View Full Version : Evo General
- Any EXPERIENCE using www.mitsubishipartscentral.com ?
- ok so this is weird
- Ashtray gauge pod
- Royal Clash
- Help oil on spark plug!!!
- HELP! Heading restoration
- Evo was hit. Need advice.
- SpoolinUp COP Swap - Engine Won't Turn Over
- Screwed up my hood latch install
- Scan tool, secondary codes, which one will read our dam cars.
- TFLcar EVO 9 review
- Toxicfab gone forever?
- S1 or S2 cams for 500-500hp build?
- New to the page
- Damn Spark plug _ Which to use _
- Evo 9 OEM front Canard
- Fun Thread: Noise from Engine bay - NVH Experts
- Fuel Pump motor seized, and sender unit fried
- Car won't rev past 1500 rpm! Help!!
- What is this resistor for?
- ACD pump in/out thread size.
- Spark Tech CDI unit order - Where's Craig?
- Oil threw exhaust Manifold
- Purchasing Evo 8
- carbon fiber air ducts
- I've screwed up my Transfer Case!!!!
- JDM rear fitment issues
- Openport 2.0 Mitsu Reflash Adapter Pin Diagram
- Evo 9 loose flywheel
- Lighter Light
- Best non OEM UK Badges?
- Clutch question slight rattle
- HVAC Vent Position Knob Stuck - Evo 8
- Race car setup ideas
- Dual pod cluster gauge, why isn't it made?
- Lancer Evo 7 import
- Shifts3ctor even ... 4door class winer
- Evo 9 gates water pump
- Securing Trunk Bins, Ideas?
- timing question Help
- Is it normal for the idle to drop when you turn the heater on ?
- Evo Front Lip
- Cam Shaft Seal Install?
- What gasket goes between Turbo and downpipe?
- Kuda Style Cell phone mount?
- evo 9 cluster buld is very low by the rpm and speedometer
- Options with a slightly used battery
- Diagnosis Help - 3 Wheels spinning
- Is it worth upgrading Cams?
- Another Stalling going into Neutral issue
- EVO AC System Question
- Evo 8-9 Spoiler Bolt Spacing
- Aftermarket seats sit too high.
- PCV - broken? Can hear it during idle (back-forth)
- Oil Catch Can - To or not to route to the intake
- Help needed with battery drain issue
- Purchasing a spare turbo
- Financing difficulties
- Still learning about my evo what does this plug go to ?
- Hi Im new here!
- What's better Evo 9 or X?
- Anyone relocated their rear bumper bolts???
- Transmission Serial Number(?)
- (MD) - Shops for 60K/Timing Belt Maintenance
- Car wont Crank. Help!
- nose chop
- Is there a "pre" T-Case death whine sound?
- AEM Digital Wideband Gauge Issue
- How much do JDM Evo VII/7 parts cost?
- PSA: Megan racing catbacks are JUNK
- What would you do
- need help, went over deep puddle, belts whine now
- Slightly smaller battery for UICP
- No Start Issue
- new to the evo world cross addicted from 240sx
- Anyone know what this bolt is does it even go to an evo ?
- New clutch and flywheel issue
- Evo 8 motor mounts
- IACV Test
- Moved the AEM Infinity to the engine bay, and other mods
- Somewhat new 06 EVO IX MR owner
- P0401 and P0069 Problems
- Boost Issue. Bad wastegate? Logged with EvoScan
- FiTronic Questions
- Flushing oil
- Evo 8 Engine help
- Base Tune
- Automakers Still Selling Cars With Defective Takata Airbags
- Help with buschur racing map switch
- Help please evo 7 fq300
- Sideskirt clip screws
- evo not boosting
- PC680 mini battery install cable routing
- New guy here
- Quick Injector Question
- Greddy Type24E LS Intercooler Kit
- Help with no start
- Evo V/VIII Inner Tie Rods
- Temp Guage going up and down? What's causing it?
- what size fuel pump i need?
- Looking for parts
- STM SS exhaust review w/ JDM rear
- Evo IV help
- TME 6.5 Engine number
- Bolt Size Question - Air Condition Lines Firewall
- Evo 9 ignition coil
- Looking for non-hid headlights that will fit my evo 9!! PayPal ready.
- Sizing fuel injectors
- Evo 9 Oil consumption?
- Starting problems
- New Guy - Evo V - Should I Buy?
- A/C Clutch noise
- Who makes/sells Lexan Windshield?
- What is it worth?
- Evovlogs have OFFICIALLY commenced! (Vlogs with my Evo IX on youtube)
- Check engine light.
- help diagnose this noise.
- Paint job
- Only getting 15-16 psi.
- E8 factory fuel lines - limits?
- On the hunt again
- Help a first time Evo owner out .
- annoying clutch sound "HELP"
- WTF is this thing?
- Removing harness from firewall to ecu
- Ringing sound after TB seals
- Evo viii tons of parts
- ETACS question.....
- P0441 and P0455
- What is this? Disconnected??
- Fluidampr.. is it for me?
- Cams
- old 4g63
- Best rear diff mounts.
- Brad penn 20w50 ?
- New IX, questions about Shifter/Shifting/Clutch
- Which Evo 5 should I buy?
- My experience with MAPerformance
- Wheel Shaking When Braking Not Rotors
- Evo 8. Big turbo, big fuel, big power
- Rally build?
- 5th gear grind
- Random Wiring Harness - Unable to connect with tantix
- Craziest thing I ever saw
- No IC Sprayer on 2003 Evo 8?
- '03 Evo weird problem -- felt like the brakes engaged?
- EVO 8 strange noise from serpentine belt area
- Car wont start on cdi ignition system.
- Evo Rolling Coal
- Evo 8 Timing/Cam Cover Bolts - What Size?
- whats the quietest 3inch exhaust setup
- Drove on wrong map
- Hose from firewall liquid dripping
- Wing won't come off
- Windshield wiper cowl clips
- Help. Tricks to un-pinning conmectors?!?!
- Power steering delete?
- Evo 8 Wiring Harness wired wrong?
- Rpf1 center cap loose
- Turbo Feed Line Filter (FP, MAP etc)
- What's a good oil to run in a 2.3
- Rexpeed parts review
- Fuel Issue In Heat
- What size fuel pump?
- Factory Mitsubishi Oil Filter what brand is it?
- removed dash harness with alarm, now it wont start
- Where to get parts for a evo 1?
- Weight Sensors under the seat. SOLVED
- 2005 Evo 8 throwing 2 codes need help.
- Evo IX Key Issue
- Diagnosing nasty transmission(?) noise
- Want to change motor oil!
- Triple Gauge Pod inn Stock MR Placemnt
- Evo 8 wiring harness diagram?
- evo twin scroll collector?
- Brick
- 🔴🔴🔴READY TO BUY MY FIRST EVO 9 GG SE strong buyer
- How many 8/9s are left!!
- EVO 8/9 trailer hitch design
- Knocking from transmission
- Just got tuned, reasonable results?
- Evo 9 Trans Rebuild cost?
- Evo tuner in NJ
- EVO IX Snapped ABS Sensor
- would my engine breath better with a oil catch can
- Hi guys, new here looking for direction please.
- Generic Brand air intake filters? Should i steer clear?
- Identifying parts
- 920 WHP Evo 8
- My newest video: Rock chip repair on my evo!
- oil pressure at WOT?
- CA smog😡
- Will a lancer dash with airbag and other srs parts fit evo 8?
- New set up on fp zero
- Apex silver with white BBS MR wheels
- My 03 Evo8 would only rev but wont go!
- Air bags deployed.
- Car sputtering at full WOT
- Rubbing...Moar camber?
- wanting to buy my first evo... help!
- Which wheels should I part with?
- Gauging the market price for a stock 81K Evo IX Drivetrain.
- Need help with headlight bulbs
- Trading my Evo in..
- EVO 9 timing belt
- Gas tank studs for sending unit
- Evo inspection condition, what do you think?
- Bumper manufacturer.
- Evo 8 Headlight, D.O.T.?
- Outlander trailer hitches on Evos
- WOT stutter and boost leak test
- New here
- Mishimoto intercooler questions
- Fuel smell after fill up - leaking sending unit?
- Need help on my boost leak
- Starting to make Youtube videos with my IX
- Evo ecu question
- It's been real
- Themostate housing bolts
- Foam breakdown in fuel tank
- when your number comes up
- Question about jdm bumper purchase
- Cell light flashing at wot
- Factory MR boost gauge
- Does anyone know this EVO 8 reg EV04JCB
- Weird start/ no start issue ongoing issue. **Help**
- Help: Evo IX tach flickers
- Need advice before making an IX MR purchase
- Smog shop recommendation in the Conejo/San Fernando Valley
- AEM UEGO noise over speaker
- Valve spring tool
- Abandoned Evo 8 In NW DC... a sad sight
- Is this why my car is idling like crap ? ( pics )
- Gates Timing Belt Snapped in Half on new build... How does this happen?
- P2195 o2 Inactive
- Shop wants me to pay for their mistake
- need help AC on my car blows hot air
- Headlight problems
- Evo misfiring after installing new plugs
- 05 Eclipse knocking issues
- Removing dash for Takata Recall
- Help my buy an evo!
- new evo 8 advice
- Suicide Evo
- Please help idle/afr's problem
- Need help purchasing mesh/grilles for my evo 9 bumper...
- 2004-2006 Lancer and Evo in expanded Takata Airbag Recall
- Shifter Cable Bushing Seized - Evo VIII Help
- Do I pay for shop for diagnosing?
- 2005 Evo 8 MR w/ 10k miles
