View Full Version : Evo General
- should i be concerned?
- Looking For Some Input
- Heel and toe maneuvering in Evo IX
- AEM truboost
- Upgrade Intercooler or wait?
- Just another manic Monday...until...
- Quesion on Importing Evo IV Shell
- Brake Light On
- Mounted the GOPRO.. couple pulls :)
- Hallman MBC mount
- Evo 6.5 TM Stock Fuel Pressure
- E-85 Drum Options
- does dry ice really remove small dents?
- OEM IX poly front bumper???
- loss of boost after shifting
- E85 Question
- Best turbo for 2.3 stroker
- Evo 9 clutch master and slave cylinders' Parts Number
- Upgrading all lines in the engine bay help!
- e85 help !
- Wrecked evo question
- Key Won't Turn
- injector tuning help!
- Ignorance
- hallman mbc in cabin
- Headlights on - dash/gauges not illuminated
- Gauge cluster
- What rods are better
- Help Please!!!!
- hallman mbc in cabin help?
- Evo IX Dynoflash mail in tune
- evo engine noise
- Carbon fiber wrap?
- Revving higher on a stock cams?
- whats the most WHP a stock can hold?
- Track Times
- Cooling fan issue
- First time down the 1/4 mile
- ECUFlash
- How to download map from ECU?
- What is better: 2.3 or 2.4
- Car meet central jersey
- Noob question, sorry :/
- power steering trouble
- Need help with p0107 code??
- Oil leak from pan for a few months and readings are still the same...
- What WHP Does One Need to Keep Up With a 600cc Bike?
- What should I expect to pay for install..
- Noob question... AYC, Tires
- Is this a good deal?
- Need Help... with O2 sensor question... on Evo IX
- Just ordered manifold from Collin @ Toxic Industries
- car just doesn't feel fast anymore anyone else get this
- Who has a FP 71 HTA set-up?
- act hdss tob rattle
- WALBRO 400 install evo 8
- First Track Session on Sunday
- Checked for a blown fuse,....now the car wont start?????????????????Please help
- So for all you double pumper users out there (esp those of you with the BlaqOps kit)
- Need help figuring out if i have a 2.0 or a strocker motor
- Hood vent/grill removal
- Fuel Economy
- Tempted to go with a FF turbo kit, BUT I WANT TO KEEP MY AC!!!
- this is crazy!
- Help me identify these parts?
- Question about model
- Benchmark tuning melrose park, il
- 120isn Compression test on all 4... suggestions
- (not idling properly need HELP!!!) have power fc
- Hood dampers
- Car pulling left
- Tuned
- evo 8 engine into a evo mr body
- 1st Time in an Evo
- Possible Starter Problem?any sugg.
- 4g63 engine number
- Which Belt Is Making This Noise...
- best intake for evo IX
- Who sells the best mini battery kit?
- battery voltage?
- Selling a RS versus a GSR
- $2000 Service...
- Double din mounting brackets?
- Egr?
- Strange Boost Levels
- SE front lip?
- Clutch isnt engaging i think its slipping
- P0401 Help
- uneven tires can they be used?
- swaybar endlinks
- side skirt guard? what is that?
- about that time.
- problem with my hvac
- evoscan question
- My idle... Vid
- Egr p0401...
- which O2 dump to get?
- Need Help to choose a Radiator.
- engine cutting out stalling
- spark blowout ----> backfire under boost?
- Evo 8 not starting with new crank and cam sensors
- PIC: is this a short shifter?
- Best in Car Camera Setup?
- bby build.. need help
- Weird clunk when taking off
- ACD fluid leaking
- tob wont release
- Fluid questions.
- Stolen EVO FL
- Intake manifold or Gt35r
- Evo 6 rs-2 ff turbo kit w/ a/c & ps
- tre maxxlock rear diff upgrade....
- Prosport Boost Gauge is just flashing?
- greddy type s question
- calling evo 4 to 6.5 owner on intake manifold
- Looking for the plug for the stock fogs
- new install question..need help!
- evo with a hood scoop?!
- what to do what to do!?!
- What gen fp green is this?
- Weird noise perplexed 3 dealers - anyone have ideas
- What would you do next?
- OBD port not working??
- check engine light! please help
- tuning question
- What #'s should I be expecting
- What kind of hp #'s should I expect?
- Removing 3" catback- Any hp gains?
- FP GREEN or Stock 8 turbo on e85?
- help spark plugs
- please help
- Fuel pressure on run position with car not running
- hmm front lips?
- Weathertech door visors
- Is FP Nuts? $2500 for a turbo?
- Cam problem??
- Opinion on exhaust
- Catalytic Converter Nut Size?
- 2.5" vs 3" Exhaust
- Underhood fire insulation removal
- AWD launch evo IX
- black evo 9 stolen 4-5am wickerpark chicago
- Not sure if this is normal *pic*
- any ways to keap the evo 9 six speed tranny from breaking or having any problems?
- New Evom Store Now Open!!!!!
- Hmm Cars acting weird take a look help a brother out.
- Removed Radiator/AC Condenser. Service Engine Soon?
- Does a Grounding kit do much with 100k+mile 03 evo?
- Need some ideas, Evo won't start!
- too good to be true?
- 350-370HP/TRQ EVOs, what's your gas milage
- external wastegate vs o2 dump
- Which boost control?
- Evo 9 turbo upgrade, now car smokes badly
- Who sells?
- car won't start after its warm ?
- Best way to buy long distance Evos?
- EVOs FS...cheaper in winter?
- What's the best way to conduct a trade
- Clutches:/
- Turbo Removal Method
- Please help Evo 9 quit
- Air to fuel ratio question.
- Temperature/Boost fluctuations
- Choosing camshafts !! HELP!!
- HP with these mods?
- any info on this evo???
- How much whp is the EVO 9 stock turbo good for?
- All of the above?
- does having a DD make the evo experience better?
- Wideband Bung Location
- Quick connect bolts or tabs for front bumper?
- Deciding to make my IX a DD/weekend track car, or get an X
- have a problem with a manual boost controller
- Evo sparco steering wheel install
- Need help finding a part number
- Fixed my chipped Volk TE37 SL, paint match for $12 (with Pics)
- Need help finding this part! Please help
- JDM evo 9 bumper parts
- Surge of flutter after installing hks ssqv
- JDM Rear Bumper pricing from drivline motorice
- PPI did a great job on my parts!
- needing to know what this is worth.
- MitsuStyle Dyno Day Pics
- wrong adaptor flange with synapse dv
- Something terribly wrong with front wheels?
- OEM Paint Job
- fuel door
- aggressive cams making car vibrate A LOT?
- words of wisdom: if it sounds like a broken belt its probably a broken belt
- 3 acd lights on
- Evo 8 Crank Position Sensor Location
- Starter pin keeps popping off!
- Plz help!
- Clunking in the rear while braking
- need help with maf pls help
- Please help - P0505 returns
- ALWAYS double check everything when you're messing with the engine...
- Advise Needed... Odd FP Oil Leak Issue
- Front License plate
- ebay vortex generators?
- timing belt slack disappeared?
- Carnage
- 4g64 build
- cam cover stuck on!
- How can my Evo sound like this?
- smoking catch can?
- i have few questions regarding a idleing miss.
- Wideband Bung Placement
- Trans fluid drain or no
- Power Steering Leak
- Need Help Identifying Some Evo's (Drag Racing Videos)
- Shep trans stamp location
- Evo 9 Starter problem
- Quick Question: When removing stock o2 Housing
- Newbie
- Any Evo VII owners near Maplewood, NJ here?
- Dashboard problem
- Rear 02 Sensor Tricks?
- 2003 Evolution 8 Headlight Trouble
- Misfiring under boost/rough idle
- BEWARE Power Plus on EBAY (MHI Manifold)
- Injectors for 4G64????
- Trying to get rid of clunking in engine bay and drivetrain
- Yakima Ski/Snowboard Rack options?
- Mishimoto Radiators
- Noise Problems
- stock replacement rotors
- My goals
- Yes another off throttle Rattle/Flutter thread...
- Drilling holes in CF Hood, any suggestions?
- evo 8 sunroof not working
- JDM HVAC control
- HID Bulbs
- Help with removing this stupid ****ING Knuckle bolt!!
- Flashing Oil Light
- help with mods???pls help
- ARC Intercooler IC Piping fitment question
- quick question.
- IC piping t-bolt clamp size?
- For those using DEFI Racer gauges....
- Kracka Crankcase Vac. kit...
- Paper Evos
- evo 8 issue need help!!
- Hard time finding evo 8's let alone an evo.
- Waste gate actuator door, rattling?!?!
- Cracked T-Case
- New evo 8, Need to figure out injector size!
- Grinding AFTER start.
- injectors
