PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Coolant Leak Mystery
  2. Need ideas to pass inspection
  3. What would be a fair labor rate for this work?
  4. Evo 8 Omni power 4 bar
  5. Anyone got a S90 70mm for evo 9 in stock?
  6. What alarm system do you use?
  7. Just blew my engine! Open to options / ideas what to do next 😂😂
  8. Is this Evo 9 legit?
  9. Evo 8 Carbon Fiber Wing Restoration
  10. Airtrek Turbo - Turbo Timer/Radiator Fan
  11. No start then backfire
  12. Wont start again
  13. Evo Built block&knock
  14. MIVEC Cam Gear
  15. Idle insanely high?
  16. Need Help Identifying Noise issue (Transfer Case or Driveshaft)
  17. Problems with 500hp walbro fuel pump
  18. fuel pump rewire question
  19. What's up everyone! New Evo Vlog starting.
  20. Turbo fitment confusion..need help!
  21. Why would someone do this?
  22. Evo ix
  23. Oil leak?
  24. fuel pump issues?
  25. WIll the Evo 9 REAR seats fit my 8 ?
  26. Interior trim and radio screws
  27. What is this vacuum line?
  28. Zeitronix or gauges
  29. Could really use some help here. Thoughts welcome
  30. What power can I make on a FP black
  31. Sputtering
  32. First time buyer - Evo 8 Need some immediate opinions
  33. Anyone near San Diego willing to help out a prospective Evo buyer?
  34. Routine Maintenance on Evo X
  35. Newb Battery Relocate Question
  36. 1995mercedes 300 d deisel
  37. Today I got my dream car.....yes an evo
  38. Original owner?
  39. Evo 7 problems
  40. Could someone recommend a good budget tire
  41. How to Check EBC Solenoid?
  42. Not even a shop knows what's wrong with my car 😔😔😔😔
  43. Which spark plugs to go with
  44. Water Pump leaking
  45. EVO 7 In Japan
  46. Oil Guide Inside Transfer Case
  47. Mahle 85.5mm piston to wall clearance?
  48. aftermarket gauge sensors
  49. Dual Walbro 450's
  50. Sprayer Pump Stuck On
  51. Service Engine Soon
  52. Clock being winded back in japan-common?
  53. Evo Drivers
  54. Is the problem a bad clutch?
  55. Drilling out LCA bolt...if possible
  56. Right Side Gauge Cluster Lights Out and Dimmer Not Working
  57. Evo IX AC vent blowing air with AC off and recirculate.
  58. Passing emissions with TP in CO
  59. Looking at this EVO 8 MR - thoughts?
  60. Struggling With a Boost and Vacuum Leak
  61. Wires for headlights.
  62. Underhood decals/stickers
  63. New Here Need Some Advice EVO 9
  64. Evo 8 built head on stock block
  65. Anyone has installed a Honda Group 51 battery
  66. Question Compression Test Help
  67. Porsche 911 Powered by EVO 8 475HP
  68. Anyone Removed the Inner Spoiler parts?
  69. Replacing front wheel bearings
  70. Picture Request: OEM PS Hose Clip in Engine Bay
  71. Regularly removable cage
  72. Boost leak test issues
  73. Repair shop recommendation in St. Louis
  74. Lifter and valve questions
  75. Finally Part Of The Family
  76. Evo "9.5" should have been a 2007, not a 2006, right?
  77. Evo IX issues
  78. New to Community
  79. Looking for original owner of 2005 Evo 8
  80. oil spray on start up
  81. Holding out just because its not a mr?!?
  82. SD setup
  83. Rear Ended & Fuel tank is done what should I do?
  84. Evo 8 ets intercooler on evo 9
  85. Power window motor Evo 8
  86. Evo 7 vs Evo 9 block differences
  87. Tps ground
  88. P0011 Variable valve timing system help?
  89. In need of help! Timing belt
  90. EVO Newbie, Tips/Tricks for Driving?
  91. Gas gauge low on cold startup
  92. Joining the dark side
  93. Evo 9 block swap
  94. Having trouble programming the remote start bypass (pku mit)
  95. E85
  96. In need of major help
  97. Shop taking far too long...?
  98. Evo 9 shifter lever
  99. What company use for shipping my Evo?
  100. Any evo clubs in dallas besides NTEC?
  101. Roadrunner transportation. Beware! Horror story:
  102. engine Misfiring need suggestions
  103. ACD Pump question.
  104. Replacement Fuel Sock for Buschur Double Pumper?
  105. Evo 7 tails
  106. Just Bought a 2003 Evo 8
  107. I need help please!
  108. Need some Advice
  109. 2006 GGP evo 9 MR sighting!
  110. Stripped nipple thread on rear Brembo caliper
  111. Weird Boost Issue
  112. Stock valvetrain with Kelford cams - causing a bad bog at dragstrip?
  113. Anyone Know this Car?
  114. Can I replace mani > turbo gasket without removing turbo or elbow?
  115. Question
  116. Tps help
  117. Car Inspection in NC without car being present?
  118. EVO Valve Cover Baffles - After Sandblasting
  119. Evo 5, Should I buy?
  120. Buying Evo 9 over 100,000 miles
  121. Recommended steps before a tune
  122. Search help, visit of MMC/Ralliart facility
  123. im stumped guys. looking for help
  124. Oil Pressure Gauge Help
  125. Evo 8 intercooler worth upgrading
  126. New IACV, now engine RPM too high
  127. Looking to buy an EVO
  128. I have no idea what's wrong with my car..
  129. Map MIVEC feed line
  130. New to the Evo world!
  131. Evo9 ACD delete
  132. Aeromotive 340 fuel pump opinions
  133. Ground issue with EGT sensor
  134. Vacuum hose question please help
  135. Evo VIII or Evo IX???
  136. 5th Gear issue
  137. Random idle issues.
  138. Valve to piston radial clearance
  139. piston radial clearance
  140. Evo8 stock fuel pre. With fuel rail
  141. Situational Ticking Sound
  142. Idling Issue??
  143. Just asking for opinions
  144. Buying Help
  145. Hood exit dump exhaust rings?
  146. Help please evo 8
  147. Need help identifying this noise....
  148. Evo life....continues
  149. Evoscan
  150. To a future evo 9 owner
  151. bad map sensor symptoms?
  152. COP Issue
  153. Need help ASAP please
  154. 550 HP built evo for cheap ?
  155. Evo 8 - sometimes dies when coming to a stop, thoughts?
  156. New guy here ! Potential evo buyer today
  157. Introduction
  158. Canadian CT9A parts
  159. High rpm voltage issue looking for help
  160. Rust!
  161. What happened to MAP ef series turbos?
  162. re: rear differential evo3
  163. Evo 8 stripped head bolt
  164. Turn signals, Hazards don't work. Need help pleaseeeee
  165. I need help with a swap
  166. Oil pressure sensor question
  167. Fp black vs fp zero
  168. Help please evo 8
  169. 4g63 stock fuel pressure psi
  170. Possibly Picking up a 05 Evo 8, but have a question
  171. Anyone setup an 03 EVO VIII with OBD2 Bluetooth & Android Tablet?
  172. New Zealand
  173. ACD pump issues/leakage rattling noise
  174. Transmission help
  175. 05 Evo 8 running lean and sounds like a lawn mower
  176. Newest member in the Evo community
  177. 30.000 k
  178. Steering rack and IM leak
  179. Fp red on stock block
  180. Buying a evo IX
  181. 2012 Evo AFR
  182. 6266 stock block
  183. Replaced my alternator in about 45mins.
  184. Evo 9 jdm headlights
  185. Not going into 2nd gear !?
  186. How to tell what Size Kelford Cam you have?
  187. I'm back!
  188. Evo 8 Engine sputtering at 4k rpm
  189. typical afr for evo 9 mr
  190. Evo 9 can't get to full boost
  191. knocking noise and smoke please help!!!
  192. Evo 9 MR Tranny Drain Plug Missing
  193. It's a sad day. Looks like I'm selling.
  194. Evo 9
  195. Cranks, No Start, too much fuel
  196. Debating on buying this Evo 9
  197. Suggestions on local transmission shop
  198. RPM won't drop down when I shift at high rpm
  199. to buy or not to buy
  200. Wiring diagram for evo 8-9 gauge cluster
  201. Suggestion to make my onw race gas, or what can I do?
  202. how to know original evo engine
  203. Tx2k
  204. Expert Help Wanted
  205. Which trans fluid for evo 8
  206. Evo 8 newbie
  207. New to the forum and looking to finally purchase one of my dream cars
  208. Cadwell Park Trackday with Kenny 2016
  209. Service engine light
  210. Help!! what is this connection
  211. 500HP Goal
  212. Weird acceleration problem
  213. Balance Shaft: To delete or not to delete?
  214. help please!!!
  215. oil restrictor size for BB turbos?
  216. Evo 7 - Launch maps & NLTS
  217. Have to bore my cylinders, what else will i have to change besides Pistons?
  218. 11.5 lift
  219. Separating and inspecting the MHI housing??
  220. Engine Removal Questions
  221. Back at it again... only this time with a IX
  222. Is Aisin oem
  223. 2005 Evo 8 "Totaled or Fixable?"
  224. Evo buying question
  225. Stock boost gauge T
  226. Running lean after wash :(
  227. Replacing strut for the second time
  228. Bypassing Heater Core??
  229. Delfi oil pressure gauge question?
  230. New to the Evo World
  231. Symptoms of a bad map sensor?
  232. From Tial Q to Tial Q
  233. good shop around Killeen tx for my evo
  234. Doing maintenance need advice
  235. SES thrown after cold start, suggestions needed.
  236. Wont start
  237. evo safety recall crossmember/subframe
  238. Interchangale CHRA?
  239. Evo 8 steering wheel Help needed
  240. Planning to do a full maintience on my 06 iX gsr! Need inputs.
  241. Thinking of buying a new Evo
  242. Bracket help
  243. Need assistance from someone who knows their stuff
  244. Mishimoto radiator and fan shroud
  245. 4g64 timing help
  246. Fuel light issue
  247. Can someone please assist me
  248. Buying a evo
  249. I want to sell my STI and Get an EVO
  250. Evo 9 GSR worth 23k?
