PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Metal chain like noise while cruising
  2. after-market or stock fuel rail?
  3. Double Din(project)
  4. Let's see your goals or projects for 2014
  5. BOV Issues
  6. weird sounding squeal
  7. fuel system
  8. Varis or voltex
  9. camera
  10. r32-34
  11. Are stock Evo 8 turbos worth anything?
  12. super charged evo
  13. 03 Evo 105000miles for $12995
  14. Greddy Turbo timer not working
  15. HID issue
  16. intake manifold gaskets
  17. Name that Intercooler!
  18. Need this trunk!!
  19. Diaqueen LSD gallon metal container no more?
  20. Safest way to go back to stock ecu?
  21. Why do people want to buy unmodified evo?
  22. Mitsu Homelink Sunvisor content--any models interchangeable?
  23. My friend's EVO 5 & my GC8
  24. Can anyone name this PLUG??
  25. Looking To Buy An Evo Soon
  26. help on bolt
  27. Fuel issue. Need Help!
  28. Best Shop to get my motor Rebuilt ...
  29. Should i buy an evo? Please help
  30. Buy an evo or not???
  31. Evo or sti??? Which should i buy. Please help
  32. Why should i buy an evo???
  33. Born to race?
  34. Axle cv Boot OEM kit won't fit?
  35. Need help with ABS Codes
  36. Fitting four wheels inside evo?
  37. Noob question?
  38. Let's see your Evo in the snow pics!
  39. Evo VIII not getting fuel. Please Help.
  40. Radiator question
  41. vacuum problem
  42. hid headlight flickering?
  43. How to convert back to stock ecu?
  44. Picture Request
  45. *sigh* rims stolen off my evo
  46. i am looking for LED dome interior lights...
  47. Merry christmas
  48. Home Made EVO 8/9 License Plate Braket
  49. Evo Rattle.... Yet another thread..
  50. Merry Christmas Everyone! Did anyone get any new Evo parts/mods for Christmas?!
  51. Which radiator
  52. Opinions. Opinions on this car?
  53. Water Temp gauge, Where to put sender?
  54. any interest in a double din kit?
  55. Mitsubishi Evo 6
  56. Need these front fenders
  57. OMRON relay failure
  58. Help identify these brackets please!
  59. SES light flashing during second gear pull?
  60. Wierd noise when I let off in high gear.
  61. Evo IX Hid bulb
  62. yet another idle issue... share your knowledge
  63. LED indicator lights cause of random fuse blowing?
  64. Friend installed Cluster overlay now Speedometer is off
  65. 3' exhaust
  66. will this 4g64 work in my evo
  67. Enkei nt03m
  68. Aem boost gauge problem?!
  69. Correct bleeding procedure?
  70. What is this?
  71. evo 8 nrg hub
  72. Clutch Job, Wont go into Gear. Help (Symptoms)
  73. (2) gallons of 87 on a 93 octane tune
  74. Track wheels on street?
  75. Evo 9 BBS ---> Evo X Enkei. Good idea?
  76. OEM Alternator?
  77. How to upload aem v2 map
  78. P0011
  79. brake help please!
  80. Commencing with repairs soon...
  81. Cold AIR BOX (PROTOTYPE)
  82. How many miles to brake in a new clutch?
  83. ETCHING PARTS on your car?
  84. Oem flywheel vs Aftermarket flywheel?
  85. high mileage wear items
  86. Who are these guys (video inside)
  87. mitsubishi evolution Seats
  88. Fuse #8 Keeps Blowing Out *NEED HELP*
  89. Cam identification
  90. Buying my first Evo?
  91. clutch question
  92. Do i need to resurface my stock flywheel?
  93. ACT Heavy Duty 6 puck vs Comp Stage 4
  94. Stuck on what to do next
  95. clutch master cylinder help
  96. MAP 2.4 HTA GT35R estimate horsepower
  97. New Clutch and it engages RIGHT off the floor
  98. Cusco 7 point roll cage help
  99. Help identifying evo
  100. Oil Weights
  101. Anyother wideband better than the ZT-2
  102. Another Evo that may be a good deal! Opinions? 2005 MR WW
  103. Wanna repaint or plastidip my wheels??
  104. Buying and evo with 138k
  105. random bracet nothing goes to on my engine??
  106. 2008 evo x boost probs
  107. Is a new tune required after motor built?
  108. What is this cut wire by the front drivers side wheel?
  109. How much to fix paint damage?
  110. Evo 8 Ignition Coil Testing *SpoolinUp*
  111. My First Evo (Possibly)
  112. Obnoxious buxxing noise coming from aem standalone
  113. test pipe question
  114. Shipping your car
  115. stored motor around 2 years. any precautions?
  116. Zeitronix ZT-2 MAP shows vacuum when exposed to atmosphere?
  117. Intake manifold options
  118. Fuel Door help..
  119. Steering wheels adjust
  120. Help! Evo 4 possible crank walk :(
  121. bad alternator?
  122. Quiet exhaust
  123. Good upper gauge console?
  124. Need help finding a bolt!!!
  125. Strange starter problem. Help me :)
  126. hey guys i have some questions for the guru out there
  127. Help! Dash lights off when headlights on and on when headlights off
  128. Boost guage power sources.
  129. What clutch should i use?
  130. GSR 1.8 T tune??
  131. Another noob question
  132. Need Some Advice....
  133. anybody knows whats piece is called?
  134. Synapse dv ( old big one with c port)
  135. Great XS-Power t3 manifold with 44mm flange result
  136. cold outside can't start my evo
  137. Evo + Snow = Fun??
  138. Where does this go?
  139. Evo VIII Sunroof Issue. Please help me fix this thing PLEASE
  140. A/C dash lights burned out...
  141. Need Opinions on Purchasing an EVO
  142. Can anyone identify this strut brace?
  143. New video Evo wagon Tokyo driving including evo wagon club meeting in Daikoku futo!
  144. Sunroof problems
  145. What is this noise? SEE VIDEO
  146. Evo 8 core support
  147. Best spark plug for Evo6
  148. Counter steering with AWD
  149. what kind of injectors and head studs are these?
  150. Evo IX 9.00@156Mph (VIDEO)
  151. Clutch Job, Now Not Going into Gear. Help !
  152. Exhaust help!!!
  153. should I sell my rhd evo 1or keep going with build?
  154. timing belt tensioner tool in.. how long can i keep it in?
  155. ANTI-LOCK on after bumping into curb.
  156. Evo6 stock fuel pressure regulator (fpr) capabilities
  157. Thinking about buying this 03 evo
  158. Cold weather and large inlets
  159. Sunroof wont open?
  160. Holset hx35 turbo
  161. Color match USDM rear bumper reflectors
  162. 9 Sec. Evo's & More (VIDEO)
  163. rs head lights to gsr headlghts
  164. Idle but won't drive
  165. Need some Advice!
  166. Club-CT9W Evo wagon meet up today in tokyo
  167. Can anyone help me find an evo?
  168. offsets?
  169. Coolant Winter Blow-up, lets hear your two cents.
  170. 06 Evo MR opinions (pics inside)
  171. Can I boost below wga lbs rating?
  172. Random cylinder misfire only on start up until cars warm
  173. pros and cons
  174. paid a visit to English Racing
  175. Difference in performance
  176. Rear floor console interchangable with Lancers?
  177. Idiotic question about ic piping
  178. clutch help
  179. Passenger VIII Recaro Cracks?
  180. evo 9 valve cover fit an evo 8 head
  181. clock, stereo & high beams not working
  182. Fuel pressure regulator.
  183. aem air intake?
  184. Spark Plugs help for E6 : ngk IGR7A i r
  185. Odd Clunking Noise Coming From Passenger Side Front
  186. Tranny Fluid Help
  187. upper console pod
  188. Condenser Line Compatibility?
  189. transmission question
  190. Jdm evo 9 vs Usdm evo 9 weight balance
  191. master clutch cyl?
  192. What type of tial dv is this? *picture inside*
  193. OEM Radiator Dimensions
  194. Evo 8 parts - store suggestion
  195. Cylinder Repair
  196. Anyone have problem idling when using FULLBLOWN 70mm tb???
  197. Evo 7 Headlights
  198. Street Outlaws.....FarmTruck takes out evo
  199. evo 9 with 100k is that ok
  200. Where to purchase??
  201. ecu Flash probem
  202. will 500 hp evo make passengers scream?
  203. looking for an evo
  204. Infamous idle dip
  205. Alignment specs for evo 8
  206. evo VIII Noob
  207. Wheels
  208. is this 05 evo worth getting? (pic included)
  209. new evo owner
  210. Evo 10 compatible with Evo 4?
  211. Help please
  212. Taipan to loud (drone)
  213. The Dream is Real
  214. newB question
  215. Idle issues
  216. Fuel Door release
  217. Wtb Headlights
  218. Will muse UICP work with JMF intake?
  219. Help an evom member by measuring something
  220. Has anyone done the Nisei BLACK FRIDAY thing?
  221. Brake Fluid Container/Filter help? [PIC]
  222. Seat belt clip not fitting
  223. P0141 code
  224. Noise coming from wheel
  225. Evo 8 OEM HID
  226. HID for evo 9 GDR non-HiD
  227. why people lie when they sell there evo?
  228. Black friday
  229. 120k mile maintenance
  230. Build advice.
  231. new evo owner
  232. Tail Light Differences?
  233. VIDEO: This is why we own Evos
  234. Wideband readings??
  235. will this starter work on my evo 9
  236. 100% ethanol
  237. Overboost problem. Searched still can't figure it out...
  238. Tuners in pensacola Florida?
  239. help help
  240. Black Friday DEALS (MASTERLIST)
  241. Zeitronix Zt-2 + LCD supported values
  242. New user, Methanol question
  243. Blowing water lines
  244. evo 8 mmrad01 cap
  245. Do I have a Bad tob ???
  246. Evo 8 bucking.. Rough idle.. Rain
  247. Alternator not charging please help!!!!!
  248. Boostin Performance gets two thumbs up
  249. Sleeving a cylinder?
  250. Please help with fuel choice!
