PDA
View Full Version : Evo General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237
  1. Engine harness uncertainty
  2. Missing at WOT/ weird afr
  3. Noob question
  4. evo won't stay on after letting off gas.
  5. Whats Your Settings? (Greddy Profec B-Spec II)
  6. Stock fuel pressure regulator and feed line question
  7. OEM Floor Mats change color?
  8. 1999 Evo VI exhaust trouble finding
  9. Titanium exhaust manifold studs?
  10. 05 evo problem starting
  11. Evo 9 on Ohlins R&T suspension
  12. running rich at cruise but idles fine
  13. Sales price for Evo 8 long block w/spun rod bearing?
  14. Zero Boost Issue (HELP)
  15. Need help finding a fan control module #1355A126
  16. Evo 8 front axles on evo 9?
  17. Quatermaster twin disk
  18. WhereToBuy: intercooler sprayer nozzel??????
  19. Evo 9 Roof trim/rail
  20. o2 Housing question
  21. Rear motor mount bolt size
  22. wiper fluid=clear coat damage
  23. REXPEED air duct install
  24. Looking to buy 05 evo modded w/ 100k miles - advice
  25. Best radiator fan for Koyo half size rad.
  26. Evo 9 MR 2.3 Stroker Build
  27. Evo 8 Gas door Release Assembly broke
  28. Evo pricing question
  29. Water temp slowly increasing to 100c
  30. To rebuild or not? Evo 1-9 4G63T Engines
  31. Time to show of my EVO!
  32. Boost pill question
  33. Mounting/balancing costs
  34. Fixed a boost leak, car drives much better
  35. EVO IX injectors upgrade
  36. Need help !!! Oil leak
  37. Whining T-Case is it safe to drive long distance?
  38. Clucth cover
  39. Ichiba users
  40. Evo sputtering?
  41. new turbo and making less peak boost??? need help!!!!!!
  42. For those with a SS clutch line
  43. Erratic idle
  44. Non HID EVO headlight
  45. Looking for an evo 9 rear bumper
  46. Question about short block 4g63
  47. buying a evo soon ... question
  48. Ultra rare Key!s Racing wheel !!!
  49. Evo 9 stock cams
  50. EF3 slow spool HELP 2
  51. Evo HID headlights questions. Please help.
  52. Evo towing questions
  53. Tyre and Diff advice
  54. Best place to get SE front lip?
  55. Should I purchase a RHD evo 4-6?
  56. WTB 4G63 ShortBlock
  57. Wheel bearings need changing
  58. Tips for building a 10 second stock block and stock frame turbo car
  59. Evo that has been sitting for a year
  60. steering wheel shakes
  61. Question to the evolutionm public?...
  62. Apexi turbo timer questions
  63. fuel delivery issues
  64. Aluminum corrosion in salt/snow?
  65. Gauge Pod Help
  66. easy way to diagnose exhaust system leaks? Anyone tried this method?
  67. New motor installed, minor issues
  68. evo 9 coil n plug
  69. From Subaru to Mitsu
  70. evo 8 mr fq400 certificate
  71. run into Invidia o2 housing issue.
  72. sunroof! help! Already searched.
  73. CT9W EVO wagon A/T upgrade
  74. MAP oil feed line replacement filter...
  75. P0107 P0113 ODB Codes
  76. Help Me Choose A Best Turbo
  77. Seibon CF Hood liner question.
  78. EVO IX's and their appreciation
  79. Thinking of getting CF mirror covers....Have couple questions
  80. Throttle body leak?
  81. Works Weather Mat
  82. Newbie
  83. evo 9 head gasket causes lower compression?
  84. Windshield bubbling
  85. need help on injectors selection
  86. Evo 9 turbine wheel
  87. Sputtering
  88. Need help on Wiseco HD2 C-clips
  89. Looking for rally car Evo 9
  90. Wot 2nd gear around 4-5k rpm sputter and rpm goes down
  91. 10mm spacer what stud length???
  92. Super Noob Question About 2003 Models
  93. Evo 8 Rollcage
  94. Evo 6 fenders plz help me find some
  95. Boosting problem on my Evo 9 Mr
  96. I need help finding the right tuner
  97. Need some help
  98. Intermittent starting issue
  99. Ac clutch replacement? Or is entire compressor needed?
  100. At a loss, need some help.
  101. What are these? ..and do i need them?
  102. white smoke after installing new turbo
  103. evos in colorado
  104. Help diagnosing play in front left wheel
  105. __Trying to sell off EVO parts but not sure on value looking for some help
  106. Good place to buy IAC (Idle Air Control Valve/Motor)?
  107. Random connector under the dash....help identify this part!
  108. Transmission mount rubber insert
  109. Gauges help
  110. About insurance
  111. Help! Dropped Clutch
  112. Evo rotor play?
  113. Bumped starter dropping dp
  114. Transmission help
  115. im stumped
  116. High Mileage Evo
  117. Wiseco help!!!
  118. Evo for later on..
  119. Boost guage for high boost
  120. Looking for a evo 7-8 rolling shell
  121. Coolant hose leak..
  122. Ebay Evo 8 front lip purchased from seller: azapracing BAD Experience/Seller!!!
  123. P0300 & P0300"pd"
  124. Considering Selling - Talk me in - Talk me out
  125. Cleaning up threads on exhaust...
  126. Question to Evos that run Evo5/6 Ecu
  127. Switching to the Dark Side
  128. Spun another bearing.
  129. shifting problems
  130. Question about these spacers
  131. Oil cooler thread size???
  132. 75MM Boomba throttle body
  133. Finally bought my first Evo
  134. clutch pedal and engagement issues
  135. Evo 7 cannot boost with A/C OFF. Need to turn on A/C to drive ! Please help !
  136. EF3 slow spool? Help!
  137. T-case or Rear diff whine
  138. Should I buy this 2003 Evo 8?
  139. Buying an evo out of state (from NY to PA)
  140. What to buy
  141. Evo 9 starter different to evo 8
  142. Place to send an ecu to test
  143. Any Evo 7 owners out there?
  144. Evoscan/charging system
  145. EVO 8/9 in Canada
  146. Hubcentric question
  147. Need to know...
  148. where to buy mitsubishi interior screws????????
  149. Looking to install HKS 272 Cams
  150. Turbo oil line problems?
  151. weird ratteling/choppy noise!??
  152. Axels
  153. Magnus & AMS intake manifolds
  154. Exedy twin disc
  155. transmission and flywheel cover
  156. Need some help
  157. Need opinions for motor issue
  158. VIII MR BOV, not happy of the change of sound since, suction pipe replacement.
  159. Royal Purple oil in Evo 9
  160. Curious, EVO IXs some have a pipe at the manifold and some don't.
  161. Need help
  162. t4 twin scroll turbine in high .8x or low .9x size Gt30?
  163. Full Blown
  164. Please help.. Fuse keeps blowing
  165. Antifreeze Hissing/Leak Under Throttlebody
  166. Please Help!! Start up whining noise!
  167. E-Tuners
  168. Metal shavings right after build (1500 on build motor)
  169. Help! Soon to be Evo owner hopefully.
  170. Retune for catalytic converter
  171. Few problems with my evo! Help please
  172. Brake Fluid?
  173. evo rs trunk for sale?
  174. Questions regarding Tuning stock Evo
  175. Evo 8 Headlight Lens
  176. help finding trim for my 03
  177. Where to buy inner tie rod end boot?
  178. Any idea what this could be?
  179. non hid headlight on 03 evo?
  180. Replacing an ETACS
  181. Evo needs a tune?
  182. Evo 8 Steering wheel shakes
  183. Need help wont start diagnosis
  184. Help...Concerns about P/C Valve Cover
  185. One Million Questions About What I Should Do
  186. Where to buy a RH Quarter panel?
  187. EGR sticking?
  188. 25mm spacers
  189. 6,518 mile '03 VIII at local dealer
  190. Help from RPF1 guys
  191. Im buying an eve 8 :D:D
  192. AFR dropped at WOT
  193. A/C Button
  194. Evo ix rear diff howl
  195. Evo 8 turbo
  196. Carfax
  197. EvoScan/Data Logging
  198. DEFI RACER Boost GAUGE not truning on
  199. Should I part out my Evo?
  200. Virtual dyno results car weighed and 71hta or 71 hta
  201. a stupid oil thread
  202. clunking or banging noise in rear end
  203. Evo IV "Bogging" Issue
  204. is my clutch going out?
  205. Reaching for 350,000 miles in #grandpaevo
  206. AEM EMS v1 vs Stock ECU
  207. Trunk Torsion bar help
  208. Evo stalls with ac or defrosters on at idle!
  209. Can I remove turbo through the bottom?
  210. Need help ASAP
  211. Block and head needed
  212. pic request jdm rear greddy rs
  213. Intercoolers
  214. Evo 8 rear strut bar wont clear oem subwoofer
  215. werid noise between 2-3k rpms
  216. Need some insight
  217. MA inspection
  218. Picture with a couple questions..
  219. Missed 4th over rev
  220. injector question
  221. Tuning an HTA 71 on Saturday
  222. MOD suggestions
  223. Whole new setup, misfire on cylinder one. Need Help
  224. High and Low Idle, Loud Hissing/Leaking Noise too
  225. Introduction
  226. Help on finding this interior piece to fit my 3 gauges ....
  227. Engine Belt Whine Type Noise Help
  228. Turbosmart Rep. on here?
  229. thinking of buying an evo
  230. modifying a 2003 Evo
  231. The beginning of another IX build
  232. what do you say??? pls help!!
  233. Data Logging
  234. where to buy 87mm oem head gasket
  235. Burning oil problem
  236. Help please!
  237. Front End parts for evo 9
  238. 2003 evo 8 for sale
  239. Need help turning off rear o2
  240. Running no oil cooler...
  241. Waste-gate solenoid valve operation
  242. Mitsubishi Concept XR-PHEV Evolution Vision Gran Turismo
  243. shady evo seller?
  244. Sticky throttle after new seals AND EGR blockoff
  245. Evo IV (cn9a) IAC valve
  246. evo rear bumper mounting bracket
  247. RPMs increase under boost while clutch is in need help
  248. Car bogging down with open throttle
  249. Car idles rough when hot, wants to stall, VAC jumps up
  250. EVO 8 - Stalling issue
