View Full Version : Evo General
- USDM Mirage/Lancer, JDM Evo 1-3 body & chassis parts interchangeability
- Evo 7 RS Sprint edition
- Why are CoPart Evolution 8/9/X so cheap?
- EVO 1 Axle interchange????????????
- I got into an accident, need some advice
- P0131 and P0137
- Block and head machining.
- What is this knocking sound on my evo 9?
- Evo 8 boss kit query
- Stock Evo 8 Stumbling While Cruising at 60 - 80 mph
- So I need advice
- R-Spec Performance oil temp sensor for factory guage
- 4G64 Evo 5 build
- Evo 4 Daily
- Evo 9 MR Idle Rhythm
- EVO 8 ACD retrofit
- EVO 9 cranking but not starting
- Another Evo Whinning issue
- 2006 evo ix gsr, detective work
- Any like new VIII or IX's left?
- New mounts for the evo 4
- Inner Tie-Rod Issue?
- Electrical Help: Headlights
- AMS 3.5 FMIC with ETS Short Route 2.5 piping
- Evo 7 GTA Block Heater?
- plastic carpet clips
- Could use another set of ears to help diagnose engine noise
- Is a converted Evo 7 GTA worth considering?
- Horrible misfire/starting issues after HG/TB/radio install
- What part is this?
- Evo 8 ignition issues
- Evo 7 engine and transmission dimensions
- Evo 4 airbox
- Evo IX Parts Diagram
- Need some help!
- NEED HELP - harmonic balancer??
- What bumper is this?
- What is this thing?
- Fuel feed line upgrade
- Can you pass Cali Smog with bolt ons?
- Evo 4 airecon delete
- JDM Evo VII GTA Intake manifold and throttle body on USDM Evo VIII shell.
- That damn cost of propulsion!
- On what date in 2006 were the Evolution IX MR and SE versions released ???
- Evo 8 Help: Vacuum Hoses
- Front Brembo Seal size
- oil temp sensor for OEM gauges
- Anyone know where I could find this part?
- Evo 5 Project - Germany
- Master Cylinder/Slave Issues
- Broke body stud
- Evo 9 stock turbo, price?
- Importing a IX to Quebec, Canada
- Evo 8 TOB not staying engaged?
- Weird bolt/pin came out from under car.
- Evo 4 front wheel arch liners
- Cable transmission 5 sped
- Evo 9 vs Possibilites and My Imagination
- Car keeps unlocking all the door
- Lean AFR
- Help me! Evo 8 FQ300 or Evo 9 MR
- 03' Evo Rusted - looking for insight on sale price
- Trigger wire/fuel pump wiring
- Evo Cam Idle Issue/Leak?
- Help needed
- Evolander
- Rust inside transmission. What now
- Loud rattling mystery noise
- Las Vegas Baby !!!!
- Replacing gas tank. Ideas on steps?
- Oil filter housing questions
- spare tire tool kit
- Injector Dynamics F750 Mounting
- will defrost work if i block off heatercore hoses 2006 mitsubishi evo
- To paint or not??
- Evo 3 crank no start
- Evo 6 E85 Timing
- Evol 9 state referee
- New Evo Owner Problems
- Spec Twin Disk Hydraulic Throwout Bearing
- Leak now gone???
- Help me decide on a Turbo and
- CA Smog problem
- Anybody Know What This Is?
- Evo III GSR Center Brake Lights (Sides of License Plate)
- New Member - Here is my EVO9 GSR
- Daily drivability Vs. Race car
- IRP, Coolerworx, or CAE shifter.
- Evo 9 stalled when braking
- Idk what to do help meeeeee
- Evo 6 lean condition
- Squeaking noise from drivers side front wheel
- When car is hot, backfire and shuts off.
- Issue with my evo
- New Wideband Spot
- EVO won’t start
- Exo IX license plate light bracket
- Anyone know about wiring up external fuel pumps in boot??
- Bluish smoke NEED HELP
- Purchasing and registering an Evolution 1-3
- Switching intercooler piping
- Idle issues cold start/trouble starting warm. HELP!
- Are my Ganadors authentic?
- Which to do first? Smog, Tune, or Recall?
- Is it possible to add 6 speed reverse ring to 5 speed shifter?
- "Mellon racing" the myth Evo off gauge cluster
- O2 sensors
- AC options for FF
- What direction should the Relays Face?
- What diffs does this guy have and how can we get in on this action?
- My First Evo 8
- What’s the best place to buy evo 9 OEM SE lip?
- Built Evo 8 Randomly Breaking up
- evo 8 head to evo 5 - heater hose problem
- Stock 9 block
- Voltex/Varis Mismatch Parts
- Building a EVO 8 today would cost over $65,000
- How to fix p0401 code?
- stilletto’s Garage
- What BOV is this?
- Lean idle, lean cruising
- Big coolant leak.
- Ignition Switch Source
- Where to find JDM Evolution overlay for cluster
- Best Tuners in NJ ?
- Lancer A/C for Evo 8
- Evo 9 ignition fuse help!!!
- Common heating problems
- Flashing/Reconfiguring *FRONT* ECU in Evo 8/9 (Not engine computer!)
- Cam angle position sensor.
- Who's using TI exhaust manifold studs?
- Valve stem seal replacement.
- Off the shelf built head or assembling parts to build
- Evo 8 running rough.... Sensors maybe? HELP!!
- Rear widebody
- Bought a modded/tuned evo 9...
- Any advice on replacing the ball joints? Upper and lower
- Coolant reservoir filling up?
- Evo 8 Yakima Baseline fitment... same as lancer?
- history of the mitsubishi lancer evolution VIII
- Evo 5 ac condenser
- 207k mile EVO VIII, sounds awful on cold start, but OK when warm(I think)
- Evo 8 alternator and timing cover help
- Drivetrain Shaft Issue Evo 8
- Recaro seat rails rubber end caps
- tips when i go back to the tuner tomorrow on an issue I have
- smog readiness
- Who still ports?
- 2005 evo crankwalk (need options)
- PCB scans/ schematic's?
- Ecuflash error
- Transmission compatibility 8-9
- Dan's 1100HP+ Evo 8 (60-130mph in 3.5 seconds)
- Continuing with this evo 8?
- Underbody Help
- Rattle Noise when Decelerating (Flexplate?)
- Will a Lancer windshield fit a Evo 4?!?!
- Idle adjustment after IACV switch. Ecuflash
- Always wanted to buy Evo... but now Im not so sure
- Having an odometer issue, need advice!
- Please Help! Turbo Oil line to head will not connect 03 evo
- 2003 evo 8 value
- Spare Tire Bolt Size
- Evo 8 or Evo 9
- questions and help please
- Evo value and buying advise
- please help rocking back and forth
- Intermediate shaft stuck in t-case
- Whats my Evo worth?
- Slack in between cam gears too much?
- Made a gauge pod
- Question/Help about ECU
- 06 MR Oil Temp Gauge Wiring
- Fuel Return and Feed Hoses
- Intake adapter plates w/ tuning
- Engage A/C clutch
- Tragedy in Evo and Cycling community (RIP Curt Brown)
- Evo 9 bumper brake duct
- AYC clutch delete to instal CuscoRS diff
- TRADE -2006 EVO MR for a 1991 240sx S13.5 + Cash?
- Evo 4 Part Numbers
- Damaged Hood repair Evo 9
- Throwing cam and crank cel after driving car hard around switchbacks
- GT Wing VS Stock Spoiler
- New car running issues
- Push Start Button Help
- Axle to to t case seal
- Driver side washer nozzle pressurized?
- Do I have an issue??? (Spark plug)
- EVO 8 New Keys?
- 52mm afr/boost combo gauge
- Evo 8 Buying Needing Advice
- Gauge pods
- Evo 8 Passenger Side Fluid Leak
- Balance Shaft Sheered Teeth
- APS Exhaust
- Evoscan shipment issues
- Wastegate spring
- Innovate ECF-1 vs AEM Failsafe Opinions?
- unknown leak passenger side
- Newbie to the channel, 4g64/4g63t swap
- Boost leak at valve cover
- New to the forum and Evo's
- Having some trouble need some help!
- Can’t rev past 2500rpm
- Front seat mounting stud question
- Bayson R sideskirt issues
- Can’t switch maps please help
- Sitting too high??
- Went to smog, now REF
- Clutch pedal soft after Built motor install
- Timing belt cost and shop Recomendation in NE Ohio?
- Looking for Correct License Plate Holder
- New to the forum
- How much would you pay for this 05 Evo MR?
- Cam angle sensor relocation kit?
- rebuilding the stock turbo. where to get the shaft balanced?
- evo ix not starting after turbo/timing work...
- 500hp Evo Diary
- Reducing exhaust drone with sound deadening
- JDM Evo 8 Replacement Key
- Evo 8 Gas Tank
- Torque solution rear motor mount question?
- Evo 8 engine light prevention
- E3 spark plugs for 9's
- Evo 4 problems
- Evo 7 Intake
- Loosing power check engine light
- What exhaust is this
- Starting issues
- VOTE / Car of the 1/4
- EVO8MR Fuel Pump Hardwire Help
- What exhaust is this. Help!
- No tune & 02 dump
- Which exhaust
- Evo IX Head Gasket Passage
- New EvoV Owner- What Would You Do?
- AEM Infinity Evo 8
- Boost leak at turbo compressor cold side
- Should I rebuild my transfer case while I have my car apart to replace clutch
- Fuel problem? Need help
- How to remove Evo IX MR reverse lockout lever ?
- Turbo suggestion for my engine..
- Who or what route should I go with for a built motor
- Evo starter options
- Fuel pressure not rising 1:1 with boost, replaced/swapped almost everything
- evo 7 help
- Nt03 falken tire setup opinions
- Test driver blew my Evo 9 transmission! 😡😡😡
- Differences in Evo IX 05 to 07 ADM models
