View Full Version : Evo General
- Evo 5 Information
- im BACK
- Looking to trade my STi for an EVO. Any specifics to look for?
- painted my headlights
- Whistle Noise!?
- Transmission Woes :(
- Recommended Automobile Transport Company
- Destroyed transmission?
- Block?
- helpp
- What is this? :/
- floor mounted harness
- ATP Manifold Adapter
- Evo 8 cat fit Evo 9?
- Boost gauge for tuning?
- Please help me.
- Rear Window
- HKS intake filter replacement
- What LICP is this?
- tcase leak...
- quarter Master Or Tilton
- What is this??
- EVO IX possible blown engine/new build!
- Prosport oil pressure sender
- weird "problem" after ecu reset
- how long did you wail 4 GSC s2 cams
- Oil leak cant find it!!
- Price for a block?
- blown head gasket
- Full Boost Racing ???
- found a loose wire, what is it?
- Is it possible?!
- anyone use these as turn signal
- Rear passenger window randomly stopped working?
- DDM HID headlights: Everything works except low beam
- Door dings
- Badges
- Timing belt job: Car makes loud noise
- 511/2011 Car Show Please Vote for my FPBlack Buschur EVO
- Which exhaust is better??
- map sensor issue?
- Why does my car act as if it hits fuel cut under half throttle
- 2006 IX Wheel Gap
- Looking for exhaust opinions
- Cant fill up with gas!/ Why do evo pedals suck so bad? Dual whammy thread.
- What's this called
- Any recommendations for warning triangle reflectors?
- random evo 9 motor question
- Is my boost guage working right?
- ATF Quicke! Have a ?
- flywheel bolt torque.
- Need some bright thinkers!
- Acceleration problems
- Anyone Have A Perrin Oil Catch Can?
- Guys with rims.
- Dealers are nagging me...
- Early Model Evos
- greddy rs bov issues?
- Those of you with 500+ ftlbs of torque, how did you battle torque steer?
- is it nessecary to upgrade rods? evo8
- Windshield weather strip
- Need Facts about evo 8 vs evo9 Help Clear somethings up
- This is why you should run a catch can
- I'm confused
- Amsoil Dominator Coolant Boost
- Wait what turbo is this?? (pics)
- Coolant leak help! (PICS)
- crash beam bolt sizes please?
- Buy a high mileage or low miles?
- Creative GoPro HeroHD Camera Mount?
- car wont start
- Aftermarket oil cooler? YES/NO?
- Take off speedsensor
- Evo 9 wagons
- Fidanza cam gears timing marks are off?
- What is this on my evo8???
- need some help with broken motor mount
- Lancer A/C compressor fit in evo ?
- Beggining the modding need a bit of help
- Turn signal WONT CANCEL
- Need some knowledge?
- Anybody else use camber strut bolts to fix their alignment?
- A little problem encountered after clutch started to slip
- Synapse Synchronic DV Fluttering?
- AEM boost gauge problem.
- Sunroof Cover Removal
- new engine rough starting
- Lost boost
- Strange noise after new clutch (video)
- Mivec problem
- Very weird idle! (with video) PLEASE HELP!!!
- Estimate My HP
- idle From Hell
- evo ix rs/gsr buying dilemma
- EVO8 AWD Swap into 2003 LANCER ES
- Does Synapse still modify the older model BOVs if you send it in?
- Need help finding
- FP Red Turbo Install, Ivey Tune to Come.
- Evo 8 completely shut off in 4th gear?!
- Need Headlights
- Need advise on launch start problem for E9..
- backed into a parked truck tonight
- Fixed door sensors, but automatic dome light still does not work??
- Front End
- Hey! I need some help! Value!
- Help - Breaking Up Issue
- Anyone have sparktech sequential non cdi for a evo 9?
- Any possibility for aftermarket headlights?
- N2MB Wot Box
- Anyone tested a gtX3071r?
- 500 hp evo build
- Need upgrade help
- Will cams kill my Evo?
- quick question on locking oil pump while doing timing belt
- Where to Buy: Spare Key / Key Fob Remote?
- Help!!! Inspection Tomorrow.. My brake lights decided to stop working
- Frustration with Synapse DV flanges
- Bizarre AC problem
- Anyone running Perrin filter on aftermarket intake
- evo 9 block with 8 head
- Happy Birthday to me!
- Loud rattling noise in 1st gear. HELP!!!!
- Evo IX handbreak.
- Summer-izing: Cooling system upgrade help
- stroker? or bigger turbo?
- AMS Delrin EVO/DSM Shift Knob or Varis Dry Carbon Shift Knob
- Headlight help
- Which body kit would be best for an Evo VIII
- Popped an intercooler hose off today at 80mph
- Intermediate Steering Shaft
- OIL pressure drops at higher rpm
- Would you stay OEM ECU or go AEM if you couldn't get SD tuned in you state?
- Oil Squirters?
- do evo 9 valve covers work on a evo 8 motor?
- evo 9 bov
- quick question
- Will Evo7 rear arm rest fit Evo6?
- Voltex for UK rear bumper
- SLVRNBLK's TB Evo 8 (a sad story....)
- So i came back from Vegas..
- Help me convert my VTA Greddy RS to Recir PICS
- Best Intake
- Exterior Door Trim... Anyone know where i can buy this?
- Shocks??
- Transfer and diff bleeding procedure??
- setups opinions reviews?
- Boost leak test gone awry...
- Possible poly do luck lip availability!!!
- Ultimate Police Repellent!!
- Battery Fuse Assembly
- clunk from drivetrain when launching!??
- Members/owners affected by the storms okay?
- car won't start.
- CF Wing Peal or Sand
- Siezing drivetrain after sitting? Is this normal?
- vortex generator=pos
- New Trunk Question
- stock wing
- Front Left Noises, SES Flashing
- Really important questions
- Synchronic BOV HELP!!
- best looking triple gauge pod?
- front and rear main seal leak
- Poly do-luck lip
- Safe to drive?
- Evo will not start...need help/advice
- Evo 8 power steering pump
- Aem Tru boost overboosting
- Suspension is stuck
- Are evo 8 headlight lense the same as 9?
- Evo wont start!
- trouble shooting
- proper place to install e-cutout?
- break-in built motor question!!!
- Will a Lancer clockspring fit on my Evo
- Starting problem
- Typical track times?
- IX Bumper Conversion Question
- super bummed...
- Performance or looks!
- can a ACT street lite flywheel be resurfaced
- Voltage Problem
- what brand motor oil/filter are you using?
- is this a good idea? oem exhaust with cutout?
- good deals on autoanything.com
- Parts from Extreme Tuners?
- Whats next to the ABS module? (pics)
- Looking for cars to record; Free dyno session
- EVO 9.......Dual Exhaust?
- How much do you think a new paint job would cost....
- hks 272 or gsc1 for stock turbo.
- Thank you tuning companies, take heed to what I'm saying.
- Help with an EVO decision?
- What should I add before a Dyno tune?
- Does this capped off port see oil pressure?
- Removing handbrake question
- What got wet?!
- Belt noise after replacement, Lubed pulleys with oil, now MORE NOISE
- How much do u pay for insurance? (under 25)
- UK VIII rear bumper on IX?
- Dash Cluster Lighting Issue...Help..
- help please! car is breaking up.
- Tranny/Diff noise...Need opinions
- Think alifter stuck
- WORKS Diverter Valve
- ACD lights problem
- Rear end whine?
- APS Twin Vent leaks
- help!
- Evo 9 rear jdm rear bumper?
- No electrical power
- Trustz Gauge Overlay Instructions Needed
- why is there coolant in my catch can?
- Anyone running turbo back straight pipe?
- Is this a bad sign?
- Had a shop lifted my EVO by the frame rails and put dents on them, any concern?
- transfer case help!
- wass up guys need help
- WHAT A GREAT dAY!!!!
- Is this too much power?
- Dont buy spec clutches!
- Just bought all new fluids, tell me what you think!
- EVO 9 oil pan same as EVO 8 oil pan?
- is a 93 evo any good.
- Evo buying questions
- Shudder in 6th when letting off gas after accelerating?
- Missing DP Exhuast bolt
- External wastegate for FP Red ???
- both reverse lights stay on
- Can I run this gas
- JM Fab intake for FP HTA Green 84mm?
- Greddy turbo timer
- My car isn't starting.. HELP
- 2x OEM Oil filters ???
- '03 TBE fitment on '05 MR
- clutch pedal issue
- 6 bolt dsm t-belt to my evo8????
- Evo's insured with Progressive
- Mechanical o2 fix
- EVO MR JDM Headlight Set - which bulbs do I need?
- installing evo 9 turbo
- Broken bolt for manifold heat shield, removal advice?
- Car trade, bad or good?
- car cutting off when gear goes to neutral
- Anybody running these gauges?
- Looking to buy my first Evo, what can I expect for 15K?
- Help with UICP
- How do you decided 2.5 or 3 UICP ?
- part number request
- What more cost effective evo guys
