Rear Wheel Behavior
  23. Oil leak help!
  24. Mitsubishi Lancer evolution sunroof chassis code
  25. Evo X fuel pump and injectors
  26. Spare Key
  27. 400-500hp 93 pump gas, rebuild. thoughts and options. please share your thoughts.
  28. AEM Widband is stuck reading "HEAT"
  29. Need help removing the radiator/fan.
  30. Need help: coil killer
  31. Intake Mani coming off, while I'm in there?
  32. Pass door wont open
  33. A'PEXi N1 Exhaust Resonator?
  34. 1000hp 4G63 Reliability
  35. Oil on the front of the engine, under the manifold.. any ideas?
  36. Evo rs driver door locks when unlock is pressed and visa versa.
  37. maybe dumb questions
  38. Is this just paint chipping from heat or should I be worried?
  39. Evo Running lean after rebuild engine
  40. Colt,mirage,cjo hb 97-01 with evo 7-9 awd swap proyect
  41. Mitsubishi Lancer evolution sunroof HELP
  42. Evo IX RS Model Code/Number
  43. Anyone use a jdm gas tank in a usdm car ?!
  44. Rear License Plate Bracket for Evo 8/9
  45. evo 8 purchase help
  46. More Popping Sound Diagnosis
  47. EVO IX ecu in DSM
  48. First Evo 4, i have some issues!
  49. Seibon Carbon Hood Restoration in. NW GA, USA
  50. Evo 8 drivetrain to Evo 9 shell
  51. Are evo 7/8/9 door handles the same as evo 10 door handles? *no fast key thing*
  52. Where to find bumpers for evo 8?
  53. Modifying OEM Oil Pump - better bearings?
  54. Low load/lift knock
  55. Mid Engine Evo 8
  56. How do you all keep your $hi+ together during teardowns
  57. It's been a good run
  58. Need help! How do I connect grimmspeed ebcs?
  59. Evo ix keyless entry fob from a outlander/galant
  60. smoother shifts
  61. Evo 8 MR Won't Start
  62. Intercooler Spray button disasembly
  63. Standard ETS intercooler on EVO 9 fitment question
  64. anyone in Centralia, WA?
  65. NEED ADVICE FOR 1992 Evo 1 GSR
  66. Car Won’t Start
  67. General Buying advice: Evo 7
  68. Fuel temp sensor
  69. Evo 5 spoiler mounting brackets
  70. Id2600-xds
  71. HELP: ACD Faulty Lights (ACD shows all the lights) AKA Tarmac, gravel, snow
  72. Evo8 starts but won't stay running, no DTCs
  73. Evo 8 idling higher in the cold
  74. Need Tephra 96260709 XML
  75. Tephra 96260709 XML
  76. Where can I find parts for right hand drive Evo 8!!!
  77. Source for "JDM" HID (Orange) Headlights & LHD non-HID (Orange turn signals)!!
  78. Body repair cost
  79. Evo 4 idle issue
  80. Boost leak tester upgrade
  81. Evo IX bogs down under load
  82. A very weird issue
  83. Evo 8 vs 9 lower timing belt cover, any better for a 2.4?
  84. Coolant Leak/Transfer Case question
  85. Evo stuck in limp
  86. support for AMS performance needed
  87. To keep it or to call it, need some help/advice
  88. IX Build Help
  89. Chasing issue with zero progress
  90. No start after AFPR Install
  91. Catch can suggestions for Evo 9 w/ built BR2.3
  92. o2 sensor help
  93. Help Valuing a car
  94. Is Magnus V5 intake manifold compatible with AMS fuel rail?
  95. transmission mount questions
  96. Engine into Shell v. Buying Car
  97. Misfire with diy coil on plug
  98. Check your alternator assembly bolts!
  99. Best street engine/turbo combo? 2.2L with 6266/6466?
  100. AMS injectors
  101. Help identifying hose in engine bay
  102. South Coast Mitsubishi Question
  103. Black Interior
  104. Evo 2 Importing
  105. Dash lights on startup
  106. 2 Nearly New Evo IXs for Sale
  107. Need help from the gurus please
  108. Stuttering after lugg
  109. Acd pump fun
  110. Evo8 shuttering under acceleration at low rpm
  111. Sound Deaden Evo Almost Complete
  112. EVO 5 idle and full boost issue
  113. Fq360 by hks
  114. Stuttering issue Evo 7
  115. Injectors not firing
  116. Knock noise on Acceleration
  117. Idle surge, lean reading (22) near 1k, map issue?
  118. 475-500whp on a mustang dyno on this set up?
  119. Evo 6 badges- where to find customs
  120. Nozzle spray while braking
  121. Evo Idle Issue
  122. Jackstand/ liftingsupport points
  123. Competition twin disc ?
  124. Evo 4 o2 sensor
  125. 6466 hp record on evo
  126. 3D Printing parts
  127. anyone here has cusco power brace with a ets 4" intercooler?
  128. Odd issue - Oil? on floor pans
  129. 1996 Evo 4 ignition issue. Cylinder 1/2 not firing.
  130. Headlight harness issue Evo 8
  131. Price for Evo 9's
  132. Bad o2 sensor ? Not sure if this is my problem
  133. Bent intercooler
  134. High bouncing idle
  135. OEM evo 8/9 brushed aluminium scuff plates
  136. General SSL package information thread. Build #s, how rare? Last sold vin+price!
  137. Evo 9 4g63 ticking noise diagnosis
  138. Another, "I need a service manual!" Thread. But...
  139. Found a problem?
  140. Boost Creep Issues!!
  141. Need some advice trade Evo 8 for a 2008 STI
  142. lean in boost and no power
  143. Evo 4 Bodykit
  144. Coolant Lines
  145. Need help deciding
  146. Subaru STI on the outside, Mitsubishi Evo on the inside.
  147. I want to make 450-550 whp advice
  148. Need advice with a strange issue....bad alternator or battery?
  149. Evo 10 Steering Wheel in a 9
  150. engine bay blueprints/dimensions
  151. GG Evo IX MR at Cosmo Motors
  152. Apexi AVC-R TypeR
  153. Injector Pintle Caps for PTE Injectors
  154. Crack in Exhaust Manifold
  155. Electric Power Steering Idea Post
  156. Injector Question and Recommendations
  157. Evo Headlights ( No aftermarket or easy replacement )
  158. Evo 8 Dies When Turning Steering Wheel
  159. Accident with a stupid deer
  160. Much help needed. Please
  161. Where do people in British Columbia, Canada, go for their Mitsubishi Evolution needs?
  162. HKS DLI ignition
  163. Largest IC
  164. Evo Oils Manual
  165. Driver side fan evo 7
  166. Evo9 hot hair constantly blowing
  167. 4g63 engine stand bolts
  168. Trying to reach 700hp
  169. Would I make a safe 350kw+ with the set up I'm building????
  170. Evo IX vin sticker under hood
  171. What could this be from
  172. 03 evo 8 running rich.
  173. Issue after issue please help
  174. Boost leak found
  175. Need help on purchase
  176. Evolution 8 shift cable issue?
  177. ISSUES: OEM Fan Control Module w/ Flex-A-Lite Fan
  178. Evo 8 door sticker
  179. Help identify what brand intercooler piping and intake are?
  180. Rattle left front at 2k RPM
  181. Rattle left front at 2k RPM
  182. AC & Recharge questions
  183. Sunglasses Holder wont close
  184. dealer underfilled oil
  185. No Power
  186. Need help with my evo
  187. Throttlebody
  188. Evo IX P0335
  189. Wideband O2 Sensor Only Showing Stoich
  190. Seat belt clip on evo9
  191. Clockspring question
  192. Wondering what evo to buy. Imported evo 3 vs evo 9
  193. Need help, no power going to ac compressor (evo 8)
  194. Need help with trans fluid/ trans noise
  195. What heart break looks like
  196. Evo 9 Air conditioner help
  197. Evo 8 MR rocker cover
  198. Anyone know how to install rexspeed k-style diffuser for JDM 7/8 rear bumper?
  199. Buying an 2006 Mitsubishi Lancer Evolution IX
  200. Can you install a lip on an MR bumper?
  201. Just a question about crankcase pressure
  202. Another weird nose thread!
  203. Replacement OEM Badges/Emblems
  204. Vacuum Line help
  205. anyone know where/what these connectors do ?
  206. Clicking when turning right after cars warmed up and driven for awhile.
  207. Broken waste gate flapper valve!
  208. Evo Shift Knob 6 speed sticker
  209. Should I buy this evo or not
  210. Car Won't Start
  211. Low Mileage MR on BaT: over $40K?
  212. Where's the Big Turbo Low Off Sound?
  213. Evo 8 block o ring diagram
  214. Discontinued Fuel Line Clips
  215. Fuel System Components Rusted / Need Replacement
  216. Front door rod end clip
  217. How do i a WTB in here?
  218. How do I get in contact with EvoScan (Limitless)??
  219. Transmission repair shop
  220. Diagnose issue - bad alternator?
  221. I guess it's my turn for a HELP I'M AT THE TRACK AND IT BROKE thread
  222. Strange Noises From Engine Bay
  223. EVO 6 RS or TME RS?
  224. Guy backed into my Evo
  225. Cluster Warning Lights Indicators
  226. Hi ,this is my presentation and ive a question
  227. 2006 Evo 9 Rs white rare?
  228. Airbag recall service
  229. Tial 44mm wastegate stopped opening
  230. Loose starter bolt
  231. Small battery
  232. 2004 Evo will not start
  233. Coolant Leaking
  234. Help
  235. Key remote Options
  236. Ac problem
  237. lean afr with ac
  238. Last day of MAP Cinco de Mayo sale!!
  239. Evo 8 grayish smoke at idle
  240. ABS light flickering and ALL ACD lights off after car audio work
  241. Headlight ball joint/grommet/clip
  242. Evo 6 electrical problem
  243. Evo 8 question
  244. Modding advice / questions
  245. Stupid Q getting a new key, mess up my tune?
  246. Oil catch can setup?
  247. Buying a beat evo 8/9
  248. Loose vacuum hose
  249. Retrofit Mitsubishi factory cruise instead of aftermarket?
  250. Need advice on how to sell my Evo
