View Full Version : Evo General
- Universal Roof Rack
- front end vibration
- What have I gotten myself into..?
- oem evolution muffler inlet diameter
- Problem plz help
- Tagged a curb :(
- evo 8/9 documentary design
- Christmas Car Parts [MERGE]
- need bumper help
- Key in part same as base lancers?
- Car Problems, PLEASE HELP! Where Do I Start???
- starter/battery/alternator or poor install
- evo 8 wiring problem p0335 HELP!!!!!PLEASE!!!!!!!
- What is this mystery noise?
- When putting the wing back on?
- Used ECU immobolizer?
- Tsukuba Track day.
- Crap.. Misfire again and now Rattle
- basic tools
- general questions about purchasing or selling a car
- Underbody braces out of stainless?
- shifter bushings wear in ?
- 4g64 down pipe issue
- Whirring sound at low gears.
- New Open Source Telemetry/Logging system being crowd funded
- Check engine light :/
- IX RS race car - Help me understand...
- CBRD- new shop sneak peak!!!!!
- Just bought new....
- RPM stays high at idle.
- Boost issues after UICP install
- Driving Evo From NYC to LA in my EVO ix .....
- Engine not starting (wheezing sound)
- how long should a tune last?
- Rear wiper help
- Evo Mr Vortex Generator help
- Parked Evo For Long
- Fp red fun facts
- For those of you with wider wheels/tires, how do you protect against rockchips?
- Votes please!
- Apexi Power FC - Evo 7 compatible with Evo 5?
- waterfeed line???
- the car shaking with no idling problem
- Possible to diagnose ACD without stock ECU?
- E6 to E4 engine swap/importing question
- Name this exhaust manifold & UICP
- What is your christmas Wish List (ONLY evo parts that you ARE getting)???!!!
- Aux belt tensioner
- Evo IX rear bumper
- How to take off shift knob?
- buschur 65mm ported tb
- Dented intercooler
- Anyone know what bracket this is???
- Gauges; Mech vs Elec?
- walked out to a smashed in rear window
- Clutch Installation in Atlanta & MTF 6 Spd Redline weight
- Ark stb install Q after installation.
- Looking for MR pedals
- Best Engine Oil For Evo VIII
- Buschur Downpipe Issue
- no battery power nothing works help
- My header has the blues..
- newbie troubleshoot with greddy profec 01
- Huge Issue Help?
- Evo IV Front Clip
- Evo 9 Price?
- What wheel brand is this?
- Evo VIII Using Oil
- Ses need help
- how far do you travel for e85?
- Demonwerkz JDM rear crash beam
- Help?! Battery Problem?
- Poor fuel mileage
- Evo Weird Shaking
- 06 Mr factory bov flutter..
- Stock Appearing Vs Custom Turbos
- Evo values rose again (KBB)
- Spoolin up bad on returning emails/calls?
- Stalling/Terrible idle
- New Exedy Stage 1- Please Help
- Need Help, JDM VIN number question!
- new exhuast set up. opinions?
- suspension under the motor
- Diesel Turbo A Evo?
- Evo vs Lancer...?
- Fb black ball bearing ebay seller
- help with downpipe guys!!!
- Pros and cons of In-line fuel filter
- next round of mods
- Where can i get AMSOIL oil & ngk copper BPR8ES plugs from?
- What to do before starting the car up after sitting?
- Buscher ported tb vs Milspec?
- EVO 8 Fitment
- DU-luck trunk
- Remaining Evo's
- Mississauga Engines - My Experience With
- Evo 6 RS2
- Help with putting power down
- Anyone else notice the price of Premium Fuel going up?
- Wire connected to oil drain plug?
- What size are these Injectors? (PICS)
- Holy Crap He's Joking Right?!
- I just hit a deer!
- Will I be content with 450 whp?
- Evo 8/9 and 02-06 lancer compatibility
- aem cam gear slipped, help!
- Stolen Evos of Chicago/Suburbs
- hose on firewall behind rear mount
- Evo IX, CEL when start up. Cold start problem
- Dashboard carbon fiber cleaner
- P0243 Turbocharger Wastegate Solenoid Malfunction
- Frustrated, need help w/ power goal direction :\
- timing belt wrench who ever has it look inside
- Thinking about moving to a EVO X
- HELP with shifter cable (underhood) bushings
- Bored today to I made a ashtray gauge pod
- pls help me win:)
- where can i buy a silencer?? locally
- Evo 8 Fuel or Boost Cut Issue?
- Anyone know hard facts on how auto insurance claims work in this case?
- Burning Oil
- Frame measured results
- what should my next mod be
- has anyone ever run spring spacers for winter hight?
- RPM Problems
- Megan dp problem
- Buying a 2003 Evo 8
- Question
- Fender spacer instructions
- Front crash beam bolts
- A-pillar gauge pod paint/color
- Fender fitment issue
- How to tell if my Walbro is faulty
- Maintenance/Longevity - should I keep my evo?
- Paint chips / deep scratches on Brembos, what to do?
- Tightening licp..
- Bouncing Idle thorttle
- Need some help
- Quick help me identify this massive boost leak on the throttle body
- Spare tire diameter
- Weird smell when hot air is on
- Exhaust issues, what should I do?
- New stock Evo X GSR - Easy and safe tunes
- Paint Base vs Thermal Spray Ceramic Coating?
- how to tell if intake tube is collapsing ?
- Evo 9 not pulling as hard?
- Evo Encyclopedia?
- Best HID Kit for $150?
- Where to mount JMF catch can?
- Funny in Car Pictures
- Baby in Car Label
- Need help with Gauges
- IC Sprayer Status Light
- Anyone relocated the oil cooler to get max caster?
- Just put my wing back on. Got thumbs up by buell speed biker. Great to be back.
- Mopar blue plate.....
- ACD pump in trunk?
- Long term storage.
- EVO IX: Rexpeed Evo 9 MR SE Carbon Splitter and Beatrush undertray
- Just got into an accident and they want to write off my car.. need advice
- Australia JDM Evo VII oem hid bulbs
- How hard do you drive your Evo?
- Dont know...
- Idle issues
- Hole under headlight ?
- 05 SSL sunroof gear replacement?
- bad parasitic drain, suspect alternator HELP!
- Anyone know what bumper this is?
- ABS HELP ! code 32 13 16
- Need help getting my evo8 running right
- bad idle with cylinder 4 compression@20psi
- Ball joint or cv joint
- OEM HID ballast
- Guy who makes the orbit style double din
- Hunter alignment
- PSRS DD/Snow duties?
- Front belly pan/splash tray ON or OFF?
- Slave Cylinder Hard Line
- Stalling after clutch job
- Jumpy Vacuum readings
- Pics of Perrin PSRS hitting frame/subframe?
- Different BOV
- Help please! info on crushed IX metal BOV i purchased
- Bolt size for LICP
- leather or suede wrapped steering wheel
- Crate engine anyone ?
- Black Friday Deals...
- Oil leak bottom cover.
- EVO 7 Gourmets/Firewall HELP! (Pics)
- evo3 gearbox replacement
- What is this and where should it go? HELP!
- stolen this morning
- bushings fitment
- Question about spark plug wires
- How to go about selling my evo with all ACD lights on?
- Stock Map sensor plug?
- Aem tru boost help!!
- 5 speed Shifter Cable Issue
- Taking wing off help !
- evo boost problem...
- Oil pressure remote kit help
- Removing Front License Bracket
- Anyone drive their track (road course) cars on the street?
- Probably the most awesome moment for a 3 year old..... in an Evo. :D
- acd pump wont prime when bleeding.
- Wire Routing
- How to access intake manifold lower bolts?
- help?
- Evo IX Trunk Interior
- Bushing Opinions PLease !
- Where can i get EVO 9 Rear Bumper For Evo 8 in Australia?
- Dyno Tuner Says I need new Dual Fuel Pump, 1450cc injectors and Head Studs???
- Where can I buy HKS SSQV 4 BOV w/ UICP??
- Emissions question.
- Evo 9 torque damper brake cylinder stopper solution
- Bad TPS connection?
- Evo 9 MR stock fmic question...
- Blew transmission bought 5 months ago at a dealership
- Quieting down your car interior?
- My new BBY evo 8
- My $300 Evo IV
- Black Friday [MERGE]
- mitsubishiparts.net?
- A pack of motorcycles tried to steal my cars soul.
- factory recirc port size?
- Evo 9 agp oil catch can hose placement?
- looking for a place to do powdercoat/rebuild brembos with core exchange
- System to lean code and breaking up between shifts?
- Bent Volk Racing CE28N :'(
- Throttle Issue
- **HELP** Clutch Assembly Bracket Cracked???? WTF
- Temporary front license plate ideas
- Few questions about my Evo..
- North dallas meet
- Injen Uicp Tbolt clamp size
- What is the factory vacuum pressure at idle?
- Big thanks to a few vendors for helping out - Oct2012 Texas Mile
- Evo 9 lip
- Coolant Leak
- Importing an Evo 5 to Canada
- Getting ready to install my rx7 wheels need help
- 06 seats vs 05 SSL seats weight?
- How much of the clutch to replace?
- o2 sensor wiring??
- Another 100k Evo Review
- How to put Steering wheel centered?
- OBDII Scanned Results
- Approaching 300k!!
- coolant leak help
- Beat rush Evo 8-9 undertray DP clearance
