PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Thinking of trading my X for a IX need advice.
  2. Fixed my warm start up issue (E85 + ETS mini battery kit)
  3. Trunk "springs?"
  4. 04 RS converting to factory HID w/fogs
  5. evo 9 mr with 5 speed what shiftboot??
  6. SSL seat replacement ..connectors ?
  7. Another transfer case thread
  8. Evo 9 fog lights not working
  9. evo 8 ac removal
  10. are people laughing at me driving an Evo?
  11. headlight angle motors?
  12. Need a new front 9 gg bumper
  13. Request: Show me how power steering lines route
  14. Cd9a fuel tank
  15. Evo 4 wont start!
  16. Bumper lip mount points
  17. Evos on instagram!
  18. About to buy this IX, can someone assist in my final decision?
  19. IACV Replacing Question
  20. Jdm Evo 8 Intake Manifold on a 6 Bolt Dsm Head
  21. Custom Radiator Brackets for Radiator Clearance Issues
  22. Duraflex rear bumper
  23. Rear diff removal
  24. What heat range plugs should I be using?
  25. Mod opinions
  26. Evoscan Error
  27. Smashed up bumper
  28. Timing Belt condition after 10 years
  29. Tips for avoiding Brembo paint damage when bleeding brakes?
  30. 4G63T vs 4G63
  31. Jdm EVO bumper on EVO 9
  32. My first Evo 9
  33. agency power cutback exhaust
  34. evo 8 clear bra
  35. Turbo upgrade question
  36. Ground clearance on lowered IX
  37. e85 quality
  38. Time to upgrade cams?
  39. Replacing condenser, o-rings needed?
  40. New COP, plug advice please
  41. Inside of steering wheel leather separating, any easy way to fix?
  42. Quarter mile pass
  43. little help plz.
  44. What RPM do you go WOT in?
  45. Is something off with my VD
  46. could another car maker start making Evo's after they finish?
  47. mitsubishi evo 5-6 gear knob thread size?
  48. Help, bad serpentine belt noise
  49. Help!!! Evo VIII stalling
  50. Moved the FPR and put a little hardline in
  51. Valve cover painting question
  52. Tuning shops
  53. My crank sensor that got murdered
  54. Hit Deer need Advice
  55. Engine bay connectors
  56. Should i buy this Evo? Need advice
  57. Gt35r
  58. Evo IX Cam Angle Sensor
  59. got into a car accident
  60. Need help with price of 05 MR
  61. Want to buy a evo 8 or 9 5 speed
  62. 4 bar map sensor issue
  63. Need smog help for my evo 9 (norcal)
  64. P0335
  65. Cruise Control for EVO 8 (Rostra's)
  66. Viscous coupling unit
  67. Cabin temps way too hot (Evo 6)
  68. anyone run QRJ?
  69. Knuckles/Hubs and brakes
  70. Need help!!
  71. Looking to lower the exhaust noise
  72. New reviews on M2 3inch TBE for a evo8?
  73. Help! Car won't start.. No crank.. Please help!
  74. Toxic Fab
  75. Cheap wheels and tires for evo 8
  76. Where can i find plugs for my trunk if i remove my spoiler
  77. Anyone have vishnu ecu diagram
  78. Haven't driven my evo for couple years need tips
  79. Need Help finding a VCU
  80. Evo 8 ecu
  81. Evo injector rail
  82. Anybody have the new jic zms coilovers?
  83. Timing belt
  84. Couple questions about my evo 9 takes a bit to turn over on start up
  85. Built Motor Oil Consumption?
  86. The book of Evo?
  87. WTAC 2015 photos.
  88. New to me Evo IV
  89. Dual walbro 450lph pumps in full blown hanger max HP?
  90. Drivers side axle removal/ small spring?
  91. Aem wideband
  92. Evo IX wont start when hot.. Help!!
  93. Crank position sensor
  94. Winter time change over to E85
  95. Evo 7 Idle issue
  96. The League TV show guest stars an Evo IX!!!
  97. is there a sweet spot for injector size running 93 pump?
  98. Timing Belt: Time Interval?
  99. Advise on my IX MR dilemma
  100. 10 facts about the EVO IX
  101. UK based Evolution magazine first US cover car!!!
  102. What do you look for when purchasing from a Vendor?
  103. Do you use mini ramps at home for small jobs?
  104. Hi, I need help finding a set of rims that look similar to this one posted
  105. Rusted tag lights mount
  106. "Custom" mud flaps?
  107. Best gen Evo for modding?
  108. Buschur 3" Catback Exhaust Question
  109. Evo 789 Exterior Air Temp Sensor
  110. Need some advice.... on reaching 475-500 WHP
  111. Video of my 10 second evo VIII Stock Block 😃
  112. Evo 8 grinding while turning right.
  113. Valve spring question
  114. 2 Quick maintainenance questions - Fuel pump / wheel alignment
  115. Need etune suggestions, just not tcomptuned please
  116. How to calibrate the omni 4 bar in evoscan
  117. Tactrix cable Midwest
  118. Evo 9 Rough idle/stall P0011
  119. EVO 7 gta problem gearbox help me please!!
  120. I want more power! for my TME
  121. Evo9 115k rebuild help/recommendations
  122. can evo 8 waste gate work on 9 turbo
  123. exhaust light on dashboard??
  124. Picking up Evo 8 this weekend
  125. Ef4 installed....no boost???
  126. Looking for INFO how to find a total loss or front clip of a EVO 8
  127. EVO 8 rear diff bushing
  128. Newly built motor misfire at idle
  129. Cant find this O ring for my life....
  130. Apex'i WS2 Exhaust Review
  131. Clunk noise when turning
  132. Oil suggestions? (For high temp like arizona)
  133. evo 8 idling issue
  134. Electrical
  135. JDM EVO iv
  136. Air conditioning popped, white smoke hissed out
  137. RPM Hang | Idle 2000rpm
  138. Question about dash panel
  139. reverse lights
  140. Question about Knock Sensor
  141. Lightning yellow Evo 9 MR?
  142. Evo IX Build
  143. Evolution ix crank upgrade
  144. 06 evo9 mr intermittent rough start
  145. Fuel cut or pre-det??
  146. Valve ticking when cold
  147. Evac solenoid questions
  148. Re-wiring standard radiator Evo 8
  149. EVO 9 Rear Axle
  150. What do you think this is?
  151. What is this?
  152. Question for those running Greddy Ti-C
  153. EVO 8/9 Seat Dimensions?
  154. Evoscan missing rpms
  155. Want to run E85 what injectors?
  156. Mivec P0011
  157. clutch issue?
  158. EVO 9 transfer case rebuild parts (does no one have them for under $1k)??
  159. After years of searching..
  160. Starter problem help plz
  161. Do I have to buy Monoloc? Help!
  162. Is it time to move on.................?
  163. Seeking advice about APR EVIL-R wide bodykit
  164. All things Billet
  165. fp red or precision 5858
  166. Carbon Fiber console cover
  167. Can someone identify the part?
  168. Requesting some car measurements from the community
  169. Evo IX out of retirement, suggestions?
  170. Did your poly lip come with mounting holes?
  171. Fort Collins Mitsubishi Dealer Horror Story, Takata Airbag Recall Evo IX
  172. Evo IV AYC to cusco LSD
  173. My glossifier experiment
  174. kiggly hla?
  175. 90550701 v7 launch control
  176. COP with toyota coils, adding dynatek arc-2?
  177. Oil filter housing problem
  178. Where to find muffler delete pipe?
  179. Clips for center console
  180. Had a business card on my window...
  181. Help To name this part of the Wire loom bracket
  182. What is nearly max hp & max torque for stock block evo 9 mr?
  183. Troubleshooting an idle issue
  184. urgent : EVO9 VOLTEX REAR UNDERTRAY INSTALLATION MANUAL
  185. Evo IX hesitation under WOT?
  186. Evo 5 ABS & AYC Codes
  187. Weird AYC Issue (Evo IV)
  188. Lancer Evo IX Recaros to normal Lancer seats? (seat bolt spacing?)
  189. 96260709 tephra v7
  190. Questions about body work
  191. Parts advice for build
  192. What's a 9 shell worth these days?
  193. Looking for Evo UK (or any non-US) Owners
  194. Any Canadians doing an upcoming purchase with forced performance?
  195. 2006 evo 9 se!!car raises idle when hit brakes!!!
  196. Oil Light Flicker
  197. Rear-ended, What should I look for?
  198. Here is Info on Colors, Options, and Option Packages for Each Evo 8/9 Model Year!
  199. Used evo had for 4 days now its running terribly
  200. Blackline Shift Knobs
  201. Need help! Car won't start..
  202. If you have te37's please read
  203. Evoscan 2.9
  204. Picking up an 03 evo 8 49k miles around 6:00.. Good deal?
  205. First time Evo buyer, things to look for?
  206. Odd idle getting fixed after WOT
  207. Evo 6 AC Removal Belt part number (RS Accessories belt)
  208. Cam gear marks wayyy off!
  209. 3 lights😞
  210. Evo belt tensioner problem.
  211. ACD vs non-ACD (Racing use)
  212. Evo 9 stutters when accelerating
  213. where to get an EVO 9 spoiler
  214. Evo ix model colors
  215. Headlight/Indicator issue
  216. Rattle/Vibration scare??
  217. Car won't start, TPS, CAS, Fuse..?
  218. Where can I buy Evolution VII Grille?
  219. Car won't start, TPS won't switch maps
  220. Car won't start, TPS won't switch maps
  221. Which non oem waterpump fits the evo 9?
  222. Threw a Rod at low speed, anyone else?
  223. Need Fan Control Module Evo 7
  224. New-ish With Evo Woes
  225. timing belt tension question
  226. Car sputtering and wanting to stall..
  227. has anyone tried plastidip clear or glossifier to protect their front bumper?
  228. BOV Spring jammed?
  229. SRS cel reset SUCCESS!! EVO IX
  230. Evo 6, 7 or 8? First proper turbo car.
  231. MAC 3 Port Boost Solenoid Install Help - Vacuum
  232. Where to set cam gears on 2.2 long rod
  233. Ortiz Custom Pods - Carbon Fiber
  234. Help, Rich Idle More Vacuum
  235. For the people of Canada
  236. Rear Console
  237. Help Evo 8 will not start
  238. AC compressor turning on and off
  239. Value for a used MR8
  240. Thinking about getting an EVO 9
  241. Continental Poly 4060705 wont fit
  242. 2006 evo 9 mr overheating issue
  243. Water pump question.
  244. Going in for Airbag recall. Advice?
  245. Should I buy?
  246. Changing Evo 7 to Golf Mk6
  247. Aem temp gauge in stock temp gauge spot?
  248. Evo Underside Picture
  249. Best way to deal with spinning wheel studs???
  250. Voltex diffuser middle support
