View Full Version : Evo General
- Evo 8 Upper Windshield Molding Help
- Evo 8 VIN question
- Inlet/Outlet Size of OEM BOV
- Wiring led to the secondary fuel pump
- automatic transmission evo
- Garage condensation
- Leaking throttle body
- Opinions: Would the ETS Short Route UCIP fit with my current battery?
- Brand new throw out bearing making noise. How long will it last?
- Why do you want to delete heater core?
- To gurney or not to gurney
- Slim Fan Help
- Evo 6 outer sill
- V-band Turbo Flange Compatibility
- Evo IX engine block stamping "LX"
- Cluster lightning issue
- Evo 4 Quarter Panel Replacement
- Low Vacuum when Evo is warmed up
- Looking for my old Evo VIII
- Transmission fluid
- Can't get car to start - cranks & sparks, fuel issue?
- Engine build
- Engine build
- Back at it with a IX RS
- Evo 8 Door locking mechanism help
- Turbo thoughts?
- Need help with unknown bolt
- Evo 5 Intercooler Fitment
- Help! Leak by the drive shaft and in front of the block
- Ag auto open?
- If You're Still Using This Forum / Thank you EvoM!
- no emblem front mesh bumper
- 2005 Evo 8 Service Manual
- Best cam gear setup for tomei 270 pon cam type r gtp712
- Evo 8 Lifter Tick or Wrist Pin Knock or Spun bearing?
- Lateral/longitudinal g-sensors
- Abs and ayc lights flashing after installing aem Ems v2
- What flex fuel sensor does everyone use and where did you mount it?
- Back to the forum
- Need help with bolt size for motor mount
- Mitsubishi GRANDIS to Lancer Evolution IX Wagon
- Map sensor
- Pass exhaust emissions
- My Evo just shuts off after start 2 or 3 sec
- From hesitating and bucking to not starting, no cel, Help
- Evo 8 MR Tranmission Mounting Bracket Issues
- Evo 9
- What could cause an ACD to not bleed?
- Retrim inner door cards fabric on a Evo 7/8/9
- clutch aid
- new ecu smog law
- Cursed short block
- spark plug recomendation
- Boost leak
- New EvO owner / Compression Question
- Evo 8 driving issues
- Best Exhaust and intercooler for evo 8
- Evo 7 wing on Evo 8 with jdm rear bumper?
- Evo 8 RPM Gauge Reading Incorrectly
- Anyone know the size of this pipe
- Modern-day alternatives to Evo 9?
- E8 - Weird oil leak on gearbox?
- Coolant disappears somewhere
- Essential Parts
- Fuel pump not priming, was priming before I replaced starter.
- EVO 8 losing power when driving, need help.
- Looking for evo 8 illustrated parts break out, with listed part numbers.
- ACD Will Not Bleed.. What Size Gauge Adapter to Test?
- Evo 9 No spark
- what oil for MAP 2.0 engine.
- Value of a rolling shell in today’s market??
- Issue after engine has been running for a while
- Evo 1-3 Rear Window Vents
- Looking to buy an EVO 8 - any red flags?
- Evo 8 Rom read error
- 2016 Lancer GT seat swap Evo Recaro seats
- I Need help reading ECU. Can not solve problem.
- Anyone ever bought an Evo knowing it would need a rebuild later?
- Cabin Air Filter for Evo 7 GT-A?
- 06 Evo MR 11PSI Boost Cut / Engine Swap Question
- Help with this noise coming from rear
- STM stainless steel catback vs Tomei Expreme ti
- 3 Pin Throttle Position Sesnor (EVO 4)
- upgrading to evoX map sensor question
- BR350 question
- Full Refresh of Evo VIII- Input Appreciated
- Exedy Twin Disc clutch not fully disengaging
- Help ! (Ran the car on Low Oil)
- omni map sensor alternate option...
- Fuel pressure drop off.
- New here / MAF issues
- Evo 8 Wing question
- Evo 9 RHD A-pillar Gauge pod
- Evo 8 Cylinder head questions.
- Cold Start Oil Pressure (Evo 4)
- No power to AC pressure switch!
- 4g63 Fan Belt Size
- Evo 7 GT-A won’t start
- Whirring noise!?!!
- Are there any aftermarket downpipes I can use to pass CA smog. W/ stock cat.
- Central locking issues
- Locked out of first gear!
- Best Engine Swap For A CE9A????
- EVO 4 Front Rotor Replacements
- ACD Malfunction: Code 74
- Oil Light Flickering
- Sticker Placement
- EVO water temp gauge
- Swap RPM and speedo gauges
- Interior Leak behind dash CM5A GSR (EVO 4 Shape)
- What size fuses for the engine?
- Help identifying rear diff
- PCV valve keeps popping out
- 03 Lancer Ls/4G94
- Auction For The Sparco Evo
- CP9A HKS Ralliart cluster?
- 04 evo 8 quarter panel rust
- Evo 8 - anyone know where these harnesses connect to
- Thoughts on my build/ turbo thoughts
- Is this a good deal?
- GTA Conversion
- Need help!!
- Does Anyone Cut EVO 8 OEM Keys?
- Evo 9 air condition is not blowing cold air
- Evo V speedometer recalibration?
- Evo 4-8 Best stroke combination for street and maybe drag racing?
- evo6 blue cluster convert
- would a evo 8 be a good car for long distance roadtrip?
- EVO 1-3 R35 coil kits (DSM 1g/2g/VR4)
- Need help!!
- E Break install?
- What's causing this??
- Loud rubbing noise
- "Cheap" 150psi sensors
- Evo II sanity check
- Evo 5 fenders on an evo 4?
- White residue (First post on here!)
- Evo9-shaking/cant hold gas / unstable idle - oil light blinking / battery light on
- EVO I AWD to FWD Gearbox Conversion
- Endangered Species!
- Evo V Gauges
- ETS Test pipe O2 bung location problem
- Evo running like crap after winter storage
- found in bell housing of transmission
- BISS Screw
- Where Can I Find A CE9A EVO II/III Engine?!?!?!!?!?!?
- IC spray light
- What is the roof weight difference of standard/aluminum/sunroof? VIII/IX
- High idle issue after recent upgrades
- oil recommendations
- starting problems evo 8 gsr
- Car not boosting past 10psi
- high mileage 200k+ mile evo 9 prices
- Random strangers asking to buy your Evo
- My evo it's a Frankenstein
- 17yr old newbie
- Time to start upgrading. Please chime in.
- Owner Says 4th Gear sometimes pops out Since New ACT HDSS Clutch
- Ix mr pcm recall failed
- Evo 4 Bumper
- Need carfax vin look-up
- Stalling/no throttle after ECU swap + SAS activation
- Stupit question but what are "silicone safe radiator clamps"?
- Did standard JDM Evo 8 or 9 have aluminum roof?
- Should I buy a Theft Recovery Rebuilt Title - California
- Evoscan
- General after marketing o2 housing confusion/question
- Tial 44 flange
- building a custom engine undershield / thin aluminum fabrication / tig welding
- Converting to speed density / Tephra mod
- OEM IX Bumper Advice
- What LSD's did Evo 8 & 9 have? USA
- Next time someone has their IX bumper off, could you take some pictures of the inside
- Repair Advice Needed
- Evo 9 underbody frame rail dent smoosh?
- Mitsubishi evo 4.
- Early Evo Ownership Concerns in North America?
- evo 5 wheel bearings
- I'm here, how 'bout you?
- Alpha injection clinic
- Decrabonization
- P0170 malfunction code?
- Any evo 7 gt-a catch can recommendation
- Evo 5 top end rattle
- How to test a Maf sensor on a Evo 8???
- new oem prepainted parts
- Josie update
- My new 02' Mitsubishi Lancer Evolution VII GT-A
- My new '02 Mitsubishi Lancer Evolution VII GT-A
- P0325 Check Engine Light
- School me on what cables are needed
- Can you pass smog with Speed density?
- 02 sensor reading
- Evo 9 intake camshaft oil seal
- What grade bolts do I use for engine accessories?
- Evo 7 help
- USDM LHD Lancer Evolution VII Vehicle Info Sticker
- EVO 7 - bad miss on idle and backfires when comes on boost
- High idle help
- Stock ECU bracket. Pls help.
- HKS sport and carbon ti
- Without further ado!
- Finally back to EVO ownership
- Is buying an evo 7 as a car newbie a wise choice?
- new ix MR owner , need some suggestions on moving forward
- do you suffer from performance anxiety?
- Strange RPM drop at idle
- What's it worth! Help a brotha out.
- Which Instrument Cluster Overlay Is This??
- How to find statistics of EVOS imported to the US in 2003
- Ix sports gauge reinstall question. MR owner assistance
- Looking for the next bottle neck on my setup
- evo 8 rear trunk panel
- Throttle body replacement components
- JDM evo 8 - Loud single "clunk" on startup cold/warm
- evo viii fq-400 for sale in the uk!
- 2003 Evo 8 Random Misfire P0300 [TSB Up to date]
- Flex fuel kit recommendations/help
- Custom Dash For Nav Screen
- Starting Issue / Too Much Fuel?
- Seat Belt Bolt
- Looking to buy an 8 or 9
- Tephra v7 engine light flashing
- Quick question!
- Crank will not spin/no endplay
- AEM oil pressure 100psi cap
- Evo 8 RPM drop when coming to a stop with stock DV?
- Thinking of buying an older EVO
- Safe rev limit for built bottom end, semi built head
- Evo 8/9 Shell Manufacturing Costs
- Newbie Evo 8 Build
- ported skunk manifold
- Evo IX MR turned off while driving
- Down for the umpteenth time...
- Show me your gauges
- Boost and gauge questions
- Jdm evo 7 gta
- Looking for options for power steering hose dress up
- 4G63T swap pricing
- Evo IV Engine 44 ign coil/power transistor system
- Timing belt help
- NY to FL drive on a cam/crank fault
- Evo VII ACD Mode Comps
- Varis carbon roof?
- Shift Knob Adaptor
- Leaving the evo outside
- Calling all evo experts, riddle me this - Evo Iv Problem
- Evo 1 control arm replacement help!!!!!!!!!!
- Rough idle issues
