PDA
View Full Version : Evo General
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Id2600 injectors who is running them
  2. Intermittent Multiple Random Misfires
  3. RHD Power Steering Rack Part Number?
  4. Power Steering AN Lines
  5. Need help in identifying part
  6. Where to get replacement pintlecaps for the OEM evo8 injectors?
  7. Aftermarket or Stock Cam? Evo 8
  8. Best Front LSD for NON-ACD
  9. Transmission Bolts Torque help needed!
  10. What Lip is this? Evolution evo lll it also has 4WD style fogs
  11. Sun visor compatibility?
  12. Estimated value of 2005 EVO needing transmission
  13. Help, battery issue
  14. High Resistance at Connectors for Exhaust CAS + MAF
  15. I’m rebuilding an evo 9 with frame damage
  16. aftermarket hood + OEM hood sourcing questions
  17. Oil feed line filter question
  18. Evo 8 LINK G4X ECU WHO IS RUNNING IT?
  19. Evo 5 cut vacuum line?
  20. Radiator cooling plate for evo 8 with 6 radiator
  21. One owner, no mods, original clutch and trans 03 Evo VIII w/ 194,xxx miles
  22. 1998 Evo 5 Compatible USDM Evo Radiator Hoses
  23. Evo IX MR A/C only works in MAX A/C and the A/C Button does not work.
  24. evo no start
  25. Bucking - Afr rich+lean on constant throttle
  26. Felpro Oil Pan Gasket
  27. I bough a crashed Evo 9
  28. Starting Issues - Loose Ground / Burnt Wiring
  29. I bought a crashed Evo 9 at the auction
  30. Help Identifying exhaust & search Silencer
  31. 3rd brake light and rear brake lights staying on constant.
  32. Evo 8 Bolt/nuts sizes on the whole car
  33. Help Identifying Bolt
  34. Teach this old dog new launch tips
  35. JDM Evo 6 Zero Fighter.
  36. Where to buy
  37. Aftermarket ABS Sensor Replacements?
  38. wideband reading rich
  39. Need help with cams
  40. Low Compression, need suggestions
  41. Readiness issue
  42. Rear wiper, water leak?
  43. Valve springs for 900whp evo
  44. Brake lights won’t work correctly when car is running and I have lights on!
  45. Streetability
  46. Rear Caliper Pin holes oblong
  47. Jdm 9 banjo looking steel line that resides right above the exhaust manifold
  48. Best shops for full build.
  49. X Rear Seats in 8/9?
  50. Where to find Hood Vent Seal?
  51. EVO 6 intercooler options
  52. Help identifying this metal piece I found inside axle
  53. New Evo VII Owner: Oil weight question
  54. Evo IV Engine Swap - ECU Options?
  55. Turn signal hyper blink
  56. 1995 Lancer Evo 4
  57. Evo 8 oil filter housing plug
  58. New Billet Engine Mount Option
  59. My Evo is hurt, sourcing parts
  60. 2x 38mm wasegates or 1x 44mm?
  61. Evo 8 stalls plus burning rich
  62. What's the best dual pumper setup?
  63. Will DSM Struts Work On My Evo III?
  64. Those without original window sticker
  65. All weather floor mats?
  66. Oil leak
  67. Resonating sound - Evo 9
  68. Evo high output alternator 160AMP
  69. Spare tire mounting bracket removal ?
  70. Windshield cowl rubber seal, part number?
  71. Twin fuel pumps external check valve??
  72. Timing belt whine but tensioner set correctly
  73. Back in an Evo Soon
  74. Trunk drain for water in spare area
  75. Build 2.0l 4g63 vs 2.4l stroker built.
  76. Fuel smell in the passenger rear wheel well
  77. Evo IV misfire then ok then misfire and cylinders stop working
  78. Jdm rear bumper
  79. I just got an abandoned evo 9 mr for free (pics inside)
  80. Help to a newbie ! My Evo loses power after a while
  81. Service Engine Light Turns Off And On When Wants To.
  82. Evo 8mr
  83. Clutch fluid goes black
  84. VP X98 safe for FIC 2150cc injectors?
  85. AC on with heater question
  86. evo 8 clicking sound after wavetrac install!!
  87. Voltex double over fenders over stock quarter panel
  88. In need of Evolution GT-A Service manuals
  89. Engine wiring harness
  90. 03 Evo 8 STFT read 0
  91. anyone looking for a stolen TME?
  92. Evo IX Launch Control - not working
  93. Mitsubishi evolution 8 differential Cooler
  94. Why not buy LHD evo 5
  95. Anyone help ?? Trying to track down my old evo....have everything but a name
  96. Cluster bulbs
  97. GTR coils
  98. catch can
  99. Oil light.
  100. shocks and Springs
  101. RARE Evo 1-9 articles and content
  102. JDM Bumper Exhaust Fitment
  103. Low RPM ticking sound, only in gear when on throttle
  104. Pairing ETS wide tank IC with Injen full IC piping?
  105. Turbo manifold to turbo washers
  106. TurboXS DTEC GameBoy Boost Controller
  107. wing braket
  108. speed density
  109. Windshield wiper sprayer hose question
  110. fan control module
  111. Best Shops in the East Coast to work on Evos?
  112. front bumber
  113. Original owners still out there?
  114. timing belt failed prematurely
  115. Evo 9 oil cooler in evo 8
  116. Question for gauge in lancer spot on cluster
  117. Evo 4 with evo 8 transfer case
  118. Evo 7 GSR Hood vent options? OEM is no more.
  119. Can you remove a rear subframe with jack stands and a car jack?
  120. Rust converter behind rear subframe.
  121. Intake Manifold Bolt
  122. I am back, Evo V on the way !
  123. evo best crankshaft? callies crankshaft forged vs billet
  124. Car covers for Voltex evo?
  125. Evo 8 crank walk eagle crank ( failure)
  126. About to buy this Evo IX - Requesting Advice
  127. P0134
  128. Stolen Evo 9 VIN locations
  129. Belt tensioner broke
  130. Evo 8 with Mitsubishi Mirage aluminum radiator
  131. Evo 8 - FIC 950cc Injectors - Running Lean
  132. Flex fuel setups
  133. Looking for an 8/9 Spoiler
  134. Tire pressures for road racing?
  135. Evoscan won’t connect to ecu trying to log
  136. Are the battery tray studs removable/replaceable?
  137. Emissions... in 2023, what are folks doing?
  138. Best AWD?
  139. Cluster plastic
  140. Mitsubishi lancer evo 2 1994
  141. Weird sound on Evo 9
  142. Evo 5 idling issue
  143. crank to Flywheel dowel pin evo 8
  144. Thinking of selling...need help on realistic price
  145. New YouTube Video on Buschur's Project White
  146. 2003 Evo Vlll Build?
  147. Dealership OEM Short Block Availability
  148. new exedy twinplate clutch. CAR IS SLOWER
  149. AC not working when raining on highway
  150. Evo IX random no start issue
  151. Evo 5 no crank. Starter clicking fast
  152. Summer progress
  153. 2003 Outlander Rear disc break swap?
  154. Coolant hose kit?
  155. Cluster overlay
  156. Evo 8 startup log - won't fire up...
  157. Changing Oil and Front Jacking Point
  158. Evo 9 Coil on plug system
  159. Need Help!! Lean spot 3.7k and bog during part throttle
  160. Wtb evo 9 usdm tail lights
  161. Brining Evo 8 back to Life - Need TS ideas/help
  162. What Is This Part Called? - Bought My First Evo Project
  163. The Hood won't close with hood shocks
  164. Replacement Alternator
  165. Evo OEM PCV Leak?
  166. Installing ETS battery kit - stupid question
  167. 2002 EVO 7 manual swap
  168. I Bought a 1947 Mile '05 Evo VIII!
  169. Speed density on Evo 7
  170. No power at ignition.... stumped
  171. Wheel bearing options
  172. Maintenance/ general information
  173. Buying an evo 6 tme
  174. FS - Evo 5 RS oem+
  175. Is this factory aero part worth anything?
  176. Window wind deflectors
  177. Grimmspeed Ebcs fitment Issues
  178. Oil pressure drop after oil cooler delete plugs
  179. Rota P1R Fitment
  180. Key FOB Not Programming
  181. extended exhaust hangers?
  182. 2 Step (clutch switch question)
  183. Iat Sensor Location?
  184. Aftermarket body panel companies
  185. Anyone use link pnp?
  186. Rear wiper motor thread broke off... Possible to fix or replace the unit?
  187. Evo-9, 200K mile club :-)
  188. After installation of cams issue
  189. Clock Alternatives
  190. Track and battery
  191. Where to buy this part
  192. Evolution engine noise when car warm up
  193. Replacement window visor clips
  194. Evo jdm rear bumper exhaust help
  195. Info about my 4g63 in Evo IV
  196. 2003 evo 8 rear window switches
  197. Evo 8 MR FQ300 front windscreen washer motor
  198. Coolant Leak under Timing Cover
  199. is my clutch smoked??
  200. still boost issues or atleast issue with boost reading
  201. Rust under windshield cowl
  202. Front bumper quick release fitment
  203. Help Needed! Rattling Sound when Accelerating - Mitsubishi Evo 6
  204. Recognize this intake manifold?
  205. HKS head gasket or OEM high boost
  206. 2.2L pistons/rods combo help please
  207. Bucking and hesitating
  208. Evo 9 Running Rich when hot?
  209. 2005 VIII MR Service MAnual
  210. Rear bumper brackets
  211. high boost valve springs
  212. Front caliper bolts stripped
  213. Clutch salve cylinder bracket
  214. steering wheel lock Evo 8
  215. Topline lifters or oem?
  216. 03 Evo 8 From Washington State
  217. How many keys can be programmed?
  218. Quartermaster twin vs exedy triple clutch
  219. Bought a used 5 speed and it's kinda trashed. What would you do?
  220. ARP 625 head studs torque specs
  221. Engine brackets evo 8
  222. Evo 8 specific inlet coolant pipe, discontinued MN143306
  223. Wobbly Power Steering Pump pulley
  224. Tomei Oil Slicing Baffle plate
  225. Need evo 8 longblock (local ish prefered)
  226. Looking for evo 8/9 rear end parts
  227. Serpentine belt idler pulley difference?
  228. Evo 8 usdm fuel tank filler neck pipe
  229. Ralliart Jackets for Sale
  230. EVO 7 radiator
  231. Ecu Tampering
  232. Looking for evo 8/9 parts
  233. Evo 8 tries to crank without key in ignition
  234. Walboro Whine Issue on Evo VIII
  235. Interior door handle
  236. Evo8 Ceramic Cat replacement
  237. Evo Shops left in Colorado
  238. 2 wasegates setup on single scroll turbo!
  239. I need help! Need a EVO 8 GSR Stock ROM (USDM Version)
  240. Original Evo articles and more
  241. Rear Window Frames - Rusted (IX)
  242. Vibrating clutch pedal
  243. tuners in south new jersey?
  244. Gsc racing balance shaft vs stub shaft
  245. Which Catch Can to do the Job I require
  246. 2003 Evo 8 new driver seat
  247. What would you do?
  248. o2 Sensors failing/P0134/afr/stumbling
  249. Remove coolant port?
  250. Rear diff upgrade
