PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Front axle nut torque spec
  2. Would changing engine oil and filter not by Mitsubshi void my warranty?
  3. Shifter3 - Destiny Video
  4. Anyone has any history/info on this car?
  5. Trouble starting!! Any suggestions?
  6. Transfer case just doesnt want to go on nicely..
  7. Recap of my previous problem
  8. AFR Bounce 13-18+(lean) non stop while idling and cruising.
  9. Fake ARP bolts ??
  10. Difference of Evo 8 10.5 hotside vs 9.8?
  11. Sticky throttle at cold engine temps
  12. Will a tune finally resolve this issue???!
  13. Oil Smell @ 21psi
  14. Electrical Retainer Clips??
  15. Fuel cut at stock boost
  16. idle shutting down when release gaz pedal
  17. Advantages of putting an Aftermarket 13 Row Oil Cooler?? (Evo VI)
  18. Multiple Issues
  19. Omni power prototype Camshafts
  20. Blocking off AIT bung
  21. Evo's at Oregon Trail Rally 2012
  22. Blown/shattered Tcase after less then 15miles
  23. Might buy this evo 6...
  24. Rear wiper/wing delete plugs?
  25. EVO 8 Recall help!
  26. Idle/BISS and TPS question
  27. Small battery? Relocate?
  28. Rear O2 sensor dilema
  29. Wiper size?
  30. Evo 8 LED Tail Lights
  31. evo 9 anti-lag on longer than 1 min
  32. FRONT CV BOOT HELP......please read
  33. Rear wiper problem
  34. Intercooler fin pack, Have you seen this before?
  35. Battery in trunk
  36. Reconnecting sunroof motor
  37. What did you name your Evo?
  38. thanks
  39. Boost won't turn up
  40. odyssey pc680 battery tender?
  41. Where to get a Condenser without breaking bank?
  42. Which way turns boost down?
  43. Rattling exhaust
  44. Ideas on the next upgrades/2 step launch
  45. Ignition Timing
  46. check engine flashing
  47. boost gauge question
  48. Revving/idleing problem
  49. For those of you with aftermarket polished/mirror heat shields..
  50. Under Hood and Shifter Base Bushing questions?
  51. Local Dyno Day Vid
  52. No more 93:(
  53. To anyone running a Tial Q
  54. Help: DC sport downpipe w/ cat delete
  55. Light came on :(
  56. Can't pass inspection! HELP!
  57. Seibon Carbon Roof Guys-Step in.
  58. Do luck rep lips back on eBay
  59. Oil for summer
  60. difference in boost reading
  61. ACD Codes 65 and 82, need help!
  62. Idleing and revs problem...pls help.
  63. Virgin Evo 8
  64. Invidia Testpipe
  65. CBRD- 5/2/12 this week, forward facing.. more
  66. Propel fuel - E85 is now available in Fullerton, CA
  67. My car was lurching, almost stalling, and running very lean
  68. check engine light after intake install????
  69. AEM wideband vs. other widebands
  70. about launching my car at the track
  71. LC-1 Logging Help
  72. Evo part, info needle
  73. odometer question
  74. Weird water flow sound on cold start
  75. what color are the front turn signal bulbs?
  76. Evo 6 No spark No injector pulse! Going crazy
  77. ashtray bulb???
  78. I'm the oldest newbie. What's the popular mods.
  79. Oil feed line help!!
  80. evo 7 alarm specialist?
  81. Takata Green Touch Up paint
  82. Need help with wheel OFFSET
  83. VIII Valve Cover
  84. Hta86 on race gas estimates
  85. bee-r power builder help
  86. how to replace exhaust manifold bolts and studs
  87. WEIRD SMELL from COILS
  88. 2 stage boost controller, opinions?
  89. what exhaust for daily driving (I HATE DRONE !) [MERGE]
  90. Pcv
  91. AC Question
  92. How to covert to SD from MAF?
  93. Weird problem with hallman.
  94. Substitute Clip
  95. Thoughts, help?
  96. Oil in bov!!!
  97. Has anyone installed one of these?
  98. throttle response cutting out
  99. are these frame rail dents bad ??
  100. Wheel key lock options??
  101. idle drops and car shakes with a/c +++, any help please..
  102. Boost Gauge reads 5psi, car feels normal
  103. Spun bearing?
  104. help Evo8 wont start
  105. 450hp on evo8 engine
  106. Apologize if redundant, but new OEM nuts/bolts?
  107. US legal evo VII with IX front end
  108. Great Website For Hoods?
  109. paint
  110. Injector setup
  111. BR Double Pumper "My car hates me!"
  112. prosport oil sender issue
  113. Strange sound when I turn right
  114. buying car with ACD problem
  115. Do Evos ecu store data?
  116. Quite input on bulb issue?
  117. 04 evo rs
  118. Is my Megan O2 okay?
  119. I have a dust problem......
  120. Has anobody fited a "Walbro 400 LPH Fuel Pump Universal In Tank" to an Evo VI???
  121. Diverter valve & v band ic pipe help.
  122. problems!!!!! BATTERY/ E BRAKE LIGHT ON
  123. Installed CAI, now IC piping keeps falling off?
  124. BR Double Pumper filter question
  125. sound diagnosis
  126. Go Fast Bits Dual port BOV issue
  127. Electronic cut outs
  128. Evo Ticking Sound
  129. Can you vent a recirculating bov to atmosphere?
  130. Can I use a filter Sandwich port for a turbo oil feed source?
  131. Bov ????
  132. Voltex 5V vs GT wing?
  133. It will take a while to start. Help!
  134. quick ? about hood vent
  135. Muse o2 Dump Leaking Air
  136. t-bolt HELP!
  137. What 4" intake with SD?
  138. Temp gauge maxed out. engine cool
  139. what to do????????
  140. Will i need a new harness?
  141. Frame damage bad or not?
  142. boosting issue on evo 8 could use some help please!!
  143. Arp head studs without swapping the head gasket???
  144. Evo 8 Tach wiring to cluster
  145. Is this Repairable?
  146. Stock Water Temp Guage Help
  147. 05 evo 8 rs guys!!!! I NEED UR HELP?
  148. can u get a "blank" no hole flywheel whit a carbonetic clutch?
  149. Help! noise from under body when takeoff
  150. Evo build number?
  151. Evo 9 Not Visible Modifications
  152. What is this part in my torque solutions bushing pack for?
  153. Screwed by towing
  154. dome light?
  155. Glove box latch
  156. Evo 9 AC panel swap on Evo 8
  157. Was wondering for our turbo's
  158. What should I do with this headlight? need some help with info. please
  159. Question about stock undertray
  160. New DNP SS Header!
  161. Headlight adjustment
  162. Fuel system leaking. Any suggestions?
  163. Weight difference between RS doors and regular GRS doors???.
  164. What is the Evap system exactly
  165. Changed my plugs how do these look??
  166. catback question
  167. How to drive for best economy?
  168. In-Laws + 1 Evo 9
  169. Weird problem~~?
  170. free stock intercooler
  171. No Disrespect
  172. Cam gears explained?
  173. fuel pump priming?!
  174. hks evc boost leak
  175. EvoVIII from norway
  176. 2000 Tommi Makinen Evo????
  177. intake hose coming off
  178. What lip is this?
  179. Looking for a gauge, and a little typing what I think
  180. help: install boost guage
  181. color change
  182. New IACV, need tune?
  183. Need an answer! Help
  184. Evo 8 Steering column in Evo 9?
  185. Need some help with this tube.
  186. Joining the Evo community
  187. What turbo is this?
  188. HTA86 real or not?
  189. Border crossing with heavily modified EVO
  190. Gauge Pod on AC Panel
  191. Opinions: Worth parting out or not?
  192. EGR valve gone bad
  193. short throw shifter good idea or no?
  194. Driver's Side Headlight Issue
  195. data logging software for mac???
  196. Boost Leak and Launch... HELP
  197. dsm 2g wiring harness
  198. Causes of knock...Should i worry?
  199. Electronic Instrument Clusters
  200. Factory alarm
  201. halos
  202. My Evo Hit the Sixth Digit
  203. Spoiler....
  204. Fog light button not working
  205. Headliner Re-lined?
  206. CF Vortex Generator Broke!
  207. ACD lights on in hot weather..any ideas?
  208. NEW MEMBER: need help from knowledgable members
  209. Looking for my old Evo
  210. Prosport Hood Dampers
  211. Evo9 Clutch
  212. coolant temp reads negative 77?
  213. My car's value and pricing
  214. Good websites to import evo's into Canada
  215. Center console
  216. Evo 8 totaled because of engine
  217. big trouble need help!!
  218. Radiator Fan always on ??
  219. how to install 1000 id injectors?
  220. p0401, p0113, p0139
  221. What did I break??
  222. sparktech question.
  223. (Poll) Interior Color, please vote.
  224. CBRD- the weeks work, and beer-
  225. Anyone had a boost problem like this? HELP!
  226. Later model steering wheels on cp9a evos??
  227. quiet universal 3 inch mufflers.
  228. Loud Droning Whine?
  229. restoring headlights
  230. Boost Pressure Question
  231. Trigger plate wobble?
  232. loud buzzing! who knows what it is?
  233. Changing the stock clock, color display.
  234. Good websites/vendors to purchase an EVO OEM JDM rear bumper? Other options?
  235. need some help here....too good to be true??
  236. Looking into a 1997 Evo 4 in Canada
  237. where is the ignition wire located?
  238. Any Evo meets goin on BBQ etc
  239. oil return line gasket to oil pan orientation
  240. Zeitronix Zt-2/Zr-2
  241. P0138
  242. Evo IX Trans fluid, whats the best to use?
  243. Evo reliability
  244. spoolinup cop
  245. Light button and traction control switch IN OP
  246. Not Actual Miles. Opinions?
  247. Maybe in this thread someone could help me reg Different wheel offset etc on my 8
  248. Does anyone own the Varis Dry Carbon Shift Knob?
  249. Anyone know where i can find tensioner?
  250. test pipe
