View Full Version : Evo General
- Advice on Bay Speed products
- Ignition Switch
- Evo 8 ACD light stuck on Tarmac
- new evo8 owner with CEL flashing
- P0183 code help!
- Fortune dealer
- Having issues with my evo 8
- New to Forum
- IX Rear Diff Question
- spark plug
- Timing belt maintenance question
- Evo 9 Rear Diff Noise...
- is there an evo 5 body kit?
- Evo not starting...
- Cosworth air filter
- Where does this vacuum line go?
- Help please! strange noise from rear of car
- Help. Fueling issue on Evo VIII
- New ST Coilovers for evo 8/9
- Volk TE37 18x7.5 +40 fitment question?
- Motul vs Amsoil
- Evo 8 auto swap?
- jdm evo 7 vc and stm fittings
- Been out of the game for a few years, need your input.
- 3 port electronic boost controller, what happens if you install it prior to a tune?
- I NEED HELP ASAP pleaseee!!! md wv va
- Exhaust Camshaft Sensor - Alternative manufactures
- Tourque Solutions - Trans Mount Question
- Busted block, will i be able to use my current Rods/Pistons on a new block?
- Interior parts?
- Boost leak woes
- Timing problem with my vr4 galant.
- Exhaust hanging too low
- fp 84mm anti surge cover worth it?
- Need a vendor for a clutch
- What is stock boost for an E4?
- AutoPage & Turbo Timer
- 2005 Evo 8 Stock Exterior Body
- Rally Red Color Scheme ideas?
- Where to find front bumper plugs? Evo 9
- question about valve.
- help please
- All Top Gear Evo Videos
- (FEELER) 800 hp Evo, sell as whole or part out?
- exhuast side valve seals need help
- Blue Batmobile Tail Lens Vinyl?
- Headligh Socket help?
- WPC metal treating, not a coating.
- APR GT3 mirrors
- Brand and weight
- Kelford cams?
- Kinugawa 3" Turbo Cover for EVO 9 20g or 25g
- Quaife QKE6U Sequential Gearkit Gearbox Dogbox
- So here's something you don't see every day...
- Oil return stock replacement?
- info trassmission evo 9
- 500 hp DBB FP Red vs 500 6266
- Evo 9 build
- Bird sound coming from under my hood
- Looking to get some RPF1's need some info
- Aem digital boost gauge reads positive psi at idle!
- look for OEM engine bay foam replacement
- evo 6 build
- PO335 code
- is it okay to take my exhaust off and just leave my cat and downpipe?
- a deer ran into me
- Oliver rod??
- LICP fitment issue Maperformance
- EVO 8 JDM Compatibility
- Weird issue running rich...
- identifying camshafts.
- JDM EVO 8 ECU? Is it the same as the USDM ECU?
- Need help No vacuum at egr nipple on T.B.
- check engine light
- Idle problem
- Help RPM's Drop slow and NOT Vacuum Leak?
- Issue with Starting Evo9
- Ct9a stoptech
- coolant lines
- My new Evo V
- Does this lip look legit to you?
- 400HP goal with E85, what other parts am i missing??
- accident
- Blend repaired panels or repaint whole car?
- Evo non-hid to HID
- Rec me an Intake Manifold for my setup..
- P0340 code..no camshaft signal!
- code 22 srs
- aftermarket bumper with best fitment?
- Texas Mile
- EvoM question
- Strange Noise
- EVO VII GT-A Front bar swap
- Which wideband should i choose? please help!
- Evo 8 CYLINDER OIL JETS (SQUIRTER) crush washers??
- abs/check brake system
- EVO IX gears
- Race tracks in NYC
- Source for missing Evo IX wing inner panel
- Apr Radiator plate question
- How do I troubleshoot starting issue related to key?
- Do you consider this stock
- rear pcv valve need help
- Please help! Fuel pump issue
- Bad power steering rack, bad power steering pump or both?
- Help Identify This Manifold
- advice and tips
- MAP vs Muse vs JMF FAB vs JDL Auto Design vs Toxic Fab O2 Dumps
- FP BLACK brothers chime in!!
- Need help to find a shop.
- Evo Starting Problems help!
- Gasket orientation
- New to evo's, could use some guidance.
- problems with lancershop.com
- Street Import Fest V4.0 Puerto Rico
- Stealth/Sleeper Engine Bays
- Plug and wire/ cat question
- Spoiler and trunk
- Anyone use Mr Copper exhaust manifold gasket
- Trouble codes
- Question re:Methanol/Water Injection, HELP!!
- Evo 7 and 8 gasket kits
- HELP! Exterior Door Handle Trim
- Evo 8 Stalling issue / Weird Problem
- Car will start sometimes but usually doesn't.
- Evo race car on the streets
- New HID's?
- CBRD- AUGUST Already- pics
- Jdm evo8 headlights
- Help me put a price on my low mile EVO
- Can I use softer motor mounts in a high HP setup?
- Question about cross make interoperability
- SS Autochrome/ XS Power FMIC for Evo IX/EVO VIII Review/Install
- Bilsteins from AutoAnything?
- Random High RPM/Throttle stickyness
- its clutch time
- Possible New Evo 5 owner
- Buying a *back2stock* Evo
- Engine Cleaners
- Turbo Swap... Manifold studs!
- Aftermarket connecting rod weights?
- Possible HP/TQ with mods
- Floor mats for Evo VI
- what price should I be looking to get for my 06 MR?
- new suspension ?
- Rebuilt engine: mods suggestions?
- Oil Feed line from Head leak!! HELP!
- True blood
- Rant: Evo starter from autozone
- Where to obtain e98, e100 fuel in orlando fl.
- Should I buy another one?
- evo 9 noise video
- Evo 8 ECU Pin
- evo 8 noise
- AEM UEGO reading rich
- EVO IX AMS intercooler VS compatibility with OEM undertray & aftermarket Alloy trays
- Tuners in NJ area
- What is needed to go from a 2.0 to a 2.4 shortblock?
- Need used head gaskets or images for work...
- Missing my old Evo
- Octane Boost.
- Oil light flicker
- Cheap Push Pins?????
- How to identify if a headlight is rhd or lhd without plugging in?
- Is this evo 9 turbo real or fake?
- Kelford 280/282 on stock turbo?
- Is my IX a 340
- Driveshaft Propeller Center Bearing Help
- GM 3 port and aem uego boost guage
- Goes lean, bogs out.
- LH Driver side head lamp
- Evo ix from Capital Mitsubishi
- Advice!!!
- Potential Evo buyer questions?
- No power steering at idle
- Has anyone placed their master key in the column and used spare keys (READ)
- Whining Noise.
- Where to buy Drive Train Fluids?
- Not allowed to post in WTB section of the for sale forum. Admin Please help
- Evo 7 8 9 4G63 2.3 stroker kit very good and cheap
- Need help with making brackets to mount headlights in Evo 5
- Cold idle issues. need help!
- JDM Rear coming from KIA N.A.?
- Just can't get enough (My Evo Story)
- Low idle and cat light on evo iv
- Racefab lower control arms
- help , car will only turn on when car is cool
- Problem With Evo 9
- TPS voltage Fluctuating
- Do the seat adjusters suck or is it just mine
- Help! Evo IV "Bogging" at full boost
- Noise in my E4.
- New Owner Getting familiar with engine
- Bov question.
- Evo got hit. Need help considering repair options.
- Evo 9 HID fuse box into NON HID car
- Factory appearance BOVs - Works etc
- Aftermarket steering wheels
- What o2 housing for 6262 turbo
- RALLIART Gauge Cluster Write Up (small)
- Evo 9 Prob Help!
- Front End Knocking
- new evo owner 2 problems
- any UICP that can be used with stock battery?
- constant white smoke when idling
- evo 9 acd pump wont turn on?
- tranny question
- Wtb: Oem evo 8 ecu
- Help with no third gear at high rpm
- Split duct for 06 oem bumper
- need advice!
- it diaqueen
- tap oil feed for oil pressure
- HELP!! Battery relocation
- Making a DIY cold air intake shield
- axle issues, need recommendations
- Anyone have a megan racing front engine mount?
- LICP that fits with Buschur street FMIC?
- Help finding parts
- Replacing coolant overflow tank with an aftermarket one, recommend any?
- WTB Evo 9 rear diff and shafts
- throttle hesitation
- Rare OEM and/or RA parts
- weird stains under car
- EVO IX 6speed
- Blew off a vacuum line.. subsequent problems
- Evo 9 rear diff...
- Does anything attach to this?
- Injector dynamics 1000cc
- Fuel pressure issue
- Changing oil pans do I need the change the oil return tube
- 06 mr 3 acd lights
- Evo 8 with evo x bumper mod
- EVo 9 body parts on a 7GTA?
- Mail call
- anyone run 3bar or 4bar map on evo 4-6?
- Breakup possible ECU issue?
- Evo 4 cut out last night now just turns over but no spark and wont start...?
- Turbo upgrades.
- boost control without Pills, MBC, etc
- couple of questions
- ethanol booster?
- fuel injectors
- Needing help evo 4
- My Old TB Evo IX MR SE Stripped To The Bone
- Manifold HELP!!
- Another Evo with starting issues
- fuel injectors
- cant seem to find the cabin air filter in my evo 9 mr JDM
- evo churping noise, pls help!
