View Full Version : Evo General
- Need advice on how to sell my Evo
- Evo 8 that needs some good TLC
- Evo 8 Steering rack problem
- HKS Downpipe Fitment Issues
- Denso 099700-2550 ignition coil datasheet?
- ACD bleed valve size
- Oil Filter question
- Sensor plug help
- Re: Fuel Rail Return Line Size?
- Show me your ducktail and wing setup
- Quality, High Temp Vacuum Caps...Where to find
- Dumb question what side of the fuel rail is feed and return?
- Used parts? partouts?
- EVO 8, aftermarket oil cooper help.
- Favorite Evo Accesories
- What's Faster for highway pulls? 2.0-2.4
- Arm Serial connection to usb.
- Evo iv front bumper on Evo ix
- Where to get 3/8BSPT to 1/8 NPT adapter
- MAPerformance Easter Sale
- Is Mil.Spec still rebuilding TBs?
- Which parts do I should purchase for make it fit Evo9 water inlet pipe to Evo8?
- Evo 8 RS daily found
- Team orange body kit
- P0401 EGR Flow Insufficient Mystery Solved
- To anyone whos pulled their dash.
- Wanted/Help: 1993 Evo Drip Molding
- Attempted Theft
- What is required to get a evolution IV 500 to 600 whp?
- R372JBJ white evo 5
- Evo 9 MR Light Problem
- ECM Failure when trying to flash ECU
- Fuel Injector Cleaner / Flow tester
- Evo 8 key stuck in ACC. HELP
- Evo 9 MR flywheel
- Engine bay cleaning
- Voltex GT Wing Type V
- Deployment storage For Evo 8. What to and what not to do
- Sparktech none cdi evo 8 help
- New Product HKS GT III RS
- High Mileage Evos
- EvoScan
- Evo 8 for $10,000 good deal or not???!!
- Ix gsr se
- OEM Mask/Bra for Evo VIII
- Transition from DSM world
- Taking out rad when it's cold to pull the head
- Launching Evo 9 at Dragstrip
- ARP L19 Headstud Length for Evo 9
- Car cuts out power at high rpm, random stalling
- Evo 8 mr fq300 stock air filter
- Evo 8 Won’t Hit Any Boost
- AfterMarket Solution for keeping the Rain guard on?
- Green coolant drain hose on firewall
- Identify these brackets
- Fuel rail spacer
- Help! Cusco Oil Catch Can
- Wiper fluid hose help
- Muse o2 dump can I turn it into a hood dump?
- handbrake takes significantly less force to pull after ebrake disassembly
- Adjusting for altitude?
- Stock Volt, Temp, Boost gauges not working
- Is this really a MR?
- Trying to sell my evo 9 need help from mod.
- Build ideas
- What's this Part?
- MAPerformance want's your input!!
- Stock Intercooler Piping
- Buying a sitting evo 8
- Innovate MTD Ethanol Gauge issue
- Reputable body shops in Tampa, FL?
- HID swap lights into LED lights housing
- Forgotten parts.. need help
- 2.4 evo wont start. TRIED EVERTYHING
- More worth it to sell car as-is or part it out?
- What is my car worth in todays market?
- Pic of open gas door please
- Evo idle problem
- Can anyone give an opinion on these evo 9 RS
- Taxmas Sale!!!
- Interior Fuse Box PIN out diagram
- HVAC cluster lights, dimmer switch not working
- Evo front fender fitment
- 4g64 Mivec head timing questions
- 4g64 Mivec timing?????
- Fuel cut??? Boost cut ?? Idk..
- What evo is it
- How to build a double pumper fuel system.
- Need help with build
- Can i install EVO X front struts on Lancer GT or Ralliart
- Dodgeed a person who spun out in the snow, slid into a curb:/
- GSR or MR?
- Don’t go to Stealership
- Evo VII - P0340 - Car wont turn on
- Should I buy this Evo?
- Stock BOV question
- Is this normal?
- Weird gauge cluster light up
- Greddy revolution rs
- Debating on getting rid of my STI for an EVO IX
- Ash Tray and Lighter Bulb our after swapping shift boot
- How to remove fuel tank?
- 4g63 Vs. 4b11t reliability
- question about evo 5 valve cover gaskets.
- Tomei Cali exhaust law
- What is this area for? Fuel pump cover
- 2 Step Flames?
- If I end up keeping the evo.....
- What evo to get
- Anyone know a free online "CarFax" VIN database?
- Nullify Fines For Loud Mufflers In California!
- Considering selling my 2003 Evo
- Evo iv idle air control valve
- Cross Member Corrosion recall SR-16-003
- Idle air control valve evo4
- whats the best HP target for a track and street tune while staying reliable?
- JDM Evo 8 doesn't have Map sensor
- How much power can evo handle
- 04 Evo non responsive throttle
- Anyone Sell a Gray Evo 9 MR w FP Black from Maryland recently?
- coolant hose location
- What are your Evo goals for 2023?
- Help,engine rebuild
- Evo 8 Interior Dome/Courtesy Light out.....
- P0300
- evo 9 spare tire
- 2004 Yellow SSL Rarity
- Having a problem with tactrix openport 2.0
- Looking for amazon link to bolts like these, 14mm
- Evo 8 Repair - Insurance only covering aftermarket parts
- Bought evo with wheel locks
- ETS intercooler kit question .
- Black Cat overlays and removing needles
- Evo 9 or 2015+ STI
- Best tuner/Shop still in business - Midwest/East Coast
- I haven't started my evo in 6 months
- How to change 3rd brake light bulb on Evo 9?
- Whats the best and most white evo paint?
- Speedo stopped working with rev limit
- Evo 8 mr transmission cruising shifting question
- BOV location with FP intake
- Help Me? Got some question
- Coolant Flush question
- Query about buying evo
- Transmission & Transfer Case for Evo 8
- Testing waters on my 2003 evo 8
- Evo 8 Rs making crackling noise
- Stock Cluster & Boost gauge bulb sizes?
- Evo 7
- Best exhaust fitment for a jdm rear bumper
- Trouble starting Evo 4 RS
- How Much is My vehicle Worth?
- Cyber WEEK!
- What's a fair price timing belt install or full 60k maintenance in 2018?
- Exclamation point dash light
- Black friday week!!
- Weird steering delay issues (aligned then not aligned)
- Hood vent needs some paint
- Stock Evo 6 Greddy Ultimate file
- Ac/heater core differences?
- Speedometer sticking
- CA Evo 8 Build
- EVO IX Chassis 55k miles (what’s it worth)
- Lancer oz rally 04-06 rear evo conversion?
- Help with wiring woes
- Will EVO 8 Ignition coil boots work on an EVO 9??
- evolution engine harness
- Help fuel pump fuse # car wont start till 03 evo 8
- Evo 8 Build
- Dealer refuses to replace airbag under recall
- Help Identify Oxygen Sensor (02 Sensor)
- Black housing evo 8/9 adjustment
- Any Evo meets
- Ralliart Mirrors
- Help identifying possible leak location, video link inside.
- Camp Pendleton Auto skills center!
- ACD lights on, can i still drive my car?
- Front bumper tab broken
- 06 evo battery drain help
- MAP Sale!!
- Jdm headlights
- Ralliart carbon side mirrors
- Evo 4 newbie, desperate need of help on buying parts
- My old ix
- Buying car from Texas to California
- Resale Values
- Another decel thread. Advice appreciated
- Loud Howling/Whining/Wind Noise After WOT Pull in 4th or 5th Gear
- EVO X GSR in Limp Mode, 4WD & ASC Service Required HELP!!!
- Turbo replacement
- Evo IX on Bring A Trailer
- Evo 8 Cold Start Problems
- Evo 7 cold weather, better idle but worse cold start.
- ID 1,700X or ID 2,000's
- Sputter hesitation at 2k
- Evoscan issues...
- Evo SSL Owners I need your help
- Evo 4 Slower after Upgrades?
- Evo IX RS Window crank issue
- Flushing clutch system
- I need the tephra roms and xml 90550001 v7 for evo 7 jdm
- Leaking
- Front lamps: replace glass only?
- should I buy a salvage evo 8 that needs a head gasket?
- P0170 code
- Evo 8 need help
- Please help to find out what front lap is it!
- Gauges explaination
- Weird start up issue
- AEM Oil pressure gauge just says SENS
- Evo road trip reliablitiy
- Defi Gauge BF and Unit V2
- My EVO 2 testing on low boost
- anyone have experience with SPEEDHUT gauges?
- Advice wanted: what’s this 2006 evo 9 MR with no motor worth?
- High flow fuel pump on stock 4g63 engine.
- Finally did the airbag recall, and now my heater knob won't turn completely CCW
- How Do I Fix My Bumper?
- Rear lower control arm
- Sparco SPX Special Edition
- Evo 7,8,9's.... Let's see your fire extinguisher installations
- Knock issue.
- When looking to buy should I avoid this?
- Haltech Street Dash odometer
- Evo 8 dash rattle.
- high iat temps solution
- MOD 2018 East Coast
- Check engine light problem
- Buying from the stealership.
- Old School FP Green turbo
- I am new with questions!!
- Sound Deaden For Less Road Noise
- Just picked up my 2nd evo 8mr!
- 2003 EVO 8, cheapest parts source?
- Need your advice for a US version in Italy
- Electric AC system
- Can anyone tell me what front lip / splitter this is?
- Spare tire bolt size / part number
- Evo 8 Front Bumper
- EVO 9 Headlight Restoration Vs New UV Clear Coat
- Anyone know what this is?
- Mitsubishi evo 4 window regulator posistion switch
- Stock couplers with aftermarket IC and piping
- Need advice for new Alternator
- 2004 Evo Key Stuck in Ignition
- Weird issue
- Evo Odd Steering Issue
- Help reviewing an evo
- EVO 5 or 6 front clip
- Seat belt buckle issue
